Monitor Audio Owners Thread - Page 342 - AVS Forum | Home Theater Discussions And Reviews
 282Likes
post #10231 of 12105 Old 07-07-2014, 11:24 AM
jhurricane30's Avatar
Originally Posted by ambesolman View Post
Your room is roughly the same size as mine. The vtf3 mk4 is on sale right now for $639, but not sure how long the sale lasts, just call. They're really nice and can help with any questions.
http://www.hsuresearch.com/products/vtf-3mk4.html
The bx1 would do well for rears. $379/pr
Center is $299
http://saturdayaudio.com
That should get you right at your budget. If you call they may give a discount ordering multiple speakers. Never hurts to ask
If you like to build stuff, you could always DIY a sub for a little cheaper. I'm about to give it a try myself just to see if I can do it.
Sent using Tapatalk since the mobile version is still
Yep, going with the BX Center and BX1 (rear), love the look and reviews.
How do you like the vtf3 mk4? Good combo sub (music/movie)? I'm still learning, but the site seemed to have it listed as both sealed and ported. I know this should probably go under a different thread.
lol
Thanks!!
jhurricane30 is offline
post #10232 of 12105 Old 07-07-2014, 12:03 PM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
You don't need 20'. My setup is on the long wall of my room. The only reason mine are so far apart is due to the French doors. You could put them near the wall and maybe a little closer to you to create more of a circle around you. I just work with what I got.
Here's a pic, ignore the mess. We're prepping for out of town guests
Sent using Tapatalk since the mobile version is still 👎
Ok!!!
In your room, I can see where wide would work. Mine is 13ft wide, and I'm using 9ft of that for the front three. I don't think my ceiling will give me the required distance for heights either.... lol
HAMP568 is offline
post #10233 of 12105 Old 07-07-2014, 12:06 PM
ambesolman's Avatar
Quoted: 1098 Post(s)
Liked: 921
lol
Thanks!!
I actually have the older version, the mk3, and is my first real sub. If ding it to my setup has been totally transformative for everything played through it. Action movies sound huge! War of the Worlds when the pods emerge and the lightning scene before it are still my favorite demo clips. It sits next to my side of the sofa (upside down, which is perfectly fine per hsu) with the driver firing toward me. It gives a tremendous tactile sensation that really ups the enjoyment level on bass heavy material.
It's just as great with music, never bloated. It's accurate, smooth and pretty tight. I listen to a lot of rock, bluegrass, metal, acoustic, some rap/r&b, electronic, etc. A pretty wide variety. Sounds great on all of it at high or low volume.
The mk4 is more versatile since, like you said, it can run in sealed OR ported so you can play with that and the other different settings to see what sounds best for you. It blends really well with my rx8s and can't recommend it enough. Excellent customer service as well
jhurricane30 likes this.
ambesolman is online now
post #10234 of 12105 Old 07-10-2014, 02:55 PM
Fjodor2000's Avatar
Quoted: 409 Post(s)
Liked: 59
Hi,
I've got Monitor Audio speakers in my surround system, and I'm looking for advise on what subwoofer to add to the setup.
I've got the following setup:
Front Speakers: Monitor Audio Silver 1
Center Speaker: Monitor Audio Silver Centre
Surround Speakers: Monitor Audio Radius 90
A/V Receiver: Marantz SR-7008
I just got the stuff, and really like it. It is improving for every initial hour used. They say it requires ~60 hours burn in time, so I'm looking forward to further improvements.
But I think I'll be needing a subwoofer to complement it. I think the Monitor Audio Silver W12 is too expensive. So I wonder what other subwoofers work well with Monitor Audio speakers? I'm prioritizing tight, controlled and detailed bass before absolutely lowest frequency response.
So I'd appreciate any advise and opinion on what would be a suitable subwoofer? Budget is around $400-700 (unless you think that is unreasonably low?).
Fjodor2000 is offline
post #10235 of 12105 Old 07-10-2014, 09:05 PM
ambesolman's Avatar
Liked: 921
Originally Posted by Fjodor2000 View Post
Hi,
I love my hsu vtf 3, sounds great with my rx8s
post #10236 of 12105 Old 07-11-2014, 12:04 PM
dac-906's Avatar
Quoted: 12 Post(s)
Originally Posted by dac-906 View Post
FS: Silver RX8
I'm selling my, little over year and a half old, MA Silver RX8 for $1,150.00 (free shipping within CONUS). I'm the original owner and they're in excellent condition (like new). I really took good care of them they are packed in their original boxes.
Here are the specs:
System Format: 3 Way
Frequency Response: 32Hz - 35kHz
Sensitivity (1W@1M): 90dB
Nominal Impedance: 4 Ohms
Maximum SPL (dBA): 116.2
Power Handling (RMS): 175W
Recommended Amplifier Requirements (RMS): 50 - 175W
Bass Alignment: Bass reflex.
Twin HiVe®II port System
Tweeter Crossover Frequency: LF/MF: 300Hz
MF/HF: 2.2 kHz
Drive Unit Complement: 2 x 6" RST® Bass drivers.
1 x 6" RST® Bass/Mid driver.
1 x 1" (25mm) C-CAM® gold dome tweeter
Product External Dimensions:
(H x W x D)
inc. plinth & feet 960 x 275 x 388 mm (37 13/16 x 10 13/16 x 15 1/4 inch)
Individual Weight: 21.76 Kg (47.88 lb)
Bump
Sources ---> Clearaudio Concept TT, Onkyo CDP, MacBook Pro/Audirvana
Pre/DAC & Power Amp ---> Emotiva XPS-1 Phono Stage, Emotiva Stealth DC-1 Pre/DAC, Emotiva XPA-1L Monos
Speaker ---> Dynaudio Excite X34
Cable ---> Audioquest Type 8 Speaker Cable, Emotiva Interconnect Cables
Headphone ----> Onkyo ES-CTI300 (SS)
dac-906 is offline
post #10237 of 12105 Old 07-11-2014, 04:17 PM
Fjodor2000's Avatar
Quoted: 409 Post(s)
Liked: 59
Ok, thanks! I'll check them out. Looking at the frequency response curve they do seem to go very low though, see http://www.hsuresearch.com/products/vtf-3mk4.html. Is the bass still tight, controlled an detailed? Because I'd like to prioritize that before absolutely lowest frequency response. In fact I should probably avoid absolutely lowest frequency response to not upset the neighbors too.
Also, I'd like to have some more alternatives to compare with as well if possible. So are there any other subwoofers fitting my requirements that would work well With Monitory Audio? How about the SVS SB-1000 for example that I've heard some mention on the forum?
post #10238 of 12105 Old 07-11-2014, 05:10 PM
ambesolman's Avatar
Liked: 921
Others may be able to chime in with their experiences with other subs, I've only owned the hsu.
Tight, controlled and detailed? I'd vote yes. Everything I've run through it sounds great. I heard crappy bass from my old JBL 8", the hsu is nothing like that.
Just because it will play low, 1) doesn't mean you have to play material with low content 2) doesn't mean it doesn't play the higher frequencies just as well and 3) it's better to have the ability (especially with movies) and not use it than need/want what you can't have or produce.
post #10239 of 12105 Old 07-11-2014, 06:31 PM
tidwelr1's Avatar
Quoted: 263 Post(s)
Liked: 73
I tried the pb-1000 which is ported, but I don't think it matters in terms of it versus the sealed version. I sent it back. Not enough output for my space. ...3000 cubic ft. Not sure what your space is like, but most would say to get a 12 inch sub. I tend to like my vtf 3mk4 sealed instead of ported. I also think my next sub will be a much more powerful sealed sub like the svs sb13 ultra or something similar.
tidwelr1 is online now
post #10240 of 12105 Old 07-12-2014, 01:11 AM
Fjodor2000's Avatar
Quoted: 409 Post(s)
Liked: 59
My room is a little smaller, 2000 cubic ft. So do you think the SVS SB-1000 might work then?
