PSB Speakers Owners thread - Page 224 - AVS Forum | Home Theater Discussions And Reviews
 199Likes
post #6691 of 6706 Old 11-04-2016, 10:42 AM
3db
3db's Avatar
Quoted: 152 Post(s)
Liked: 39
Originally Posted by riker1384 View Post
I don't know why Sound & Vision would go to the trouble of testing them but not release graphs. Do they put the graphs in the print magazine?
Sound and Vision graphs are not very accurate. Stick to Stereophile or Soundstage as shown below;
http://www.soundstagenetwork.com/ind...nts&Itemid=153
Here's soundstage's actual review;
http://www.soundstagehifi.com/index....3-loudspeakers
Receiver: Yamaha RX-V1800/Yamaha RX-V1500
Display: Vizio SV-470M 47"/Toshiba 32" CRT
BluRay/CD: Sony BDP-S360/Toshiba DVD/VHS; Turntable ProJect Xpression III
Speakers PSB: Mains Image T-45/Alphas; Center Image 8C/100C; Srnd Image 1B/Alpha Mites
Subwoofer: Rythmic LV12-R/PSB Subsonic 5
Media Player WD + 3TB USB drive/Iomega + 1TB internal drive
3db is offline
post #6692 of 6706 Old 11-04-2016, 06:23 PM
riker1384's Avatar
Quoted: 14 Post(s)
I was referring to the missing graphs of the SVS Ultra Towers, not the PSBs.
riker1384 is offline
post #6693 of 6706 Old 11-27-2016, 01:27 PM
notjoe's Avatar
Quoted: 13 Post(s)
So,
I'm taking advantage of this black Friday thing and I saw something that would complement the 3.1 setup I have already.
Do I buy two sets of these : http://www.audiozona.com/psb-imagine-b for the rear and sides?
OR
Do I buy these http://www.audiozona.com/psb-imagine-t2 for my fronts and move my Image X2T to the rear?
Thoughts?
notjoe is online now
post #6694 of 6706 Old 11-27-2016, 01:56 PM
KenM10759's Avatar
Quoted: 963 Post(s)
Liked: 541
Which center speaker are you currently using? If the Imagine XC then just go with the B1's. If you have one of the better Imagine C series, mate that with the T2's.
KEF R500, R200C, R100, SVS SB2000 sub, NAD T758 receiver, Pro-Ject RPM1 TT w/ Sumiko Pearl, Bluesound Vault2, Sony BDP-S480 BlueRay player, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer.
KenM10759 is online now
post #6695 of 6706 Old 11-28-2016, 02:50 AM
notjoe's Avatar
Quoted: 13 Post(s)
The center speaker is the PSB Imagine C
http://www.psbspeakers.com/products/...agine-C-Centre
post #6696 of 6706 Old 11-28-2016, 05:29 AM
KenM10759's Avatar
Quoted: 963 Post(s)
Liked: 541
Well then, there's your answer. If you can afford to get the Imagine T2, you'd definitely be boosting the sound quality of the most important speakers in a 5.1 system...the front three.
post #6697 of 6706 Old 11-28-2016, 05:48 AM
notjoe's Avatar
Quoted: 13 Post(s)
Can I afford not to with over 1000 euros in savings?!
KenM10759 likes this.
post #6698 of 6706 Old Today, 11:50 AM
notjoe's Avatar
Quoted: 13 Post(s)
Anyone know what gauge wiring I should use for these Imagine T2 speakers?
Center: PSB Imagine C
Front L/R: Imagine T2
Read L/R: PSB X2T
Receiver: Pioneer Elite
post #6699 of 6706 Old Today, 11:52 AM - Thread Starter
firebook23's Avatar
14 or 12 gauge will work fine. But the thicker the better IMHO
firebook23 is online now
post #6700 of 6706 Old Today, 11:55 AM
notjoe's Avatar
Quoted: 13 Post(s)
https://www.amazon.es/FosPower-altav...ker+wire+white
What do you think of that?
Read L/R: PSB X2T
post #6701 of 6706 Old Today, 12:00 PM - Thread Starter
firebook23's Avatar
I don't read spanish but it looks ok. is it fire rated for in-wall runs?
I would get the thicker 12 gauge
post #6702 of 6706 Old Today, 12:04 PM
notjoe's Avatar
Quoted: 13 Post(s)
I don't read Spanish either...makes living in Spain that much more difficult. I mainly use google translate for everything.
Not sure if it is rated for in-wall fire but it'll be external not internal.
connectivity
premium FosPower CL2 in wall speaker wire is used to connect power amplifiers and receivers audio to speakers in home environments, school, church or business. Use with banana wall plates, connectors bare wire, banana plugs, spade connectors receivers, A / V, amplifiers and other home and professional audio applications.
CL2 in-wall UL
speaker cable has FosPower CL2 by Underwriters Laboratories (UL) for use in the wall.
Oxygen-free pure copper wire
count high strand wire oxygen - free copper, produces a high quality, clean sound. Consider pure oxygen - free copper to buy the speaker cable. Mixture of aluminum alloys such as copper wire (CCA / copper clad aluminum) can lead to a less conductive wire, poor sound quality, with fragile / weak wires can easily break. Speaker cables Poor quality have pockets of oxygen in copper.
American Wire Gauge (AWG)
AWG refers to wire gauge oxygen - free copper without the insulating cover. GTE is used in North America to measure and regulate the thickness of the copper wire. Do not be confused by the speaker wire low cost with the "Scale" label can be smaller.
Jacket with color coded cables
Each cable oxygen free copper sheathed in a flexible coating, PVC is color coded for polarity to ensure proper installation, easy and fast. The whole cable assembly is coated with a PVC jacket nominal CL2.
Convenience queued for
speaker cable is wound around a spool for storage and easy dispensing
Read L/R: PSB X2T
post #6703 of 6706 Old Today, 12:05 PM
ClawAndTalon's Avatar
Quoted: 280 Post(s)
Liked: 204
Went to a high end retailer the other day and PSB was his best brand. Even with 50k$ models from other makes.
I haven't heard accuracy they have from a non-horn before.
"Most theories on audio and audio reproduction will be proven wrong only when the laws of physics change."
ClawAndTalon is online now
post #6704 of 6706 Old Today, 12:18 PM - Thread Starter
firebook23's Avatar
CL2 in-wall UL
Ya the white shell is a fire ratted material i think. different codes if you want to run in a wall cavity. However it will be fine for regular use as well.
post #6705 of 6706 Old Today, 12:22 PM - Thread Starter
firebook23's Avatar
Yep PSB is an audiophile best kept secret. lol
I have never been a fan of horn speakers (kliptch) they mostly sound way too bright and fatiguing.
post #6706 of 6706 Old Today, 01:49 PM
Quoted: 280 Post(s)
Liked: 204
The PSB had a lot of energy and accuracy, which is what I like. Great design, great presentation.
A horn or waveguide is just another way. I've heard all designs not properly applied, and sound poor, and all correctly applied and sound amazing. Generally, speaker placement is key. Im running Klipsch Reference II and they have nothing fatiguing presented.
Reply Speakers
Audyssey , image s5 c5 , Nad , Psb , psb image b6 , Psb Image T6 Tower Floorstanding Speaker , Psb Speakers Image B5 Bookshelf , Psb Speakers Image C5 Centre , Psb Speakers Image T5 Tower , Psb Speakers Subseries 200 Subwoofer , psb speakers x1t , psb speakers x2t , Psb Synchrony One , Rythmik Audio , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer
