Dali speakers - Page 123 - AVS | Home Theater Discussions And Reviews
 6Likes
post #3661 of 3664 Old Today, 02:05 PM
mogorf's Avatar
Quoted: 402 Post(s)
Liked: 161
Originally Posted by eladrion View Post
hello guys i am gonna buy my first dali zensor setup and cant decide for the fronts.First i would like to say will be 80% for movies and 20% for music...my room is 3,5meterX3.5meter and i cant decide if i will buy the zensor 3 for fronts or zensor 5...any advice? the rest of the setup is : dali zensor 1(rear) ,dali zensor vokal(center),svs sub pb-1000,yamaha rx-v677...thank you for the answers!
Hi eladrion. You seem to be hesitating between a floorstander (Z5) and a bookshelf (Z3) type of array. While looking at the specs of both types the sensitivity is equal at 88 dB, so that's not a deciding factor. Max. SLP is also the same: 108 dB, impedance is also the same: 6 Ohm. IMHO a deciding factor should be placement. Do you have better room for a floorstander or a bookshelf type?
mogorf is online now
post #3662 of 3664 Old Today, 02:23 PM
mogorf's Avatar
Quoted: 402 Post(s)
Liked: 161
Originally Posted by Jonathan_John View Post
What amp is that called, with the microphone that can measure room and out put accordingly?
Most of today's modern AVRs (Audio-Video Receivers) come with a digital room correction software and are bundled with a test microphone. Yahama calls it YPAO, Pioneer: MCACC, Denon/Marantz: Audyssey, etc. Do a bit of homework to study each. You will be pleased to see how modern technology advanced.
Hope this helps
post #3663 of 3664 Unread Today, 04:14 PM
Liked: 0
Have a MARANTZ MCR510? Any idea?
Jonathan_John is online now
post #3664 of 3664 Unread Today, 04:22 PM
mogorf's Avatar
Quoted: 402 Post(s)
Liked: 161
This Marantz is not an AVR. If you'd like to upgrade to a Marantz with room correction software you need to look for a Marantz AV-Receiver: http://us.marantz.com/us/Products/Pa...Id=AVReceivers
Reply Speakers
Dali Bookshelf Speaker , Dali Ikon Vokal 2 Mkii Center Channel Speaker , Dali
