Energy Owners Thread - Page 1844 - AVS Forum | Home Theater Discussions And Reviews
 438Likes
post #55291 of 55309 Old 08-22-2017, 10:20 AM
Quoted: 144 Post(s)
Liked: 56
Originally Posted by clarkkent06 View Post
Rubber in subs will deteriorate over time, I generally wouldn't get a sub that old. If your budget is around $150-200 and you have a Fry's nearby I would suggest the Klipsch R-112SW. It goes on sale every now and then for $200. Much superior sub
No sadly I'm in Canada we make great audio but we are getting screwed sidewise when it comes to deals.
MerrlinT likes this.
The_Forth_Man is offline
post #55292 of 55309 Old 08-22-2017, 10:26 AM
clarkkent06's Avatar
Quoted: 66 Post(s)
Liked: 47
Ahh, gotcha. I would still probably avoid a 20 year old sub, though
clarkkent06 is offline
post #55293 of 55309 Old 08-22-2017, 11:54 AM
Quoted: 144 Post(s)
Liked: 56
Yeah thats what I pretty much thought but I figured I'd ask anyways.
post #55294 of 55309 Old 08-22-2017, 05:34 PM
brendelac's Avatar
Quoted: 160 Post(s)
Liked: 90
Quick question for energy sub owners
I could get a e:XL S12 for fairly cheap (around 150) how do they old up over time given that this sub is almost 20years old should I consider it or not
It would be entering a dual sub set up where the other cheap sub as the same power 150w 600w peak but goes only to 35hz. I'm looking to add some depth to my set up.
Any advice is welcomed.
Even if you were to disregard the age, it isn't a very good sub. You should be able to do better for $150. If you would like to stick with the Energy brand, you should be able to find a used S10.3 for around $200. Also, the Mirage omni S10 has the same amp and driver as the S10.3 so it's pretty much the same thing.
brendelac is offline
post #55295 of 55309 Old 08-23-2017, 03:10 PM
Quoted: 144 Post(s)
Liked: 56
Anybody running dayton Audio sub with CF-50 I didnt know them but for such a low price they seem solid.
I'm looking at dual sub-1200 or sub-1500.
I cant find any decent/recent energy Sub around me and anyhow everybody tells me that it doesn't matter.
post #55296 of 55309 Old 08-23-2017, 06:17 PM
brendelac's Avatar
Quoted: 160 Post(s)
Liked: 90
Ya, matching subs to speakers doesn't need to be brand-specific. I don't know anything about Dayton subs other than they generally have a good bang-for-your-buck reputation. Are you using it mostly for music or home theatre?
post #55297 of 55309 Old 08-24-2017, 05:09 AM
Quoted: 144 Post(s)
Liked: 56
Well they are in the theatre part of the basement witch opens up on the rest here my basement layout.
I'll start a new thread not to pollute this thread as its not about the Energy Brand anymore.
Chris
post #55298 of 55309 Old 08-24-2017, 07:20 AM
deano86's Avatar
Quoted: 299 Post(s)
Liked: 152
I don't think you are polluting this thread at all! Things have slowed down a bit here for obvious reasons with the slow painful death of what was once an amazing performance for their price speaker brand. Good to read and help out anyone using their Energy speakers and asking questions about them in their systems ...
deano86 is offline
post #55299 of 55309 Old 08-25-2017, 09:45 AM
Quoted: 144 Post(s)
Liked: 56
Thanks from what I'm gathering availability and price wise It'll probably be dual dayton sb-1200 or a single DIY I dont know if I want to go down that rabbit hole tho!
post #55300 of 55309 Old 08-27-2017, 05:54 PM
brendelac's Avatar
Quoted: 160 Post(s)
Liked: 90
I am using a a second-hand DIY sub and it is indeed pretty amazing.
post #55301 of 55309 Old 08-27-2017, 09:10 PM
alooffool's Avatar
Anyone running Atmos/DTS:X with an Energy or Veritas bed layer? Would love to hear what other people are using.
I'm looking into adding height speakers going from 7.1 to 7.1.4.
