Monitor Audio Owners Thread - Page 287 - AVS Forum | Home Theater Discussions And Reviews
 217Likes
post #8581 of 11692 Old 05-26-2012, 08:46 PM
big_marcelo's Avatar
Originally Posted by damienbuckley View Post
I've probably asked before (apologies) but what surrounds are you running with your GX gear?
I'm running my old fronts.... The RX8's.....
I have the crossovers set to 50hz, so I actually use most of the range of the speaker and it matches ok - however if I was buying from scratch, I'd choose either the RX1 or the GX50 ( depending on budget) and set the crossover at 80....
A friend of mine which doesn't have much room behind his couch, is opting for the GXFX speakers and putting the on the wall... His house is still under renovation so the speakers are not installed yet, so I can't say how they perform.... However, if the fronts are anything to go with, the mid and HF should balance very well together indeed....
When I was running my RX centre, I was pretty happy with it, and no complaints really... Now doing the home test on th GX350, the HF and mids are very well integrated in the front channel, and this causes a perceptual increase in the sound field and the transition in the front sounds seamless...
Can't get enough of technology .... Love the toys!!!
big_marcelo is offline
post #8582 of 11692 Old 05-27-2012, 03:49 AM
damienbuckley's Avatar
Thanks. I'm talking to my dealer about which choice. Bizarrely MAh ave suggested RXFX on sides & RX1 or GX50 at the back but I'm still considering GXFX sides & GX50 rears.
I'm going to switch my RSFX to dipole (side walls) and see if I hit the out of phase with the rear pair issue MA are talking about?
damienbuckley is offline
post #8583 of 11692 Old 05-27-2012, 06:20 AM
After spending the Sunday swapping between the GX350 and the RX centre.... I'm still undecided.... I believe the RX gives you a clearer dialogue, but the Gx sounds a little more natural, plus the Gx integrates better with the rest of the fronts...
Now considering a smaller rear speaker and reading about dipoles, etc.... I'm undecided.... The Rx8 are giving a great full sound with body...... And my amp, emotiva xpa5 for the surrounds and centre has enough grunt to drive the Rx8 properly....
The Rx1, IMHO, would be a worthy addition, as would the Rxfx centre
I think I will end up keeping the GX350 centre because of the soundstage , even though I'm not sure it's worth the extra cash....
The key reason to go to a GX range speaker for rear and centre would gpbe the HF integration.... I'd demo the GX50, RX1 and Rxfx before deciding on which...
As far as rear channel goes, there is very little dialogue, if any, mostly effects and sounds... The Gx may integrate well, and I think the rx1 may surprise you...
I may have a chance to sell my Rx8 and RX centre to a friend, in this case it would be worth my while to do so.. And change from the rx8 to the gx100 for the rears...
post #8584 of 11692 Old 05-27-2012, 06:37 AM
Good points on dipole bipole here... http://arstechnica.com/civis/viewtopic.php?f=6&t=772713
post #8585 of 11692 Old 05-28-2012, 01:00 AM
today I ordered GX350 for the centre and GX100 for the rears ... with the expensive speaker stand... I couldn't audition the GXFX or RXFX... so I bought the GX100 ... matches well with the GX300 (without the bass response) .... but not in stock ... so 8-10 weeks wait.... oh well ...
also picked up the GX15 sub ... upgrade from the RX12 ... again, couldn't audition it... so buying blind... anyone here has experience with the GX15? specially how it compares with the RX12?
post #8586 of 11692 Old 05-28-2012, 04:13 AM
Thanks for the link. I'm still thinking the full GX 5.1 plus GX50's as this seems to fit with the THX setup guidelines.
post #8587 of 11692 Old 05-28-2012, 05:18 AM
buddahead's Avatar
I have MA Rs6 that I bought 4 years agp after reading the Stereophile review.They loved them and I have been very pleased with them.Great sound and they look good.Now I have been thinking of upgrading my speakers.I just got a new integrated Music Hall a70.2 integrated amp that sounds great and oppo CD player.Are the Gold series much of a upgrade over my Rs6's'Back when I bought them new they were $875 for a pair.The Gold speakers are over $4k a pair'which I find over priced IMHO.Their are many other killer speakers in that price range like the Goldenear triton 2' Salk'Vandersteen'ect.Are the Golds that good to command that price.This is a 2 channel system.Thanks
buddahead is offline
post #8588 of 11692 Old 05-28-2012, 08:39 AM
I've spoken to someone who has recently 'upgraded' from the RS to the new silver range, the RX..... MA trickles down technology from higher ranges... The current GX range is not far off the Platinum range..
I suggest you audition the RX6 and see how that compares... For stereo, on the GXbrange I'd reco,mend the GX100 upwards...
post #8589 of 11692 Old 05-28-2012, 10:50 AM
BarracudaDelGato's Avatar
I think that the main source of the price difference is in the cabinet work (do you care)? I think that there is also a noticeable increase in SQ, though that is more subjective.
The best thing would probably be to try a side by side comparison - if possible...
I listened to rx6 and rx8 (not the RS) before buying my gx200, and IMO the difference in SQ was not too subtle.
If I had a chance to do it all over again, I'd probably taken more time, and seriously considered Salk and Philharmonic Audio, if anything because they are so well regarded on this forum.
BarracudaDelGato is offline
post #8590 of 11692 Old 05-28-2012, 11:16 AM
jd_alpha's Avatar
Hi All:
Just got a GX 5.1 system set up on the weekend. I can't say enough about the fit and finish, quality, and attention to detail Monitor Audio has put into the speakers, right down to the packaging! Just outstanding engineering, product quality, and design. Each speaker looks like a piece of fine art.
I haven't heard enough material yet to say anything too definitive, and the speakers do need breaking in, but from what I have heard the highs are truly goregeous.
Back on topic - the ribbon tweeters in the GX series are a big step up over the domes in the RXs (which are no slouches either) IMHO. I've been a fan of ribbons for a long time now (had some Maggies with an amazing ribbon tweeter way back in the day). I also think Barracuda is right about the cabinetry, although I'm sure the RX cabinets are really nice as well.
Try to audition both speakers and decide for yourself if the increase in price makes sense for you. That's a judgement on value no-one else can make for you.
I would also have liked to hear something from Salk. I think some of their speakers are very comparable to the GXs (even down to having ribbon tweeters).
- JD
jd_alpha is offline
post #8591 of 11692 Old 05-29-2012, 07:55 PM
Originally Posted by jd_alpha View Post
Hi All:
- JD
JD, which speakers did you get for your rears??
post #8592 of 11692 Old 05-30-2012, 10:41 AM
jd_alpha's Avatar
Hey big_marcelo:
I got the GX50s. I had considered the GXFXs, but in my set-up I have to jam the rear surrounds into the back corners of the room. This placement would mean I wouldn't be able to use the GXFXs in di-pole mode. I also wanted to use stands rather than wall-mounting the speakers.
I didn't go with the GX100s mostly because of cost, but I also didn't think there would be that much of a performance improvement given they are just receiving surround channel signals and are being crossed-over to the sub at 80 Hz.
So far I'm pleased with the sound, but I hope I don't regret not going with the GX100s in the future.
- JD
jd_alpha is offline
post #8593 of 11692 Old 06-01-2012, 01:07 AM
Hey big_marcelo:
- JD
great stuff...
for surrounds I'm sure the GX50 is more than enough.. the reason I"m going with the GX100 is that if I have the opportunity to upgrade my bedroom setup, I can move the GX100 up, and then buy a GX50, or the GXFX .... or something else... I wanted to try at home having all 5-7 speakers with the same drivers, specially the HF ....
with the GX350 in place now for a couple of days, and going through some basic calibration.... they match beautifully .... so different than the audition at the store....
so now I'm waiting for the GX100's and the GX15" sub to arrive... no stock, so 6-8 weeks....
anyone here with a GX15"? how did the calibration go? the shop manager said he had great difficulty calibrating the GX15" properly on his first install a few months ago... he doesn't stock it, only on order ... so I couldn't demo it... the RX12 sub is fine... but....
post #8594 of 11692 Old 06-01-2012, 03:22 AM
great stuff...
Couple of Q's relevant to me joining this exclusive club - if you DO go to 7 speakers, will you mix GXFX & GX50? MA advising me against this & I'm unconvinced.
With the GXW15 having its own equalisation, what do you do with your amp setup?
post #8595 of 11692 Old 06-01-2012, 08:37 AM
jd_alpha's Avatar
On the GX15 sub - I'm a little hesitant to comment as I've not had it all that long or had the chance to give it a good workout yet.
The LEO (integrated sub room correction/EQ) set-up was very easy -- position the sub, attach the provided microphone, run the program (like running Audessy or MCACC on an AVR). You can also set the sub to auto-on mode so it will shut on and off automatically depending on the presence/absence of a LFE signal.
I have an Elite SC-57 AVR and its MCACC program does not do sub EQ. So I just ran LEO on the GX15 first and then ran a full MCACC on the AVR. There were no issues with the set up and everything sounds fine so far. I still need to do a lot of listening though ...
If you have an AVR with sub EQ, or outboard sub EQ, you likely wouldn't want to run LEO on the GX15. Or maybe in that case it would be best to experiment to see what configuration works best.
If I were to change to 7.1 and I could either wall or stand mount the two side surrounds, I think I'd go with the matching GX50s. I do like the idea of di-polar speakers for surround channels though, and I also like the fact the FXFXs are switchable. They are both really great speakers for the job - I'm sure you'd be happy with either. Could you wall-mount all of the surrounds in your set-up?
Cheers,
JD
jd_alpha is offline
post #8596 of 11692 Old 06-02-2012, 02:38 PM
ArtMusic's Avatar
Dear all,
This will be my first post on this forum, so please be gentle . I am a very big fan of Monitor Audio speakers. A few years ago I bought a pair of Monitor Audio BR1 speakers that I ran with a Denon dm38 dac amp/cd player and was blown away by the rich full sound coming from these unassuming bookshelf speakers. I have this system in my small bedroom and it serves its purpose well.
Last week for the sitting room (4 meters x 7 meters) I bought my first floor standing speakers ever, the Monitor Audio BX5 coupled with the Marantz PM 6004 amp and the Marantz 6004 CD player. I positioned the speakers 3 meters apart and 3 meters away from my sitting position forming an equilateral triangle as per the instructions in the manual. Played Verdi's Rigoletto and instantly noticed the wide soundstage produced by these speakers. The sound was remarkably warm, but the vocals lacked focus. So I started experimenting with toeing in and it is here that I got into trouble. First I angled the speakers 30 degrees so that they were directed at me. This didn't work as the voices lacked space. After 45 minutes of toe in adjustments I finally settled on the speakers firing just at my shoulder location on each side. With a group of singers I could hear some coming from left of centre and others like the chorus of the Duke's entourage from the right. Is this the effect I should be going for? Or do all the voices have to come from the centre?
Also do you think that the BX5 speakers are too far apart from each other at 3 meters?
I would really appreciate any advice you an give me.
Thank you,
Artmusic
ArtMusic is offline
post #8597 of 11692 Old 06-02-2012, 07:13 PM
Cheers,
JD
I have to put the side surrounds on the wall - I have RSFX now, but I have full-height bookshelves all along the back wall so cant use GXFX on the back, hence considering GX50 there.
The problem is, MA are advising against mixing GXFX/GX50 due to phasing issues. Theyre suggesting its either 4 x GXFX or RXFX + RX1.
This doesnt make sense to me as THX recommend dipole sides and direct-radiating rears as the ideal setup...
post #8598 of 11692 Old 06-02-2012, 07:14 PM
Cheers,
JD
With the GXW15 I'll use LEO so that its doing the work when I run analogue direct (from my bluray) but I'll run MCACC over the top of that for when I'm using amp-based surround & EQ
post #8599 of 11692 Old 06-02-2012, 08:08 PM
Originally Posted by ArtMusic View Post
Dear all,
Thank you,
Artmusic
3 m apart maybe too much. I found that the image improved a lot as i moved the speakers 1 m (3 ft) from the wall. Just my experience, but it's something cheap to try. :-)
post #8600 of 11692 Old 06-03-2012, 12:52 AM
ArtMusic's Avatar
Thank you. I'll try to bring the speakers closer to each other and see what I get. Not sure if it is worth placing the speakers along the 7 meter length of wall as opposed to the current setup along the 4 meter width?? in this case I'd be sitting right up against a wall........ Perhaps this is NOT advisable.
Artmusic
ArtMusic is offline
post #8601 of 11692 Old 06-04-2012, 04:18 PM
Artmusic
I'd probably keep working on positioning the speakers along the short side. It is good to have some space (if possible) both between the speakers and the front / side walls, and between the LP and the rear wall. Of course each room is different, try different things and see what works best for you.
post #8602 of 11692 Old 06-04-2012, 09:55 PM
rokbyter's Avatar
Quoted: 13 Post(s)
Dear all,
Thank you,
Artmusic
Regarding your experience with toeing in the speakers, I had the same experience with my RX-2s. If I toed them directly at the listening position, it just din't sound right, but toeing them out just a bit from that point (about shoulder width, like you mentioned) really helped. I would imagine what you heard with some of the vocals being slightly to the left or right was probably accurate. I hear this all the time when watching TV - the voices seem to come from exactly where the actors are on screen. Some may say this is sighted bias, or whatever, but I've not previously experienced imaging like this in any of my previous speakers. I like it a lot!
rokbyter is offline
post #8603 of 11692 Old 06-05-2012, 02:02 AM
ArtMusic's Avatar
Thank you rokbyter. The effect stunned me when I first heard it. I too loved this effect, but i wanted to check that it was not a result of an error in speaker setup on my part. As I was listening to a CD, I could actually pick out exactly where those singers stood in that aural stage produced by the Monitor Audio BX5s! It must be a real thrill to bring visuals into the mix, as in the setup you have.
