Monitor Audio Owners Thread - Page 282 - AVS Forum | Home Theater Discussions And Reviews
 265Likes
post #8431 of 11970 Old 04-05-2012, 06:48 PM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
Originally Posted by Canadaffy View Post
I'm just sort of curious how it works without ports. Is it because the 2 drivers are midrange? There's tech/science involved that makes it better without a port or two? I'm not doubting the speaker, just wondering how it does what it does. The answer is probably SCIENCE! but I'm genuinely curious as to how it works.
Did some measurements and stuff: no way it goes on top of my TV. The plastic around the TV would end up bending over time since it's quite weak. On the other hand if it sits slightly below the screen it's not that far away from the midrange/bass driver (basically what HAMP568 was talking about) of the 6's and it'd be easier to angle it UP instead of trying to not have it fall off the TV and kill my cat.
Darn it!!! If I knew that would happen to the cat, then I wouldn't have suggested to place below the screen... Just kiddin!!!
You stated having the midrange/bass driver lined up, that's fine, but the audio trick is having the tweeters lined.
An example, you know when you are listening to two channel music, and if you sit in front of your left and right speakers and close your eyes(or even keep them open). If your speakers have a nice sound stage, you will swear that there is a third speaker/center channel in the center of the left and right playing just as loud as the right and left.(I call that a simple explanation)
All I'm suggesting is, don't mess up that really nice soundstage that the MA's can produce when watching a movie. Get those tweeters lined up.
HAMP568 is offline
post #8432 of 11970 Old 04-06-2012, 04:30 AM
Canadaffy's Avatar
Yeah, see that can't happen with me because it's physically impossible. I mean I'd love to, and in a perfect world I would, but because of my television (currently) it can't be done.
It sucks but there's not much I can do about it. I suppose a L to R or R to L panning wouldn't be that terrible because at least it's a matching speaker that has the same size drivers.
Of course there's also the problem with the centre being 7" in front of the mains (again, because it's a CRT RPTV) but I'm sure it's not a huge deal. Makes me wonder what people did before LCD's and plasma's.
Canadaffy is offline
post #8433 of 11970 Old 04-06-2012, 08:22 AM
Gary Bechtold's Avatar
Quoted: 91 Post(s)
Liked: 104
I use to have a Sony 40 inch XBR TV. Polk Audio CS350 Center channel speaker sat on top of it back in the day as well as a Sony 32 inch before that TV, etc. I'm glad I have something that puts a center channel speaker shelf under the TV/
Gary Bechtold is online now
post #8434 of 11970 Old 04-06-2012, 08:55 AM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
I use to have a DLP too, and I had my center channel on top. It was like that before someone explained to me with lining up the tweeters. Just as long as it's not more then a foot apart, and it should work.
Here is an idea for the top, You can build a shelf behind the TV with it long enough to reach the TV and then place your center channel on top.
I'll try and find a picture, so you can see what I mean, I will update this post or make another post with the pic or a link to the pic
HAMP568 is offline
post #8435 of 11970 Old 04-06-2012, 09:48 AM
j4nash's Avatar
how do the W380-LCR inwall speakers compare to the CP Gold inwall speakers?
j4nash is offline
post #8436 of 11970 Old 04-06-2012, 01:14 PM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
I wonder pretty much the same thing. I am looking to add two more channels to my room, from the 7.1 to 9.1, and I was wondering which of these should I use for the heights.
I've been looking at the
CP Silver inwall
W380-LCR
W280-LCR
W180-LCR
The webpage isn't updated with the new line of these. In the description, They mention the GS and RS line to timbre match. I do know they have newer models, I had a brochure and I misplaced it.
HAMP568 is offline
post #8437 of 11970 Old 04-06-2012, 02:14 PM
rokbyter's Avatar
Quoted: 52 Post(s)
Liked: 35
Cool, another person who is using the monitor and sub combo. I really didn't know how large the subs were when I ordered them, and then they came, I was thinking 'Oh, Boy, where in the hell am I'm going to put these things'.
I had bought them between leaving my apartment and looking for a new house, and it seems I lucked up with the house I bought.
My RX2's are close to the wall, and I have the back port closed. I seriously doubt I am missing any bass that way. I love the depth from the mid range from the center and RX2's upfront. One example is from any of the Transformers movies, when Optimus speaks.
I wouldn't worry about wanting to upgrade anytime too soon, I'm the opposite of you, I hope mine never gets old, I LOVE EM!!!!
In order for me to upgrade, I would have to go up more than a couple levels, and I don't want to.
Honestly, as much as I love the RX2's, I'm just as proud of the RXFX's for my surrounds. They are incredible, and the reviews are correct when they mention timbre matching all the way around.
Which AVR are you using with your Monitor Audio?
Those subs certainly take up quite a lot of room, but I bet the sound is worth it. My next upgrade may well be the subs, I've had my eye on those sealed Rythmik subs for a long time.
My RX-2s are close to the wall as well, but I haven't noticed much difference between where they are and moving them out a bit. I haven't tried the port plugs, but I may just to see. The midrange quality is definitely what first drew me into the sound with Monitor Audio, and it's funny you mention the Transformer movies: when I went to audition the RX-6s, the newest one is what they used to demo them for HT. The way they resolved everything, especially when there was so much going on in the scene really did it for me. Most speakers just turn those big loud action scenes into mush.
No, I agree, actually. I hope mine never get old either. I'm tired of the always thinking something better might be out there treadmill that I was on. Very pleased with these, even just looking at them. I haven't been able to bring myself to put the grilles on yet! And I'm with you on upgrading too, I think I'd have to spend $2-3k+ just on speakers before I'd notice much difference, if any and I'm not looking to spend that.
I'm running mine with an HK-3490, which is only stereo, but then I'm only running 2-channel anyway. I have an older HK AVR254 if I get the itch for surround, but I'd probably sell that and get something else if I go down that path, only because it's older and lacks some newer features. I have an Emotiva UPA-2 stashed away as well, but so far haven't felt the need for the extra power. It's only rated at a few more watts than the HK is, and I'm not lacking for volume or headroom as far as I can tell.
rokbyter is offline
post #8438 of 11970 Old 04-06-2012, 02:21 PM
Reefdvr27's Avatar
Quoted: 1578 Post(s)
Liked: 1060
Originally Posted by SweElite View Post
Hi guys,
Anyone know if there's some foam plugs for the bass ports on the PL300 ?
I cannot answer this, but I would like to know if any RX8's or RX6 oweners are using the foam port bungs LOL, I love that name! Are these for if they are close to the back wall? Any sound change?
CP Silver inwall
W380-LCR
W280-LCR
W180-LCR
One website said that these are discontinued?
Reefdvr27 is offline
post #8439 of 11970 Old 04-06-2012, 08:09 PM
wagnerc's Avatar
Quoted: 37 Post(s)
I just pulled out my old Monitor Audio 4i speakers for my home office and connected them to my Sonos ZP90 with my Marantz MA700 mono blocks. I am very pleasantly surprised. These speakers still sound great!
After spending so much time with my GR20's, GR10's, PL100's, and PL300's I was not expecting them to sound this good!!
I had been using them as surrounds until I replaced them with some GR10's. They then went in the dinning room connected to my old Onkyo. I never expected them to sound this good in the office.
wagnerc is offline
post #8440 of 11970 Old 04-07-2012, 07:16 AM
jayman_1975's Avatar
Wanted. GS10 in Walnut
jayman_1975 is offline
post #8441 of 11970 Old 04-08-2012, 04:49 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 669
Be forewarned about the GS60s in black that were just listed on Audiogon for $2199. That owner just bought them off of EBay last week for about $1400 and is trying to turn a nice profit. OK, he's free to try that. But the text in the ad is an exact copy of the EBay ad. And I wouldn't be surprised if he hasn't even received them yet!
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #8442 of 11970 Old 04-08-2012, 06:08 PM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
i had to go back and read something to make sure, and you are running a 2channel? I would get the center channel before I upgrade your subs. The RX center is pretty amazing for it's size.
HAMP568 is offline
post #8443 of 11970 Old 04-09-2012, 03:48 AM
jimfrench's Avatar
I agree, the addition of the RX center made a great difference. I thought the older Paradigm center was working well until I put the RX center in place. Better timber match and clarity was immediately obvious to both my wife and me. There are many good subs available, most are lower cost than the M/A subs for the same or better quality (or so "they" say). No doubt they are more expensive.
jimfrench is offline
post #8444 of 11970 Old 04-09-2012, 11:41 AM
goneten's Avatar
Hi guys,
Anyone compared the Paradigm Studio range to the GX range? I own the Studio 100's with the CC590 center. But I'm moving soon and I need to downscale as I am moving to a smaller space. However if I'm going to go smaller there is one aspect of the system that I need improved on: dialog clarity. It's not that great on the CC590 center (apparently it's the design, not the room).
I was thinking of going GX100's with the dipole configuration. But instead of using the typical center found in the range I was thinking of perhaps using an identical GX100 for the LCR. Perfect panning for the front stage. I'm also looking at the XTZ range, also with ribbon tweeters (in fact, the very same ribbon as used in the GX and Platinum range).
Am I making a mistake going to the GX range? I assume the ribbon tweeter is able to resolve tons of detail in move soundtracks? Any opinions would be appreciated. Thanks.
goneten is offline
post #8445 of 11970 Old 04-09-2012, 01:23 PM
Quoted: 91 Post(s)
Liked: 104
Originally Posted by goneten View Post
Hi guys,
I did not know about these XTZ speakers. They look nice. Are they distributed anywhere in the USA?
post #8446 of 11970 Old 04-09-2012, 01:38 PM
goneten's Avatar
Gary, I have no idea. They do look nice. These speakers (99.25/26/36) use Seas Excel mid-range/bass drivers with Fountek ribbon tweeters, so although they seem budget priced, the components being used are very high-end. I've never heard them in person and to be frank I never even heard of the brand until yesterday.
