Monitor Audio Owners Thread - Page 352 - AVS | Home Theater Discussions And Reviews
 25Likes
post #10531 of 10559 Unread 02-23-2015, 09:14 PM
Kal Rubinson's Avatar
Quoted: 188 Post(s)
Liked: 191
Originally Posted by Grendel007 View Post
I realise that all speakers should be placed within the distance you write about. However, I heard that this particular model silver 8 is abnormally sensitive to its placement to back wall.
Not particularly.
This is mainly because it gives quite a lot of low end .
Good but not more than some others of similar size.
It is also claimed that silver 8 is recommended mostly to about 30m2 or larger rooms.
It did fine in my 25m2 room.
So maybe someone who has had them can say whether it is true or not.
OK.
Grendel007 likes this.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #10532 of 10559 Unread 02-23-2015, 10:05 PM
calyco's Avatar
Still love my RX6, a bit bright at times but phenomenal with reference material. I cant believe I am looking at the gold line now *looks at wallet*. Any thoughts on GX200 vs PL200, improvement over RX6? TIA
calyco is offline
post #10533 of 10559 Unread 02-23-2015, 11:27 PM
Quoted: 26 Post(s)
Liked: 2
My friend will upgrade his RX6 to the new Gold 300 -no more GX- next month, so I can give some feedback later.
w1000i is offline
post #10534 of 10559 Unread 02-24-2015, 07:55 AM
Grendel007's Avatar
Quoted: 21 Post(s)
Originally Posted by Kal Rubinson View Post
Not particularly.
OK.
Well, I must admit that I might have made a wrong assumption. I read comments about the direct predecessor of Silver 8. It was model RX8 which was characterised as bass heavy and not for smaller rooms. I thought that Silver 8 was quite similar in this aspect. I don't know but maybe it was because RX8 had only one rear bass port. Silver 8 has two - maybe it allows for better bass control?
Do You think Silver 8 would be appropriate for rooms 18-20m2?
Would You consider smaller soundstage and spatality as the only con in Silver 8?
How would You compare these two factors in reference to Focal Aria 936?
I will be very grateful for your answer.
Grendel007 is online now
post #10535 of 10559 Unread 02-24-2015, 08:02 AM
Quoted: 188 Post(s)
Liked: 191
I have no aquaintance with the Aria 936 and most of what I have to say about the S8 is here along with measurements: http://www.stereophile.com/content/m...-8-loudspeaker
Kal Rubinson
post #10536 of 10559 Unread 02-24-2015, 12:25 PM
SweElite's Avatar
Thanks for the info. However it sounds really stupid. Why would they use better filters in the 200 compared to the 300 ?
Originally Posted by w1000i View Post
Pl200 was better than pl300 because monitor audio used a better filters in pl200; however, the old gold GX it has a tweeter with lower distortion under 4000 compare to the PL and the new Gold has an even better tweeter and the other drivers have the same technology as the platinum.
so it is all come to crossover-network if it is the same or better and I believe the new gold is a monster .
SweElite is online now
post #10537 of 10559 Unread 02-24-2015, 04:17 PM
WestCoastD's Avatar
Quoted: 76 Post(s)
Liked: 41
Not particularly.
OK.
Are you actually using Silver 8's in your set-up these days Kal?
WestCoastD is offline
post #10538 of 10559 Unread 02-24-2015, 04:41 PM
Quoted: 188 Post(s)
Liked: 191
Nope. I am considering them for the 2nd system but I have not pulled the trigger.
Kal Rubinson
post #10539 of 10559 Unread 02-24-2015, 06:09 PM
ambesolman's Avatar
Quoted: 571 Post(s)
Liked: 526
What's in your primary system?
Sent using Tapatalk since the mobile version is still
ambesolman is online now
post #10540 of 10559 Unread 02-24-2015, 08:01 PM
Quoted: 188 Post(s)
Liked: 191
L/C/R = B&W 800Diamonds.
Kal Rubinson
post #10541 of 10559 Unread 02-24-2015, 09:03 PM
ambesolman's Avatar
Quoted: 571 Post(s)
Liked: 526
Nice. Just looking for something different from b&w?
post #10542 of 10559 Unread 02-24-2015, 09:12 PM
Quoted: 188 Post(s)
Liked: 191
The B&W is in my apartment in NYC and the other system is in my house in CT. One is more elaborate and expensive than the other and, by design, I do not choose the same brand of equipment for the two systems, except for the Oppos.
Kal Rubinson
post #10543 of 10559 Unread 02-24-2015, 09:40 PM
ambesolman's Avatar
Quoted: 571 Post(s)
Liked: 526
Makes sense to me. So what other three way towers in the $2k range are you considering?
post #10544 of 10559 Unread 02-25-2015, 03:40 AM
Quoted: 26 Post(s)
Liked: 2
pl200 introduce latter after pl300
w1000i is offline
post #10545 of 10559 Unread 02-25-2015, 09:16 AM
Quoted: 188 Post(s)
Liked: 191
Just follow my reviews. This has been an ongoing project.
ambesolman and Shadowed like this.
Kal Rubinson
post #10546 of 10559 Unread 02-25-2015, 02:07 PM
Akil3x's Avatar
Any thoughts between silver 8 and 10???
