Energy Owners Thread - Page 1746 - AVS Forum | Home Theater Discussions And Reviews
 438Likes
post #52351 of 55309 Old 08-31-2014, 02:18 AM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 143
Originally Posted by LDBecker View Post
Sorry to resurrect an old thread... But I just wanted to say Thanks to burkeydvm. I've had these speakers (non-i Veritas) for like a decade and have tried several times to clean the tops of the sticky residue and only made it worse. Even called Energy a year or so ago and they had no clue... But, other than the stickiness, I love my 7.1 cherry Veritas speakers.
I was giving my home theater some love this week - receiver died and time for something new... And thought I'd try one more time to search for a solution... Denatured alcohol really did the trick! I have 4 speakers with the rubber tops and rubber sides on the center... They are all now smooth and soft to the touch- and there's nothing that the dust will stick to! It took about 15 min a side with gentle rubbing with a soft cloth saturated in the alcohol, and a final wiped own and they are now smooth and not sticky at all.
So- thanks for posting this- these are absolutely great speakers, and they're now like new!
Larry
Edit: the tops of the speakers are now smooth black plastic, which looks GREAT. I think there was a rubberized coating on top of that originally, which, thanks to our LA smog, turned to gummy, stick goop. The denatured alcohol I used just removed that initial VERY THIN rubberized coating and took it down to the hard surface of the tops. The tops are still the 1/4" or so black plastic. If one wanted to, the tops could be sprayed with a rubberized coating again I suppose - they look/feel great as is at this point. Easier to dust as well! I'm not sure I want to risk it - LB
Pictures?
brahn likes this.
Gmash is offline
post #52352 of 55309 Old 08-31-2014, 07:51 AM
LDBecker's Avatar
Quoted: 76 Post(s)
Originally Posted by Gmash View Post
Pictures?
Will try to post them after the holiday... thanks for asking - never posted a photo here before.
LDBecker is offline
post #52353 of 55309 Old 08-31-2014, 08:57 AM
deano86's Avatar
Quoted: 295 Post(s)
Liked: 152
Originally Posted by deano86 View Post
There may be more than just the shape for differences between the "C" in ceiling speakers and the "W" in wall designated speakers.... be sure to check the mounting depth specs between the two models... In ceiling speakers may be deeper as they are intended for the additional space typically afforded ceiling mounting, whereas the in wall speakers should for certain fit in the typical 2 X 4 stud frames as far as depth....
Just an update to this: Checking the specs on the Energy-speakers.com site, shows that the EAS-6C has a mounting depth of only 2.75 inches!... so they would be fine for mounting in walls also... actually shallower than the EAS-6W's 3.25 inches... even the EAS-8C has a depth of only 3.25 inches..... so wall mounting in a 2x4 (1.5 X 3.5) studded frame wall should be no problem I would think....
The mounting depth issue would only come into play if by chance you were able to find the RC series of in ceiling speakers... the RC-6C and the RC-8C have a greater than 4 inch mounting depth... whereas the RC-6W is the only one with less than 4 inch mounting depth...
deano86 is online now
post #52354 of 55309 Old 08-31-2014, 12:30 PM
brendelac's Avatar
Quoted: 160 Post(s)
Liked: 90
brendelac is offline
post #52355 of 55309 Old 08-31-2014, 05:52 PM
laserjock II's Avatar
Quoted: 774 Post(s)
Liked: 434
Would be worth a look/listen if I lived near them.
laserjock II is offline
post #52356 of 55309 Old 09-01-2014, 08:26 AM
Aarghon's Avatar
Quoted: 160 Post(s)
Liked: 380
So, Laserjock, did you fiddle with the rc70s a little ? =D
Polk Audio LSIM703, Polk Audio LSIM704c, Polk Audio RTI-A1 surrounds
Dual Reaction-Audio BPS212 turbo subwoofers
Marantz AV8801 preamp, Rotel RMB-1095 power amp
Pioneer Elite n50 network player
Marantz CD6004 cd player, Marantz UD5007 Blu ray player, Modded Rega RP1 turntable
Panasonic Tcl55dt60 led tv,Playstation 3 and a lot of old consoles
Aarghon is offline
post #52357 of 55309 Old 09-01-2014, 09:52 AM
Quoted: 774 Post(s)
Liked: 434
One day! Lol
Still in the box.
I need to get em out and get them broke in.
Aarghon likes this.
post #52358 of 55309 Old 09-01-2014, 07:06 PM
ah_1014's Avatar
Quoted: 69 Post(s)
Liked: 33
Hey guys,
I'm considering adding front heights to my 7.3 system and I have a few question. I currently have the RC setup and was wondering which Energy speaker would be the best tonal match, the CB-10 or the Veritas mini? Also, do any of you have experience using front heights and how much does it add to a movie/game experience? I'm not seeking a drastic change, but I'm expecting more immersion with ambient sounds.
Television: Panasonic TC-P65VT60
Receiver: Yamaha RX-A2010
Speakers: Energy RC-70's, RC-LCR, RC-10 (4), JTR Captivator 1400, Rythmik FV15HP (2) and Velodyne VDR-12 (3)
ah_1014 is offline
post #52359 of 55309 Old 09-01-2014, 08:31 PM
deano86's Avatar
Quoted: 295 Post(s)
Liked: 152
Originally Posted by ah_1014 View Post
Hey guys,
I would just go with the Veritas Minis as they would be the easiest to mount and come with mounting brackets already... and the drivers look more similar to the RC line also. But, for my room, heights just didn't seem to do anything that great...especially when compared to wides, but that is with Audyssey DSX expansion.. whereas your heights may be using your receiver's own height surround mode? So, I have no idea on how much those will add... but, it seems that the higher your ceiling, the better.. what is your ceiling height?
post #52360 of 55309 Old 09-01-2014, 08:57 PM
ah_1014's Avatar
Quoted: 69 Post(s)
Liked: 33
Because of the venting system, 1/3 of the basement is lower then the other 6"10 compared to 7"8.
Since My Yamaha uses its own DSP for front heights I wonder if that will make much a difference compared to the DSP that is available in your receiver?
The reason I asked between these two speakers is because they are on sale. The CB-10 are going for $169.99 a pair and the Vminis are going for $139.00 each. If the Vminis will be a better tonal match I'll go for those, but is it worth the $130.00 difference?
ah_1014 is offline
post #52361 of 55309 Old 09-02-2014, 11:01 AM
LDBecker's Avatar
Quoted: 76 Post(s)
Pictures?
Ok - as promised, pictures of tops and sides (on Center channel) of recently cleaned/renewed cherry veneer Energy Veritas speakers. You can see in the first one, of the left 2.3 Veritas, it's now shiny black on top, rather than the formerly sticky black with cat hair. You can see from the L-C-R shot what they look like as a group (and that I'm a Trekkie!), and the wider shot shows one of the 2.1 speakers on a Veritas stand, and one of the 2.0r surround speakers on the wall.
I was thinking of spraying a rubberized finish on the tops again, but I think I like them the way they are, and for the life of me am not sure why they put it on in the first place - maybe they didn't know it would turn to goo in a few years.
I'm on the verge of getting a receiver with Dolby Atmos, so am trying to figure out how to fit two more Height channel speakers in the already too small room... the WAF is already pressed beyond reason - thinking maybe of adding a couple of Orb speakers firing up.
Larry
Name:	Becker Veritas L closeup.jpg
ID:	242338   Click image for larger version
Name:	Becker Veritas wider shot.jpg
ID:	242346   Click image for larger version
Name:	Becker Veritas L-C-R.jpg
Gmash and burkeydvm like this.
LDBecker is offline
post #52362 of 55309 Old 09-02-2014, 01:32 PM
JKR1963's Avatar
Quoted: 249 Post(s)
Liked: 108
They look nice and shiny now!! Nice.
JKR1963 is offline
post #52363 of 55309 Old 09-02-2014, 01:34 PM
JKR1963's Avatar
Quoted: 249 Post(s)
Liked: 108
@brendelac : awesome how some deals can be made at futureshop... I could have bought a pair of veritases 6.3c for... 799$. Considering how much I've drooled upon them, I still can't figure why I didn't buy them.
That would have been a good deal.....the lowest I had ever seen them for at Future Shop online or in Metro Edmonton was $799. per speaker.
JKR1963 is offline
post #52364 of 55309 Old 09-02-2014, 04:28 PM
Aarghon's Avatar
Quoted: 160 Post(s)
Liked: 380
Yup, futureshop seems to do cluster pricing in store.. Often I've seen stuff lower
in store than advertised online... Must depend on the sales rate in local markets... And Energy veritas speakers and RC aren't on the website anymore... So the stores still having them on hand have to be doing something. Maybe a manager's deal.
Aarghon is offline
post #52365 of 55309 Old 09-02-2014, 05:04 PM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 143
Larry
Those look good! Nice job. I'll have to remember the denatured alcohol trick.
Gmash is offline
post #52366 of 55309 Old 09-02-2014, 05:21 PM
LDBecker's Avatar
Quoted: 76 Post(s)
Thanks! I posted a lot about it so that others who have these speakers and the same issues will have a clue of what to do. I have had this issue for several years - my wife was sick of it, and now she just laughs at how easy it was to fix - "After all these years!" Sorry, Dear!
So, now people know what to do. And I found a brief hint of it from a Google search that pointed me to part of a thread from a year ago.
Larry
LDBecker is offline
post #52367 of 55309 Old 09-03-2014, 12:36 PM
mobileES's Avatar
Quoted: 67 Post(s)
Liked: 45
Recently picked up a C-C1 center and a pair of C-R1 side surrounds to add to my C2 mains. Working on replacing my 120w Sony sub and Sony surround back speakers with a Velodyne sub along with Energy Take Classics. The center channel was a huge increase in sound quality, blows me away and the side surrounds are very impressive. Pics of the center....
mobileES is offline
post #52368 of 55309 Old 09-03-2014, 12:47 PM
boardinguy100's Avatar
Quoted: 13 Post(s)
Hello fellow energy owners. I had a chance to listen to my Energy RC 70's near reference level today and I noticed that the sound was lacking in the left speaker. I put my ear up to it and noticed that the tweeter and driver just below it weren't producing any sound. I checked the wires and connections and even tried it with another amp and still no sound. Anyone have any ideas? Thanks in advance.
boardinguy100 is offline
post #52369 of 55309 Old 09-03-2014, 12:56 PM
stejhu's Avatar
Hi. I hope I'm posting in the right place. I recently bought an onkyo tx-nr636 that came with 5 small jamo 360 s25 speakers. I already have two energy CF30s I can use as fronts. Should I throw it all together and get a cc10 as a center channel with the small s25s for surrounds/rears? Would that work? Better suggestions? Thanks in advance!
stejhu is offline
post #52370 of 55309 Old 09-03-2014, 12:57 PM
stejhu's Avatar
I forgot to mention that I also already have a rhythmik LV-12r sub.
stejhu is offline
post #52371 of 55309 Old 09-03-2014, 01:22 PM
Aarghon's Avatar
Quoted: 160 Post(s)
Liked: 380
Well, if anything, a well matched ( ideally a perfectly matched ) front stage is the main thing that is going to affect your home theater sound quality. I would indeed match the center if available easily to you. Optimum situation! Going the same speaker series is always a good idea!
If the surrounds can be matched too, it's a good thing, but wayyyyy less critical than having a front stage match. If you get some center unmatched to your fronts, you might notice a "Panning breakage" when, for example, a motorcycle crosses the screen,... You'll be able to notice the different tone when going from front left to center, then center to right. To sum it briefly, the sound transitions will sound bumpy, not fluid and uneven.
stejhu likes this.
Aarghon is offline
post #52372 of 55309 Old 09-03-2014, 01:25 PM
stejhu's Avatar
Thanks for the reply. I appreciate it. Is there a better option that timbre matches to the CF30s than the CC10, or should I just start looking for a decent deal on the CC10?
