PSB Speakers Owners thread - Page 192 - AVS Forum
 4Likes
post #5731 of 5742 Old Yesterday, 11:37 AM
Alec88's Avatar
Originally Posted by JeppeP View Post
Hi there, i am gonna make my first HT ever, so bare with me as i am very wet behind the ears.
I am thinking about different setups with PSB speakers and would like your thoughts on them!
It will be used for movies only.
My room is 4 meters wide and 8 meters long. In feets it will be 13x26.
Panasonic PT-AT8000e
Fixed frame 136" screen
Setup 1: 7.2
Image T6 fronts
Image C5
Image B6 surrounds
Image B6 surround backs
Dual SVS PB2000
Onkyo TX-NR1010
Setup 2: 9.2
Image T5 fronts
Image C5
Image B5 heights
Image B5 surrounds
Image B5 surround back
Dual SVS PB2000
Onkyo TX-NR3010
Setup 3: 11.2
B5 fronts
C5
B5 heights
B5 wides
B5 surrounds
B5 surround back
Dual SVS PB2000
Onkyo TX-NR3010
Emotiva XPA-5
Any comments or other ideas would be nice.
When i have saved more money I plan to expand to 4 subs.
The first option (7.2) but with the B6s as fronts unless you want the towers to avoid using stands. If you're only going to use the system for movies and you have a sub the towers aren't really needed. The NR1010 is a good choice and it should have enough power for decent rear surround sound at lower volumes, at least in 5.1 mode.
Sony 5700ES
PSB Image T5, PSB Image B5, PSB Image B4, PSB Image C4
Alec88 is offline
post #5732 of 5742 Old Yesterday, 04:10 PM
mark42mc's Avatar
Setup 1: 7.2
Image T6 fronts
Image C5
Image B6 surrounds
Dual SVS PB2000
Onkyo TX-NR1010
Setup 2: 9.2
Image T5 fronts
Image C5
Image B5 heights
Image B5 surrounds
Dual SVS PB2000
Onkyo TX-NR3010
Setup 3: 11.2
B5 fronts
C5
B5 heights
B5 wides
B5 surrounds
B5 surround back
Dual SVS PB2000
Onkyo TX-NR3010
Emotiva XPA-5
I would go with set up 3 and with that receiver I would do Atmos 2 in the ceiling
mark42mc is offline
post #5733 of 5742 Old Yesterday, 07:04 PM
Liked: 0
Thank you for the reply
JeppeP is offline
post #5734 of 5742 Old Today, 06:04 AM
Liked: 0
I have now been to the dealer and listened to the PSB speakers and have now got a new setup in my head. Lol.
This setup will include atmos.
9.2.2
Pioneer SC-LX87
Image B6 fronts
Image C5 center
Image B6 wides
Image B6 surround
Dual SVS PB2000
2 in ceiling speakers for atmos (dont know which yet)
I am more keen on this setup I guess, but not really sure yet.
What do you think?
JeppeP is offline
post #5735 of 5742 Old Today, 06:22 AM
Brian Fineberg's Avatar
Quoted: 86 Post(s)
Liked: 467
is the center going under the screen?
optimally you would want B6's for all 3 front channels if it will fit of course
Panasonic 65VT30 | Panasonic AE8000 HD PJ | Denon x4000 | Emotiva XPA-5 | PSB imagine B's | PSB image c5 | PSB B4's | DUAL PSA XS30 | OPPO 103 | minidsp
My first HT build thread
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Brian Fineberg is online now
post #5736 of 5742 Old Today, 07:52 AM
Liked: 0
The center would go under the screen I got 50 cm from the floor untill the bortkom of the screen.
I Worry about using B6 as fronts, as if they got enough power. I will be sitting 18 feet from the screen.
Or should I go with towers... Cant choose
JeppeP is offline
post #5737 of 5742 Old Today, 08:18 AM
Quoted: 86 Post(s)
Liked: 467
I used B6's as mains...and they have PLENTY of power...Im currently using imagine B's
so rest your worries in that dept. unless your room is extraordinarily large...you will be fine
post #5738 of 5742 Old Today, 08:40 AM
Liked: 0
So you would go with
B6's for front, center, wide, surround and surround backs?
I thought that i had to you use a Real center speaker. Will the dialogue still be as clear with a B6?
JeppeP is offline
post #5739 of 5742 Old Today, 08:44 AM
Quoted: 86 Post(s)
Liked: 467
only reason for a sideways center channel is to fit under a TV or screen...
if you can fit another B6 under the screen that is the preffered choice...it will give you 3 identical speakers across the front...
so yes 7 or 5 (depending on your setup) of the EXACT same speaker is the best..in this case ALL B6's
in fact I am looking for a single imagine B to replace my C5 center
post #5740 of 5742 Old Today, 08:52 AM
Liked: 0
I can fit it in there np, it will be on a stand. But it will not be in the same height as the 2 other fronts
JeppeP is offline
post #5741 of 5742 Old Today, 09:10 AM
Quoted: 86 Post(s)
Liked: 467
still is preffered.....but perfection would be the tweeters all the same height
post #5742 of 5742 Old Today, 01:40 PM
AVS Club Gold
sdrucker's Avatar
Quoted: 112 Post(s)
Liked: 139
And if you're thinking about Atmos, and are considering (for now, non-PSB ) Dolby-Enabled upfiring speakers rather than in-ceiling ones, it's a good idea to aim for ear height for those tweeters. Or so goes the thinking in the Dolby Atmos thread.
Stuart
Denon 4311 with XT32 and Audyssey Pro
Oppo 93 and 103
Panasonic VT50
Sherwood R-972 with its version of the Trinnov Optimizer
MiniDSP 10x10 HD
PSB Imagine T2, Center, and Surrounds (as of 5/2014); HSU ULS-15 subs (2)
The Audyssey FAQ Guide can be found here:
sdrucker is online now
Reply Speakers
Psb , Psb Speakers Image T5 Tower , Psb Speakers Image C5 Centre , Psb Speakers Subseries 200 Subwoofer , Psb Speakers Image B5 Bookshelf , Psb Image T6 Tower Floorstanding Speaker , Nad , Psb Synchrony One , Rythmik Audio , Audyssey , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer
User Tag List
