PSB Speakers Owners thread - Page 228 - AVS Forum | Home Theater Discussions And Reviews
 223Likes
post #6811 of 6840 Old 08-22-2017, 05:26 AM
Redoryx's Avatar
Quoted: 36 Post(s)
Liked: 41
As much as I love PSB, you can find better subs.
SVS, PSA, Rythmik, HSU etc.
Redoryx is offline
post #6812 of 6840 Old 08-22-2017, 05:28 AM
Redoryx's Avatar
Quoted: 36 Post(s)
Liked: 41
Has anyone used the in ceiling PSB speakers?
I am installing ATMOS and am looking for speakers that will go with the Imagines. (not the X)
The XA Atmos speakers are a no go.
Redoryx is offline
post #6813 of 6840 Old 08-22-2017, 08:19 PM
GIEGAR's Avatar
Quoted: 837 Post(s)
Liked: 1427
I've got older 6.5" coaxial PSB CW60R's. Perfectly fine for surround duty with my Images, and a lot of my listening is multi-channel music.
The current crop of CS speakers look even better with the same titanium dome tweeter as the Imagine on a small waveguide. They're a no brainer I'd say.
GIEGAR is online now
post #6814 of 6840 Old 08-23-2017, 04:50 PM
Frisco John's Avatar
Quoted: 34 Post(s)
Liked: 1
I"m looking at buying a pair of X2T's and the Imagine XC center. This will be used 90% HT/TV and 10% music. Room size is 18 x 28 (with 22 ft vaulted ceilings) - very wide open room. My concern is with the center channel. Will it be big enough for my room size?
Frisco John is offline
post #6815 of 6840 Old 08-23-2017, 05:22 PM
sdrucker's Avatar
Quoted: 888 Post(s)
Liked: 600
Eek, that room is large!
Actually, if it were me, I'd do a matching X2T as a vertical center channel speaker to provide identical speakers up front, and minimize off-axis response issues and comb filtering. But you'd need a AT screen/projector setup to make that work.
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Misc.: Oppo 103, Oppo 203 UHD player, JRiver
Speakers: PSB Imagine T3 LCR, Imagine T Wides and Side Surround 1, T2 Side Surrounds, Imagine XB rears, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 11.4.6
sdrucker is online now
post #6816 of 6840 Old 08-23-2017, 05:25 PM
Quoted: 34 Post(s)
Liked: 1
There is no way I could do a X2T as the center (the wife would kill me). Thoughts on if the center will be to small?
post #6817 of 6840 Old 08-23-2017, 05:39 PM
sdrucker's Avatar
Quoted: 888 Post(s)
Liked: 600
My reaction was to say "yes", but how far from the front speakers would you sit in that room? And do you have an idea about how loud in db you listen?
That matters because you can estimate if the XCs have adequate amp handling for your needs with something like this, based on distance, db, and the speaker sensitivity (88 db):
http://www.crownaudio.com/en/tools/c...power_required
Figure maybe 10-15 db above your average listening to be consevative for peaks, especially if you don't have a sub.
There's the Imagine C, but it's better suited to the T2 based on the same woofer tech.
post #6818 of 6840 Old 08-23-2017, 05:47 PM
Quoted: 34 Post(s)
Liked: 1
Right now we sit about 15 feet from front speakers. I haven't found anyone close to me that stocks these for me to listen to at this point.
post #6819 of 6840 Old 08-23-2017, 06:07 PM
sdrucker's Avatar
Quoted: 888 Post(s)
Liked: 600
That works out to about 5 meters on the Crown Audio calculator. Assuming 90 db peaks, which is 15 db above Audyssey/medium room reference of 75 db, you should be OK as long as your amps can produce about 80W/channel with multiple channels driven.
OTOH, if you crank the sound to extreme 105 db peaks, you would want to rethink this...
post #6820 of 6840 Old 08-24-2017, 05:42 PM
Quoted: 34 Post(s)
Liked: 1
Where is the best place to buy the X2T and center? Any good deals out there?
post #6821 of 6840 Old 08-24-2017, 05:54 PM
sdrucker's Avatar
Quoted: 888 Post(s)
Liked: 600
Crutchfield, Audio Advisor, and Saturday Audio Exchange are reputable online options. I think you can check the PSB site for local dealers as well.
post #6822 of 6840 Old 08-25-2017, 07:36 AM
Quoted: 34 Post(s)
Liked: 1
I was looking at the dimensions again for the center channel vs. X1T. Could I do X2T towers with a X1T center? Would that match correctly? Are there any issues turning the X1T on it's side? I would have to place my TV on top of the X1T as well. Would that have more output than the XC center? In other words, will it have that much more to make it worth my while.
I still have to validate that the wife will allow this.
post #6823 of 6840 Old 08-25-2017, 09:36 AM
sdrucker's Avatar
Quoted: 888 Post(s)
Liked: 600
It would (200W vs. 150W), but the disadvantages of that approach outweigh the benefit.
I wouldn't go that route, because if you turned the X1T sideways to be a horizontal speaker (assumedly resting on the floor or a shelf that could support a 38 lb speaker), the tweeter of the speaker would be off-axis relative to MLP, which ideally would be centered at the midpoint between the left and right speakers. The tower speakers have the tweeter toward the top of the speaker, rather in the center as with a more traditional MTM design like the Imagine XC or C, and that's going to compromise your sound.
Beyond that, you'd have the issue of where the speaker would be in space vertically relative to the mains. Being a tower, placing it on the floor sideways rather than having it standing up is going to throw off your sound for HT, that is where the dialog will be coming form will appear to be significantly underneath the imaging from your mains. That's true with horizontal speakers in general, but it's even worse if the speaker's laying horizontally on the floor.
Given those choices, I'd do the Imagine XC with the X2Ts as the best match, if you can't do identical L/C/R vertical speakers. One other option for you, possibly, would be to use the Imagine XB as a vertical speaker IF you could have it rest below your TV while being placed vertically. Same power handling as the XC, but you'd avoid the off-axis issue with the tweeter at higher frequencies, where it matters more than for lower frequencies.
On a different note, do you have a subwoofer? That's going to ease the burden you put on the speakers, as you can hand off < 80 Hz or so bass (dedicated LFE as well as redirected bass with bass management) to the sub or subs.
Tell us more - what AVR or separates are you running?
post #6824 of 6840 Old 08-25-2017, 10:44 AM
Quoted: 34 Post(s)
Liked: 1
AVR - probably will get either the Denon 3300 or 4300. I will be getting a sub as well. Haven't decided which one yet either. Looking at HSU, SVS, or Rythmik. I'm open to any other suggestion as well. Need to keep the sub under $800.
post #6825 of 6840 Old 08-31-2017, 02:40 PM
skads_187's Avatar
Quoted: 150 Post(s)
Liked: 32
did you buy any yet? Im hoping to purchase the CS610 model soon , but it could be awhile before i actually set them up.
skads_187 is online now
post #6826 of 6840 Old 08-31-2017, 03:53 PM
Redoryx's Avatar
Quoted: 36 Post(s)
Liked: 41
No purchase yet,
Only in the planning stage.
This will most likely be done during the spring or summer next year
Redoryx is offline
post #6827 of 6840 Old 08-31-2017, 06:02 PM
TL5
TL5's Avatar
Quoted: 78 Post(s)
Liked: 40
I'm thinking of getting either the 650's or 610's for Atmos. The tweeters on the 650's seem to be a closer match to the ones in my Synchronys. Does it matter for Atmos use?
TL5 is online now
post #6828 of 6840 Old 08-31-2017, 06:23 PM
skads_187's Avatar
Quoted: 150 Post(s)
Liked: 32
this is the question ive been asking myself for awhile, for me, its a good 400$+ CDN more for the pair, and from what I see the the only difference is the tweeter, woofer looks identical.
thats a lot for just the tweeter. Ill have to go to 2-3 stores and see what the difference really is.
Im thinking, the only thing coming out should be surround effects, rain, helicopter, etc, is the tweeter that important? im thinking no, but if anyone else can chime in that would be great,
Im going to start with 7.1.2 for now, as I would need another amp to go to 7.1.4
Might post this in the atmos thread and see if there is any input.
post #6829 of 6840 Old 08-31-2017, 07:21 PM
MagnumX's Avatar
Quoted: 122 Post(s)
Liked: 58
If you're really worried, you can change all the tweeters out for a replacement fabric-dome replacement tweeter. I got some for about $18 a pair for my PSB B15/S50 speakers (both use the same drivers) when I could not locate enough (3 or more) aluminum models to repair 3 failed tweeters (I thought only two had failed on one speaker, but testing showed one of the S50 (similar to current Imagine S) had only one working tweeter also. I did find two alumnium ones and took one out of my rear center speaker to repair the side surrounds and then put the fabric dome in the less important rear center surround. Once I ran YPAO, I couldn't hear any obvious differences offhand in the pink noise signal from the fabric dome rear surround and given its relatively limited use, I'm not too worried about it. I was concerned about potentially buying the X2T for fuller range L/R speakers and how well it would match the B15 center (seeing as the newer PSBs switched to Titanium tweeters from aluminum and added clay to the woofers, creating a substantial material difference, but it's hard to say how much sound difference it would have with the same diameter and the same +/- 1.5dB rating of frequency response rating over most of the range (1.5dB is a pretty small difference in either direction even if they are at different frequencies with a maximum of 3dB difference coming out of the speaker at any given frequency within that range. A more typical +/- 3dB would give a much more significant up to 6dB swing total which could definitely sound very different as most speakers are at that rating and DO sound very different from one another). I assume similar driver size and cabinet size would help as well in PSB's case between many newer models and their older counterparts along with similar internal designs (more evolutionary than revolutionary), but then without a direct comparison, it's hard to be sure how a newer model compares.
MagnumX is offline
post #6830 of 6840 Old 09-21-2017, 05:04 PM
Acaps's Avatar
Quoted: 44 Post(s)
Just got my PSB Imagine T's....wow
I just received my PSB Imagine T speakers in gloss black to replace my 15 year old Paradigm Studio 100v2's. I've only had them on for a few hours, listening to Spotify in pure direct via my Denon 4300h. First impressions..... all I can say is wow. The detail and imaging from such a small foot printed tower is nothing short of amazing in my opinion. They are very clear and easy to listen too, definitely an upgrade from my trusty beasts paradigms. Unfortunately I will have to continue to use the paradigm studio 570 center until I can sell it along with the studios. I have not re-ran audssey, but will be watching some football in 7.1 tonight, so pretty excited to get these going in my ht set up. I ami pressed, just curious, but it seems like PSB in general doesn't get much love in this forum, or am I off base?
Oh, and I think the gloss black look great!
skads_187 and Scarriere like this.
Acaps is offline
post #6831 of 6840 Old 09-22-2017, 01:27 AM
sdrucker's Avatar
Quoted: 888 Post(s)
Liked: 600
I think it's less that PSB gets little love so much as PSB owners tending to be satisfied with their speakers here. Also, they're a relative value brand compared to the likes of JBL M2s or Revel Performa3 F208s; a well-performing speaker with great NRC measurements like the Imagine T2 for LT $4K/pair, let alone a budget Imagine X series speaker under $1K/pair, just isn't interesting to some folks. On the other hand, you do get some respect from the trade press (e.g. reviews of the Imagine T3s in Stereophile or Sound and Vision, as well as the one by iMagic here awhile back). Personally I'd love to see PSB build on the T3 technology and come up with a flagship bookshelf line to match it, or even get into the active crossover speaker world the way that Paradigm has.
It's also a Canadian brand and has that understated Canuck personality promotionally compared to the likes of Revel or even Paradigm. You go to CEDIA and while there's a PSB/NAD booth (mostly focusing on the Bluesound tech), they don't have a demo room and hence don't get a lot of trade buzz. Their distribution network also has something to do with it - you can buy them at Audio Advisor or Crutchfield, and they don't have the exclusive dealer network that, say, Triad does, so they're not on the radar with customer installers (CIs) the way other brands might be as a prestige item. All of that contributes to the lack of buzz here IMO.
I'm highly biased with a 11.4.6 Atmos room based on PSBs (see my signature for details), but I'd hold PSB Imagines up against any other passive speaker on the market. Hey, if Sandy Gross can show off his Triton Reference and in-wall speakers at CEDIA with a Trinnov Attitude, imagine (pun intended) what a room with PSB Imagine T3s and their range of speakers could do .
post #6832 of 6840 Old 09-22-2017, 02:23 PM
skads_187's Avatar
Quoted: 150 Post(s)
Liked: 32
yup, glad you like them, the imagine T was the reason why I ended up listening to the T2 and eventually buying it. I was really impressed with those speakers.
post #6833 of 6840 Old 09-27-2017, 10:17 AM
sdrucker's Avatar
Quoted: 888 Post(s)
Liked: 600
Forgot to mention another reason why PSB is "underrated" on AVS. It's a completely silly one....try doing a search for "PSB" or "PSB Imagine" using the Search tool within the current Forum template, from anything other than the PSB Speakers thread...
You won't get very much, if anything relevant because the three letter word "PSB" is too short to be used by the search engine for finding meaningful results.
You just get hits with the word "Imagine" and neither PSB or T3 would be included in that example. Apparently two or three letter words are too short for the engine to use, even if you want all words included.
The message I get is:
"The following words are either very common, too long, or too short and were not included in your search: PSB"
Seriously. I couldn't even search for "PSB Imagine T3" for that reason.
Of course, if you search for "JBL Synthesis", Synthesis is a relatively unique word, so you'll get more hits...
post #6834 of 6840 Old 09-27-2017, 02:49 PM
glemigh's Avatar
Liked: 24
My way around the search problem is to use google, and in the search box type something like:
site:www.avsforum.com/forum psb imagine t3
YMMV
glemigh is offline
post #6835 of 6840 Old 09-27-2017, 04:05 PM
sdrucker's Avatar
Quoted: 888 Post(s)
Liked: 600
YMMV
At least on my system, that gives me a nasty message telling me that I'm generating a ton of Internet traffic and asking me to confirm I'm not a robot, with at least two screens of pictures to verify a count of objects in the picture. More detail is that the search apparently violates some sort of TOS.
At least that's the second time I tried searching today. I first tried this without the "/forum" suffix, using THIS syntax:
site:www.avsforum.com "psb imagine t3"
...based on a suggestion on the Forum Control Center, and got a ton of hits, but 90% of them were of posts I made that had PSB Imagine T3 in my signature. That's what we call a not useful tautology (truism). Not very much mileage here
Bottom line is that if you're trying to use AVS for research for PSB speakers, go somewhere else to find information or just search in the PSB Speakers thread only with the dysfunctional search AVS engine, and wade through all posts that come up with the word "Imagine" (since a two or three letter model number is "too short" to find). LOL.
post #6836 of 6840 Old 10-03-2017, 05:44 PM
Speaker Robert's Avatar
Quoted: 23 Post(s)
Liked: 24
I'm a little late to the party, but congrats on the speakers! I've had my Imagine Ts for a few months now and really enjoy them! I eventually picked up the Imagine C & Imagine Bs as I sold my other speakers and it is a perfect blend for my 5.1 system powered by my MRX 520. They are easy to drive, very dynamic, and my receiver has no problems powering them. PSB's dealer presence is really light, with the closest dealer being within about 2 hours from my city (population 250,000+). As a result, there are not many owners in my region. I picked up mine from a local dealer that I've dealt with since my early high school days in my former hometown. Crutchfield was an option, but their price for the Black Ash Imagine Ts was much higher than what my dealer offered.
Speaker Robert is online now
post #6837 of 6840 Old 10-03-2017, 06:15 PM
KenM10759's Avatar
Quoted: 1605 Post(s)
Liked: 852
My cousin got a smokin' deal on a pair of Imagine T as floor demo models from our favorite dealer. He started with his Denon AVR510BT receiver but later upgraded to a lightly used Anthem MRX710 from the same dealer (consignment sale.) He then added an Imagine C, all in the cherry finish. He lastly added the Imagine S pair in a similar finish. While not the same as the speakers it's close enough and hard to tell being across the room from each other. He's running an SVS SB1000 sub to augment the low end, perhaps an upgrade sometime in the future.
He loves the setup, and I do too!
KEF R500, R200C, R100, SVS SB2000 sub, NAD T758 receiver, Pro-Ject RPM1 TT w/ Ortofon 2M Red, Bluesound Vault2, Sony BDP-S480 BlueRay player, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer.
KenM10759 is online now
post #6838 of 6840 Old 10-04-2017, 05:49 AM
Redoryx's Avatar
Quoted: 36 Post(s)
Liked: 41
Congrats to the new Imagine T owners. Great sounding speakers. They really come alive when played a bit loud. (-20 to -15 on Yamaha RXA-2030)
Have had my set for 4 years, In the rare Walnut finish.
Redoryx is offline
post #6839 of 6840 Old 10-14-2017, 05:24 AM
Quoted: 23 Post(s)
Liked: 24
I always enjoy buying open box, clearance, or demo specials at either my dealer or online. I got a great deal on a closeout pair of Image B6 speakers a few years ago now powered by my Powernode 2 setup. My wife always talks about buying stuff on clearance from time to time.....I can now say the same thing too!
Scarriere and KenM10759 like this.
post #6840 of 6840 Old Today, 09:37 AM
Jon SS's Avatar
Imagine B Bookshelf - speaker stand recommendation please
I just bought the Imagine B Bookshelf my surround speakers but realized the bottom is curved which looks great but worried that not stable on my speaker stands (I used to blue tach all 4 corners of my other flat bottom speakers but can now only do the front of the speaker).
Any speaker stand recommendations for the Bookshlef speakers? I am in Canada. Thanks in advance
HT Room: Marantz AV7005 (replaced Parasound Halo C2), Parasound Halo A51 & A23, Monitor Audio GR60, GR Centre, GR10, GRFX, ASW210, Pioneer Elite PRO-141FD, PS3 & PS4, Pioneer Elite DV59avi.
Family Room: Yamaha RX-A2060, PSB Imagine T2, Imagine Centre, Imagine B, Oppo Digital BDP-80, Sony KDL-55HX701
Jon SS is offline
Reply Speakers
Audyssey , image s5 c5 , Nad , Psb , psb image b6 , Psb Image T6 Tower Floorstanding Speaker , Psb Speakers Image B5 Bookshelf , Psb Speakers Image C5 Centre , Psb Speakers Image T5 Tower , Psb Speakers Subseries 200 Subwoofer , psb speakers x1t , psb speakers x2t , Psb Synchrony One , Rythmik Audio , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer
