Energy Owners Thread - Page 1795 - AVS | Home Theater Discussions And Reviews
 200Likes
post #53821 of 53831 Old Yesterday, 09:31 AM
Iron Maiden's Avatar
Quoted: 169 Post(s)
Liked: 43
So it almost sounds as if the run of RC's is done. Damn, maybe I will pick up another pair!!!
I'm still keeping an eye open for Veritas crossovers and tweeters.
I'm thinking it would be a fun experiment to just swap in the Veritas xovers into the RC70s.
Will need to double check the impedance of all the drivers to make sure they match to the Veritas before hand, and take a look at the individual xover points of the drivers.
60" Panasonic Plasma ~ BenQ HT1075 / 92" fixed Dragonfly Screen ~Onkyo TX-NR3008 as my Pre/Pro
Earthquake Sound Cinenova Grande Amplifier ~ Crown X1000 ~ Oppo BDP-103
Musical Fidelity Tri-Vista Tube DAC ~ Monster Cable Signature Series HTPS7000
Energy Veritas 2.2i (mains) & Veritas 2.0c (center) ~ Energy RC-70 (side surrounds)
CAT Tiburons(rear surr) ~ Sub... custom 15" Diamond Audio Technology ~ Xbox One
Iron Maiden is offline
post #53822 of 53831 Old Yesterday, 11:29 AM
kgallerie's Avatar
Quoted: 23 Post(s)
Liked: 70
Interesting concept changing the rc-70 tweeters for some i series. I dont know how that would work though work the cabinet and the cut openings. It appears that the veritas tweeter/midrange module was crossed over at ~550 hz, and the RC-70 crosses between the 5.5" midrange and woofers at 600hz. So you would need to replace both the RC-70 tweeter and 5.5" midrange with the one veritas module, so the opening in the RC-70 cabinet would be way too large.
If you were planning on using the veritas module with the 5.5" midrange and woofers of the RC-70's, there wouldnt be enough space above the 5.5" midrange for the module, unless you turned it sideways. Even then I think it would be way too tight.
Its an interesting concept, but I think it reality it would be quite difficult to do.
kgallerie is offline
post #53823 of 53831 Old Yesterday, 12:01 PM
jimbonyc's Avatar
can anyone help recommend a pair of rear speakers for the following setup i already have in a dedicated 13x20 media room?
denon x2100w
energy rc-70 pair up front
energy rc-lcr center
axiom qs8 side surrounds
svs pb1000 sub
i was leaning toward getting a pair of rc-10's to wall mount at the rear of the room (about 5-6 feet behind the seating area). but the rc-10's are quite big to wall mount. would a simple pair of satellite speakers of some sort be adequate for the rears? any suggestions would be appreciated!! thank you.
jimbonyc is offline
post #53824 of 53831 Old Yesterday, 02:20 PM
Quoted: 169 Post(s)
Liked: 43
I would swap the tweeters no problem. As far as the whole csm module(Veritas mid & tweet) it's far smaller than the 5.5" mid/tweet setup on the RC70. It would fit but obviously not without modifying the cabinet/baffle.
My goal all along was to find a damaged 2.3i/2.4i to build into a center channel. Have never liked the 2.0i center. It really should have used the dome mid as well.
One of these days I will find what I need to make something custom. For fun if nothing else.
post #53825 of 53831 Old Yesterday, 02:49 PM
batpig's Avatar
Quoted: 1724 Post(s)
Liked: 1934
denon x2100w
svs pb1000 sub
What about another pair of QS8's if you're happy with them? Or the smaller QS4s if you want to save some cash.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #53826 of 53831 Old Today, 10:45 AM
kgallerie's Avatar
Quoted: 23 Post(s)
Liked: 70
It looks like you could replace the tweeter on the V2.0Ci with the whole csm module, which would be pretty cool. It looks like it would fit between the woofers and you would just need to cut the right size hole. You could probably use the csm module from a 2.2i, 2.3i, or 2.4i, but like you said before you would need to check the resistance. I would imagine you could use the crossover from each of those as well with some modification. It looks like the V2.3i is a 4 way design and the V2.4i is a 5 way design, so those might be a little more complicated.
I wonder if you could use the crossover from an RC-LCR and use it for the modified V2.0Ci since its a 3 way design. That might be interesting to try out, and probably on the easier side in comparison. The RC-LCR crosses over at 600 hz and 2.5 khz, and the 2.2i crosses over at 550 hz and 2.0 khz, so they are in the same ball park.
I really dont know much at all about modifying crossovers, but I'm finding your project quite interesting. So please keep us updated.
Iron Maiden likes this.
post #53827 of 53831 Old Today, 11:01 AM
kgallerie's Avatar
Quoted: 23 Post(s)
Liked: 70
Iron Maiden, I just found this if you are interested:
http://reconingspeakers.com/product/...e-2-2-2-3-2-4/
post #53828 of 53831 Old Today, 11:09 AM
Liked: 0
Hi
i have energy cf30, cc5 and cb5 setup...i am glad using energy speakers...
i wanna change center for cc10, isthe difference will be huge..
and also i first equip them with pioneer vxs520, then jump to marantz nr1602 and now pair them with yamaha rx-v767...yamaha sound is huge with them..what brands match with energy speakers best?
Yigit Yusuf Mutlu is offline
post #53829 of 53831 Old Today, 11:43 AM
Quoted: 169 Post(s)
Liked: 43
Wow. It is saying brand new. Will contact them to see if they actually have them. A bit pricey but used are not much cheaper.
My thought on the center with a CSM module would be to fiberglass a pod for the module so that it positions the dome mid centered between or slightly above center of the woofers. The tweeter would sit above the top of the enclosure. Think B&W tweeter pods. I would fiberglass a pod like that to house it. The crossover is the issue. Still think a 2.3i crossover would work for it. Would be a fun little project.
post #53830 of 53831 Old Today, 05:23 PM
JoeNc's Avatar
Quoted: 14 Post(s)
So it almost sounds as if the run of RC's is done. Damn, maybe I will pick up another pair!!! snip...
When I bought my RC setup years ago, a lot of members were saying 'this
is the end of the energy speakers , get them now ! '...
and yet the rc 70's rcr and rc 10 speakers are still selling like crazy...
JoeNc is offline
post #53831 of 53831 Old Today, 06:18 PM
Quoted: 33 Post(s)
Liked: 3
Clearly, "members" have no clue what they were talking about. Just one repeats after another.
tinhvo is online now
Reply Speakers
Energy , Energy Loudspeakers , Energy S8 3 Subwoofer , Energy S12 3 Subwoofer , Energy Take Lcr Speaker Single Black , Energy Take Sat Speaker Single Black , Onkyo Tx Ds 656 , Receivers Amplifiers , Osd Audio S 10 High Powered 10 Inch Home Theatre Subwoofer Black , Energy Speakers , Energy Speaker Systems , Energy C 100 Bookshelf Speakers , Energy Rc R Surround Speaker Black , Energy Bookshelf Speakers C 50
