Monitor Audio Owners Thread - Page 388 - AVS Forum | Home Theater Discussions And Reviews
 204Likes
post #11611 of 11623 Old 11-30-2016, 03:23 PM
danthony1's Avatar
Quoted: 78 Post(s)
Originally Posted by jjkelly84 View Post
Soooooooo no one can a get me in the right direction then?
Take a look at he classifieds forum, audiogon, eBay, etc. I'm sure you'll find data points whereby can set your price.
danthony1 is online now
post #11612 of 11623 Old 11-30-2016, 09:45 PM
ambesolman's Avatar
Quoted: 1074 Post(s)
Liked: 892
I can tell you what I've paid for my used rosenut setup over the past few years...
RX8 + rxc: 1250 (GREAT deal)
2 pr of rx1: 335 & 320 (pairs bought separately)
Plus shipping
ambesolman is offline
post #11613 of 11623 Old 12-02-2016, 04:11 PM
Liked: 0
My new Gold W15 sub will not turn on
Originally Posted by AudioArchitect View Post
Everyone who is a proud Monitor Audio owner, I would love to hear about your systems, any question/concerns, rants, or raves. Thanks.
Hi, this is my first post on this forum, and my problem is a little embarrassing - I am not able to power up my Monitor Audio subwoofer (Gold W15). I bought it today, connected it carefully according to the instructions and turned on the power using the rocker switch. A red LED lit up on the back panel, like it is supposed to. I now should be able to turn the sub on by pushing the so-called encoder on the sub, or by pressing the stand by button on the remote. In both cases, the sub should go through a power cycle sequence, but nothing happens, except that when using the remote, a red light flickers on the control panel of the sub.
Could this be a sign that the fuse is blown? I have opened the little fuse 'drawer', but I have not managed (or tried very hard) to remove the fuses. I cannot tell which of the fuses is the spare, or if any of them is defective.
If anyone has a solution to this, I would be a happy man.
Earbones is offline
post #11614 of 11623 Unread 12-03-2016, 04:06 AM
Liked: 1
Originally Posted by ambesolman View Post
Have you a/b'd the two for comparison?
I have, but it's been two years now, back when I was looking for new speakers.
The new Silver 8's seemed like a clear upgrade compared to the RX8's. Im not talking about small, struggle-to-hear differences, but about tighter bass, clearer mids, smoother highs, better integration top-to-bottom. In short, a much better speaker in all respects.
I ended up with the Silver 10's though, because I liked their presentation better (the 8's sounded a bit forward by comparison) and because I have a large living room. Downside is, their bass sounds overwhelming with some recordings.
ambesolman likes this.
eyebee23 is offline
post #11615 of 11623 Unread 12-03-2016, 05:33 AM
Liked: 0
To answer my own question and to prevent anyone spending time on this, I am happy to say I solved the problem. Turns out I had connected the 12 Volt Trigger Input, so all I had to do was turn on my AV amplifier, then the sub powered up.
Earbones is offline
post #11616 of 11623 Unread 12-04-2016, 03:02 AM
Nosferatu's Avatar
Quoted: 116 Post(s)
Liked: 53
Keep them and jam them out. Back in my grad school days I used an Outlaw LFM-1 EX in a 2 bed / 2 bath apartment and just practiced common sense and didn't have much issue the 4 years I was in that living situation. Don't jam at stupid hours. Now my Seaton would likely cause foundation cracks!
Theater: Monitor Audio Platinum PL200/PL350C, Seaton Submerssive, 150" 3D Elite Screens +more
Living Room: Aperion Grand Verus, Outlaw LFM-1 EX, 70" Sharp Aquos +more
Stage 1 - Enthusiasm, Stage 2 - Realism
Stage 3 - Obsession, Stage 4 - Acceptance
...Which stage are you on?
Nosferatu is online now
post #11617 of 11623 Unread 12-07-2016, 09:58 AM
Liked: 1
Choosing a Center speaker C150 or C350
I have just entered the mid end of home theater, Marantz AV8802A, PM-11S3, and I added a pair of MA Gold 300 to the front, with the rest of the speakers being Q Acoustics 3000 series (moving my previous LR Q Acoustics 3050 to be Surround Speakers in my 7.4.4 setup). My room is mid size 240 sqf (22sqm) with a normal ceiling hight 8.4 feet (2,56m). I was quite cash strapped after my recent last binge, so I found a used power amp Sherwood A-965, which I think sounds good, for seven of the speakers. The MA Gold 300 are run on the PM-11S3. Front height speakers get juice from a Marantz PM-8003.
I´m not sure if it is wrong with my hearing but I honestly think the LCR is quite timber matched, which feels wierd because the Q Acoustics 3090 should differ from the 300's.
Next step is to upgrade the center, and I´m contemplating on C150 and C350. Since it´s still a living room and not a dedicated HT the furniture is not fully optimized except for the sweetspot. I have read that the C350, being a three way, has a better off axis response than the C150, which obviously is an MTM. It is however a bit more expensive, but more problematic, larger, and harder for me to accomodate in my AV furniture below the tv.
I also live in a flat with neighbors close by, so I refrain from playing at reference levels. My subwoofers are two SVS SB2000 and two Q Accoustics 7070Si, so I do not necessarily need to go truly low with the center.
In order to weigh my options, what could be the better choice for me, considering I will have these LCR's for the next 10 years.
Q Acoustics likes this.
Excommunication is offline
post #11618 of 11623 Unread 12-08-2016, 10:30 AM
ynos6600's Avatar
Hello. Could someone please tell me how would MA bronze 2 pair with Yamaha rx-381? Searching for budget receiver for Bronze 2 speakers.
Thank you very much.
http://m.usa.yamaha.com/products/aud...x/rx-v381.html
ynos6600 is offline
post #11619 of 11623 Unread 12-08-2016, 04:51 PM
NuDLP's Avatar
Quoted: 39 Post(s)
Heavily Evaluating First Monitor Audio Setup... Need Advice on Receiver Pairing
Hey everyone! Building a smaller HT in the main living area right now... doing a lot of listening and evaluating along the way and had the pleasure of hearing some Gold 50 bookshelves in Seattle and really liked them!
I currently own KEF and have owned AR, Klipsch and others over the years. My new home has a funky downstairs and I needed a sealed center channel and began researching. It quickly narrowed down to 2 choices- the new Monitor IW460X center paired with either Gold or Platinum 100 line L/R's and CP-CT380 IDC for surround duty. It'll be a 5.2 system and I already own the SVS Sb2000 to which I'll add a second sub.
I listed to the Gold 50's and spent 2hrs listening to a massive amount of music in an untreated room (they are just moving in still) sitting on an AV console (this is how mine will have to be, unfortunately, no stands due to build in bookshelves) and the speakers weren't even toed in or anything to improve image. I have to say, it excelled with voice and for a small bookshelf offered a lot of weight to the voicing. It also had a magnificent top end where those tweeters could shine. I did hit one track that felt like murder to my ears though - Louis Armstrong La Vie en Rose... that trumpet was shrill but the Golds were hooked up to a Marantz NR1600 series with NO EQ and I'm wondering if that, and the hard floor and untreated walls could have lent to the track sounding so difficult. It was really the only one that made my wife and I look at each other, turn down the volume and find a new track... Out of say, 100 tracks sampled throughout the 2hr period.
I'm thinking of pairing them with either an Anthem MRX 720 OR the new NAD T777 V3 that drops next month with Dirac Live RC and BlueSound wireless. My listening is split about 50/50 between 2 channel music - with help from the Sub so really 2.1 - and Blu Ray discs.
I have two major questions for the informed here:
1- Do you believe the Gold's exuberant and capable tweeters would be tamed with EQ using one of the receivers noted above? My room is NOT heavily treated but I have a large soft carpet, soft blinds on one long sidewall and soon I will fit an acoustic panel on the other early reflection point.
2- Does anyone currently run a similar set up with Anthem or NAD paired with the Gold series bookshelves? What is your true and honest (hopefully unbiased) opinion? I'd like to know if there is anything of note that would be reported as less than excellent? And anything that maybe you didn't know about the speakers before connecting to either of these AVRs.
Lastly, I am evaluating the Focal Electra series for comparison though thus far I've only listened to them through a $10,000 Naim system. Initial impressions on that system just after the 2hrs with the Monitors... it wasn't nearly as engaging. The imaging was INCREDIBLE but there wasn't a panache or a zest from the speakers. Voices were perfect more or less but instruments seemed to take such a back seat that it just felt like listening to borderline acapella... I will listen to them again next Friday on some NAD and Anthem equipment but probably won't get the chance to do so with Monitor as there aren't dealers with both on hand in the area... for many hundreds of miles.
NuDLP is online now
post #11620 of 11623 Unread Yesterday, 09:01 AM
Shadowed's Avatar
Quoted: 636 Post(s)
Liked: 536
Yes... they work very well together. I have heard the bronze 2 with both the RS202 bluetooth receiver and the RXV381. All work very well together , the 381 has the added benefit of room correction and future expansion to 5.1.
Shadowed is online now
post #11621 of 11623 Unread Yesterday, 07:32 PM
Pacodutaco's Avatar
Quoted: 278 Post(s)
Liked: 1374
The Bronze 2 will work nicely with any Yamaha, Marantz or NAD. I tried several combinations myself. I almost went with a Yamaha until I found the deal I got on my Marantz and opted for it.
Marantz PM5005 Integrated Amplifier | Marantz CD5005 Compact Disc Player | Monitor Audio Bronze BX2 Bookshelf
"My CD's don't earn interest...they play sweet music."
"Vinyl-free since 1983"
Pacodutaco is offline
post #11622 of 11623 Unread Today, 12:11 AM
Liked: 0
Any major retailer that carries the monitor audio bronze 2 so I could demo. I tried looking around but couldn't find any. I have shortlisted MA BRZ 2 and wharfedale 225 bookshelf's so far for my 2.0/2.1 setup. Any online stores that can help me avoid return shipping And restocking fee ? I found audio bronze on crutchfield, anybody has experience with that ?
curiousgally is offline
post #11623 of 11623 Unread Today, 09:08 AM
Nosferatu's Avatar
Quoted: 116 Post(s)
Liked: 53
There is a significant difference if you do not match the center channel in terms of having a fluid sound stage of objects in multi-audio tracks moving around. It'll appear that the sound is coming from "that speaker" versus the sound coming from "somewhere over there." Refer to what I told the gentleman below though:
At the end of the day all that matters is if your ears enjoy it then it doesn't matter what you have.
As for your other question of C150 vs C350 go for the C350. It'll better match the drivers to the other towers. I thought long and hard about doing the Platinum 350C since it's a monster (in size and sound) but I wanted the mid range and tweeter to perfectly match the PL 200 I use. Sure it's got a larger woofer but I cross them at 60Hz to my sub so it's a moot point. Plus, I didn't want to think "what-if" down the road if I didn't just shoot for the moon with my setup.
Question 1:
Tamed...sure.
Totally fixed...no.
You have to like the speaker first and not use an EQ to fix it. Personally I know it's there but I don't mind it. I demo'ed Silver 6, Gold 300, and then the Platinum 200 I own currently. They all have it a little bit (albeit the Silver the least since it doesn't use the ribbon driver). I wouldn't replace these speakers ever in my lifetime they sound that good. I wouldn't let one track sway you against what you find your ears enjoy.
Question 2:
Such a subjective question and referring back to your first question....find what your ears enjoy. Some here are so super analytical about things but at the end of the day it's an electrical signal that's moving a driver that your ears are picking up and ultimately your brain processes as audio bliss.
Reply Speakers
cp-wt380idc , Denon Avr 3806 Av Receiver , Denon Blu Ray Dvd Cd Player , Jl Audio Brand , Monitor Audio , Nad , Parasound , Receivers Amplifiers , Sunfire , Toshiba
