Klipsch owner thread - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 7542Likes
post #331 of 53884 Old 12-31-2006, 03:30 PM
Brahmzy's Avatar
Quoted: 479 Post(s)
Liked: 368
Definitely don't do the RC-52 with the RF-82's - I got to listen to the complete Klipsch Ref lineup in almost all combinations for hours and hours and hours. The RC-62 is defintely the best match for the RF-82's.
HTPC | 12TB NAS | Harmony Elite | DENON X4200W | Sony XBR75X940D
Philips BDP7501 | Klipsch RF7II,RC64II,CDT5650CII | SVS SB2000 x2
Brahmzy is offline
post #332 of 53884 Old 12-31-2006, 05:47 PM
fsullivan3's Avatar
Thanks to all. Now it's time to wheel and deal. I'll let you guys know when I've acquired the merchandise.
fsullivan3 is offline
post #333 of 53884 Old 01-02-2007, 10:12 PM
schuang74's Avatar
OK so I am on a strict budget given my Christmas spending bindge. I recently had to replace my old Sony All in one home theater system with a separate Onkyo 7.1 Reciever (TX-SR674) and a 5 disk Sony 1080i upconverting DVD player. I also had to replace the existing sub with a Klipsh Synergy III 10" sub. I decided to hang onto the sattilite speakers that came with my old Sony, since I figured that I could survive a while.....
Well after replacing my Sub i began to realize exactly how little range my sattilites captured. The sound didn't seem as full as I would have liked, while the sub added a lot of strenth on the lows, it just didn't sound smooth (sorry I am new at this so I don't know how else to explain it). The sound is either high, or very low.
Anyhow so I wanted to replace my L and R and center. So given I was happy with my sub I felt that I should try to match those speakers with the same brand and family. The C-2 and B-2 speakers seem to be what I need. Given that it fits my $400 budget are these a good choice?
I don't have enough to get the R series speakers, but It seemed to me that these were the cheap equivelent to the R series speakers. I would appreciate any input anyone can provide. I tried diggin through this thread and it seems like everyone is buying the Reference series so I was hoping someone could help a guy just starting out. Thanks in advanced.
schuang74 is offline
post #334 of 53884 Old 01-03-2007, 05:17 AM
Hdpro's Avatar
Reference 4 RF-82 Home Theater System here except I subed in the RT-12d sub for increased lows
Very happy with my Klipsch using them with a Denon 3806
Hdpro is offline
post #335 of 53884 Old 01-03-2007, 05:30 AM
Management's Avatar
Can some people comment on the Klipsch Reference line mated with a Pioneer Elite AVR? Also is it bad to get the discountinued models? It would be cheaper right?
Management is offline
post #336 of 53884 Old 01-03-2007, 05:49 AM
GoND's Avatar
Has anyone else tried the RF-83's with the RC-64? It seems like everyone except me went with the RF-82's and RC-62 instead.
Then again, mine are in a basement with plenty of room, and I have to admit the RC-64 is a somewhat large center channel to try to place, so that might be part of the reason.
GoND is offline
post #337 of 53884 Old 01-03-2007, 06:05 AM
Hdpro's Avatar
I'm actually thinking to move up to the RF-83s and RC 64 and have a buyer lined up for the RF-82s
How would RF 83s fare with a Denon 3806 (120W/ch) till I buy a more powerful amp. I'm thinking to go with Anthem MCA50 and use the Denon for a pre/pro but not right away.
Hdpro is offline
post #338 of 53884 Old 01-03-2007, 07:18 AM
DuffyBank's Avatar
management
I have a pair of rf-62's (bi-amped) and a rc-62 connected to an Elite 84 and I am very happy. Next is a pair of rb-61's for the back (waf prevents rf-82's and moving the 62's to the back).
I listen to 65/35 music/movies.
Waiting however for Pioneer to fix the LFE glitch.
DuffyBank is offline
post #339 of 53884 Old 01-03-2007, 07:50 AM
Management's Avatar
Originally Posted by DuffyBank View Post
management
I have a pair of rf-62's (bi-wired) and a rc-62 connected to an Elite 84 and I am very happy. Next is a pair of rb-61's for the back (waf prevents rf-82's and moving the 62's to the back).
LFE glitch? In the Elite 84? I have a Elite VSX 52 TX. Would I have a glitch?
Do people really use Floorstandings in the back? What makes that any good? How would one get the envelope that a bipole/dipole provides?
Also, are you using a power amp?
Also, is it bad to get the RF-5 and the other system models or are the RF-62's and teh rest better than those discontinued models?
post #340 of 53884 Old 01-03-2007, 10:30 AM
DuffyBank's Avatar
Not sure about the 52, but take a look in the elite 84 thread for info on the LFE problem.
CSR's at pioneer are telling people it is being worked on but no "official" word as yet.
No power amp, just the 84.
post #341 of 53884 Old 01-03-2007, 02:51 PM
Perch33's Avatar
The RF5/7 were very good speakers, but you would need to do a side by side comparison if possible to detect any differences. I believe the newer series have been smoothed out in the upper frequencies. I am still using my RF3II, with the RC7 and like this very much. I can not justify upgrading just because of a newer series.( Unless it is to the much bigger 83's)
Perch33 is offline
post #342 of 53884 Old 01-03-2007, 09:54 PM - Thread Starter
nitro1max1's Avatar
Quoted: 21 Post(s)
GoND, I have the RF-83 and RF-82. I did a side by side test between the two. There is large difference in sound between the two. To me the 83 are much better sound, but they are over twice the cost too. Just my 2 cents worth
nitro1max1 is offline
post #343 of 53884 Old 01-03-2007, 11:26 PM
Invisible hand's Avatar
Hi everyone
I just purchased a RF-62 package (can't wait to hook them up on Sunday).
I would really appreciate your input on mounting the Rear RS-52 speakers.
I have a not so perfect room where I will need to use a wall mount that can support 15lbs (6.8kgs) AND be able to rotate. My room is such that I will need to mount the right rear on the back SIDE wall as the rear of the room (where the speaker should go) leads to a hallway.
Any advice would be great!...and yes I've searched the forums, but I can't seem to find anything in relation the these speakers.
Invisible hand is offline
post #344 of 53884 Old 01-04-2007, 04:39 AM
Dallben's Avatar
I've been looking for mounts for the rs-52's for weeks now. Do you actually have a pair? I called klipsch, and the guy recommended BTech or Haropa mounts, but they don't seem to have anything that looks like it would work. The omnimounts would probably be perfect, but their 20lb mounts have 3/8-16 threaded rods and the rs-52 has 1/4-20 holes. If you have a pair, are the mounting holes on the top or bottom of the back? How far are they from the connectors?
I don't know why I don't just shut up and give up and lay down and die.
Dallben is offline
post #345 of 53884 Old 01-04-2007, 05:55 AM
petergaryr's Avatar
If this helps: I have RF5's as well as RB81's. Perhaps the new tweeter in the RB81 is a bit smoother, but to my ears not so dramatic that the RF5 needs replacement.
petergaryr is offline
post #346 of 53884 Old 01-04-2007, 06:39 AM
Management's Avatar
Ok, got back from J&R in Manhattan, NYC who has the new Reference model in a listening room. They also had the Polk and NHT set up and I listened to all of them. I really like the sound of the Reference model but for some reason heard a static sound but I also heard it on all the speakers so I do not think it was the speakers. It was hooked up to a Sony receiver. Are those considered bright or warm? The Klipsch model sounded the best though and my female friend (knows nothing about audio) thought so too. I might forget the Axioms and go this route. I can't listen to the Axioms  I actually decided against the Athena AS-F series as well because I couldn't get a chance to listen to them either. I'm really like auditioning speakers My lady friend was laughing at my diction. She though auditioning was quite a funny way of putting it.
post #347 of 53884 Old 01-04-2007, 07:36 AM
Brahmzy's Avatar
Quoted: 479 Post(s)
Liked: 368
I worked at Soundtrack / Ultimate for a few years, 5-6 years ago and did not like the SONY dound through the Klipsch's - I always went to the DENON's or second choice, Elite. The Yamaha sounded as bad as the SONY's to me. But, this is me, and that was 5 years ago.
Brahmzy is offline
post #348 of 53884 Old 01-04-2007, 09:42 AM
Management's Avatar
Yeah I really don't think I would purchase a SONY receiver lol. I have an Elite.
post #349 of 53884 Old 01-04-2007, 10:01 AM
GoND's Avatar
I found the same thing when it comes to sound quality, but, like you said, the price makes it tough. I got mine in a 50% off sale, so it made it worth it, but I agree that I'm not sure if they're worth twice the price of the RF-82's.
