Dali speakers - Page 126 - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #3751 of 3753 Old 08-18-2015, 10:08 PM
Liked: 1
Dali says Opticon 1 requires 25-100w, so both your options should be able to run it it we believe the specs. Though the 1606 is on the lower/mid end with 50w, it should be ok. Might be a good idea to listen to that config if your dealer carries it. Especially since it's slimline might fit better the wife factor.
gtubert is offline
post #3752 of 3753 Old 08-19-2015, 11:54 AM
Chucka's Avatar
Quoted: 58 Post(s)
Done anyone know the MSRP of the new Opticon in the U.S. and when these will be available?
Chucka is online now
post #3753 of 3753 Old 08-20-2015, 06:45 AM
Quoted: 31 Post(s)
Liked: 0
Yes - if they won't audition (smaller shop that handles the Dali) I may buy one and bring it over to test. The crazy part is I like the larger screen visual of the 1606 and my Comcast remote will control it. WAF all over that one :-)
Pricing for Opticon is on the web if you Google it.
wardman1 is offline
Reply Speakers
Dali Bookshelf Speaker , Dali Ikon Vokal 2 Mkii Center Channel Speaker , Dali
