Ascend SE Owner's Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 95Likes
Old 04-12-2006, 07:47 AM
---k---'s Avatar
Originally Posted by Sam1000 View Post
The stands don't have WAF.
I'm laughing because my wife likes the Ascends stands. She didn't want another wood colour in the room that wouldn't match something else. I guess I'm just blessed with lower WAF needs.
Lots of differnt stands are out there, but imho good retail ones are going to run $100+
---k--- is offline
Old 04-12-2006, 08:56 AM
Grayson73's Avatar
Quoted: 12 Post(s)
Grayson73 is offline
Old 04-12-2006, 09:22 AM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
A great feature of the Ascend custom stands is the supplied backplate that attaches the speaker to the stands by utilizing the threaded insert on the speaker. With the stand filled with sand, and the speaker attached with the backplate, together they are not easily moved or tipped over.
When I had my custom stands built, I also utilized the threaded insert to secure the speaker to the stands:
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
Old 04-12-2006, 12:38 PM
Samurai Jack's Avatar
Yeah, the Panny is definatly high on my list. I was thinking on getting the XR57 when that comes out. I'm only going to run 5.1 and I heard that the XR57 can dual amp the front two channels in 5.1 mode.
Yeah, that's a nice plus. Unless you care about the 1 HDMI input (yes, one) I'm not sure there's any reason to wait on the XR57 except for availability.
And I thought you could bi-amp even if you were using 7.1, but I guess I didn't really look yet, not having the speakers. The only time I'd really like to do this is for 2-channel stuff...but it would be a nice "freebie" feature to discover.
Each moment only once.
Samurai Jack is offline
Old 04-12-2006, 12:42 PM
Grayson73's Avatar
Quoted: 12 Post(s)
I don't care about HDMI, but I'm waiting for the XR57 so that I can dual-amp the front speakers in 5.1 mode. Twice the power to the mains should be awesome!
Old 04-12-2006, 12:49 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Here is a good thread on the Ascend Forum on bi-amping the 340's that also includes good posts from DaveF.
http://forum.ascendacoustics.com/showthread.php?t=745
-curtis
cschang is offline
Old 04-12-2006, 02:01 PM
Grayson73's Avatar
Quoted: 12 Post(s)
How do you bi-amp with the XR57 in 5.1 mode? Do you actually have to wire the surround channels to the mains or does the receiver internally route the power to the mains to give 200wpc to the mains? I was thinking that the receiver would route 200wpc to the mains and 100wpc to the center and rears automatically without needing to additionally wire from the surround channels that aren't being used.
Old 04-12-2006, 02:13 PM
cyberbri's Avatar
Liked: 53
Check the manual. I think it has you use the rear surround speaker outputs, changing a setting in the setup to tell the receiver to double the output from the mains to those channels.
cyberbri is offline
Old 04-12-2006, 02:24 PM
Bikedorian's Avatar
Same here. She wanted nothing that would detract from our other furniture and the Ascend stands worked for both of us. I held my breath because the Ascend stands were my first choice in what I could afford. It's my job to pay for this stuff and her job to decide if I can keep it. Well defined rolls don't ya thinK? Whadayamean, PW'ed?
David
Bikedorian is offline
Old 04-12-2006, 02:42 PM
Grayson73's Avatar
Quoted: 12 Post(s)
Seems like XR57 will allow dual amping to a single set of binding posts.
There appears to be a difference between dual amping and bi amping for the XR57.
The manual says:
"The advanced dual amp function activates automatically when you use 2-channel stereo playback or 5.1-channel playback. The unit takes advantage of the unused surround back speaker amplifier, and runs one speaker with two amplifiers when this function is on. Advanced dual amplifier offers you sounds that are clearer and higher in audio quality than those available in normal playback."
Sounds to me like you don't need to wire the unused channels to the mains.
Old 04-12-2006, 03:03 PM
cyberbri's Avatar
Liked: 53
That is doubling up the power to a single speaker output.
Biwiring and biamping are powering the two drivers in a speaker separately with separate amp channels, basically.
cyberbri is offline
Old 04-12-2006, 03:11 PM
Grayson73's Avatar
Quoted: 12 Post(s)
Great news! That's exactly what I want to do. I'm planning on a 5.1 setup with 340 SEs across the front and 200s in the rear. With the XR57, I can double up the power to the 340 mains which should increase the performance.
Old 04-12-2006, 03:16 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
I just posted in the Ascend forum.
The specs do not specify the power when the dual amp function is engaged.
Also, more power does not necessarily mean more performance. I have had 340's with amps from 100wpc to 400wpc. The only difference that was readily perceived was better bass with the 100wpc amp.
-curtis
cschang is offline
Old 04-12-2006, 04:31 PM
The_Dark_Knight's Avatar
That's pretty much what I want to do as well.
The_Dark_Knight is offline
Old 04-12-2006, 04:59 PM
mderka's Avatar
I received my 340's today, got them hooked up and cruedly adjusted (using the auto setup with my Outlaw 990 preamp). Relocated the HTM200's to serve as my second pair of sides and fired up a movie (batman begins).
Initial impression is obviously a lot more fullness and depth in the front stage. I set my crossover for the 340's at 60hz but still have some tinkering to do. My second pair of surrounds makes the front row much more acceptable, but as I suspected the rear seats are still the sweet spot. I think the front row sits fine for viewing aspect (13ft), but may be too close to the front speakers because they seem to overwhelm the surrounds, and at 9ft away the rears are tougher to hear.
Anyway I am very pleased with my initial observations. I'll post some pics when I get a chance.
mderka is offline
Old 04-13-2006, 05:32 PM
wnaegele's Avatar
...as my second step towards the world of surround sound. My first [also just ordered] was to purchase the last of the Kenwood AV receivers [the 9070].
What I am basing the system on are four 30-year-old speakers: a pair of Model Two Allison Acoustics [floor-standing -- essentially Model One's with a pair of 6" instead of a pair of 10" woofers], which I have had since the mid '70s, and a pair of Model Three's [corner, with a single 10" woofer], which I recently inherited. The Allisons are very neutral speakers and I hope the 340 is a good compliment.
I plan to use the system 50/50 for DVDs and stereo [CDs and satellite -- DirecTV XM Radio -- music channels.
If you have any suggestions about pitfall avoidance, I would surely appreciate it [hoping I've not waited too late for any such help].
wnaegele is offline
Old 04-13-2006, 06:01 PM
postalguy's Avatar
I've got a little heads-up when ordering.
Last month I ordered three CMT-340 SE's for front and center, and just happened to notice that it's $28 cheaper to place this same order using "System Advisor" instead of "Add to Basket."
You would think their ordering system would be a little more consistent. Guess I should send an email asking if I can get the better price, $884 as opposed to $912.
postalguy is offline
Old 04-13-2006, 06:46 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
You can "add to basket" the package as well rather than the speakers individually.
Someone has posted this before, if you call Ascend, they will give you the package pricing.
-curtis
cschang is offline
Old 04-13-2006, 07:01 PM
PD50U's Avatar
Originally Posted by The_Dark_Knight View Post
Yeah, I really don't like those stands to be honest.
I know it may sound silly but I don't want my bookshelfs to have a tower look.
I think some people have used these stands with Ascends:
MU Metal Series stands
which are less blocky. Your personal preference may vary.
Hearing is believing vs Believing is hearing.
PD50U is offline
Old 04-13-2006, 07:57 PM
chasw98's Avatar
Usually they will catch it and just show a credit for you. They did for me. Plus anything else you order from them in the next 45 days (give or take a few days) they will sell to you at system price as if you had bought it all at once.
chasw98 is offline
Old 04-13-2006, 08:01 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 263
I use the relatively inexpensive WT stands (see attached pic)--they match very well colorwise--but did find it necessary to weight the base. As you can see, I have 2 15 lb. barbells on each one!
millerwill is offline
Old 04-16-2006, 03:39 PM
BBoley24's Avatar
Has anyone else received their ascends?
BBoley24 is offline
Old 04-16-2006, 05:21 PM
Amerikes's Avatar
Nope, not yet. I hope to get them in the next two weeks......
Ordered on January 27. 340 SE's Left, Right, and Center, and two pairs of HTM-200's, in which I asked to just have them all shipped together. I've commited to these speakers, and will wait it out. I can't be any more of a hurry to get these speakers, as Ascend is to get them out. This has to be costing them dearly.
Amerikes is offline
Old 04-16-2006, 05:23 PM
Yeah, I sure hope it's worth it!
Old 04-16-2006, 06:54 PM
garykagan's Avatar
Are the ascends good for the 4 surrounds - 2 on the left and 2 on the right in a 7.1 setup or is it better to put two in the back and two on the sides?
I see so many theaters with the surrounds (4) with 2 on the left and 2 on the right and none in back. Is there a reason for this?
Gary
garykagan is offline
Old 04-16-2006, 07:06 PM
garykagan's Avatar
One more question - my room is 23 x 21 about. Will the ascends fill that size room nicely? I plan on using the yamaha 2600. 340's paired with 200's is the current plan.
Gary
Old 04-16-2006, 08:13 PM
Capek's Avatar
Gary
Very nicely. While my room is only 22x13, my 340SE's more then fill the space. I tried them out in my living room, which is 25x50 or so, with only some columns seperating the living room from the dining room, and they filled the space plenty well.
Capek is offline
Old 04-16-2006, 08:15 PM
Capek's Avatar
Gary
This is the way it should go, if your room allows:
http://forum.ecoustics.com/bbs/messa...79/129023.html
Capek is offline
Old 04-16-2006, 08:21 PM
mderka's Avatar
Gary, I'm sure the 340/200 setup should be fine for your size room. I'm sure most would suggest 2 sides and 2 rears vs. 2 pairs of sides as recommended by dolby labs etc. There's always a debate about direct raidiating (the 200's) vs. a more diffuse side surround (a dipole speaker). most agree a monopole is good for the rears.
I choose the 200's for my surrounds because I was going with two rows of side speakers and dipoles would not work for this setup.
mderka is offline
Old 04-17-2006, 07:38 AM
---k---'s Avatar
Um yeah, but Ascend doesn't sell any dipole speakers.
There is a reason.
---k--- is offline
Ascend Acoustics , Pioneer Vsx 1014txk Thx Select Av Receiver , Receivers Amplifiers , Velodyne Impact 10 10 Subwoofer