I ended up moving the speakers a bit closer together and further from the side walls. They now sit 2.5 meters apart and I am very pleased.
As a side note for those on a modest budget I highly recommend the Monitor Audio BX5s with the Marantz PM6004 amp and Marantz 6004 CD player. This is a winning combination! I bought the whole package a few weeks ago online for £899 delivered from Roy Jowett. Easily one of the best entry level high end audio systems on the market.
Artmusic
ArtMusic is offline
post #8604 of 11692 Old 06-06-2012, 08:22 AM
AVrebel's Avatar
I'm currently running a pair of Silver 5is which I bought for $300 about 6 yrs ago. I've recently upgraded my subs and I would like to upgrade my mains as well. I would like to have something with a bit warmer sound.
How do the 5is compare to Monitor Audio's current offerings. How do they compare to other brands such as Polks RtiAs or B&Ws?
resolution good....
AVrebel is offline
post #8605 of 11692 Old 06-06-2012, 08:49 PM
rokbyter's Avatar
Quoted: 13 Post(s)
Artmusic
Good to hear that Marantz is a good match with them as that is one of the brands I'm considering for my next upgrade. I'm also looking at NAD if anyone has any input there. The 326BEE integrated amp looks to have pretty much everything I need, but so does the Marantz 5007 coming out soon. Main thing being that I don't need the extra channels in the Marantz since I run a 2.2 setup and I really have no itch to upgrade to 5 or more channels. I'm running a HK 3490 right now as a preamp (left channel seems to have gone wonky) into a Emotiva UPA-2, which sounds good, but I'd like to get that down to one component if possible.
rokbyter is offline
post #8606 of 11692 Old 06-09-2012, 04:25 PM
VMat's Avatar
Quoted: 13 Post(s)
I also have BX5's here, driven by a Yamaha A-S500, which I highly recommend. Give it a try if you have a chance.
VMat
VMat
In use: Yamaha NS-BP300 + Technics SU-Z65 + ST-Z45 + Squeezebox V3 + Pioneer DV-420, Audio-Technica ATH-M35 + Audioengine D1 + Strawberry Pi.
In storage: Some MA (BX/GX) and CA (Minx) Speakers, Yamaha A-S500 and RX-A1000, CA DacMagic, Sansui TU-D99X, HK TD4500, Pioneer BDP-320 and DV-610, BIC Acoustech H-100, Audio-Technica ATH-M40fs.
VMat is offline
post #8607 of 11692 Old 06-15-2012, 12:09 PM
jimfrench's Avatar
Dear all,
Thank you,
Artmusic
I had a problem with RX6's as front L/R. In an effort to find the right position for music I gradually separated them to about 9 feet. This was a great position for music listening. When I later put in a movie, the sound was lost. There was no body of sound and even the surround speakers could dominate. I moved them back closer and the problem disappeared. I also read that using the port bungs in the front tended to support the bass level and tried that. It seems to have created a good balance between music and HT. Just a thought as to how important positioning can be, even small differences can lead to big changes in SQ. Moving speakers costs nothing, so its usually worth a try. Thanks to posters here and on other forums for suggestions.
jimfrench is offline
post #8608 of 11692 Old 06-16-2012, 12:40 PM
John T30's Avatar
Hi guys recently bought brand new RX6, RXC and RX1. The RX1 on one speaker has scuffs to the
white paint on the bass golf ball cone about 12 o'clock position above the pointed dome in the
middle. Although possibly only cosmetic I'm concerned longer term this could have detrimental
effect on the cone once it is out of warranty. The fact it is new it should be perfect in my
opinion.
Looking at the picture am I being too fussy if it is just paint or is it reasonable to expect a replacement.
Do you guys think I should take it back to the shop and get it replaced?
John T30 is offline
post #8609 of 11692 Old 06-18-2012, 07:38 AM
The Upsetter's Avatar
Is it something you have tried to wipe off? If you can do so gently without incurring any further scuffing or damage I would try that. If there's any damage to the ceramic coating, no matter how small, I would return it asap.
The Upsetter is offline
post #8610 of 11692 Old 06-18-2012, 10:23 AM
Gary Bechtold's Avatar
Quoted: 81 Post(s)
Liked: 76
Monitor Audio Silver RX6 loudspeaker review on Stereophile
http://www.stereophile.com/content/monitor-audio-silver-rx6-loudspeaker
Gary Bechtold is online now
Reply Speakers
cp-wt380idc , Denon Avr 3806 Av Receiver , Denon Blu Ray Dvd Cd Player , Jl Audio Brand , Monitor Audio , Nad , Parasound , Receivers Amplifiers , Sunfire , Toshiba
