Monitor Audio Owners Thread - Page 341 - AVS Forum | Home Theater Discussions And Reviews
 248Likes
post #10201 of 11895 Old 06-23-2014, 11:46 AM
tidwelr1's Avatar
Quoted: 207 Post(s)
Liked: 61
Originally Posted by DiNZi View Post
It sounds a little bit better now, I've moved the Sofas out the room and re-run YPAO a couple of times, results are better.
It set the Bass Crossover to 120Hz, also set my Subwoofer to -1 with the Level at the back of the Subwoofer to around 60%.
When I first got the MA Vectors, and I didn't do much configuring and I just set the Crossover to 80Hz, I watched Lone Survivor and during one of the helicopter scenes my Right Rear Speaker made like a crackling noise, as if too much treble and I thought I had popped the Speaker.
I did a test tone afterwards and it's fine. But, I now realize that, that happened because the Crossover was set to 80Hz, it's too low for these Speakers.
YPAO set the Crossover to 120Hz, I watched I Frankenstein the other day and it sounded ok.
I watched a Bollywood flick and in those films you have 5-7 min songs during the film, I noticed that the Subwoofer was giving out too much bass during one song, it may be the crap authoring of the bluray as bollywood blurays aren't that impressive but maybe I was thinking, I could set the Satellites to give out little more bass so instead of 80Hz, set to 100Hz instead of YPAO's set of 120Hz?
Is a 10Hz jump considerable? If I heard that worrying noise from my Surrounds during that Helicopter scene, I don't want that to happen again it could damage my Speakers.
If missed this I apologize, but what kind of sub are you using?
tidwelr1 is offline
post #10202 of 11895 Old 06-23-2014, 01:55 PM
Raijinbu's Avatar
Hello, I currently have a pair of RX2s and an RX Centre and I power these with a Marantz SR6007. My room is about 25ft x 20ft and I sit about 10ft away from the speakers. Do you think I will benefit from adding a power amp to the RX2s? I was thinking of an Emotiva XPA200 or older UPA series. Thank you in advance for your input.
Raijinbu is offline
post #10203 of 11895 Old 06-23-2014, 03:34 PM
DiNZi's Avatar
http://www.monitoraudio.co.uk/suppor...ts/vector/vw8/
DiNZi is offline
post #10204 of 11895 Old 06-24-2014, 10:24 AM
tidwelr1's Avatar
Quoted: 207 Post(s)
Liked: 61
ok thanks. The problem you're having is probably a combination of things, but the sub is a really important part of your setup bc the other speakers are fairly small and you need to direct all of the bass to the sub. The best thing you can do to improve your setup over the long term is to improve the sub. You would be amazed at how much it helps your overall system. The sub you have may seem like it sounds great, but the reality is that it's not a very powerful sub with clean bass at high volume. Subs typically require a much bigger box to produce the bass you need and want unless you spend a good bit more money to buy a smaller one with a much stronger amp. You're definitely in the ballpark in terms of the crossover. 100-120 seems about right for those speakers. I think you really need a bigger and better Sub to really improve that system. 100 watt subs won't give you that clean mid and lower bass that you need to complement those speakers unless the room is on the smaller side. You'll need to spend a min of $500 to get a decent sub from one of the internet direct companies like HSU, SVS, PSA, etc. The other issue of volume is likely due to a problem with your settings in the AVR which I think was mentioned previously. Hope that helps.
tidwelr1 is offline
post #10205 of 11895 Old 06-25-2014, 03:11 PM
dac-906's Avatar
Quoted: 12 Post(s)
Originally Posted by dac-906 View Post
FS: Silver RX8
I'm selling my, little over year and a half old, MA Silver RX8 for $1,150.00 (free shipping within CONUS). I'm the original owner and they're in excellent condition (like new). I really took good care of them they are packed in their original boxes.
Here are the specs:
System Format: 3 Way
Frequency Response: 32Hz - 35kHz
Sensitivity (1W@1M): 90dB
Nominal Impedance: 4 Ohms
Maximum SPL (dBA): 116.2
Power Handling (RMS): 175W
Recommended Amplifier Requirements (RMS): 50 - 175W
Bass Alignment: Bass reflex.
Twin HiVe®II port System
Tweeter Crossover Frequency: LF/MF: 300Hz
MF/HF: 2.2 kHz
Drive Unit Complement: 2 x 6" RST® Bass drivers.
1 x 6" RST® Bass/Mid driver.
1 x 1" (25mm) C-CAM® gold dome tweeter
Product External Dimensions:
(H x W x D)
inc. plinth & feet 960 x 275 x 388 mm (37 13/16 x 10 13/16 x 15 1/4 inch)
Individual Weight: 21.76 Kg (47.88 lb)
Bump
dac-906 is offline
post #10206 of 11895 Old 06-25-2014, 10:30 PM
ambesolman's Avatar
Quoted: 1087 Post(s)
Liked: 915
Nobody? Its a good deal that includes shipping!
ambesolman is online now
post #10207 of 11895 Old 06-26-2014, 11:31 AM
Raijinbu's Avatar
Hi, what's the color of the RX8s you are selling?
Raijinbu is offline
post #10208 of 11895 Old 06-26-2014, 12:40 PM
dac-906's Avatar
Quoted: 12 Post(s)
They are Rosenut Real Wood Veneer. I posted some pictures on page 340 of this thread. You'll see them on Post #10198 .
dac-906 is offline
post #10209 of 11895 Old 06-26-2014, 02:32 PM
Raijinbu's Avatar
I'm trying to decide on the finish since it wouldn't match my RX centre, what part of Southern California are you in? I'm in San Diego.
Raijinbu is offline
post #10210 of 11895 Old 06-26-2014, 02:49 PM
dac-906's Avatar
Quoted: 12 Post(s)
Ok let me know if you decide to purchase them. What's the color of your center?
I'm in La Palma, very near Knott's Berry Farm (3.6 mi) and Disneyland (10 mi).
Sources ---> Clearaudio Concept TT, Onkyo CDP, MacBook Pro/Audirvana
Pre/DAC & Power Amp ---> Emotiva XPS-1 Phono Stage, Emotiva Stealth DC-1 Pre/DAC, Emotiva XPA-1L Monos
Speaker ---> Dynaudio Excite X34
Cable ---> Audioquest Type 8 Speaker Cable, Emotiva Interconnect Cables
Headphone ----> Onkyo ES-CTI300 (SS)
dac-906 is offline
post #10211 of 11895 Old 06-26-2014, 03:24 PM
Raijinbu's Avatar
Thanks, the center is black veneer.
Raijinbu is offline
post #10212 of 11895 Old 07-01-2014, 09:23 AM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
Ok, I have read too many conflicting comments about having presence speakers. I have heard some of the same things about rear surrounds.
I plan to contribute to the mass of post on the subject real soon. I have decided to use some RX1’s in this test. I do have a bit of construction to do for proper placement, but I do look forward to hearing it.
Currently I do have my AVR Onkyo 5008 powering the front stage, with (2) separate 2channel amps for the side and rear surrounds. I won’t take away from the AVR amp in this setup, but add another 2channel amp just for the front heights.
Onkyo 5008 for front stage of RX2’s and RX center
Onkyo 2channel amp for side surrounds
Onkyo 2channel amp for rear surrounds
Onkyo 2channel amp for the height speakers.
HAMP568 is offline
post #10213 of 11895 Old 07-05-2014, 10:09 AM
dac-906's Avatar
Quoted: 12 Post(s)
FS: Silver RX8
Here are the specs:
MF/HF: 2.2 kHz
(H x W x D)
Still available
ambesolman likes this.
dac-906 is offline
post #10214 of 11895 Old 07-05-2014, 07:02 PM
jhurricane30's Avatar
Monitor Audio BX6
OK! So I fell in love with Monitor Audio today in a store showroom (thx to this forum).
The BX6 seem to fit my budget.
If there are any owners of this set on this thread, how do you like them??
Any suggestions for a center or sub to match this set?
jhurricane30 is offline
post #10215 of 11895 Old 07-05-2014, 08:30 PM
ambesolman's Avatar
Liked: 915
I'd go with the bx center or bx2 for the center. Look at internet direct (ID) companies like hsu, svs, power sound, etc for good subs. Personally I have a hsu vtf 3 and it sounds amazing for movies and excellent with music too.
How big is you room? Budget?
Sent using Tapatalk since the mobile version is still 👎
post #10216 of 11895 Old 07-06-2014, 01:32 PM
Thanks, the bx center looks excellent. I'll check out the subs you recommended.
The room is 21x17, but it has an open air layout with the kitchen (for music).
Budget $2500- with $1200 being set aside for the BX6 and receiver.
So i have to squeeze a center, sub and two rears out of the remaining, or do the unthinkable and not finish the rears until later.
post #10217 of 11895 Old 07-06-2014, 04:59 PM
ambesolman's Avatar
Liked: 915
Your room is roughly the same size as mine. The vtf3 mk4 is on sale right now for $639, but not sure how long the sale lasts, just call. They're really nice and can help with any questions.
http://www.hsuresearch.com/products/vtf-3mk4.html
The bx1 would do well for rears. $379/pr
Center is $299
http://saturdayaudio.com
That should get you right at your budget. If you call they may give a discount ordering multiple speakers. Never hurts to ask
If you like to build stuff, you could always DIY a sub for a little cheaper. I'm about to give it a try myself just to see if I can do it.
post #10218 of 11895 Old 07-07-2014, 05:59 AM
tommaazz's Avatar
Quoted: 229 Post(s)
Liked: 127
Hi. I have the BX6, BXFX, BX center, BX1 (FRONT HEIGHT) and 2xSVS SB12 na di like it very much. The subs blends perfectly with the BX6...my room is around 1600 cubic feet...i am a little more on music then movies but for movies i would like ported sub for a little more shaking . I am just on the fence if i will sell my 2xSB12 and get on PB12 PLUS...but i think for now i will keep this combination...i will see.
tommaazz is offline
post #10219 of 11895 Old 07-07-2014, 06:13 AM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
How do you like the BX1's as front height speakers? Do you think it was a waste or they are too much speaker for the job?
or
Do you feel they work perfectly for you? How much information are you getting from the front heights? Would you recommend the front height timbre matching to someone else setup
I'm in the process of adding some RX1's for front heights.
HAMP568 is offline
post #10220 of 11895 Old 07-07-2014, 06:51 AM
tommaazz's Avatar
Quoted: 229 Post(s)
Liked: 127
or
Hi...i was on the fence buying them or not for almost half a year...and then after a numerous thread i read i have decided to buy them...and i would say i am not sorry for buying them...i listen to neo:x with height processing as i found that neo:x gave more use of them as audyssey dsx or dolby plZ but that also depends on movie, music...sometimes with audyssey the movies sounds odd because also the speech is coming from height channels sometimes not...for now i am listening to neo:x but i will experiment futher. I can almost instantly hear if they are not in use so i would say that there is a difference between having heights or not..and i mind you i dont have perfect location for them as they are only around 0,4 m above front speakers but the sound is fuller in front..i like it so if you have a space for them go for it
tommaazz is offline
post #10221 of 11895 Old 07-07-2014, 07:19 AM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
Thanks for the input. I've been on the fence for much longer then you. while I thought about doing it, I bought a few things I may need to install them, and now I am ready to try it out.
I do not have a high ceiling so I suppose you can say, mine won't have proper placement either.
HAMP568 is offline
post #10222 of 11895 Old 07-07-2014, 07:34 AM
tommaazz's Avatar
Quoted: 229 Post(s)
Liked: 127
Attachment 151209
WOW nice setup are those pb13 ultra? If i had a space i would have one but i am a few cm short .
tommaazz is offline
post #10223 of 11895 Old 07-07-2014, 09:06 AM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
Thank you!
No, I wish they were the PB13 Ultras... lol
They are the PB12Pluses, and I have 2sets of RXFX's, and I love those di-pole speakers.
I hope I have them all installed before the weekend is out. I am looking forward to a nice 9channel setup.
HAMP568 is offline
post #10224 of 11895 Old 07-07-2014, 09:07 AM
ambesolman's Avatar
Liked: 915
I'm using some 10+y/o JBL sats for heights since I had them lying around. Gotta say, I feel like wides add more to the experience. Ymmv.
post #10225 of 11895 Old 07-07-2014, 09:39 AM
tommaazz's Avatar
Quoted: 229 Post(s)
Liked: 127
Thank you!
I thought they were PB12+ but i wasnt 100% sure . I wish i had a few cm of place to put a PB12+ on the left or right side...if i exchange bx6 for bx2 that would be possibility . I had a ported sub before mirage omni S12, very very nice sub but it seemd boomy in my medium sized room so i exchanged it for 2xSB12 and what a difference but a little short of impact. I like the sound very much but i think i miss a little more impact and shaking when watching movie. I had one SB before but it wasnt enough for my taste so i purchased another one and it was better. They shake but not that much. I was thinking 2xpb1000 (should be plenty for my room) or 1xpb2000 (about same as 2xpb1000) or my favourite PB12+ (that is what i want, nice to have a little headroom ) i didnt know that i am such a basshead LOL . How you like your PB+ s ?
tommaazz is offline
post #10226 of 11895 Old 07-07-2014, 09:42 AM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
How far apart are your main speakers?
How far apart are your wide set?
How far away is the MLP from the left/right main speakers?
HAMP568 is offline
post #10227 of 11895 Old 07-07-2014, 09:54 AM
ambesolman's Avatar
Liked: 915
7.5'
20'
~11'
post #10228 of 11895 Old 07-07-2014, 10:06 AM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
I love'em
I no longer describe how they sound, but how they feel. I am amazed at time that they seem to shake the floor, but that isn't possible since they are sitting on concrete.
HAMP568 is offline
post #10229 of 11895 Old 07-07-2014, 10:11 AM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
7.5'
20'
~11'
That type of spacing wouldn't work for me. My room is 13ft wide, and I sit 9ft from the screen. I do have my speakers 9ft apart.
I don't think wide would work for me even if I had the room, 20ft apart is just too much unneeded space to me.
HAMP568 is offline
post #10230 of 11895 Old 07-07-2014, 10:23 AM
ambesolman's Avatar
Liked: 915
You don't need 20'. My setup is on the long wall of my room. The only reason mine are so far apart is due to the French doors. You could put them near the wall and maybe a little closer to you to create more of a circle around you. I just work with what I got.
Here's a pic, ignore the mess. We're prepping for out of town guests
Reply Speakers
cp-wt380idc , Denon Avr 3806 Av Receiver , Denon Blu Ray Dvd Cd Player , Jl Audio Brand , Monitor Audio , Nad , Parasound , Receivers Amplifiers , Sunfire , Toshiba
