Energy Owners Thread - Page 1843 - AVS Forum | Home Theater Discussions And Reviews
 411Likes
post #55261 of 55279 Old 07-02-2017, 04:35 PM
rscecil007's Avatar
Liked: 24
I'd like a bit of advice for the experts. My wife and I recently bought a new house and will be moving in a month or so. Fortunately I will now have a dedicated room to put our HT, where previously I had to have it in the great room and had to deal with some limitations. There I could only do 5.1. Now in this new house, I can really do a lot more.
I've attached a pic with the dimensions of the room, it's really quite large.
Here's the components we currently have in use:
Haven 72" console/tv stand
Samsung 65" JS8500 4K tv
Denon 4311 receiver
Energy RC-70 as mains
Energy RC-RCL center
Veritas VS dipole/bipole surrounds
SVS SB13-Plus Sub
I also have these in storage but not being used:
Energy C-6 (pair)
Energy AC-300 center
Any suggestions on how to best set up the room for speaker placement, to get the most out of the system and room? I was thinking the TV go against the 14' wall, the Veritas VS on the walls adjacent to the couch, and the pair of C-6's in the rear against the 11' wall? And later I'd try to pick up another pair of RC-10s (or RC-30/70's if RC-10's weren't available), to use as front wides? I know with the wides it's important to have as close a timbre match as possible.
Would the RC-10, if I could find them, be better as height speakers instead of wides?
Also, FWIW, this is an existing house built in 1993, so not a purpose built dedicated HT room. This was a family room/play room, so normal ceiling height,etc.
I've not looked into Atmos, so no idea what's needed there. I can't see the 4311 being replaced anytime soon, but you know how that goes.
Thanks for any and all advice!
rscecil007 is offline
post #55262 of 55279 Old 07-04-2017, 03:48 PM
Rgdeuce's Avatar
Quoted: 130 Post(s)
Liked: 120
Not an expert, but I finally ceiling mounted my pair of CB-5 speakers and turned my 5.2 setup into a 5.2.2 in my dedicated theater room, roughly half the size of yours. Been demo'ing movies all day and my wife and I are completely floored at how significant of a jump it was. RC-LCR as the center, RC-10s L/R, RVSS surrounds, two CB-5s on the ceiling, and two SVS-PB12NSD. Have to think the Denon x4300 and x6300s will be available at clearance prices pretty soon, I believe the former would allow for four ceiling-mounted satellites, and the latter four on the ceiling and put use to your C-6s as rears. I'm sure someone will try to talk you into a second SB13-plus as well
rscecil007 likes this.
Rgdeuce is offline
post #55263 of 55279 Old 07-09-2017, 07:34 PM
xb243's Avatar
Quoted: 12 Post(s)
Liked: 1
Need your inputs. I can't seem to get my entry level (Yamaha RX-v375 + Energy Take Classic 5.1) setup to sound wide. My old htib samsung HT-z220 sounds better, much wider and more immersive. I've tried different crossover settings but none have made the sound wider. Not sure if upgrading my entry level yamaha would fix this or if my energy speakers are causing this.
And also, are yamaha receivers a good combination with the Take Classic 5.1 as i've noticed movies sound bright.
xb243 is offline
post #55264 of 55279 Old 07-10-2017, 06:07 PM
brendelac's Avatar
Quoted: 157 Post(s)
Liked: 87
I'm not sure what you mean exactly by "wide sound", but you should be able to be much happier with what you have than you were with your samsung HTiB. Can you confirm that all 5 speakers are functioning?
brendelac is offline
post #55265 of 55279 Old 07-12-2017, 05:47 AM
PSUShane's Avatar
I have a fantastic energy veritas setup with 2.4's, 2.0c, and 2.0r. Recently I added two svs subs and decided to purchase 2 used 2.0r's. Both came with frozen woofers and I was refunded my purchase and the seller told me to keep them.