Only problem is that I can't audition them. It's only sold online. It would have to be a blind buy, which is risky. There is a UK distributor (Audiosanctum, I think).
goneten is offline
post #8447 of 11970 Old 04-09-2012, 01:41 PM
goneten's Avatar
Has anyone bought 3 GX100's for LCR's? Can you even buy a single GX100 or is it only sold in a pair?
goneten is offline
post #8448 of 11970 Old 04-10-2012, 10:10 AM
goneten's Avatar
Anyone?
goneten is offline
post #8449 of 11970 Old 04-10-2012, 02:51 PM
rokbyter's Avatar
Quoted: 52 Post(s)
Liked: 35
Correct, I'm just running a 2-channel setup. I'd have to go back to my old AVR or get a new one for multi-channel, and in my room I suppose it's possible but it would be a tight fit (mainly the surrounds).
That is good to hear about the RX Center though, because it does look small in the pictures I've seen and I've wondered how it performed. You may just completely derail my plans! haha!
rokbyter is offline
post #8450 of 11970 Old 04-11-2012, 10:02 AM
VMat's Avatar
Quoted: 22 Post(s)
When I had a similar problem (and a CRT TV too) I made this shelf with aluminum feet to put the speaker under it. It may give you an idea.
(for those wondering: I recently had to move the speaker up to add that amp until the new cabinet is ready - i.e., in about two weeks)
VMat
In use: 1) Yamaha NS-BP300 + Technics SU-Z65 + ST-Z45 + Pioneer DV-420, 2) Audio-Technica ATH-M35 + Audioengine D1 + Strawberry Pi.
Temporary (woohoooo!!!): MA GX200 +
Yamaha A-S500 + Squeezebox V3.
In storage: Some MA (BX) and CA (Minx) Speakers, Yamaha RX-A1000,
CA DacMagic, Yamaha CDC-697, Sansui TU-D99X, HK TD4500, Pioneer BDP-320 and DV-610, BIC Acoustech H-100, Audio-Technica ATH-M40fs.
VMat is offline
post #8451 of 11970 Old 04-11-2012, 10:08 AM
VMat's Avatar
Quoted: 22 Post(s)
Also... if you go with the temporary speaker solution, remember not to place a non-shielded speaker close to a CRT.
VMat
VMat is offline
post #8452 of 11970 Old 04-14-2012, 02:49 PM
barasn's Avatar
Quoted: 33 Post(s)
hi think to buy all pl series just for home theater is it ok for home theater?
http://www.whathifi.com/review/monitor-audio-pl300-av
or go for bw nautılus 802,center htm 1 surround 805 nautılus subwoofer pb 1 which set better for home theater?
barasn is offline
post #8453 of 11970 Old 04-14-2012, 05:44 PM
damienbuckley's Avatar
or go for bw naut?lus 802,center htm 1 surround 805 naut?lus subwoofer pb 1 which set better for home theater?
Honestly, if you have the money and suitable source / amplification, you are going to be VERY happy with either of those choices
damienbuckley is offline
post #8454 of 11970 Old 04-15-2012, 09:23 AM
barasn's Avatar
Quoted: 33 Post(s)
any ideas
barasn is offline
post #8455 of 11970 Old 04-15-2012, 09:37 AM
petetherock's Avatar
Quoted: 1171 Post(s)
Liked: 593
The sonic signature will be very different, so audition..
And make sure your amps and source are also up to the mark.l
petetherock is offline
post #8456 of 11970 Old 04-18-2012, 01:38 PM
barasn's Avatar
Quoted: 33 Post(s)
bw eliminated
need help for home theater
Pl 300 set vs Dali Euponia MS5 Set
which set better ht and stereo the amp will be krell
really need help i will buy in 2 days
barasn is offline
post #8457 of 11970 Old 04-18-2012, 03:44 PM
barasn's Avatar
Quoted: 33 Post(s)
and last question is think to make mix system like
Front : dali ms 5
center: MA Plc 350
Surround: pl 100 Ma
what u think about mix system?
barasn is offline
post #8458 of 11970 Old 04-18-2012, 04:31 PM
jimfrench's Avatar
Front : dali ms 5
center: MA Plc 350
Surround: pl 100 Ma
I think you will find a lot of recommendations that the front and L/R should be of the same timber. This is easiest done from the same manufacturing and model line. For myself the addition of the RX center to the RX6's was the completion of the system.
post #8459 of 11970 Old 04-19-2012, 11:58 AM
barasn's Avatar
Quoted: 33 Post(s)
anyone help?
barasn is offline
post #8460 of 11970 Old 04-19-2012, 12:28 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
anyone help?
I agree with Jim-I wouldn't mix and match your front three. Surrounds would probably be OK.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is online now
Reply Speakers
cp-wt380idc , Denon Avr 3806 Av Receiver , Denon Blu Ray Dvd Cd Player , Jl Audio Brand , Monitor Audio , Nad , Parasound , Receivers Amplifiers , Sunfire , Toshiba
