PSB Speakers Owners thread - Page 204 - AVS | Home Theater Discussions And Reviews
 42Likes
post #6091 of 6113 Old 06-17-2015, 07:42 AM
nakkiran's Avatar
Liked: 1
Originally Posted by GIEGAR View Post
Yep, PSB is the one. But do you mean Image C4 or Imagine C? If you can afford it and it fits in your space, the Imagine C is the pick.
If you must go with a smaller centre, the Imagine mini c would be the better choice.
Sorry, I meant the Image C4.
The only reason I am buying this now is that the distributor is closing down and is offering both at a very low price - equivalent of $160.
Seeing that I can't really afford a decent centre speaker right now, this will do until I have saved enough for a decent one
nakkiran is offline
post #6092 of 6113 Old 06-23-2015, 06:37 PM
danielb6752's Avatar
Originally Posted by Pitbull0669 View Post
Hey does anyone have any luck or Info on the PSB CW260 In Wall Surround Speaker ? I want to use them for my sides and Front wide speakers any Ideas?
Sorry, I don't look at this thread as often as I should. I bought the step-down CW26 speakers from Crutchfield when they were half off for my den, and am pleased with the sound. I use CW180Rs as rear speakers in 5.1, and in two bedrooms, with a CW88R in a bathroom. My only wish is that they had an enclosure.
I do love my PSB speakers and am sure these would serve you well. You might want to consider direct radiating speakers if you ever want to go with an Atmos setup...
danielb6752 is offline
post #6093 of 6113 Old 06-23-2015, 07:32 PM
Pitbull0669's Avatar
Quoted: 37 Post(s)
Actually that's what I'm doing Thanks.
Pitbull0669 is offline
post #6094 of 6113 Old 06-24-2015, 08:53 AM
Quoted: 37 Post(s)
Any one use or have used these? I'm looking for a pain to buy or trade my Def Tech 7006bp for. The PSB Imagine Tower Speaker X2T
post #6095 of 6113 Old 06-26-2015, 08:19 PM
Quoted: 18 Post(s)
Liked: 0
Hello, I am new to speaker world, can you rank the following speakers ?
I listen to soft pop,jazz,female/male vocal. Probably 50% 50% Home Theater and just listening music.
- PSB Imagine T2
- SVS Ultra Tower
- Polk Audio LSi M705
- Definitive Technology Mythos STS SuperTower
I am leaning towards PSB T2 but the subwoofer is only 5 inches, should that be a concern ?
Thanks !
Sennheiser HD800 / Hifiman HE6 / Fostex TH900 / Beyerdynamic T1 and T5p / Audeze LCD 2 / Denon AH-D7000 and many more.
canadian411 is online now
post #6096 of 6113 Old 06-26-2015, 08:26 PM
AustinJerry's Avatar
Quoted: 2726 Post(s)
Liked: 1387
- PSB Imagine T2
- SVS Ultra Tower
Thanks !
Not if you include a subwoofer in the configuration, which you should consider doing regardless of which speakers you choose. The Imagine T2 are highly rated, and I don't see how you could go wrong by choosing them.
I have never been in favor of tower speakers with integrated subwoofers like the Mythos.
AustinJerry is online now
post #6097 of 6113 Old 06-26-2015, 09:16 PM
AVS Club Gold
sdrucker's Avatar
Quoted: 305 Post(s)
Liked: 207
Jerry,
As you will likely remember, I spent five years with the Mythos ST as my mains, and as time went by and I got more sophisticated with measuring (in good part thanks to your REW guide :), I found that the Mythos built-in sub approach was more trouble than it was worth. The biggest problems were properly dealing with calibrating the powered vs. the non-powered parts of the speaker to equal volume, and the whack a mole element of trying to solve lower bass problems with REW and finding that changes I made created ripple effects due to the bass radiators of the speaker relying on harmonics from lower frequencies to boost bass above the woofer's crossover.
Bottom line is that the towers with powered subs are IMO only useful one way: a two-channel stereo system without subs for music-focused rooms. In that context, simply run them full-range, after level matching the two sections of the speaker, and you're as set as you're likely to be.
Having had both the PSB Imagine T2s and the Mythos, I'd take the PSB hands-down as a better value, far easier to set up, and also because Paul Barton's multi-woofer configuration for helping with "floor bounce", to the extent placement can do so.
One side note: the Imagine line comes with ports that can be plugged to help with boomy bass. YMMV but at least in my room, plugging the bottom part (there's three) was useful to help smooth the crossover area (60 Hz at the time) before any room EQ.
Audio Gear: Trinnov Altitude 16/24, NAD M27 amp
Display: Panasonic VT50, Lumagen Radiance Mini
Misc.: Oppo 103, Apple TV, JRiver ID NUC
PSB Imagine T2, Center, and Surrounds; HSU ULS-15 subs (2)
More gear to follow as I get going with the Altitude...
sdrucker is offline
post #6098 of 6113 Old 06-27-2015, 10:30 AM
Quoted: 37 Post(s)
WTB/WTT PSB Imagine Tower Speaker X2T
Any one use or have used these? I'm looking for a pain to buy or trade my Def Tech 7006bp for My Def techs.They are in Great shape. Or something Comparable. .Thanks guys.
post #6099 of 6113 Old 06-27-2015, 11:53 AM
Quoted: 18 Post(s)
Liked: 0
Originally Posted by sdrucker View Post
Jerry,
So can I assume that PSB T2 is equally good as Mythos ST ?
I am going to get two SVS PB13 Ultra subwoofers.
I just want to get a tower speaker that has an organic sounding mids. Let me know if PSB is the right choice for me.
Thanks everyone.
post #6100 of 6113 Old 06-27-2015, 08:32 PM
MaxTemp's Avatar
Liked: 9
Thanks everyone.
If you can stretch your budget a little, you can pick up T3's and get subs with equal or better performance at half the price.
MaxTemp is offline
post #6101 of 6113 Old Yesterday, 07:13 AM
Quoted: 18 Post(s)
Liked: 0
Ah.. I thought T2 was the top of the flagship from PSB until I saw this T3. Thanks for the info.
So basically T2 is with the subwoofer I guess, more I read in this forum my budget is keep increasing, (is it good or bad ? haha).
Thanks again.
post #6102 of 6113 Old Yesterday, 08:18 AM
Liked: 1387
Thanks again.
OK, let's make sure you think about what Max has recommended. The main difference between the T2 and the T3 is the size of the low frequency drivers. Since you are planning on having subs in your configuration anyway, the larger subs in the T3's are not going to make that much of a difference. Otherwise, the mid and high frequency drivers are close to being the same. Both speakers are very well rated.
Now, the question is, can you select lower-priced subs of equal performance? There will be differing opinions on this, but the subs you mentioned are top performers, and mated with the T2's are going to result in an awesome system. Just my opinion, of course, and no disrespect to Max.
post #6103 of 6113 Old Yesterday, 09:52 AM
MaxTemp's Avatar
Liked: 9
I think these 2 subs for example will match the SVS sub.
http://www.powersoundaudio.com/colle...products/v1500
http://reaction-audio.myshopify.com/...ant=1156514633
Both have in home trials and you can get dual Echo 15's for $1800.
MaxTemp is offline
post #6104 of 6113 Old Yesterday, 10:14 AM
Liked: 1387
True enough, but I still question the value of upgrading to the T3's if the OP is going to be using subs. I myself have Synchrony One's with four 15in sealed subs, and question whether I am getting full use out of the One's.
post #6105 of 6113 Old Yesterday, 05:33 PM
Quoted: 18 Post(s)
Liked: 0
Ah I see, so basically I can choose one of these combination?\
1. PSB T2 with Echo 15/SVS PB13/V1500 subs
2. PSB T3 (no extra subs needed)
3. Definitive Mythos ST-L (no extra subs needed)
I kind of narrow down the selection, I can get PSB half the MSRP so it's a plus for me, but Mythos ST-L have really good review.
I can't decide !
post #6106 of 6113 Old Yesterday, 05:53 PM
MaxTemp's Avatar
Liked: 9
True, but I think you can get even cheaper speakers and be satisfied. If the price isnt much more or it can be afforded, I would still get the flagship. Its a mental thing
MaxTemp is offline
post #6107 of 6113 Old Yesterday, 07:31 PM
Liked: 1387
I can't decide !
Sorry, you have it completely wrong.
You will want subs with either the T2 or the T3 speakers. Regardless of the size of the low frequency drivers in the T3's, they will not reach the performance of two dedicated subwoofers.
You received feedback from me, and from Sdrucker (who owned Mythos speakers and replaced them with T2's), that the Mythos is not a good choice. Did you read those posts?
IMO, your option 1 is the best choice of the three you listed (even though the list is flawed).
post #6108 of 6113 Old Yesterday, 08:43 PM
AVS Club Gold
sdrucker's Avatar
Quoted: 305 Post(s)
Liked: 207
You will want subs with either the T2 or the T3 speakers. Regardless of the size of the low frequency drivers in the T3's, they will not reach the performance of two dedicated subwoofers, but as we know, with advanced room measurement experience there's an argument for as many as four pending what you see in your room .
I'd agree that the T2 is certainly the best use of his money, in combination with dedicated subwoofers - ideally two to help with smoothing out low frequency room response for many of us, especially if you research sub placement and have independent measurement software ..
The only comment I'd add about a reason to purchase the T3 with additional subs is that, as per the PSB website ( http://www.psbspeakers.com/products/...agine-T3-Tower ):
"Additionally, the bottom woofer can be disconnected from the amp and shorted using the provided woofer shorting bar, thus creating a 'bass trap' or damper to further suppress room resonances."
In other words, you can optionally use the bottom woofer, reaching the lowest frequencies, as a kind of active "bass trap" generated from the speaker to offset room gain. In that case, it's assumed that the user already has one or more subwoofers.
That would seem a unique feature of the T3s, one that Paul Barton told me at the Saturday Audio Exchange meet and greet in December was instituted to provide added value for people that had no need for a tower in a system with subs, or had a small room but otherwise was a likely buyer for the T3s. However, AFAIK there has been literally nobody on AVS that has used the T3s this way, and there's certainly cheaper ways to address room gain with acoustic treatments and/or room correction. Not to mention that without independent measurement, you'd have no idea whether this method of active bass trap is helpful or harmful.
I'd also look at the X2Ts as well as the T2 if I were him.
sdrucker is offline
post #6109 of 6113 Old Yesterday, 09:07 PM
Liked: 1387
Uh oh. Canadian's head is going to explode now, Stuart. I agree that the clever use of the bottom driver is interesting, but only someone on the fringe is going to actually use it this way.
post #6110 of 6113 Old Yesterday, 11:01 PM
AVS Club Gold
sdrucker's Avatar
Quoted: 305 Post(s)
Liked: 207
Don't look at me...the T2s and the subs are the smart way to go.
sdrucker is offline
post #6111 of 6113 Old Today, 04:05 AM
Quoted: 18 Post(s)
Liked: 0
Hi Jerry, ya I read that post about STL earlier, but I was considering to coming back to STL because I felt like it doesn't need the subwoofers.
Looks like I still need to get two dedicated subs with T3 or T2.
Why picking the speakers is so hard ? haha.
I've been running around the city and can't find places to audition speakers in Toronto here.
thanks again Jerry.
post #6112 of 6113 Old Today, 04:20 AM
Quoted: 18 Post(s)
Liked: 0
I want to make a smart choice and my head is spinning after reading the review of X2T. So many good speakers.
Thing is I can only get T2 50% of the MSRP price tag, which is probably the best choice for me.
So what are the dedicated subs do you recommend ?
I was initially looking at SVS PB13 but there are also Echo 15/V1500 subs as well.
I am not a basshead person, I still like the deep bass but more into mids as I listen to vocal/jazz and bit of classic.
Will be 50% 50% Home Theater and Music use.
post #6113 of 6113 Unread Today, 05:48 AM
Liked: 1387
I prefer sealed subs for music listening (and they are equally good for home theater effects), which makes the SVS a good choice. I am not familiar with the Echo brand, so can't comment on those. Both Stuart and I have Hsu ULS-15 subs, another good choice.
And for overall smoothness of response, at least two subs are better than a single sub.
Reply Speakers
Audyssey , image s5 c5 , Nad , Psb , psb image b6 , Psb Image T6 Tower Floorstanding Speaker , Psb Speakers Image B5 Bookshelf , Psb Speakers Image C5 Centre , Psb Speakers Image T5 Tower , Psb Speakers Subseries 200 Subwoofer , Psb Synchrony One , Rythmik Audio , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer
