Energy Owners Thread - Page 1839 - AVS Forum | Home Theater Discussions And Reviews
 390Likes
post #55141 of 55155 Unread 03-01-2017, 05:00 PM
Sousa86's Avatar
I recently purchased a set of near new Energy C-R3's. turns out, one of the side mid ranges does not operate as it should. The sound seems small if none at all. Anyone know where i could get a replacement woofer? I sent a request to klipsch about any possible spares but have not heard back. Wanted to know if any of you guys have an idea what or where i could find a spare or replacement.
James Bond: I think I'll call it a Vesper.
Vesper Lynd: Because of the bitter aftertaste?
James Bond: No, because once you've tasted it, that's all you want to drink.
- CASINO ROYALE
Sousa86 is offline
post #55142 of 55155 Unread 03-01-2017, 06:13 PM
deano86's Avatar
Quoted: 237 Post(s)
Liked: 121
I assume you have tried turning the mid range driver volume knob up all the way or just moved it around in general just to see if that helps... with a possible poor connection... If it still is noticeably quieter or dead as compared to the opposite side mid range, then open the speaker up and check for a loose or broken connection. The chances of Audiovox/Klipsch/Energy having a spare mid range for that old model is slim to none... your most likely only recourse is to find another cosmetically damaged single or pair to use for parts...or just try to position it so that the dead midrange points more towards the back of your room.... or just turn the volume knob all the way down and use it in monopole mode.
deano86 is online now
post #55143 of 55155 Unread 03-03-2017, 08:26 AM
FTO13's Avatar
Hey everyone,
Doing some research for mounts. Are there any RC-R owners that have them mounted? I haven't been able to find the mounts that came with the speakers and now that we're in our permanent home, I'm wanting to wall-mount those bad-boys. I've been using them on stands at our last 2 places. Any suggestions or ideas would be greatly appreciated. I'm contracting out the wiring and install, but would like to have the mounts already in-hand and not have to rely on the AV company's equipment supplier. Many thanks!
KC
FTO13 - "Forever the Optimist
"Energy RC-70's, RC-LCR, RC-R's
Emotiva XPA-5, Yamaha RX-V863
FTO13 is offline
post #55144 of 55155 Unread 03-03-2017, 10:49 AM
batpig's Avatar
Quoted: 3604 Post(s)
Liked: 3453
Originally Posted by FTO13 View Post
Hey everyone,
KC
The factory mount is really simple, it's literally just a bolt that screws into the hole in the back and then you use the head of the bolt to hang it on a plastic keyhole piece that is attached to the wall. If you can go to the hardware store and find the right sized bolt to screw into the back, you may be able to fabricate something simple to affix to the wall that you can hang the speaker onto.
Comp1demon likes this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #55145 of 55155 Unread 03-03-2017, 03:43 PM
loknload's Avatar
Quoted: 102 Post(s)
Liked: 35
If anybody is looking for rear or surround speakers or is otherwise interested, I just posted a pair of RC-R's and a pair of RVSS's in the classified section. My RC-70's and RC-LCR are also posted in a different ad. I will not sell the RC-LCR by itself until the 70's have sold and the new owner of the 70's has had the first right of refusal.
loknload is online now
post #55146 of 55155 Unread 03-05-2017, 06:18 AM
FTO13's Avatar
Thanks Batpig,
I didn't remember them looking like that. Should be fairly straightforward to recreate.
Cheers,
KC
FTO13 is offline
post #55147 of 55155 Unread 03-08-2017, 09:45 AM
eightninesuited's Avatar
Quoted: 84 Post(s)
Liked: 55
Hey guys. Right now i'm running RC30s RC LCR and 2 RC-Rs. I want to go ahead with 7.1. Do i use the RCR for rears or for surrounds. And would you recommend RC minis for rears? I used to have a full 9.2 setup that i never got around to using and ended up selling the rest of my energy speakers because i lived in s condo for years. Now i'm getting back into things and wished i hadnt sold them.
eightninesuited is offline
post #55148 of 55155 Unread 03-08-2017, 01:01 PM
batpig's Avatar
Liked: 3453
Typically you'd want to use the wide-dispersion bipole/dipole type speaker in the side surround position, so it spreads the sound along the side wall to mimick the array of side surround speakers in a commercial theater. RC-Mini's would be OK for rears but another pair of RC-R would probably be even better if you're wall-mounting.
Setup Guide and FAQ
post #55149 of 55155 Unread 03-08-2017, 06:47 PM
Quoted: 84 Post(s)
Liked: 55
Thank you. I'll try to look for a pair of RCR.
Proud Member of "Bass-a-holic Anonymous" - Bottle of Choice: SVS PC-13 Ultra. Drink of Choice: Flight of the Phoenix Crash
post #55150 of 55155 Unread 03-09-2017, 10:05 AM
batpig's Avatar
Liked: 3453
they are very hard to find! unfortunately you just missed out on a pair that was on sale a few posts up from "loknload".
RC-mini's will work too especially if you have enough space to mount them at least a few feet back
Setup Guide and FAQ
post #55151 of 55155 Unread 03-09-2017, 11:32 AM
Quoted: 84 Post(s)
Liked: 55
Would you believe me if I told you I had a pair of RC10s and RC-Rs sitting never opened in boxes for a year before I sold them. That was back in 2010 when I dismantled my HT.
In Canada, they were available through Future Shop, which was closed by the parent company, Best Buy. Energy Speakers pretty much died with future Shop.
post #55152 of 55155 Unread 03-16-2017, 08:56 AM
brendelac's Avatar
Quoted: 148 Post(s)
Liked: 83
http://www.kijiji.ca/v-electronics/c...1-8/1246220872
Anyone in western Canada with deeper pockets than myself interested in a nice V1.8/Adcom setup?
brendelac is offline
post #55153 of 55155 Unread Yesterday, 08:47 PM
Comp1demon's Avatar
Quoted: 38 Post(s)
SO My Current Setup is....
A3060 Receiver.
My Speakers are CF 70 for Front L and R
MY Center is LC LCR
6 Polk Audio RM8 Satellites for LS RS, LR, RR, FRONT PRESENCE L/R
The Polks do not pair well with my Front stage. I want to update them.
Should I Update the CF70's? WOuld the RC 70's be a good upgrade - I can get a pair for $700?
IF I leave my front stage alone, what would be good speakers to pair with them (that I can actually get my hands on) for L/R Sur L/R Rear.
Also Want to go 7.2.4 Currently at 7.2.2 so I have the AMP for the X.X.4 but I am thinking in ceiling speakers for Rear Presence.
Should I also go In ceiling from front pres? or just upgrade the RM8's I have mounted on my wall to better Speakers?
Lastly thinking about emotiva Amp 5 channel for Front stage (L/R/C) and using the Yamaha 360 to power LS,RS,LR,RR,Front and Rear Presence.
I also have a 2 Channel Niles Amp That I could use for something. But Rather Not MIX amps.
Either Use the NILES for Power my L/R CF70's and then use 3060 for the rest X.2.4 or Buy the Emotiva 5 channel and sell the Niles and use it for Front Stage CF 70 and RC-LCR power the rest with 3060.
Suggestions appreciated.
Comp1demon is online now
post #55154 of 55155 Unread Today, 06:19 AM
deano86's Avatar
Quoted: 237 Post(s)
Liked: 121
A3060 Receiver.
MY Center is LC LCR
Why spend $700 on front tower speakers you already have? Get rid of those Polks... at least on the base layer and go with the still easily available (Ebay anyway) Energy CB-5 small speakers which are from the same series as your CF-70s and are wall mountable, if needed.. Any of those speakers do not require an Emotiva amp for power... I assume your receiver can power 9 channels? If so, then just use your existing Niles amp for 2 channels somewhere.. Use that extra money that is burning a hole in your pocket for an upgrade at sub instead.
hernanu likes this.
post #55155 of 55155 Unread Today, 01:13 PM
Comp1demon's Avatar
Quoted: 38 Post(s)
I already have TWO EW-100 Subs. I think they do the job. Especially with the Front stage I am currently using. I do not think Upgrading the sub is necessary at this time.
I agree the POLK need to go but the CB-5 look much like the polk. I want to go with something more like RC-R but They are hard to find.
Any suggestions on a speaker in that style that will pair well (klipsch perhaps)? I want something that when I wall mount is very movie theater like. I do not want make it look like bookshelf speakers mounted to a wall. The R-CR and Klipsch Series Reference surround mount flush to the wall.
As for the AMPs, I read that the 3060 while it can power 9 channels, it struggles to sound good at high volume levels when using a large number of speakers. Hence people are recommending using an Amp for for the front stage or more. Personally If I can get an emotiva upa 500 for under $350 I will do it. Just to power my front stage. So the Surround and Presence speakers are getting full juice from the 3060.
As for X.X.4 Height / front-rear presence are new to me. I just got the 3060 a few weeks ago and the Front Presence I had hooked up but never used (which is what the Niles amp was for, to power the front presence with my onkyo 809 which was only a 7 channel amp, I mis-read and through I could do 9 channels with the pre-outs but I was wrong). Anyways not even sure I am getting anything out of them. YAPO says they are there and working and I hear them during the test, but I am not sure what content would be good to really hear the difference. Personally I think they are just getting drowned out by the front stage as like I said they do not pair well with the CF70 and LC LCR even know someone suggested them 5 years ago to be with the CF-70's and CC-10 (which I upgrade to the LC-LCR on a fantastic deal).
Personally I like the sound of them, in the 5 years I have had them, the opportunities I get to turn them up really loud and watch tv and movies, I am impressed, only problem is the surround and the spacing of the surrounds. they need to be RE-DONE they are too FOward to where I sit, but even when I take a beanbag chair and pop it in the sweet spot my surrounds do not impress me. I am bringing in a speaker wire guy to re-reun all my surrounds and install Rear presence for me. Need to figure out what speakers I am going to get for that as they MUST be ceiling mounted.
I should post pics and start a post in the speaker setup forum for people to help me there. But that is another story.
Reply Speakers
Energy , Energy Loudspeakers , Energy S8 3 Subwoofer , Energy S12 3 Subwoofer , Energy Take Lcr Speaker Single Black , Energy Take Sat Speaker Single Black , Onkyo Tx Ds 656 , Receivers Amplifiers , Osd Audio S 10 High Powered 10 Inch Home Theatre Subwoofer Black , Energy Speakers , Energy Speaker Systems , Energy C 100 Bookshelf Speakers , Energy Rc R Surround Speaker Black , Energy Bookshelf Speakers C 50