I see little feedback about silver 10 and silver 8 already a lot of people already bought them, there is some reason in particulary??
Akil3x is offline
post #10547 of 10559 Unread 02-25-2015, 02:53 PM
Shadowed's Avatar
Quoted: 56 Post(s)
Liked: 34
The silver 10s are crisp and clean with smooth bass and punchy midbass. They easily fill 24x24x9ft room. IMO they are too much speaker for rooms half the size.
http://www.theabsolutesound.com/arti...dio-silver-10/
Shadowed is offline
post #10548 of 10559 Unread 02-26-2015, 04:39 AM
Akil3x's Avatar
Do you already ear silver 8???
Akil3x is offline
post #10549 of 10559 Unread 02-26-2015, 06:48 AM
ohrbrcko's Avatar
The Silver 10s, 8s and all the rest of the line are exceptionally speakers which has gotten great reviews. Also, this is the 4th or 5th generation of the line. Meaning that, MA continues to make improvements with each new release. There is no buyers remorse with MA Silvers. I replaced my RS6s with the 10s. I am very please with them. The only thing I would criticize is that they are nothing special to look at-not a lot of personality in that regard.
ohrbrcko is online now
post #10550 of 10559 Unread 02-27-2015, 08:39 AM
dchalfont's Avatar
Quoted: 38 Post(s)
Can someone explain how the Gold 350 centre is the same weight as the Gold 100, when the cabinet is about 60% bigger, and it has an addition 6.5" driver and a midrange driver which the Gold 100 lacks.
9.9kg each...I don't get it. Small centre speakers from other manufacturers weight more, like the Paradigm monitor centre 3, 25% heavier and 50% smaller.
dchalfont is online now
post #10551 of 10559 Unread 02-27-2015, 08:50 PM
beaveav's Avatar
Quoted: 170 Post(s)
Liked: 370
Somebody asked the same question here a few months ago. The answer is that they don't weigh the same. It's a mistake in their brochures/website/etc.
For every new thing I learn, I forget two things I used to know.
beaveav is offline
post #10552 of 10559 Unread 02-28-2015, 06:04 AM
dchalfont's Avatar
Quoted: 38 Post(s)
Thanks for the response, I thought that must be the case, being actly 9.9kg a piece seemed weird.
They made the same mistake in both the old and new gold series specs, haha.
post #10553 of 10559 Unread Yesterday, 04:24 PM
Liked: 0
Amplifier Advice for Monitor Audio Silver 10s? My system right now will consist of a MA CP In Wall Center and Surrounds and Silver 10s for front channel speakers. I have a Yamaha RX-A840 receiver to power the system, but I'm thinking of getting an external amp to power the Silver 10s or possibly the front 3.
I'm thinking of the :
  • Emotiva UPA-200 $299 (200 Watts @ 4 Ohms)
  • 2X Emotiva XPA-100 2X $399 (400W @ 4 Ohms)
  • XPA-3 $799 (330W @ 4 Ohms into 3 channels)
Does anyone own that Silver 10s that would like to comment on how much power is needed to drive them well. I know the MA spec say 80W-200W recommended power, because of that I'm leaning to using the UPA-200.
Daniel Smith 2 is online now
post #10554 of 10559 Unread Yesterday, 04:25 PM
Liked: 0
Out of curiosity what are you driving your Silver 10s with?
post #10555 of 10559 Unread Yesterday, 04:32 PM
Liked: 2
I'm in the club now.
Stuart Anderson is online now
post #10556 of 10559 Unread Yesterday, 04:52 PM
llep64's Avatar
guys, what would be a fair price for a pair of GR60s?
llep64 is offline
post #10557 of 10559 Unread Yesterday, 05:43 PM
ambesolman's Avatar
Quoted: 571 Post(s)
Liked: 526
The upa-200 works great on my rx8s. You only use a handfull of watts most of the time anyway, especially if crossing to a sub.
post #10558 of 10559 Unread Today, 07:34 AM
ohrbrcko's Avatar
I am using a Parasound A-21 2 Channel amp with my AVR (Yamaha RX-V1030) as a pre-amp. Now, truth in advertising, I have been in touch with a dealer who sells the French made, Triangle Signature Delta speakers. They are nearly $8K pair. The reviews on them, which are many, are all good. I haven't made any final decisions yet. But they are on my radar screen as the next step in the evolution of my audio system. I am also looking one or two other brands at or near that same price range. Somehow I need to tell the kids that there will be no inheritance for them. :-)
post #10559 of 10559 Unread Today, 10:10 AM
Liked: 0
Thanks for the information. I will be running these full-range but will have a single subwoofer on the LFE Channel. The Yamaha receiver only has a single crossover point, all the other channels will be crossed over at 80Hz and the 10s will be run full range.
I'm going to start with the UPA-200. I figure if I feel like I need more power later I can always sell or re-purpose that amp easily and upgrade later.
Reply Speakers
Monitor Audio , Denon Avr 3806 Av Receiver , Receivers Amplifiers , Nad , Jl Audio Brand , Parasound , Sunfire , Denon Blu Ray Dvd Cd Player , Toshiba
