PSB Speakers Owners thread - Page 190 - AVS Forum
 1Likes
post #5671 of 5685 Old 08-21-2014, 06:18 PM
Kirnecto's Avatar
Hi , just bought a pair of PSB Image B5 Cherry to replace my Athena S2 and im kinda disapointed ! I own a pair of PSB image T4 since 5years now and i love them ! But the B5 just seems to have not bass and no highs ... Compared to the Athena S2 ... Powered by a HK3270 for a 2.0 setup . Do they need some kind of break in period or something ? Maybe they are underpowered ?
Thx
Kirnecto is offline
post #5672 of 5685 Old 08-22-2014, 08:59 AM
amchillin's Avatar
Hey guys, just entered the Psb family with the purchase of a pair of t2's. Looking into some surrounds and want to keep in the imagine line. I'd like some feedback of imagine minis vs. b's vs. surround s. My best deal is with the surround s. Thanks for the input.
amchillin is offline
post #5673 of 5685 Old 08-23-2014, 10:42 PM
Orta's Avatar
Any Imagine X2T owners or dealers in here? I'm looking to find out the width and depth of the actual housing, NOT including the protruding feet. I suspect the official specs and product materials are including feet in their dimensions, which look like they could be adding about an inch to the recorded 9" width.
Orta is offline
post #5674 of 5685 Old 08-24-2014, 08:05 AM
Tstan7777's Avatar
Quoted: 18 Post(s)
Thx
I bought some too and am somewhat disappointed. I only paid $212 for them so I thought I'd take that chance to hear some psb's. I have klipsch in my main setup and I planned on using these at the computer. I'm using a Native Instruments audio interface and an adcom amp to power them(60w). I also moved them on top of the Klipschs and powered them with my crown xls. They seem like a sideways move from the Klipsch. They sound different but not exactly "better". One thing I noticed is they really bring out the voices in music, not really the "music" if that makes sense. The cymbals and snare almost fell into the background and they sound a little flat/lifeless. I think x'd over at 80hz, the bass was smoother than the Klipsch above xover because my sub magically sounded better. The Klispch had noticeably larger soundstage. But I didn't find much detail or imaging improvements. I don't like them much nearfield at the computer. The rear port is causing trouble, I thought there would be enough space but the bass is bloated and I'm sure that can't be right. There's probably at least 6" of space behind them. On the flip side, my wife likes them better than the Klipschs and they look fantastic!! I'll be moving them to one of my kids rooms when we move next summer. I'll be acquiring a few more bookshelves over the next year to figure out which I'd like to replace the Klipschs.
Tstan7777 is offline
post #5675 of 5685 Old 08-24-2014, 07:35 PM
Chris Isble's Avatar
Chose the minis as surrounds with my T2s.
I contacted PSB about this, because the B's would be a very tight fit. They recommended I go with the minis, and I am happy with the result.
Descartes' corollary: I don't think very much, therefore I may not be.
Chris Isble is offline
post #5676 of 5685 Old 08-25-2014, 08:31 AM
mark42mc's Avatar
Are you still having problems with the psb-B5 I bought the B-6's and I love them.
mark42mc is offline
post #5677 of 5685 Old 08-27-2014, 11:54 AM
amchillin's Avatar
Thanks for your response. I have a fairly large room, 30'x15' with vaulted ceilings, didn't know if the minis as surrounds would fill the room.
post #5678 of 5685 Old 08-27-2014, 01:44 PM
My room is smaller, about 20x15 with 7.5 foot ceilings. My T2s are 12' from the listening position, and the minis are only 6' away. I am using my receiver, an Anthem MRX-300 as the pre-amp, and I have a 200 wpc Rotel power amp.
Anthem Room Correction (ARC) is crossing over the T2's and the C at 60Hz, and the minis at 100Hz. No correction was needed to "level match" the minis to the T2's.
Given the closer distance, the higher crossover frequency, and the fact that there is usually not a lot of content in the Surround channel anyway, you may want to give the minis a shot. Perhaps your dealer will let you audition the minis for a few days, and take them back and apply the price to the B's if they don't work for you.
post #5679 of 5685 Old 08-27-2014, 03:27 PM
mark42mc's Avatar
I feel like that was a good choice to go with the minis as the surround speakerswhat type of receiver do you have for your home theater.
mark42mc is offline
post #5680 of 5685 Old 08-27-2014, 08:18 PM
amchillin's Avatar
I'm don't think the dealer have the minis in stock and I might try to pick up the surrounds used. There is a good price online for the surround s but I am not familiar with that type of speaker, always used bookshelves. I have a Denon 4520 and sometimes listen to 5.1 instead of stereo. I was able to demo the t2s at the same time I had the Verus Grand Towers and as you can tell the Psb's were better for me.
post #5681 of 5685 Old 08-27-2014, 08:29 PM
AustinJerry's Avatar
Quoted: 456 Post(s)
Liked: 691
I have PSB's all around in a 11.1 setup (see the My Setup link in my sig). I also have the 4520, and listen to a lot of music in 5.1 PLII Music mode. IMO, you will be much better off with a direct-radiating speaker, rather than the Imagine S. I have both the Imagine B's and the Imagine Mini's in my setup, and can highly recommend either.
AustinJerry is offline
post #5682 of 5685 Old Yesterday, 04:29 AM
mark42mc's Avatar
the Denon 4520 is a nice receiver I was actually looking at it last night because it's on sale at Amazon for $1400 what do you think about Onkyo receivers when it comes to the speaker configuration I couldn't use towers in my listening area because of the
configuration of the living room so I went with PSB B6 bookshelves Front and rear of the living room and PSB C5 Center and I'm extremely happy with that setup.
mark42mc is offline
post #5683 of 5685 Old Yesterday, 06:25 AM
amchillin's Avatar
Thanks, I appreciate the input. I was kind of leaning that way. I'll probably try to find some b's due to the size of my room and height of celings. $1400 is a heck of a price, the Denon is great.
post #5684 of 5685 Old Yesterday, 11:54 AM
Forum Sponsor Cleveland Plasma also sells PSB. You may want to give them a call to compare prices.
post #5685 of 5685 Old Yesterday, 07:01 PM
Budley007's Avatar
I have a pair of Imagine S' in a 7 channel setup. The Imagine S is a "tri-mode surround" speaker. It can be wired Dipole, Bipole or as 2 separate channels in a direct radiator configuration, which is what I did. I have them mounted close to the ceiling and about 3' from the back wall. I think the Minis can reach a little lower on the FResp, but I wouldn't say they sound any different. I would honestly rate them almost exactly the same in SQ. The only reason I would pick one over the other would be because of odd room dimensions. The Minis would give you more configuration choices and better control. My back wall and side walls are square and symmetrically identical, so the Imagine S' work fine. The only advantage is 2 extra channels at almost twice the price. It would be "a wash" between the 2 speaker choices in my living room. Both great speakers! Enjoy your system
Budley007 is offline
Reply Speakers
Psb , Psb Speakers Image T5 Tower , Psb Speakers Image C5 Centre , Psb Speakers Subseries 200 Subwoofer , Psb Speakers Image B5 Bookshelf , Psb Image T6 Tower Floorstanding Speaker , Nad , Psb Synchrony One , Rythmik Audio , Audyssey , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer
User Tag List
