Question about Wall mounting HTM-200's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-13-2006, 07:35 PM - Thread Starter
Hyperlite's Avatar
I'm wall mounting two htm-200's in my new theater, and i am running into a little problem...The speakers are being mounted behind the listening position on the left and right side walls, aimed at the listening position. I'm using those Omni 20 brackets from Ascend, the ball and socket ones, but it seems like it would be impossible to mount both speakers with the tweeters on the sides not closest to the wall, as suggested. Does that compute? I would have to flip one upside down to make it so that both the tweeters were on the inside, but because of where the mounting holes are on the HTM's, (across the bottom of the speaker) one speaker would be lower than the other unless i put the bracket higher on the wall, which i can't do because of how i did the bracing between the studs before sheetrock. is it that important that both of the tweeters be on the inside?
Hyperlite is offline
Closed Thread Speakers
