Energy Owners Thread - Page 1783 - AVS | Home Theater Discussions And Reviews
 154Likes
post #53461 of 53484 Old 03-24-2015, 11:04 PM
snowyo's Avatar
Originally Posted by clarkkent06 View Post
Someone near me has a pair of A3+2's on sale for $300. Good deal?
I sold mine for $400.You need a sub with these but the detail and imaging is second to none.
snowyo is offline
post #53462 of 53484 Old 03-25-2015, 01:13 PM
DrewRosenHouse's Avatar
Originally Posted by batpig View Post
The adjustible knob controls the dispersion -- it's a volume control for the side-firing midrange drivers. If you set it to bipole and turn the volume all the way down, you basically turn it into a direct-firing speaker.
So, you kind of have to experiment and see what sounds good to you. There's not really an "ideal" per se.
Thanks for the info, this clears things up. The YPAO seems to have done a good job, even with the left side surround sitting significantly closer, it blends extremely well. The only time I notice it is when Im sitting on the part of the sectional where the speaker is 2 ft from my head.
DrewRosenHouse is offline
post #53463 of 53484 Old 03-25-2015, 01:58 PM
ffactoryxx's Avatar
I currently have 3 LCR Fronts, VS Surround and RC 10 Rears with a NSD-PB12 SVS sub.
I primarily play Video Games and Watch movies. Would the RC-70's as fronts be a major upgrade? Room is about 12x22 with TV and LCRS along the 12' wall.
When we move into a new house i plan on a theater room bigger than that. Could still use the RC70's as a 2.1 in living room. They are about $250 shipped each right now.
ffactoryxx is offline
post #53464 of 53484 Old 03-25-2015, 02:18 PM
The Postman's Avatar
Veritas Tweeter Aluminum Dust Cover
Does one know if you can buy the dust cover for the Veritas V5.2C tweeter ? Thanks !
The Postman is offline
post #53465 of 53484 Old 03-25-2015, 02:36 PM
rajdori's Avatar
Want RC70 pair (used six months, clean) for $400 at Houston?
I had bought RC70 pair for $600 in 2013. Used those only for six months, are now lying in box at Houston.
I have moved to CA now. I was planning to move RC70s and my other speakers to San Jose now. But then saw RC70 deal at 250/each at Frys.
If someone purchases my RC70 pair at $400 at Houston...
I will be saved from shipping those monsters from Houston to San Jose, and can instead purchase from Frys at San Jose.
Buyer saves $100 compared to Frys current deal.
Let me know if anyone is interested.
rajdori is offline
post #53466 of 53484 Old 03-25-2015, 09:44 PM
Quoted: 28 Post(s)
Liked: 7
Anyone want one veritas 6.3. Piano black. Has small damage on the side. Pm me I'll send some pics. Have box and all accessories. Want $300
Timothy1180 is offline
post #53467 of 53484 Old 03-26-2015, 02:32 PM
ffactoryxx's Avatar
Anyomne?
post #53468 of 53484 Old 03-26-2015, 03:18 PM
mattdub1's Avatar
Quoted: 139 Post(s)
I believe you need to purchase the whole tweeter assembly.
mattdub1 is online now
post #53469 of 53484 Old 03-26-2015, 03:21 PM
mattdub1's Avatar
Quoted: 139 Post(s)
Has anyone noticed that the screws securing the drivers in the cabinet get loose after removing the drivers a few times? Each time I have taken them out, more and more wood shavings come out with the screws and the looser they seem when screwing them back in. Only thing I can think of is to try the toothpick trick down the road???
post #53470 of 53484 Old 03-26-2015, 03:21 PM
Thanks... I called the distributor in Canada and it costs $50.
post #53471 of 53484 Old 03-26-2015, 03:24 PM
hernanu's Avatar
Quoted: 187 Post(s)
Liked: 484
Anyomne?
Tough question. The RC-LCRs are very good and having all three across the front is a sweet situation. I don't have the 70's but the next step down, the RC-50's with and RC-LCR center, I didn't progress from the LCR's but from RC-10's.
I would think it would normally be a good step up, but the RC-LCRs are pretty good especially with a good sub. If you could do three RC-70's across the front, it would be easier to say that it would be better.
Sorry I can't be more help, but if forced to, I'd do it only if I could do three RC-70s, otherwise I'd just get another sub.
hernanu is offline
post #53472 of 53484 Old 03-26-2015, 04:30 PM
ssthrd's Avatar
Just a few suggestions:
Be careful with the toothpicks. The box material could be MDF, and every time you take the screw out, the material disintigrates a bit. Hence the shavings. If you fill the hole and then put the screw back in, you might split the cabinet. Use only one if you have to.
Wrap the screw with a layer or two of paper and reinstall the screw. Or use Teflon pipe tape.
Not sure what thickness you have to work with or how long the screws are, but you may be able to simply use a longer screw.
Maybe the next size larger diameter screw would work. eg, if the screw is a #10 , go to the same length in a #8 .
Lots of ways!
If all else fails, you could drill a hole large enough to glue a piece of dowel into. then drill a new undersized hole for the screw.
Good luck!
Yamaha HTR 6190, Mains Energy RC-70, Center Energy V5.2C
Surrounds Energy V2.0R, Rears Energy V-Mini, Subs Omni S10 and Omni FRx-S10
Sharp 52" LCD, Toshiba BR Player, Apple TV, 27" iMac
ssthrd is offline
post #53473 of 53484 Old 03-26-2015, 05:19 PM
brendelac's Avatar
Quoted: 67 Post(s)
Liked: 55
Major upgrade? No. If you do see yourself with another 2.1 setup in the future, you may be wise to buy them now while you can (been saying that for how many years now?) but for your current setup, it would be a moderate upgrade at best. As hermanu said, a second sub would more significant.
I have one. As I recall, it works fine, but the dust cap is creased. If you're interested, I will test it and sell it for cheap, but no guarantees.
brendelac is offline
post #53474 of 53484 Old 03-26-2015, 05:21 PM
batpig's Avatar
Quoted: 1553 Post(s)
Liked: 1832
Anyomne?
Personally, I wouldn't think the RC-70's would be a "major upgrade" over the RC-LCR's for movies/games usage. Especially since you have a good subwoofer. The RC-LCR's are also a 3-way design, they are flat to 60Hz, and you have a perfectly matched front soundstage. It would be one thing if you wanted to do critical 2ch music listening with full range speakers, but for movies and gaming... meh, probably not worth the effort.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #53475 of 53484 Old Yesterday, 01:34 PM
Liked: 0
If i have to make sure sound come from my SUB while listening to music, what are the options? I am having RC-70 set as Large Speaker with crossover at 50Hz.
sandysrivastava is online now
post #53476 of 53484 Old Yesterday, 01:46 PM
batpig's Avatar
Liked: 1832
It depends what receiver you have, but in general you have two options. Option one is to set them to "small" and then low bass is redirected to the sub. This is standard bass management. The other option is to engage a "double bass" setting in which the signal is copied to the subwoofer without bass management.
batpig is offline
post #53477 of 53484 Old Yesterday, 02:36 PM
Liked: 0
I have Pioneer Elite VX-44. I set the speakers as SMALL but still no Sound from SUB. I am not sure how to try second option.
When i force the sound mode to Dolby Pro Logic, i do get 5.1 sound but then it doesn't sound good for Music.
For the same SONG while my Car Speaker is able to produce better BASS, i don't get the same BASS with RC-70 so i really want to try SUB for it.
post #53478 of 53484 Old Yesterday, 04:07 PM
brendelac's Avatar
Quoted: 67 Post(s)
Liked: 55
I don't know pioneer receivers, there should somewhere in the menu options to adjust your stereo and direct settings. On my Denon, the menu navigation is as follows:
Manual Setup - Audio Setup - 2ch Direct/Stereo
From there, the settings are different then they are for multi channel listening. You'll need to go through again and adjust your front speakers to small or large as desired and also enable your subwoofer. It is likely disabled which is why you are getting sound out of it in 5.1, but not 2.1
post #53479 of 53484 Old Yesterday, 05:41 PM
rajdori's Avatar
Unhappy
How crazy is it, that no one is interested in RC70 pair at $400, in excellent condition... No one?
rajdori is offline
post #53480 of 53484 Old Yesterday, 05:45 PM
laserjock II's Avatar
Quoted: 161 Post(s)
Liked: 78
If I didn't already have a set.
laserjock II is offline
post #53481 of 53484 Old Yesterday, 06:09 PM
Aarghon's Avatar
Quoted: 54 Post(s)
Liked: 314
@ sandyrivastava : The double bass setting that Batpig is referring to is called "PLUS" on your Pioneer receiver. What is the X-over that you have set with the small setting ? 50hz too?
Polk Audio LSIM703, Polk Audio LSIM704c, Polk Audio RTI-A1 surrounds
Dual Reaction-Audio BPS212 subwoofers
Pioneer Elite sc-61 AVR, Rotel RMB-1095 power amp
Pioneer Elite n50 network player
Marantz CD6004 cd player, Marantz UD5007 Blu ray player
Panasonic Tcl55dt60 led tv,Playstation 3 and a lot of old consoles
Aarghon is offline
post #53482 of 53484 Old Yesterday, 06:15 PM
Aarghon's Avatar
Quoted: 54 Post(s)
Liked: 314
@ sandyrivastava : I know it surely has been pointed out, but are you using the pure direct mode for 2 ch audio?
Aarghon is offline
post #53483 of 53484 Old Yesterday, 10:48 PM
brendelac's Avatar
Quoted: 67 Post(s)
Liked: 55
Post them in the for sale section and on craigslist. Your price is good, but shipping is a bad idea and expensive so finding someone local, browsing this thread and in the market for these particular speakers is a tough go.
post #53484 of 53484 Unread Today, 01:53 AM
Liked: 0
Thanks @batpig and @Aarghon .
So i tried following options:
1. Set RC-70 (Front) as Large and SUB Set as PLUS (Double BASS where receiver is duplicating the BASE to SUB)
2. Set RC-70 (Front) as Small and SUB Set as YES
With the both cases i tried the X Over Frequency is set to 50Hz, 80Hz and 100Hz.
But still same issue.
Reply Speakers
Energy , Energy Loudspeakers , Energy S8 3 Subwoofer , Energy S12 3 Subwoofer , Energy Take Lcr Speaker Single Black , Energy Take Sat Speaker Single Black , Onkyo Tx Ds 656 , Receivers Amplifiers , Osd Audio S 10 High Powered 10 Inch Home Theatre Subwoofer Black , Energy Speakers , Energy Speaker Systems , Energy C 100 Bookshelf Speakers , Energy Rc R Surround Speaker Black , Energy Bookshelf Speakers C 50