My room is a 16' W x 13' D x 8' H (flat ceiling) family room with plaster walls and long drapes, but no acoustic treatments. Things like decor and furniture arrangement take priority over home theater use. My use is 90% gaming/movies and 10% music.
I have Veritas 2.4s fronts, 2.0Ci center, 2.2i surrounds (side walls), and 2.0R rears, with a Velodyne subwoofer.
I have a Denon X4300H so probably looking to add 2 channels of external amplification to drive the 2.4s, unless anyone can think of a good reason to use more channels of external amps for the other speakers.
1. Are there any recommendations for amplifier brands or models I should try or definitely avoid with the Veritas? Would the Audyssey XT32 help minimize amplifier/speaker issues and help the fronts to blend with the rest?
2. Any recommendations for height speakers to try or to avoid?
I can't put heights on the ceiling, but could put them high on the walls and either point them down or bounce them off the ceiling. I was considering using Energy Take Classics for height speakers, but am open to other suggestions for smallish wall-mountables.
I could also get Atmos upfiring modules like the Elac A4s and put them on top of the mains (about 8 feet apart on the front wall) and the side wall surrounds. If the fact that the rear heights would be almost twice as far apart as the front heights is an issue, maybe I could elevate the backs slightly to change the angle of reflection. I also have a ceiling fan in the center of the room, so wondering if that will be a significant issue with upfiring.
Edit:
I've found a set of RC-Micro 5.1 nearby, which might be an improvement over the Take 5.1. I haven't heard either.
I've also read a little about SVS's Prime Elevation satellites, which seem like a good option.
alooffool is offline
post #55302 of 55309 Old 08-28-2017, 10:28 PM
jasonmichaelh's Avatar
Quoted: 170 Post(s)
Liked: 67
Originally Posted by alooffool View Post
Edit:
I would go for the Prime Elevations if you don't mind spending the money. If you get the black gloss they should match the Veritas somewhat in looks. They might actually look a little better.
Micros and Takes will be very limited in bass response and you'll have to cross at a higher frequency. Atmos specification says heights should be capable to 80hz.
Upfiring speakers are a compromised solution. Avoid them if possible.
My 5.3.4 system is comprised of Mirage speakers, former Energy's sister company. Four OMD-5's make up my heights and while slightly shy on bass the omnipolar design works well for an Atmos setup. I'm not sure I would use them in your setup though, since used ones go for about the same price as the Primes, and the rest of your setup is already made up of direct radiating speakers.
Whatever you do just make sure all of the heights are directed towards the listening area.
If you haven't heard an object oriented sound system at home, I think your going to be amazed
Edit: one other thing - when you go to Atmos tune your 2.0R's to be direct radiating instead of bipolar or dipolar. That's a nice feature of the 2.0r, they're not obsoleted by the Atmos/DTX specifications for surrounds.
alooffool and Magellan55 like this.
Sony XBR-75Z9D | Oppo BDP-203 and 103D | UBD-K8500
Mirage OMD-28 (LR) | OMD-C2 (C) | OMD-5 (SS, FH, RH)
Yamaha CX-A5100 | NAD T973 x 2
SVS PB12Plus/2 | Dayton UM18-22 Sealed x2 w/ iNuke 6000DSP
Monster Power HTPS 2000
jasonmichaelh is offline
post #55303 of 55309 Old 08-30-2017, 06:21 PM
brendelac's Avatar
Quoted: 160 Post(s)
Liked: 90
http://www.canuckaudiomart.com/detai...m_medium=email
The one that got away
Veritas 1.8s in rosenut for $500. A 4 hour drive for me, but couldn't get there soon enough because of work.
The person that bought these has re-listed them for $1500
https://vancouver.craigslist.ca/rds/...283096191.html
post #55304 of 55309 Old 08-30-2017, 10:38 PM
Quoted: 170 Post(s)
Liked: 67
1.5k seems kinda high. I would go 1k for those. Someone recently listed 2.8's on CL Phoenix for 2.2k and the ad disappeared within a few days. Not sure if they sold or the seller had a change of heart.
post #55305 of 55309 Old 08-31-2017, 08:31 AM
brendelac's Avatar
Quoted: 160 Post(s)
Liked: 90
$500 was definitely a steal. It's just frustrating that I wasn't able to grab them early enough and then the person that scooped them turns around and flips them for significant profit in under 3 months. If they had owned them for a year or longer, at least then it would seem like they enjoyed them before seeing dollar signs.
post #55306 of 55309 Old 09-03-2017, 06:16 PM
Iron Maiden's Avatar
Quoted: 537 Post(s)
Liked: 207
Bummer.
60" Panasonic Plasma ~ BenQ HT1075 / 92" Screen~Onkyo TX-NR3008(Pre/Pro)
Earthquake Cinenova Grande Amplifier ~ Oppo BDP-103 ~ Xbox One & PS4
Musical Fidelity Tri-Vista Tube DAC ~ Monster Cable Signature Series HTPS7000
Energy Veritas V2.3i (mains)~Veritas V2.4i (Front Wides)~Veritas V2.2i (center)
Energy Veritas V2.1 & CAT Tiburons(Surr)~Subs: 2 FTW-21's~Fp10000q clone/2x4dsp
Iron Maiden is offline
post #55307 of 55309 Old 09-03-2017, 09:15 PM
nc88keyz's Avatar
Quoted: 179 Post(s)
Liked: 100
I have a 5.2.4 setup with 2.3ci for mains, 2.0ci for center, 2.0r for surrounds, 4 rc-6 in the ceiling, and 2 SVS sb13-ultras powred by an Denon avr-7200wa. I think.it sounds rather amazing with Veritas soundstage!
Sent from my SM-G935V using Tapatalk
alooffool likes this.
HT1: UN78JS9500, AVR: AVRX-7200WA, AMP: UPA-7, SPKRS: L/R: Veritas 2.3I C: 2.0CI SUR: V2.0R,, SUB: SVS SB13Ultra x2 ATMOS: 4X RC-6C, NV SHIELD(2D)Haswell NUC i5(3D)
HT2: OLED65G6P, AVR: AVRX3300, SPKRS: L/C/R: Veritas 2.2C, SUR: RC-RCRx2, SUB: 10.3x2, NV SHIELD(2D) Zidoo X9S(3D)
HT3: OLED55C6P, AVR NR6700 L/R/S, NV SHIELD(2D)
18 Hybrid Raid, (It Just Works!!) R/C: Harmony Elite HarmonyOneX2
nc88keyz is offline
post #55308 of 55309 Old 09-07-2017, 11:50 AM
tomnan24's Avatar
Quoted: 108 Post(s)
Liked: 30
I was recently very fortunate to find a cherry RC-LCR from a wonderful forum member( drm27) at a great price to replace my cherry RC mini-cc. It makes quite an improvement in vocals during movies,etc.
My 9.5/10 cherry RC mini-cc is boxed up and in my closet. I plan on keeping it forever. I would part with it only if a fellow Energy RC lover needed a replacement to keep his system intact. If anyone ever fits this situation just pm me. Don't care about the $ and will not post in classifieds.
Samsung UN55KS8000
Denon AVR1610
Cherry Energy RC10 mains, RC-LCR center, RCmini surrounds
PA120 Sub(broken,to be replaced)
tomnan24 is online now
post #55309 of 55309 Old 09-07-2017, 06:14 PM
brendelac's Avatar
Quoted: 160 Post(s)
Liked: 90
http://www.ebay.com/itm/Energy-Speak...25.m3641.l6368
Veritas 2.3i towers in Dallas, TX on ebay. Current bid $199 with 3.5 days remaining.
Reply Speakers
Energy , Energy Loudspeakers , Energy S8 3 Subwoofer , Energy S12 3 Subwoofer , Energy Take Lcr Speaker Single Black , Energy Take Sat Speaker Single Black , Onkyo Tx Ds 656 , Receivers Amplifiers , Osd Audio S 10 High Powered 10 Inch Home Theatre Subwoofer Black , Energy Speakers , Energy Speaker Systems , Energy C 100 Bookshelf Speakers , Energy Rc R Surround Speaker Black , Energy Bookshelf Speakers C 50