My veritas speakers never experienced this issue. I have two questions.....1) Has anyone ever successfully repaired a frozen woofer....2) Alternate woofers that are available for sale to be used in their place?
A third question....any recommendations for surrounds that may match closely to the energy veritas if the answer to both questions above is no?
PSUShane is offline
post #55266 of 55279 Old 07-13-2017, 03:03 PM
Quoted: 100 Post(s)
Liked: 2
Anyone looking for black ash RC LCR? I have one sitting and collecting dust that need to let go. If interested pls pm me. Thanks
Sent from my SM-G950U1 using Tapatalk
parekoy is online now
post #55267 of 55279 Old 07-15-2017, 12:14 PM
brendelac's Avatar
Quoted: 157 Post(s)
Liked: 87
1) To the best of my knowledge, frozen woofers are not repairable.
2) Occasionally, used woofers do show up here and there, but not often. It would be worth trying Energy directly to see if they have some still available, but likely not and I imagine they would be very pricey if they do.
3) My best guess for the closest match would be the newer generation veritas VS surrounds, RC-R surround or CR-3 surrounds.
post #55268 of 55279 Old 07-16-2017, 09:07 PM
Iron Maiden's Avatar
Quoted: 537 Post(s)
Liked: 206
I had fixed one of mine and it held for a few months, then crapped out again. IMO, they are repairable but you need an alignment tool to do it. The tool is simply a sleeve that slips over the phase plug and centers the plug between the voice coil. With the proper sized sleeve, you could easily re-glue the driver where it fails and be good to go. I'm saving the few bad drivers I have in hopes I find a piece of tubing just the right size for the job.
60" Panasonic Plasma ~ BenQ HT1075 / 92" Screen~Onkyo TX-NR3008(Pre/Pro)
Earthquake Cinenova Grande Amplifier ~ Oppo BDP-103 ~ Xbox One & PS4
Musical Fidelity Tri-Vista Tube DAC ~ Monster Cable Signature Series HTPS7000
Energy Veritas V2.3i (mains)~Veritas V2.4i (Front Wides)~Veritas V2.2i (center)
Energy Veritas V2.1 & CAT Tiburons(Surr)~Subs: 2 FTW-21's~Fp10000q clone/2x4dsp
Iron Maiden is offline
post #55269 of 55279 Old 07-16-2017, 09:50 PM
jasonmichaelh's Avatar
Quoted: 160 Post(s)
Liked: 61
3D Printer?
Sony XBR-75Z9D | Oppo BDP-203 and 103D | UBD-K8500
Mirage OMD-28 (LR) | OMD-C2 (C) | OMD-5 (SS, FH, RH)
Yamaha CX-A5100 | NAD T973 x 2
SVS PB12Plus/2 | Dayton UM18-22 Sealed x2 w/ iNuke 6000DSP
Monster Power HTPS 2000
jasonmichaelh is offline
post #55270 of 55279 Old 07-18-2017, 01:06 AM
Quoted: 537 Post(s)
Liked: 206
Originally Posted by jasonmichaelh View Post
3D Printer?
Sure, but it would take trial and error unless you knew the exact size. I stumbled onto a site once that sold a repair kit for these speakers. Forget what all came with it but the one item I remember was a simple cardboard looking roll/tube. Rather thin walled, maybe 16th of an inch. If you look at a Veritas driver, you can see the tiny gap between the coil and the phase plug. It needs to fit snug on the phase plug and center it in the voice coil. When the epoxy or other glue dries, it can be pulled out and the phase plug will be centered so the coil will not rub and short out. The one I fixed was not dead center and eventually failed. But seeing how they fail, I went and epoxied all the other drivers that were still good to prevent more coming apart. This is for the non "i" series drivers only. Most of my Veritas collection is "i" series but still have a few pairs on V2.1's. One pair has the replacement drivers that have the updated design but still fit the older cabinets.
post #55271 of 55279 Old 07-22-2017, 05:46 AM
xb243's Avatar
Quoted: 12 Post(s)
Liked: 1
By "wide sound" I mean that the voices from energy center are sounding a little boxed in compared to my tinier samsung htib center channel which has a wider sound stage. Not sure if anyone experiences the same on their energy take center or this is due my entry level reciever which probably has the basic ypao. And yes all of them are working
xb243 is offline
post #55272 of 55279 Old 07-22-2017, 06:15 AM
automaton's Avatar
Quoted: 44 Post(s)
Not looking for an LCR, but did post in another thread that I'm looking for either an RC-Mini or a V-Mini to match one I picked up a while back. If anyone has one they'd be willing to part with, let me know.
automaton is offline
post #55273 of 55279 Old 07-22-2017, 07:30 PM
brendelac's Avatar
Quoted: 157 Post(s)
Liked: 87
I wonder if the tweeter on the center speaker is dead. Try using one of the satellite speakers in place of your center and see if that sounds any better.
post #55274 of 55279 Old 07-23-2017, 10:20 AM
mobileES's Avatar
Quoted: 67 Post(s)
Liked: 45
Just found a deal on a pair of Veritas 6.3's, cannot wait to pick them up. There is a few chips in the Rosenut finish. Does anyone know the cost a shop would charge to repair or put a brand new piano gloss finish on them?
mobileES is offline
post #55275 of 55279 Old 07-25-2017, 12:18 PM
Jakethegriff's Avatar
Quoted: 44 Post(s)
Liked: 26
So,
I just picked up a pair of CF50's, and a CC10 from Craigslist for a smoking deal. I got them for a friend, and want to test them out on my Yamaha RX-V477 to make sure they work, and see how they sound.
Are these CF50, and CC10 speakers all classified as "large" speakers, with regards to the sound settings in my receiver?
I currently have CB20's and a CC5 center, and front speakers set to "small" for my listening.
I am 75% sure the CF50's are, but I'm unsure of the CC10. Also, I don't want to change it from small, to large - only to find out I defaulted my settings on my receiver (RX-V477) and/or have to go through the setup again when I put it back.
Any help is appreciated.
Jake
Jakethegriff is offline
post #55276 of 55279 Old 07-25-2017, 02:35 PM
batpig's Avatar
Quoted: 3685 Post(s)
Liked: 3528
You can leave them as "small", in nearly all cases where you have a powered subwoofer in the system you should do that because the "small" setting is just code for "turn on bass management and send the low frequencies to the subwoofer".
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #55277 of 55279 Old 07-25-2017, 02:43 PM
hernanu's Avatar
Quoted: 659 Post(s)
Liked: 1163
Originally Posted by Jakethegriff View Post
So,
Jake
batpig is the man, so I'd take his advice.
Large or small is tragically misnamed in my opinion. It's just whether you want your speakers to handle the full range (large) or whether you use a sub to handle the low frequency sounds (as batpig ably describes).... (small)
I use two subs with my RC-50 towers, have no problems calling the '50s and an RC-LCR small. Great sound.
hernanu is offline
post #55278 of 55279 Old Yesterday, 05:49 AM
Quoted: 44 Post(s)
Liked: 26
thanks guys! I tested them last night, and can't believe how great they sound for what we paid ($100 for all three)
post #55279 of 55279 Old Yesterday, 01:08 PM
kgallerie's Avatar
Quoted: 63 Post(s)
Liked: 85
Wow....that is a silly good deal!
kgallerie is offline
Reply Speakers
Energy , Energy Loudspeakers , Energy S8 3 Subwoofer , Energy S12 3 Subwoofer , Energy Take Lcr Speaker Single Black , Energy Take Sat Speaker Single Black , Onkyo Tx Ds 656 , Receivers Amplifiers , Osd Audio S 10 High Powered 10 Inch Home Theatre Subwoofer Black , Energy Speakers , Energy Speaker Systems , Energy C 100 Bookshelf Speakers , Energy Rc R Surround Speaker Black , Energy Bookshelf Speakers C 50