Also, when you said that the PB-1000 did not have enough output for your room, how was that noticed? Did you e.g. not reach sufficient sound volume levels, was the "impact" too low, or something else? Finally, what was the impression of the SVS PB-1000 apart from that. I.e. did it sound good otherwise, so you can recommend it as a sub in a smaller room?
post #10241 of 12105 Old 07-12-2014, 07:14 AM
ambesolman's Avatar
Liked: 921
Better to have too much and be able to turn it down than not have enough
post #10242 of 12105 Old 07-12-2014, 11:27 AM
tidwelr1's Avatar
Quoted: 263 Post(s)
Liked: 73
not enough output was based on actually using it for both music and movies, and then not feeling the impact or level of effect that I wanted. You can turn up the gain on sb-1000, but I don't like the idea of running it at 3/4 Max gain. You can always try it and send it back if you don't like it. Sealed subwoofers require more amps for decent output compared to a ported subwoofer. I really don't think the sb-1000 will provide enough impact when watching movies. The smaller the box, the more amps you need for decent output, slam, effect, whatever you want to call it. I think you'll find this to be the case.
post #10243 of 12105 Old 07-13-2014, 03:59 AM
Fjodor2000's Avatar
Quoted: 409 Post(s)
Liked: 59
Ok I see. Well, I guess it depends on what you're looking for. In my case I'm not looking for something that rattles the sofa and gives me a punch in the chest. I'm primarily looking for a subwoofer that can add the frequencies not present in the Silver 1 & Silver Center speakers that I have. I'm assuming that the SB-1000 should be able to help with that at least.
Also, in my case I'm factoring in size too, because I'd like it to blend into my living room being noticed as little as possible. If I should be picky, I'd also like the subwoofer to be available in high gloss white since all my other speakers have that finish. That does limit the amount of subwoofer choices quite a bit though!
post #10244 of 12105 Old 07-13-2014, 09:46 AM
tidwelr1's Avatar
Quoted: 263 Post(s)
Liked: 73
The vtf 3 doesn't rattle our couch and you can't feel it in your chest. I guess what I meant to say is that it just fills in the gap much better than the ps-1000 for my setup. Again, they have a free return policy so you can try it and see what you think. Lastly, most in the subwoofer forum would guide you to a 12 inch sub. I like the hsu subs over svs in the < $ 800 price range bc of their flexibility in setup. You can go ported or not ported. You can adjust the q control which affects how clean the bass is for any level of gain you set the sub for. Hsu doesn't provide for free returns though, and I don't think they offer white gloss as a finish.
post #10245 of 12105 Old 07-14-2014, 01:45 PM
zonzi's Avatar
hello
I have RX center, RX6 front, RXW12 and RX1 for surround. RX1 want to change to RX FX, but now I do not get anywhere this series, becouse new one come out. The question is can I mix the old version (RX Center, RX6 and RX W12) that runs on 6 ohms with the latest Silver FX that operating at 8 ohms? I use Yamaha RX-V3900 reciver which now is set to be connected 6 ohm speakers.
zonzi is offline
post #10246 of 12105 Old 07-14-2014, 02:04 PM
ambesolman's Avatar
Liked: 921
Originally Posted by zonzi View Post
hello
You should be fine. If you have rosenut rx1s and want to get rid of a pair let me know
post #10247 of 12105 Old 07-14-2014, 10:11 PM
zonzi's Avatar
And what better to set yamaha to 6 ohms or 8 ohms?
I'm sorry but the speakers are already sold.
zonzi is offline
post #10248 of 12105 Old 07-15-2014, 09:36 PM
ambesolman's Avatar
Liked: 921
I'd just leave it at 6ohms but either setting should be fine.
post #10249 of 12105 Old 07-20-2014, 05:34 AM
jdjaye's Avatar
Quoted: 17 Post(s)
I love my Monitor Audio Silver Rx-8s, but we are merging households and I need the space. They are walnut color, perfect condition, 1.5 years old. I have the original boxes, so Msg me if you are interested.
jdjaye is offline
post #10250 of 12105 Old 07-26-2014, 11:18 PM
dac-906's Avatar
Quoted: 12 Post(s)
fs: Silver rx8
i'm selling my, little over year and a half old, ma silver rx8 for $1,150.00 (free shipping within conus). I'm the original owner and they're in excellent condition (like new). I really took good care of them they are packed in their original boxes.
Here are the specs:
System format: 3 way
frequency response: 32hz - 35khz
sensitivity (1w@1m): 90db
nominal impedance: 4 ohms
maximum spl (dba): 116.2
power handling (rms): 175w
recommended amplifier requirements (rms): 50 - 175w
bass alignment: Bass reflex.
Twin hive®ii port system
tweeter crossover frequency: Lf/mf: 300hz
mf/hf: 2.2 khz
drive unit complement: 2 x 6" rst® bass drivers.