Aarghon likes this.
stejhu is offline
post #52373 of 55309 Old 09-03-2014, 01:34 PM
Aarghon's Avatar
Quoted: 160 Post(s)
Liked: 380
My pleasure sir!
Well the cc 10 would indeed be the perfect match. And the CF-30 woofer size exactly matches the cc-10, so I think that it would be hard ( if not impossible) to get a better match. Especially since the cc-10 is easily available with a good deal. I wouldn't look elsewhere, personnally!
stejhu likes this.
Aarghon is offline
post #52374 of 55309 Old 09-03-2014, 02:22 PM
Aarghon's Avatar
Quoted: 160 Post(s)
Liked: 380
Well, if you've tried it on different amps, and that the problem is replicating... Most likely not an amp issue. I hope you didn't blow a tweeter and a midrange by driving them too hard... What is the power source that you've used to drive them near reference level?
Maybe just a connection that came loose by vibrating...I'd try to open them first.
Usually the rc70s can take quite a beating from what I've read...
If it's the case, Klipsch still has parts to fix them, and if they are under warranty, usually they back their product.. If I were you, I'd contact them.
Hope it helped a little!
Aarghon is offline
post #52375 of 55309 Old 09-03-2014, 02:37 PM
brendelac's Avatar
Quoted: 160 Post(s)
Liked: 90
Do you have the bridge plate connected between the terminals at the back of the speakers? That would be the first thing to check. What about with the volume turned down?
post #52376 of 55309 Old 09-03-2014, 02:44 PM
Quoted: 13 Post(s)
I'm using an Anthem MRX 310 with an emotiva XPA 5. I've actually had it louder at times with no problem.
post #52377 of 55309 Old 09-03-2014, 03:11 PM
Quoted: 13 Post(s)
Yes it does the same thing with the volume low and the plate is connected. I've never blown a speaker before so I'm not sure what to expect. Is this typically what happens...a driver or drivers just stop working?
post #52378 of 55309 Old 09-03-2014, 03:21 PM
brendelac's Avatar
Quoted: 160 Post(s)
Liked: 90
Plates (plural, 2 per speaker. Black to black and red to red) are both connected, right? Sorry, this is basic stuff that you are probably aware of, but seems the most likely problem to cause your issue. I have never blown a driver myself, but I have had 1 or 2 DOA on speakers that I have bought new and they still produced sound, just nowhere near what they were supposed to. The fact that you have a tweeter and mid-range both all of a sudden not working at all would lead me to assume that they are not blown.
I'm not the troubleshooting guru, but I'll try to help until batpig or someone more learned chimes in.
post #52379 of 55309 Old 09-03-2014, 05:53 PM
Quoted: 13 Post(s)
Brendelac thanks for the tips, I have made sure everything is connected properly and tight. I have to admit I'm completely stumped.
post #52380 of 55309 Old 09-03-2014, 06:30 PM
deano86's Avatar
Quoted: 295 Post(s)
Liked: 152
Disconnect the bi-amp/bi wire shorting straps and connect only to the upper set of terminals... double check that you have no sound whatsoever... If so, I would say most likely you had wire/connector come loose somewhere inside the speaker... on a crossover circuit? or a component on a crossover board went bad, causing the lack of sound. Either way, you may need to open up your 70.... take out the drivers and take a look inside... looking for loose wire or some visual sign of damage to a crossover circuit board... or something....look at the wiring and follow it and try to determine the most likely culprit areas for the lack of sound coming from both your tweeter and midrange driver...
Reply Speakers
Energy , Energy Loudspeakers , Energy S8 3 Subwoofer , Energy S12 3 Subwoofer , Energy Take Lcr Speaker Single Black , Energy Take Sat Speaker Single Black , Onkyo Tx Ds 656 , Receivers Amplifiers , Osd Audio S 10 High Powered 10 Inch Home Theatre Subwoofer Black , Energy Speakers , Energy Speaker Systems , Energy C 100 Bookshelf Speakers , Energy Rc R Surround Speaker Black , Energy Bookshelf Speakers C 50
