Question about Vandersteen model 2 speakers. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-17-2006, 09:29 PM - Thread Starter
mberlin74's Avatar
A friend of mine is getting rid of his Vandersteen Model 2 speakers and to be honest I have never heard of them. I need a pair of speakers but was not sure if they were good speakers or not. They are used but I looked at them yesterday and he could have told me he just bought them they looked so good. Mint. Any help would be much appreciated. Any suggestions on a good purchase price? Thanks.
"Everything is relative to the center of it all, which is music in motion through time and space." Bill Kreutzmann Grateful Dead
mberlin74 is offline
post #2 of 12 Old 05-17-2006, 09:58 PM
scorch123's Avatar
mberlin74,
Vandersteens are pretty enjoyable loudspeakers. Find out the exact model - the Model 2 came out the late 1970s and has been through several revisions (2A, 2B, 2C, 2CI, 2CE, and finally the 2CE Signature). The difference between 2 and 2CE Signature is significant.
Regular twos used - I'd offer around $300 for the pair. Definitely audition them with your setup first.
- Steve O.
scorch123 is offline
post #3 of 12 Old 05-17-2006, 10:04 PM
clarke68's Avatar
I've seen a pair of 2Cs go for as little as $150. Brand new 2Ce Signatures run just under $1700.
I've heard the older ones still sound quite good, but may not last very long. You can send them to Vandersteen to have the drivers refurbished and new grill cloth put on, but it's fairly expensive. Bring a flashlight so you can inspect the driver surrounds, and play some bass-heavy material and listen for distortion.
Hit Google with "Vandersteen 2" and you'll find a lot of reviews & info.
clarke68 is offline
post #4 of 12 Old 05-17-2006, 10:06 PM
Habs4life's Avatar
Hey mberlin74, The price will depend on how old and what version they are? Vandersteen have been making the model 2 since the late 70's up to the present but they have been constantly upgrading the design with better drivers and crossovers. If they are older ones you want to pass unless the price is right .They have always been a favourite of Audio magazines and Audiophiles .
Habs4life is offline
post #5 of 12 Old 05-17-2006, 10:19 PM
scorch123's Avatar
Hi,
Obviously, be realistic about getting used speakers. A pair of good quality 2Cs for $150 is a "blue moon" deal. While it's convenient that you live in CA, and you could send in the old 2's to be refurbished or updated, it will cost $$$ for those updates.
If you were to send them back to the factory, it would be important to have the original packing boxes to avoid shipping damage.
The 2CE Signatures are the ones that really get all the attention and rave reviews. Why not give Richard Vandersteen himself a call and have a chat? He's quite friendly over the phone.
- Steve O.
post #6 of 12 Old 05-18-2006, 07:57 AM - Thread Starter
mberlin74's Avatar
Thanks guys, that really helps. I will be over there today and will be more exact on the model. I will also check out the inside with a flashlight. I will let you know what I find.
post #7 of 12 Old 05-18-2006, 08:09 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
If they are the 2C or 2CE Signatures, jump on them. ;)
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
post #8 of 12 Old 05-18-2006, 01:17 PM - Thread Starter
mberlin74's Avatar
Just got back and found out what they are. They are model 2C speakers. I couldn't open the grill though because they seem to be meshed all the way around. Any way I say the receipt and they were purchased in 1985 for 1200.00. Back then that must have been a fortune for speakers. Any way, let me know what you think and what a decent price would be. Thanks all.
post #9 of 12 Old 05-18-2006, 07:56 PM - Thread Starter
mberlin74's Avatar
Anyone, Anyone???
post #10 of 12 Old 05-18-2006, 08:38 PM
Habs4life's Avatar
Gee 21 years old, and if they have never had any factory upgrades maybe $250- $300. asumming all the drivers are still working. For closer inspection of the drivers(if your friend allows ) the wood panel at the base of the speaker can be unbolted.Then the grill material can be slid up like a sock.
post #11 of 12 Old 05-18-2006, 08:48 PM
scorch123's Avatar
mberlin74,
250-300 would be a nice price for the set. Keep in mind the upgrade from 2C->2CE Signature may not be offered by Vandersteen anymore, if that's important to you.
According to Vandersteen's website, that may be the case: http://www.vandersteen.com/pages/Updates.htm
Bring along music or movies you are familiar with, that have good dynamic range. In addition to checking for visible damage/wear, listen carefully to hear if there could be any damage to the tweeter or woofer. I would also swap left/right channels to make sure both speakers are playing fine.
Good luck!
- Steve O.
post #12 of 12 Old 05-19-2006, 09:30 AM - Thread Starter
mberlin74's Avatar
Thanks guys, I will do that.
Closed Thread Speakers
