PSB Speakers Owners thread - Page 189 - AVS Forum | Home Theater Discussions And Reviews
 212Likes
post #5641 of 6762 Old 08-29-2014, 05:47 PM
Tstan7777's Avatar
Quoted: 88 Post(s)
Liked: 27
Originally Posted by aydu View Post
People buy separates for a reason. Separate amps add to the sound your speakers produce. Some will notice it, others not.
There is a reason for pre outs and amps.
If you are fortunate enough not to hear a difference, you'll save a ton of cash and frustration in matching components.
I always run at least a 2 channel amp. I love adcoms. Had a aragon until it broke. I have a crown xls now. I swear by separate amps. There is the anti-watt crowd, but I'm not one of them. You know the story, double the power only nets +3db, 50w is all you ever need. To me, an amp "wakes" the speakers up. Even if there isn't much difference in sound, it's peace of mind knowing the speakers are driven properly and you can turn them up to your hearts desire. I like to have distortion lights as well. See....adcom, crown.
Tstan7777 is offline
post #5642 of 6762 Old 08-29-2014, 09:34 PM
mark42mc's Avatar
thank you for that information on the separate external amps you are right I've been trying to learn about them and I see that not only does it add more volume and quality it also protects the speakers from clipping andsudden burst of sound that could blow them outI would imagine that it also take stress off the receiver tobut like I said I'm on this forum to learn and to see the best possible way to do my home theater at a reasonable price so anything that anyone can tell me would be greatly appreciated thank you I hope we can all continue this still
mark42mc is offline
post #5643 of 6762 Old 08-29-2014, 09:46 PM
Quoted: 31 Post(s)
Liked: 6
Interesting if 50w is all you need and a typical receiver provides 100-125w per channel then why would one need an amp then. Does the amp make a difference in the quality of the sound?
Sk76 is offline
post #5644 of 6762 Old 08-30-2014, 07:51 AM
Tstan7777's Avatar
Quoted: 88 Post(s)
Liked: 27
Kind of being sarcastic about the 50w. If you follow the rules, going with a 200w external amp would gain you roughly +6db. For some that's worth the money for some not. I personally believe there are slight differences in amps based on the ones I've owned. Many argue there are none. I wouldn't buy amp on sq improvement. Buy it based on volume level and ability to drive. The comment about speakers "waking up" has to with the amp's ability to drive them than it does improving sound quality.
Sk76 likes this.
post #5645 of 6762 Old 08-30-2014, 09:27 AM
amchillin's Avatar
Originally Posted by Budley007 View Post
I have a pair of Imagine S' in a 7 channel setup. The Imagine S is a "tri-mode surround" speaker. It can be wired Dipole, Bipole or as 2 separate channels in a direct radiator configuration, which is what I did. I have them mounted close to the ceiling and about 3' from the back wall. I think the Minis can reach a little lower on the FResp, but I wouldn't say they sound any different. I would honestly rate them almost exactly the same in SQ. The only reason I would pick one over the other would be because of odd room dimensions. The Minis would give you more configuration choices and better control. My back wall and side walls are square and symmetrically identical, so the Imagine S' work fine. The only advantage is 2 extra channels at almost twice the price. It would be "a wash" between the 2 speaker choices in my living room. Both great speakers! Enjoy your system
Thanks for your insight.
amchillin is offline
post #5646 of 6762 Old 09-01-2014, 06:28 AM
aydu's Avatar
Quoted: 139 Post(s)
Liked: 115
I value sound quality. I never listen to music at concert level volmes.
Amps provide the best sound possible from my speakers. No debate with me. My wife thinks everything sounds "nice" regardless of equipment and wants any selected volume turnrd down a notch.
Lesson learned is that the listener is the biggest variable in the signal chain.
aydu is offline
post #5647 of 6762 Old 09-01-2014, 03:59 PM
mark42mc's Avatar
Hi
I am a newbie and trying to get some help with my setup. I just setup my T6 and C5 with my Denon X4000. I mostly use the setup for movie wand shortly will install my S5 (already bought). I plan to keep it to 5.1 or max 7.1. Room size is 1500 cu ft. My questions are the following
1. I notice that I have to increase the volume to around 75 for the loudness that I like. Is that normal? I have run Audyssey and stored the settings
2. Somehow I am not getting too excited with the tower's performance. Something make me feel that I am not extracting too much out of them ( I may be wrong). Do I need an external amp? If yes then do I need a one that has more than 150w per channel considering AVR already puts 125w.
are you still there wondering about having problems with the volume having to SET too loud to wake up your speakers
mark42mc is offline
post #5648 of 6762 Old 09-01-2014, 11:58 PM
Alec88's Avatar
Quoted: 27 Post(s)
Originally Posted by Kirnecto View Post
Hi , just bought a pair of PSB Image B5 Cherry to replace my Athena S2 and im kinda disapointed ! I own a pair of PSB image T4 since 5years now and i love them ! But the B5 just seems to have not bass and no highs ... Compared to the Athena S2 ... Powered by a HK3270 for a 2.0 setup . Do they need some kind of break in period or something ? Maybe they are underpowered ?
Thx
The B5 should definately have enough bass. I just chose an entire Image set which includes a pair of B4s and even the B4s have quite a bit of bass. They will take some time to break in to sound their best, around 50 - 100 hours. Maybe a setting on your receiver is causing decreased bass? Like a graphic equalizer. I wanted a new system of Legacy studio speakers but unfortunately it would have forced me to use too large of drivers for the rears considering my space restrictions.
Will post pics of the new speakers soon.
Alec88 is offline
post #5649 of 6762 Old 09-02-2014, 12:23 PM
Alec88's Avatar
Quoted: 27 Post(s)
Originally Posted by mark42mc View Post
this questions a little bit out of my reach I'm looking for a new home theater receiver but I keep hearing about external amplifiers and monoblocks one brand is Emotiva instead of spending a fortune on a receiver can I buy a cheaper one and by a external amplifier to run my home theater speakers does hey wire run from the receiver to the external amplifier not sure how that works if anyone can help with this I appreciate it I just have some questions about all that Thanks
If you go that route also consider Outlaw's great 7125 amplifier. Outlaw also has a combo deal with that and their processor.
Alec88 is offline
post #5650 of 6762 Old 09-02-2014, 04:10 PM
Quoted: 31 Post(s)
Liked: 6
Volumes at 75-80 on my X4000 sounds good and felt home theater like. Below that is just fine. I guess I am beginning to appreciate the sound to some level. I will be buying the woofer in the next week or so hence reducing the load of the towers and making them small in my setup. Hopefully that will change things a lot. Will wait and see how that would sound
Sk76 is offline
post #5651 of 6762 Old 09-02-2014, 06:02 PM
mark42mc's Avatar
1 idea I want you to check on because you have a nice setup so far is you probably have ran the Odyssey set up for the speakers sometimes when that runs it will automatically put the front speakers to small size sounding go into the settings and set the front towers to large speakers I think that might make the difference I have to do it on my Yamaha receiver every time I use auto setup and puts my fronts to small which I don't want so go in but it sounds fuller and a bit louder when they are set to large give that a try let me know.also always having a subwoofer is a great idea it takes up the slack in the soundstage I have one also in my theater.and that was a great thing I did for the system...
Remember set everything to Large.
mark42mc is offline
post #5652 of 6762 Old 09-02-2014, 06:25 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6967 Post(s)
Liked: 3884
Sorry, bad advice. If a sub is present in the configuration, then setting the speakers to Small is the correct answer. The sub is much better at handling the low frequencies than the mains. If there is no sub, then Audyssey will not set the speakers to Small. However, adding a sub would significantly improve the overall audio quality.
AustinJerry is offline
post #5653 of 6762 Old 09-02-2014, 07:52 PM
mark42mc's Avatar
to reply back to you about being bad adviceI don't agree with you one bit the only thing I do agree with you about is when Odyssey is running if there's a sub involved it will set the other speakers too small but when you're looking for a certain sound the suggestion I was giving him was that I set mine too large then I added the presence of a sub and they gave me even more full of sound that is a suggestion I think is worthy
Andas he said at this time he does not have a subwoofer so make sure the speakers are set to large let me know.
mark42mc is offline
post #5654 of 6762 Old 09-02-2014, 11:57 PM
Liked: 0
Hey guys!
So I'm trying to decide on the speakers for my first (budget) audiophile system. After auditioning, I've narrowed it down to the PSB Imagine X2T and the Paradigm Monitor 11s. I figured the PSB owners thread would be a good place to ask this question, as I've heard so little about the X2Ts and it's a bit daunting for an audiophile newbie.
To give some context on my setup: it's going to be a living room setup for a college house of 6 guys. As such, it's going to be playing just about every genre of music, and for that reason I've been leaning towards a neutral sound signature (I tend to like that anyway). Also, as our living room is a little awkwardly laid out, it's important that the speakers still sound similar at angles. (I noticed that the Monitor 11s have a superior frequency response at 30 degrees to the X2Ts; am I correct in assuming that this means the Monitor 11s will perform better at an angled listening position?)
I thought it would be easy to compare the two after auditioning, but I'm having far more trouble than I thought. To my untrained ears, they both sound great. The only note that I could make was that the Monitor 11s seemed to have slightly more fatiguing (and airy) vocals, though I have no clue if this had something to do with the amp setup, room size, or volume. I'm going in again to audition them back-to-back on Thursday, but it's just so tricky comparing speakers when they're at different stores and you can't listen to them them side by side.
So, for that reason, I'd greatly appreciate general opinions about these speakers and speaker brands. How do they compare? How have your experiences been with the brand/specific speakers? I'd also really appreciate any tips on "remembering" the two unique sounds that I hear from the speakers and comparing them. Are there certain things I should be looking for?
I'm really excited to begin my audiophile journey, and I'd be so grateful if you guys could help steer me towards the best decision!
Thanks so much.
Dim
Dimentio is offline
post #5655 of 6762 Old 09-03-2014, 08:17 AM
mark42mc's Avatar
Very nice choices on the speakers I can see your dilemma on this the X2D is a more neutral sounding speakers were the monitors 11 are a little more bright on highs for me but depends on the surroundings is it ceramic tile concrete rugs what type of when you go to audition them bring a favorite CD and a favorite DVD movie Blu ray that way you know the sounds that are familiar to you and if it sounds better to you on certain sceneswhat type of equipment do you have and are you also don't you add a sub or two to the setup.
mark42mc is offline
post #5656 of 6762 Old 09-03-2014, 06:10 PM
amchillin's Avatar
I received my T2's last week am very pleased for the most part. I am picking up a little bit of distortion or buzzing in some of the vocals in music and dialogue. Has anyone experienced this with these speakers? For now I'm chalking this up to needing more break in time.
post #5657 of 6762 Old 09-03-2014, 06:50 PM
Liked: 3884
Modern speakers need no break in time. I specifically called PSB when I purchased my Synchrony One's asking about break-in time, and they assured me none was required.
A buzzing sound is more likely due to electronics, than to something with the speakers. I would try a process of elimination to see if you can identify the source of the noise.
Interesting read: Burn in Q&A
post #5658 of 6762 Old 09-04-2014, 11:04 AM
Liked: 0
Thanks for the input! The walls in the living room are currently pretty bare, and are made of concrete. Would this make the sound brighter or warmer?
EDIT: Also, I have two more questions that I've been wondering about.
The PSB X2T cites its 30 degrees off-axis frequency response as 45 Hz - 10,000 Hz, while the Paradigm Monitor 11s supposedly have a FR off-axis of 42 Hz - 18,000 Hz. Does this mean that the Monitor 11s will sound better at greater listening angles?
Lastly, do you guys think that the PSB X2T has sufficient bass without need of a subwoofer?
Thanks again guys.
Dimentio is offline
post #5659 of 6762 Old 09-05-2014, 04:31 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
bare walls make for brighter sound as well as poor imaging....sound treatments to a room are THE biggest and most cost effective upgrade you can make you want to try to dampen reflections as much as possible
Brian Fineberg is offline
post #5660 of 6762 Old 09-05-2014, 09:18 AM
3db
3db's Avatar
Quoted: 216 Post(s)
Liked: 51
My latest PSB purchase for my secondary system. Very nice sounding speakers
3db is offline
post #5661 of 6762 Old 09-05-2014, 05:49 PM
mark42mc's Avatar
Very nice speakers you got congratulations on your purchase.
mark42mc is offline
post #5662 of 6762 Old 09-06-2014, 08:22 AM
3db
3db's Avatar
Quoted: 216 Post(s)
Liked: 51
Thanks Mark.
My secondary system has now been completed from a speaker purchase POV. It started with a trade of a Blackberry Torch for a pair of original PSB Alphas to be used as my left/right mains. I already had a sub, a PSB Subsonic 5 which was replaced by a Rythmik LV-12R in my main system. This put me on the road to complete the center and surround speakers.
I picked up PSB 100c center channel in July for $75 and a pair of B Tech stands for $20 to support the Alphas. I picked up a pair of Alpha Mites and another pair of stands for $140. I now have two complete systems.
What's cool is the 2nd system is built on left overs and used components found on Kijijji, a site selling used everything .
Alec88 likes this.
3db is offline
post #5663 of 6762 Old 09-07-2014, 05:54 PM
mark42mc's Avatar
Thanks Mark.
wow you did great excellent deal you got on your speakers so you're all set have you hooked up yet and how does it sound
mark42mc is offline
post #5664 of 6762 Old 09-08-2014, 04:34 PM
sdrucker's Avatar
Quoted: 735 Post(s)
Liked: 498
Hey guys,
Are any of you using Outlaw amps for your PSB Imagine or Synchrony setups? I know that many believe that amps tend to be neutral in their impact upon sound quality, as I have as a matter of common sense, but I'm debating between going with a new Class D NAD M27 and a used, almost new Class A/B Outlaw 7700 I have a lead on from the classifieds. Other than convenience features, do any of you have a sense of reliability (meaning: lack of hum issues) from the Outlaw line vs. a Class D amp, by point of comparison in terms of the response of the T2s in particular? The Outlaws are highly regarded by some, but curious what the thoughts are with the line we know and love here in practice.
The Outlaw 7700 I would get is about LT 40% of the cost of the new NAD (the M27 is almost $4K), and I'd use it to power my 7.1 Imagine-based configuration (see my sig for details), so unless there's strong feelings/issues I should know about with the Imagine towers and Outlaw, I'd lean toward the cheaper solution for our room. I'm going to a separate amp in preparation for moving to a pre/pro for Atmos, hence I'm looking at seven-channel amp solutions with plenty of headroom. Both the 7700 and the M27 would easily fit the bill there, giving me about 200 W/Channel @ 8 ohms, with the primary difference being the M27 being Class D and size: 90+ lbs. for the 7700 vs. around 31 for the M27.
I'm also going to CEDIA - I don't see any PSB/NAD representation at the booths AFAIK.
Audio Gear: Trinnov Altitude 16/24, NAD M27 and Wyred4Sound MMC-7 amps
Display: Panasonic VT50, Lumagen Radiance Mini. Misc.: Oppo 103, Samsung K8500 UHD player, JRiver
Speakers: PSB Imagine T2, Center, Imagine T Wides and Side Surrounds, Imagine S rear surrounds,
PSB Imagine XA Dolby AE Speakers (4), HSU ULS-15 Mk 2 subs (4) - 9.4.4
sdrucker is offline
post #5665 of 6762 Old 09-09-2014, 09:45 AM
3db
3db's Avatar
Quoted: 216 Post(s)
Liked: 51
I've had the center channel (100c), the left/right mains (Alphas) and the subsonic 5 already running and it sounds very nice. I haven't had the chance to get the surrounds engaged yet,, in the process of modifieing stands to support them. Unfortunately for me, the room is set up correct from a positional perspective but as a 2nd system, it will do. The sub is behind the entertainment center.
ID:	254602   Click image for larger version
3db is offline
post #5666 of 6762 Old 09-09-2014, 09:48 AM
3db
3db's Avatar
Quoted: 216 Post(s)
Liked: 51
Originally Posted by sdrucker View Post
Hey guys,
I would go with the Outlaw for cost alone. NAD used to have a bad reliability problem but I don't know if this is still the case.
3db is offline
post #5667 of 6762 Old 09-09-2014, 10:01 AM
Liked: 3884
Definitely the 7-channel ATI AT6005, Stuart.
post #5668 of 6762 Old 09-09-2014, 10:40 AM
sdrucker's Avatar
Quoted: 735 Post(s)
Liked: 498
116 lbs, dual line cords, and ideally used with dual 20 amp circuits. 300 watts @ 8 ohms, and 450 watts @ 4; just the thing you'd want to use with those PSB Imagine T2s, if I feel the need to crank up Master and Commander in our condo living room. Also $7995. :eek
At least the baby (who incidentally turned 1 today, so he's been promoted to toddler) won't be able to knock it over .
http://ati-amp.com/AT6000.php
sdrucker is offline
post #5669 of 6762 Old 09-09-2014, 03:26 PM
mark42mc's Avatar
I've also been thinking about buying a external amp for my system been trying to find out more about them and also need a new audio video receiver with the pre outs to use the amplifier I've been watching videos on Emotiva website they seem really nice so is outlaw amps I think there more expensive than Emotiva which one do you like I don't mind about paying more for quality and the one thing I can't find out about is how or why is there a humming problems with amplifiers...:sunglasses:
mark42mc is offline
post #5670 of 6762 Old 09-11-2014, 08:19 PM
Liked: 0
Hey guys, it's the PSB X2T vs. Paradigm Monitor 11 guy again, this time with some actually answerable questions if I could borrow another moment of your time! So I just went and auditioned both of the speakers, and I'm glad that I'm able to actually comprehend a notable difference between the two. Like I expected, the Paradigms had a brighter tone, to the point where some songs just barely began to sound sibilant. The PSBs had a slightly more laid back midrange which prevented a lot of that sibilance, and to my great surprise, had significantly stronger bass.
There were some very significant variations in the auditioning rooms, though, and I'd be super grateful if you guys could help me understand how these differences may have affected the sound.
The most major difference was the size; the Paradigm auditioning room was a quite large (300+ sq foot) room, whereas the PSB room was probably a little over a third of the size. Also, the large Paradigm room had pretty much all bare walls, and was pretty sparse other than more speakers in the corners, while the PSB room was very actively covered in carpets, rugs, and "sound dampener" walls in the corners (like those in lecture halls?).
The amps used were also quite different; the Paradigms were on some model number Pioneer 7.2 150W receiver, and the PSBs were on the NAD 356BEE that I'm going to be using.
There are a couple reasons for my suspicions that the room differences are making my comparison a little less accurate. The most surprising thing about my auditions was that the PSBs had a MUCH more powerful bass response than the Paradigms, which confuses me greatly since the PSB has 1 whole less subwoofer than the Paradigms. The more that I've thought about this, the more I feel like the room and amp played a big part in making the PSBs way bassier than the Paradigms. Am I right that a smaller and more sound-treated room will have a warmer, bassier sound? And a bare room would push towards a brighter sound? And, most importantly, would the PSBs likely sound less almost overbearingly bassy if I were to put them in a 300 sq foot room (like the room they're going in in my house)?
I also have a slight suspicion that the NAD amp is bassier than the Pioneer receiver, but I don't have a clue what the sound signature of Pioneer amps is like. If anyone happens to know, that'd help me out a lot. Googling hasn't yielded me much.
Unfortunately, the small size of the PSB room didn't give me a chance to test out the X2T's off-axis frequency response, which was one of my biggest concerns given its unfavorable data: Paradigm claims an off-axis by 30 degrees FR of +-2 DB 42 Hz - 18 KHz, while the PSBs supposedly have a poor-looking off-axis FR of +- 1 1/2 DB 45 Hz - 10 KHz. From these numbers is it just safe for me to assume that the PSBs will sound worse off-axis than the Paradigms?
I'm at the point where I understand the general tone of each speaker, but I really need to figure out what is and what isn't a valid assessment of the speaker, and I really need to understand how that sound is going to change when it comes into my large, bare walls living room. It'd be awesome if I could tone down the brightness of the Paradigms with the NAD amp, but I don't know if that's how it actually works. I'd love the X2T sound but only if the bass was toned down a bit from how I heard it in that small room.
If you guys could help me with even one of these questions it would make this really stressful decision a lot easier for me.
TL;DR: big room bare walls brighter sound? Small room sound-treated walls very bassy and warm sound? Pioneer receiver sound signature? Off-axis frequency response?
Dimentio is offline
Reply Speakers
Audyssey , image s5 c5 , Nad , Psb , psb image b6 , Psb Image T6 Tower Floorstanding Speaker , Psb Speakers Image B5 Bookshelf , Psb Speakers Image C5 Centre , Psb Speakers Image T5 Tower , Psb Speakers Subseries 200 Subwoofer , psb speakers x1t , psb speakers x2t , Psb Synchrony One , Rythmik Audio , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer
