PSB Speakers Owners thread - Page 197 - AVS Forum
 16Likes
post #5881 of 5904 Old 12-29-2014, 02:12 AM
stereofella's Avatar
Originally Posted by mwalton90 View Post
I would pay to hear a side by side comparison of the T2 vs T3 vs One. With the big price jump up to the T3 it would be interesting to see how much the law of diminishing returns comes into effect. Let us know what you think!
Heck forget the T2, lets put it next to a Revel F208 or Kef R900 and see if it is $2500 superior to them.
Maybe I'm underestimating Paul Barton.
stereofella is offline
post #5882 of 5904 Old 12-29-2014, 10:18 PM
mlundy57's Avatar
PSB Image B6s & B4s Get New Home
As a Christmas present, I passed my 2 year old PSB Image B6s and B4s on to my grandson. Wish I had picked up a C5 or C4 before they sold out, then I could have given him a complete set.
Any ideas what center would work well with the B6s?
Mike
mlundy57 is offline
post #5883 of 5904 Old 12-29-2014, 10:28 PM
GIEGAR's Avatar
Quoted: 71 Post(s)
Liked: 352
Mike
Hi Mike. The C5 was replaced by the Imagine XC. The XC is almost identical to the C5 and will be perfectly fine with the B6's.
GIEGAR is offline
post #5884 of 5904 Old 12-30-2014, 06:56 AM
ghengisk78's Avatar
Can PSB Image 3LR handle my amp?
Hello all,
I was recently given a pair of PSB 3LR's and an image 8C center. I have a Pioneer Elite VSX 91-THX Receiver that I would like to use to power the speakers so I can bi-amp the fronts. The 3LR's are rated at 6 ohm and at that resistance my amp would put out 150 continuous to each channel. I can't find specs for the 3 speakers and not sure if I would overpower them or not.
Any help here would be appreciated!
ghengisk78 is offline
post #5885 of 5904 Old 12-30-2014, 06:12 PM
Originally Posted by ghengisk78 View Post
Hello all,
All 3 are rated at 150 watts so should be fine. Most speakers give fairly generous wattage limits to allow for peaks.
At 92db those are very efficient speakers also, so there is no way you could handle listening to them at full volume without going deaf
post #5886 of 5904 Old 12-30-2014, 07:52 PM
ghengisk78's Avatar
But, if I am bi-amping them, wouldn't that double the wattage to 300 per speaker?
post #5887 of 5904 Old 12-30-2014, 10:40 PM
No, because the drivers will only draw the wattage they need being its a passive crossover. So the low pass will get the full 150 now if you crank it up at max, but the high pass will only ever need 10 (roughly). So at max volume you would be getting a little more than 150 but not much.
post #5888 of 5904 Old 12-31-2014, 01:00 PM
mlundy57's Avatar
Mike
mlundy57 is offline
post #5889 of 5904 Old 01-01-2015, 08:09 AM
leeshanok's Avatar
Quoted: 13 Post(s)
Are the T3's $7500 per pair? If yes, they're up against some tough competition. The Focal Electra 1028BE is a tough one to beat at this price range. I've heard good things about the Revel F208 at $5K per pair. They are on my list to audition.
leeshanok is offline
post #5890 of 5904 Old 01-01-2015, 11:41 AM
beaveav's Avatar
Quoted: 140 Post(s)
Liked: 353
Yes, $7500 per pair. The Synchrony Ones were $5500 per pair before they were closed out in late 2014.
For every new thing I learn, I forget two things I used to know.
beaveav is offline
post #5891 of 5904 Old 01-09-2015, 12:26 PM
Liked: 0
still have C5 for sale?
Originally Posted by Brian Fineberg View Post
BTW only have my Image C5 center for sale still..
150$ (steal of the century )
I would like to buy the C5, if you still have please let me know
tatikonda is offline
post #5892 of 5904 Old 01-09-2015, 12:51 PM
Brian Fineberg's Avatar
Quoted: 848 Post(s)
Liked: 922
sold sorry
Panasonic 65VT30 | Panasonic AE8000 HD PJ | Denon x4100 ATMOS 5.2.4| Emotiva XPA-5 | PSA MT110 x 3 FL/C/FR | PSB B4's | DUAL PSA XS30 | OPPO 103 | minidsp | Buttkicker LFE
the SadieMax HT build thread - my first build
Brian Fineberg is online now
post #5893 of 5904 Old 01-09-2015, 01:14 PM
ilocos boy's Avatar
Tatikonda I have one for sale C5 and pair T6 if you interested for $850
ilocos boy is offline
post #5894 of 5904 Old 01-09-2015, 09:23 PM
hdtvluvr's Avatar
Hard to tell, are those dark cherry or black ash?
hdtvluvr is offline
post #5895 of 5904 Old 01-09-2015, 09:36 PM
ilocos boy's Avatar
They are black ash...
post #5896 of 5904 Old 01-10-2015, 07:20 AM
Veda's Avatar
Quoted: 96 Post(s)
Liked: 52
Don't have the Revel but last year I did borrowed a dealer's T2 and did a side by side comparo with my R900 in my own house. The T2 isn't bad at all but the R900 is much more coherent. For movies the T2 seems more exciting on the upper end.
Veda is offline
post #5897 of 5904 Old 01-10-2015, 04:23 PM
hdtvluvr's Avatar
Im thinking of upgrading some of my speakers. Here is what I currently have:
PSB Alpha A/V (Fronts)
PSB 200 (Center)
PSB Ambient II (Di-pole Surrounds)
PSB Century Subsonic 2i
PSB Alpha A/V Compact Monitor, Rear Ported (One 1 3/4")
One 1/2" Polymer Dome Tweeter
One 6 1/2" Polymer-Coated Fiber Woofer
Nominal Impedance: 6 Ohms
Sensitivity: 90 dB/w/m
Manufacturer's FR Specs: 68 Hz - 21 kHz ± 3 dB
Size: 12 3/4"H x 7 3/4"W x 9 3/4"D
Magnetically Shielded
Weight: 11 Pounds Each
PSB 200
One 1/2" poly-flare dome with Ferrofluid Tweeter
Two 5 1/4" polypropylene with rubber surround Woofer
Nominal Impedance: 8 Ohms
Sensitivity: 90dB
72 - 21,000Hz
Size: 6.5" x 19.25" x 9.4"
The sub has done well and I'll probably keep it. Also, the Di-poles are great so they stay. So I guess I'm considering new fronts and a center. I'm confused about having larger fronts. If I crossover to the sub, won't that defeat the purpose of having larger speakers? I'm using a Yamaha RX-V3900 which won't be upgraded this year (and maybe not next). I know on the Yamaha I can set the fronts to small or large and they are currently set to small. How much of an improvement would I get moving to a larger center and fronts. Say a Image C5 and Image T6's or current equivalent?
Room is 14 X 48 completely open and the screen is on the 14 ft wall at one end of the room. Seating is about 17 ft from screen.
hdtvluvr is offline
post #5898 of 5904 Old 01-12-2015, 11:57 AM
redevil's Avatar
Finally placed an order for my PSB Imagine X Series speakers. I went with the XT2, XC, and XB speakers for my home theater build. Can't wait till they arrive.
Video: Sony KDL65-W850A LED TV, PS3 Blu-ray player
Audio: PSB Imagine X series speakers
Receiver: Sony STR-DN1050
redevil is online now
post #5899 of 5904 Old 01-12-2015, 12:06 PM
skads_187's Avatar
Quoted: 40 Post(s)
currently i own psb image t45, c40 + bookshelves.
Im going to be upgrading to possibly either, paradigm studio 60 or monitor audio silver 8.
I wanted to compare also with the imagine t2, but its over my budget unfortunately.
however, I want to listen to the imagine t since its more in my budget.
but wanted to know, can I mix the imagine t with the imagine c3 center?
and would the imagine t be much inferior compared to the others I mentioned?
skads_187 is online now
post #5900 of 5904 Old 01-12-2015, 05:26 PM
Savageite's Avatar
Let's see what response I get in this section. Lol I currently have some older Klipsch RF-3's and I found a pair of PSB Image 6t for sale on CL. Do you think that would be a decent upgrade? Also what center channel goes with those towers?
Savageite is offline
post #5901 of 5904 Old 01-12-2015, 09:19 PM
skads_187's Avatar
Quoted: 40 Post(s)
For the center I believe you need the 9c.
Is it an upgrade? Not sure never heard either. You should definitely audition it, doesn't seem like a huge upgrade to me, but it's your ears that count.
post #5902 of 5904 Old 01-21-2015, 12:47 PM
Liked: 0
PSB In-Walls and In-Ceiling Speakers
Hi everyone! I am thinking of joining the PSB Owners club so............ Just thought I would ask here if anyone has the PSB W-LCR2's installed and how they like them? I am thinking of doing a 7.2/5.2.4 setup and I would use 5 W-LCR2's and then 4 more from the PSB line for the ceiling.
Getting a demo of almost any in-wall or in-ceiling speaker is difficult, any comments from people that have these installed would be great. There are a large amount of speakers in this price range and would like to know if they sound awesome for HT and for music listening. It is not a dedicated room so there will be lots of music listening as well.
Thanks for anything helpful in advance!
Snorfster
Snorfster is offline
post #5903 of 5904 Old 01-21-2015, 02:31 PM
65 Electra Glide's Avatar
Liked: 24
Originally Posted by Snorfster View Post
Hi everyone! I am thinking of joining the PSB Owners club .....
I just did!
I have long been wanting to try out a pair of Imagine Bs or Ts, but I recently noticed what I thought looks like a screamin' deal on a pair of Synchrony 2Bs from an authorized dealer for about half price, so I had to pull the trigger. I also picked up a set of the noise-cancelling PSB headphones.
Tracking for the shipping shows that they arrived today. I'll check out the headphones tonight, but it may be this weekend till I get to try out the bookshelves. Looking forward to it.
65 Electra Glide is offline
post #5904 of 5904 Unread Today, 09:26 AM
skads_187's Avatar
Quoted: 40 Post(s)
I want to audition the imagine t2, how big of a jump is it from the image t45?
Reply Speakers
Psb , Psb Speakers Image T5 Tower , Psb Speakers Image C5 Centre , Psb Speakers Subseries 200 Subwoofer , Psb Speakers Image B5 Bookshelf , Psb Image T6 Tower Floorstanding Speaker , Nad , Psb Synchrony One , Rythmik Audio , Audyssey , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer
