Energy Owners Thread - Page 1836 - AVS Forum | Home Theater Discussions And Reviews
 382Likes
post #55051 of 55069 Old 11-15-2016, 09:14 PM
afrogt's Avatar
Quoted: 945 Post(s)
Liked: 710
afrogt is online now
post #55052 of 55069 Old 11-16-2016, 08:33 AM
GEOgamer's Avatar
Thanks. is Carbon-fiber speaker like Energy Sub got better than paper based ones?
GEOgamer is offline
post #55053 of 55069 Old 11-18-2016, 06:25 PM
Quoted: 69 Post(s)
Liked: 25
Originally Posted by afrogt View Post
These mics are typically used only one time, so you might find it cheaper on eBay or could even borrow one from some local person that has a Yamaha AVR - I'm guessing they all use the same mic.
Also, what speakers do you have? That would dictate what your crossover setting should be. 100 is good for many bookshelves, but too high for floor standers and too low for satellites.
Magellan55 is offline
post #55054 of 55069 Old 11-18-2016, 06:32 PM
Quoted: 69 Post(s)
Liked: 25
I'm not sure it makes all that much difference. More important to hear how it sounds, how flat the response is, how loud and low it goes. I've got the ESW-8 from the Take Classic 5.1 package and it's pretty damn good for how cheap and small it is. I've since upgraded to an SVS SB2000 and the ESW-8 can hang with it pretty far. So the ESW-10 should be a mighty fine sub. Enjoy!
post #55055 of 55069 Old 11-19-2016, 03:49 PM
djkal's Avatar
Anyone can tell me if the excel model is older than the encore model or which one is better thank you
djkal is offline
post #55056 of 55069 Old 11-19-2016, 07:41 PM
afrogt's Avatar
Quoted: 945 Post(s)
Liked: 710
If you're talking about the Excel and Encore bookshelf speakers they're from around the same period. Early 90's I think.
Excel has 6.5" woofer while the Encore has the 5.25" woofer. I have the Excel speakers and they sound great. The only drawback is that the grill does not come off. A little brighter than the RC-10's I have and very basic build quality. I got my pair off Craigslist for $50 so they're just fine for my use.
There is also the Encore satellite/sub system but those are completely different. They came out in the early 2000's a few years after the Takes.
Afro GT
post #55057 of 55069 Old 11-19-2016, 08:29 PM
djkal's Avatar
thanks for the reply afrogt
djkal is offline
post #55058 of 55069 Old 11-19-2016, 09:15 PM
afrogt's Avatar
Quoted: 945 Post(s)
Liked: 710
I had it backwards. The Encore was the one with the larger 6.5" woofer.
Specification:
Type: Vented-2 way design
non-diffracting enclosure
Tweeters: 1 - 1/2" titanium dome
Woofers: 1 - 6-1/2 injection molded with foam surround
Frequency Response(+/- 3dB): 48 Hz - 20k Hz
Usable Bass: 42Hz
Crossover Points: 2.5 kHz
Sensitivity: 87.5 dB
Impedance: 8 ohms nominal/ 4 ohms minimum
Rec. Amp. Power: 25 watts - 100 watts
Maximum Power Handling: 100 watts
Dimensions(HxWxD): 12-1/2" x 7-3/4" x 9-1/2"
Finish: Black Ash
Energy Excel has the 5.25" woofer
- rear firing bass reflex port
- 1/2" Titanium dome tweeter
- 5 1/4" poly woofer
- sensitivity 86 dB
- nominal impedance of 8 ohm
- power handling 25 to 80 Watt
- frequency response 60 HZ - 20 KHz (+/-3dB)
- crossover point 3.5 KHz
I have the Encore bookshelf pair
Afro GT
post #55059 of 55069 Old 11-20-2016, 03:02 PM
fwsiv's Avatar
Time for another HT. The room is 12' x 16'. Thinking of some CB-20 for the fronts with the RC-LCR. What should I use for the rears? Right now I'm able to find these new.
fwsiv is offline
post #55060 of 55069 Old 11-21-2016, 07:07 AM
kgallerie's Avatar
Quoted: 59 Post(s)
Liked: 85
Its typically not recommended to mix and match the front 3 because of timbre matching. The CB-20's will be a bit brighter that the RC-LCR. If your receiver has a good room correction software, it may be able to match them pretty well. But personally, I would look into the RC-10's with the RC-LCR, or a CC-10 with the CB-20's.
As for surrounds, are you looking for bookshelf or bipolar speakers? I personally use a pair if Fluance XLBP bipolar speakers with my RC-10/rc-mini-c system and they work pretty well.
http://www.fluance.com/bipolar-speak...pair-black-ash
Its not as important to match the surrounds to the front 3 due to the separation of the speakers and the limited content sent to the surround channels.
kgallerie is offline
post #55061 of 55069 Old 11-21-2016, 07:23 AM
fwsiv's Avatar
Thanks for the suggestion- I wanted to go with the CC-10, but I'm having a hard time finding one.
My other setup- link below, is using the CR-10's in the rear. Can't find any of these either right now. I'll look into the fluance- what about klipsch R-14S?
fwsiv is offline
post #55062 of 55069 Old 11-23-2016, 11:28 AM
djkal's Avatar
Afrogt should i buy old speaker encore energy at 40$ or newer one like cb-20 for 100$ ??? thanks
djkal is offline
post #55063 of 55069 Old 11-23-2016, 11:44 AM
batpig's Avatar
Quoted: 3509 Post(s)
Liked: 3343
I would get the newer speaker at those prices. Build quality / cabinet aesthetics are better, and less chance of something having gone bad over the years. The CB speakers sound pretty good too.
EDIT: also it's going to be much easier finding matching speakers on the used market to expand to a full surround setup with newer models
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #55064 of 55069 Old 11-23-2016, 11:52 AM
djkal's Avatar
thank you,,, it makes sense because the encore speaker we cannot remove the black grill cannot see if the cone is damage over the years.
djkal is offline
post #55065 of 55069 Old 11-23-2016, 11:56 AM
batpig's Avatar
Liked: 3343
those older Encore/Excel models are over 20 years old at this point, good move to get the newer model
Setup Guide and FAQ
batpig is offline
post #55066 of 55069 Old 12-02-2016, 06:30 PM
brendelac's Avatar
Quoted: 143 Post(s)
Liked: 81
brendelac is offline
post #55067 of 55069 Old 12-02-2016, 07:41 PM
afrogt's Avatar
Quoted: 945 Post(s)
Liked: 710
Yep, they are old but my Encore pair sounds great. But the grilles cannot be removed so I would have said go for the CB-20.
Afro GT
post #55068 of 55069 Old Yesterday, 08:02 PM
GEOgamer's Avatar
It's worth to add some extra speakers on Energy ESW-V10 Sub and what kind of ?
Will extra SUB speaker push volume up?
GEOgamer is offline
post #55069 of 55069 Old Yesterday, 11:52 PM
afrogt's Avatar
Quoted: 945 Post(s)
Liked: 710
Your question isn't really clear. Are you trying to buy a second subwoofer or other speakers.
What is your current setup?
Afro GT
Reply Speakers
Energy , Energy Loudspeakers , Energy S8 3 Subwoofer , Energy S12 3 Subwoofer , Energy Take Lcr Speaker Single Black , Energy Take Sat Speaker Single Black , Onkyo Tx Ds 656 , Receivers Amplifiers , Osd Audio S 10 High Powered 10 Inch Home Theatre Subwoofer Black , Energy Speakers , Energy Speaker Systems , Energy C 100 Bookshelf Speakers , Energy Rc R Surround Speaker Black , Energy Bookshelf Speakers C 50