1 x 6" rst® bass/mid driver.
1 x 1" (25mm) c-cam® gold dome tweeter
product external dimensions:
(h x w x d)
inc. Plinth & feet 960 x 275 x 388 mm (37 13/16 x 10 13/16 x 15 1/4 inch)
individual weight: 21.76 kg (47.88 lb)
*** sold ***
ambesolman likes this.
dac-906 is offline
post #10251 of 12105 Old 07-27-2014, 08:52 PM
Liked: 0
Centre speaker for PL300s
Hi all. I'm a proud owner of new(ish) black PL300s (replaced B&W PM1s) that I got a great deal on. I am using them for both music and AV and was hoping to move away from needing a centre speaker. However our seating is spread about a bit (for AV) and hearing voice dominate out of L or R when not sitting in the 'sweet spot' is driving me nuts. I am using an Oppo 105D with a Perreaux E250i for the PL300s and the owner of Perreaux has offered me a wonderful deal on an E150i for driving a centre.
I would love to get a PLC 350 for the centre. What are they like and how do they match with the PL300s? Also is there another Centre that would work with the PL300s just as well (or very close) but in a less expensive price bracket? It's just that the PLC350 is really quite expensive in NZ and more than I paid for the pair of PL300s. Also any cable recommendations? I'm currently using MIT ATV2s for FL and FR but don't have any for the pending centre, whatever that ends up being. Thanks in advance.
Colville12 is offline
post #10252 of 12105 Old 07-28-2014, 07:26 AM
wowzors's Avatar
Should be receiving in my Silver 8's in high gloss white today
wowzors is offline
post #10253 of 12105 Old 07-28-2014, 08:50 AM
ambesolman's Avatar
Liked: 921
Whether or not you'll be able to tell the difference in sound quality with a mismatched center is subjective. Though I have a matching center for my RX8s, I can't use it now b/c it doesn't fit in the entertainment center. Instead I'm using an old JBL center without issue. Better ears than mine may be able to tell, but I'd be pretty hard pressed to hear it doesn't match my mains. YMMV
If you wanted to try it, I'd look at the gxc350.
post #10254 of 12105 Old 07-28-2014, 10:42 AM
bkeeler10's Avatar
Quoted: 339 Post(s)
Liked: 214
Cool, let us know what you think. What speaker are you coming from?
bkeeler10 is offline
post #10255 of 12105 Old 07-28-2014, 10:58 AM
wowzors's Avatar
I am coming from some B&W 600 series bookshelfs. They are around 10 years old I think, cant really remember when i bought them.
wowzors is offline
post #10256 of 12105 Old 07-28-2014, 06:28 PM
wowzors's Avatar
Real quick question again. I bought the silver 8's and silver center in high gloss white. I have heard the sub for these isn't that great, are there any good sub's that would match these speakers?
wowzors is offline
post #10257 of 12105 Old 07-28-2014, 09:47 PM
ambesolman's Avatar
Liked: 921
My hsu vtf3 is a great match to my rx8s. Check out hsu, svs, power sound, etc.
post #10258 of 12105 Old 07-29-2014, 05:58 AM
ohrbrcko's Avatar
Quoted: 38 Post(s)
Liked: 38
I recently bought a SVS PB-2000 for my Silver 10s. It is a rather large subwoofer. The sealed version is much smaller. I have had an HSU but decided to go with SVS as they provide great customer service. Pretty good return policy too. Check them out.
ohrbrcko is offline
post #10259 of 12105 Old 07-29-2014, 11:10 AM
bkeeler10's Avatar
Quoted: 339 Post(s)
Liked: 214
Acoustically, the subs mentioned will be great, and I might add Rythmik to the list.
I think, perhaps, you were also referring to matching your speakers aesthetically. I am not aware of the aforementioned companies offering their subs in gloss white . . .
post #10260 of 12105 Old 07-29-2014, 11:56 PM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
If you are talking about a sub in gloss white, then SVS does have them.
HAMP568 is offline
Reply Speakers
cp-wt380idc , Denon Avr 3806 Av Receiver , Denon Blu Ray Dvd Cd Player , Jl Audio Brand , Monitor Audio , Nad , Parasound , Receivers Amplifiers , Sunfire , Toshiba
