Boston Acoustics Owners Thread - Page 109 - AVS Forum | Home Theater Discussions And Reviews
 46Likes
post #3241 of 3267 Old 02-15-2017, 01:25 PM
zieglj01's Avatar
Quoted: 1345 Post(s)
Liked: 1190
Originally Posted by Rgarc View Post
However I am still concerned that the gear I am interested in and look at first is still out of stock. maybe they are consolidating their lines, which is a good thing. Anyway, If they are going to come out with new speakers, I hope they come out soon and uphold the standards that we value their products for. I am not interested in mediocre soundbars, I need a system that can fill a large room. 16'D x 18' W (24' if you count the open concept dining room) x 17'+ H. Fortunately my Micro80's system 8000 can fill a room that is 13'x24'x8' so I know its not a stretch for BA.
What type speakers are you looking for -- bookshelf or floor standing speakers?
__________________________________________
Who AM I
Speakers -- Snell K7 > Digital Phase AP-.5 > Harman Kardon Ten > Boston VS240 -- Receiver > Integra 50.2
zieglj01 is online now
post #3242 of 3267 Old 02-15-2017, 02:26 PM
Quoted: 41 Post(s)
what i am actually trying to do is build a 5.2.4 atmos setup and that may be skewing my responses. I was primarily looking at bookshelf speakers for the fronts but I want my speakers to match tonally.
Rgarc is offline
post #3243 of 3267 Old 02-15-2017, 05:28 PM
zieglj01's Avatar
Liked: 1190
The A series Boston speakers are well reviewed -- The A26 is also a good option to use as a center channel. You can always by a pair from Amazon to test out
https://www.amazon.com/Boston-Acoust...rds=boston+a26
Use the A25 for surrounds on the 5.2
https://www.amazon.com/Boston-Acoust...rds=boston+a25
They also have the smaller A23
https://www.amazon.com/Boston-Acoust...rds=boston+a23
The HSi in ceiling is one to think about for Atmos
https://www.amazon.com/Boston-Acoust...208585&sr=1-10
Who AM I
post #3244 of 3267 Old 02-16-2017, 10:33 AM
Quoted: 41 Post(s)
[QUOTE=zieglj01;50794177]The A series Boston speakers are well reviewed -- The A26 is also a good option to use as a center channel. You can always by a pair from Amazon to test out
Thank you for your recommendations. The specs on the A series are definitely in line with everything else I've looked at so far. I think will pick up a pair of the A26's or A25's and to test. At least I will end up with good pair of speakers for a 2.0 setup or adding to current BA setup for a 5.1.2 system in the den, which will get more daily use than the living room system because it's closer to the bedrooms.
It would definitely be cool to experience the Boston sound in atmos.
zieglj01 likes this.
Rgarc is offline
post #3245 of 3267 Old 02-16-2017, 10:43 AM
zieglj01's Avatar
Liked: 1190
Enjoy the adventure
Who AM I
post #3246 of 3267 Old 02-17-2017, 03:24 PM
joey_truelove's Avatar
Shall I take that as you don't get any level of boxiness from the A26 when used as a centre? My listening room isn't very large at all, but I never could get mine to perform in this position without sounding strained. Could be some acoustic phenomenon pertaining to the room rather the speaker.
joey_truelove is offline
post #3247 of 3267 Old 03-02-2017, 09:00 AM
Liked: 0
Hello,
Did anyone put M25 bookshelf speaker on a stand? Which stand would you recommend?
Best regards,
Eugene
SilencerRUS is offline
post #3248 of 3267 Old 03-10-2017, 04:39 PM
I'm still struggling with one of the 965s...
The cross-over still won't pass signal. I thought that if I just resoldered the coil that had come uncoiled that would be the last of it. But as it turns out...
Then the amp plate won't amplify. It kind of goes "pop" on power off, but not as loudly, which would indicate that the output does work as such. It just doesn't pass the attenuated high level through. As if that wasn't enought: the low level input seems to be an closed circuit internally. That's to say there is zero resistance between + and -.
Any suggestions on what to do?
post #3249 of 3267 Old 03-18-2017, 07:54 PM
Does anyone know if the VR960 features the high-level to low-level conversion thing of the 965? I was offered parts for the 960 for repairing my 965, but it seems that the 960s have a smaller amp board (in size as well as smaller component count) and a completely different crossover network (w. just the two coils, suggesting that the lows aren't filtered out).
Obviously the 960s had some issues which were then corrected in the 965s. But I have this hunch some other features were added or changed as well, so I'd better be sure what I'm in for to avoid nasty surprises.
post #3250 of 3267 Old 03-21-2017, 03:07 PM
Quoted: 41 Post(s)
Has anyone used the 5" BA Soundware speakers in a 2.0 or 2.1 setup, are those only good for background listening. i bought a pair a while back to use in the kitchen as background speakers and really liked them, I have to remove them because of my remodel and I want to find a way to repurpose them rather than getting rid of them. Would it be better to add them as fronts in my home theater setup (5.1 Micro 80) and buying dedicated bookshelf speakers for a 2 channel setup, or use the Soundwares and the sub from my home theater in a 2.1 setup and buy a deeper sub for the home theater? The Micro80pv sub is rated down to 30Hz but it may only reach 44
Rgarc is offline
post #3251 of 3267 Old 04-04-2017, 09:38 AM
Liked: 0
Hi guys,
I need help. I'm having M25 bookshelf speakers now. Is it worth upgrading them to M250 floorstanding speakers?
post #3252 of 3267 Old 04-04-2017, 09:51 AM
zieglj01's Avatar
Liked: 1190
Originally Posted by SilencerRUS View Post
Hi guys,
the M250 should play a little louder with about 5 hz more bass -- however, it will be more like a bookshelf speaker with 2 woofers on a stand. Depending on cost, you will have to make that decision. Something like the M340 would be a bigger upgrade.
Who AM I
post #3253 of 3267 Old 04-05-2017, 01:22 AM
Liked: 0
Thank you! I am using them as surround speakers. The idea is to get rid of the awkward looking stands.
post #3254 of 3267 Old 04-05-2017, 08:17 AM
image1's Avatar
add a sub
Hi guys,
Those are fine speakers. Adding as good entry level sub (like a svs PB-1000 ~$500) is going to make a much greater impact on your system than upgrading to the M250's.
image1 is offline
post #3255 of 3267 Old 04-09-2017, 09:21 PM
da1951's Avatar
Owner of Micro 9000 System setting up new BA HTS
I have had a Micro 9000 system (micro 90x mains, VRS surrounds, micro90c center and pv90 sub) set up in a small room since late 1998. Overall quality has been excellent. Had to play around with sub placement to smooth out the bass and also stuffed up the sub ports to reduce their activation of standing waves (room is about 11' square - definitely not ideal).
I am now setting up a home theater system with what will be a 55" tv in a larger room. So far I've acquired on ebay a pair of micro 90x's to use as surrounds and just tonight purchased a VR-10 because for $50 plus about $45 shipping costs it seemed like too good a deal to pass up. I still don't have that much lateral room to work with because the set up can't block access to storage space and the main speakers will be on a stand that will also hold the TV. So I'm looking for some not too wide main bookshelf speakers that have the VR tweeter. (That tweeter is a large part of the reason I wanted to do another Boston set up.) I have been looking at the VR-M50 (7.1" wide) (available on Ebay for a little over $300 including shipping), the Micro 100x (6.3" wide) available on Craig's List in various locations for considerably less than the VR-50s, the E40 (6" wide) which is hardly available anywhere except as a single speaker at Accessories4less, and the Micro 130x (5" wide), available as new from only one source on Ebay for about $250. I will be getting a sub, probably a 10" downward firing unit.
The left main speaker will be near a wall that creates a notch in the room. The notch wall ends about 12-16" in front of where the left speaker will be. So the narrower the main speaker, the further away it can stay from that wall.
Any advice or suggestions about how to complete the system are appreciated.
da1951 is offline
post #3256 of 3267 Old 04-10-2017, 03:55 AM
H Stevens's Avatar
I had the same set up as you many years ago (Micro's and VRS surrounds), I still use the VRS surrounds but I purchased the A25's for fronts and the 225C center. I have always preferred the Boston sound and I have to say that the A25's are very satisfying. The Kortec tweeter in the "A" series is very well designed and smoother in the higher frequencies than the SWB tweeter that they used in the VR series. Just a personal observation in my room.
As far as subwoofers, it may be out of what you have budgeted, but I had the opportunity to audition a Rythmik F12 in my room and with the high damping setting on the Rythmik, it was a perfect match with the Boston's all around.
H Stevens is offline
post #3257 of 3267 Old 04-15-2017, 05:41 AM
Bacovish's Avatar
Liked: 37
Hello guys,
Anybody here still using the m350 tower and your thoughts on how they might compare to the A series towers. I know the m series will soon be extinct and I can pick up a new pair for 525.00. At that price is it better than the A-series. Unfortunately I can't audition them before buying.
I have read some mixed online reviews. I don't believe everything I read online good or bad. I also did a search here and read a couple posts a little while back.
I've always been a fan of the BA from back in my car audio days but haven't really kept up with them. Thanks for any help or info.
Sony XBR 940D
Dali Zensor 7
Dali Vokal center
Klipsch RP 240s
Paradigm PDR12
Yamah RX-A1050
Bacovish is offline
post #3258 of 3267 Old 05-08-2017, 05:52 AM
Liked: 0
Originally Posted by Bacovish View Post
Hello guys,
I do have all M-series speakers. From the aesthetical point of view they are superb! You will like the way they look. Bought them 2,5 years ago and still have them in boxes since my house is not ready yet. So I can't tell you how they sound but something tells me I will not be disappointed.
post #3259 of 3267 Old 06-21-2017, 07:28 AM
Captmaturin's Avatar
Liked: 0
Hi everybody.
I have a question to ask to fellow BA enthusiasts. Few words about me ? I discovered Boston when I bought at age 18 (and that's 18 years ago), my first real Home Theater set up. It was composed of 2 VR950 (LR), a crappy Opal CC10 (middle), and two CR8 as surrounds.
18 years later, I've got the same set up, but I added two CR8 as surround back. And I don't want to change. Except for the center speaker.
So here's the deal. I'd like to have a L/C/R front which is homogenous.
As I'm European, it's quite hard to find second hand VR950 in here. But I found one pair, far away from my town, at 299E.
I also found two VR2 for 290E (and I could buy a single one from a shop for 220+shipping).
I also found somebody selling a 1999 THX boston kit (2 VR35, 1 VR14 center and 2 VRS dipole surround speakers) for 500E (including two outdated Denon receivers, one AVR-2808 and one AVR-3802)
I currently run an HK AVR630, which sounds great, but my left channel died on me, and it has no HDMI. So I'm using my Oppo 93E to decode then send the signal to the AVR630 multich inputs. So I'm also thinking about buying for 400Euros a second hand recent receiver.
So question short, what would be the best deal, in terms of sound ? Are VR 35 better than Vr2 ? Is it the contrary ? Would my VR950 marry enough with one VR2 or should I buy a complete 3 set ? Or would my two Vr950 be great with one VR35 as a middle ? Or should I go for the very expensive second hand vr950 ?
Looking forward to hear from you Boston lovers
Captmaturin is offline
post #3260 of 3267 Old 06-21-2017, 08:03 AM
Docethic's Avatar
Quoted: 305 Post(s)
Liked: 268
Originally Posted by Captmaturin View Post
Hi everybody.
Can you use the vr14? The vr35 and vr14 are the best Boston made so jump all over those and use the vr950s as surrounds. The VR2 are superior to the 950s but not to the vr35. I have been waiting for a vr14 for years they are rare and carry a premium price so jump on that!
Docethic is offline
post #3261 of 3267 Old 06-21-2017, 08:11 AM
Liked: 0
Hey mate, thanks for your reply.
Yeah I can use the VR14 where I used my CC10. I trust you on the VR14 quality, but what makes the VR14 a better speaker than a full colum ?
I contacted the guy selling them anyway, I hope they're still available
post #3262 of 3267 Old 06-21-2017, 10:27 AM
Liked: 0
The 1999 THX Kit is still up for sell. I'll call the guy tomorrow and even try to bargain it, since he can't post, can't deliver and I'll have to drive more than 300 km round trip. I'll keep you posted
post #3263 of 3267 Old 06-21-2017, 10:36 AM
Docethic's Avatar
Quoted: 305 Post(s)
Liked: 268
Three VR35 would be ideal but the VR14 will be fantastic. I have never heard the 14 but the VR12s I owned were fantastic. Incredible voice presence for movies and sensitivity far beyond their rating. The 14 should be even more dynamic and efficient and being sealed you can really push them without any fear of boominess in male voices. The vr950s are great, but the 35/14 set should be a noticeable step up.
Docethic is offline
post #3264 of 3267 Old 06-22-2017, 06:32 PM
gotcory's Avatar
Hi everybody.
I am going to pile on here and say I vote for the VR35/VR14 combo.
I'm a big fan of these, I have them in one of my rooms, along with the matching VRS-Pro surrounds, and the whole set is nearly the best system I have ever had. In my opinion only better is the Boston Acoustics E100/E60 7-ch in the main room. The vrm60 are also great bookshelves and a good option, I use those as 2 channel sonos in a couple rooms.
Happy listening!
gotcory is offline
post #3265 of 3267 Old 06-22-2017, 11:00 PM
Liked: 0
thanks guys for the replies ! So, I followed your advice and called the seller. I bargained, quite easily actually, he accepted right away the price I asked for his set.
I'll pay 300 hundreds euros for the whole set. The THx set, and two amps !
I'll keep you posted !
post #3266 of 3267 Old Yesterday, 03:21 PM
ouimetnick's Avatar
Is Boston Acoustics even still around? I know they have a website, but they haven't had any new products in quite a few years now. The Peabody MA location was closed and sold. They aren't embracing the digital age of bluetooth speakers or AirPlay, and the entire product line is stale. I know D&M Holdings was recently purchased by the owners of Polk Audio....
ouimetnick is offline
post #3267 of 3267 Old Today, 10:54 PM
husq2100's Avatar
Quoted: 12 Post(s)
hey all,
Im looking for 1x E70 extra base support, and 2x E series wall mount.
http://www.bostonacoustics.com/US/Pr...ostonAcoustics)
As you can see the wall mount is still listed on BA's USA site. They will not deal with me as im outside the USA (Australia) The Australian distributor is a joke and cant offer any help and cant get info from BA USA...
Hopefully the pic i have added works, this shows the extra base support.
cheers
Serg
husq2100 is online now
Reply Speakers
Boston Acoustics Brand , Boston Acoustics , Boston Acoustics E40 , Boston Acoustics Vr Mc , Boston Acoustics Powered Subwoofer Asw250 , Boston Acoustics Asw650 10 Inch Subwoofer