By the way, these are part of a new basement system I'm putting together, and still haven't purchased a receiver or pre/pro for them (waiting to see what shakes out at CES), and am right now using an old Denon 1600 from the late 90's that I had in a closet. You guys would be surprised how good that old 60 watt per channel Denon drives these speakers. I look forward to giving them some real beef to chew on in a few months.
GoND is offline
post #350 of 53884 Old 01-04-2007, 11:53 AM
WolfsBane's Avatar
Just a few inputs over the last few posts.
The RF-83 is the current top of the line floorstand speaker in the Reference line. It has a larger compression driver and tweeter than the RF-82. It is a little smoother. It also mates better with the woofer to which it is crossed over to. The RF-82 is the sweet spot in the floorstand reference line. It has a smaller compression driver. It is not as refined as the RF-83, but at the same time, you are paying quite a bit more money for the top of the line. It comes down to price vs performance, and how much you want to spend. The RF-82 has developed quite a following since it hit the market a few months ago.
There are lot's of owners that use floorstands all around, (for both mains and back speakers). The reason they do this is for better imaging when they are listening to music on 5.1 mode. You have to absorb the cost of the speakers, plus find adequate space for them... they are fairly large floorstands.
If you are looking for a cost effective althernative to the Reference line, then you are looking at the Synergy line. Lower cost materials, and not on the same level as the new Reference line, though they still will provide excellent value for the money.
Receiver wise, Klipsch users seem to like Dennon, Marantz, and Yamaha receivers. And there is quite a sector that also love tubes for two channel application.
Welcome... to the house of Rock and Jazz !
WolfsBane is offline
post #351 of 53884 Old 01-04-2007, 01:03 PM
Management's Avatar
Thank you very much and would appreciate as many 2 cents as I can get . BTW I read everywhere that one should stay way from Yamaha receivers if using Klipsch speakers. I read only one post that stated the samething about Denon. Everyone else likes it. Plus I do not want to get the Synergy Line because that is the Line I have read the most about being harsh and head piercing lol.
What about the 62s? Anyone has those and can comment?
post #352 of 53884 Old 01-04-2007, 01:43 PM
Quickster2's Avatar
I have an Elite VSX-74 on loan until my 4306 arrives. I can say that this set-up sounds excellent and have grown to admire the Pioneer's easy set-up and intuitive remote. My speakers are 7.1 RF-35 system with RW-12 sub. Been waiting on 4306 since October. Have Denon 3930CI to round out the package. Great DVD player!
Quickster2 is offline
post #353 of 53884 Old 01-05-2007, 11:03 AM
petergaryr's Avatar
I have tried Yamaha, Denon and Rotel with the Klipsch RF5s. I would rate the success in matching in exactly that order (again, in my opinion and in my listening room).
post #354 of 53884 Old 01-05-2007, 12:28 PM
JetJockey1's Avatar
Hi all, just thought I would throw in my thoughts.
Setup....
Dedicated HT 20'x15'
Klipsch RF83's, if you have the money and the room its the only way to go.
Klipsch RC62, First Klipsch speaker I bought, so good I had to have the 83's, sounds fantastic in movies and music, lots of bass too. Will upgrade to the RC64 later but no real need to right now, sounds amazing.
Mirage OM260 floorstanders for surrounds...excellent "surround" speaker..LOL.
Paradigm PW2200..friggin monster sub, tons of power and great for movies and music.
Mirage 10" sub backs up the PW2200 for a little smoother response.
Polk Rt10 for rear surrounds.
Yamaha RX-V2500 Avr...sounds excellent but did take some tweaking, 130wpc but drives the 83's with ease of course, adding the Anthem Mca50 amp shortly for some extra low end grunt.
Sanyo Z5 projector onto a 96" 16x9 screen....simply stunning PQ.
http://i123.photobucket.com/albums/o...1/IMG_0012.jpg
http://i123.photobucket.com/albums/o...1/IMG_0013.jpg
http://i123.photobucket.com/albums/o...1/IMG_0008.jpg
http://i123.photobucket.com/albums/o...1/IMG_0006.jpg
JetJockey1 is offline
post #355 of 53884 Old 01-05-2007, 02:27 PM
jswriter's Avatar
I was planning to buy a pair of HTD Level 3 bookshelf speakers to use as part of my PC's audio system, but they're backordered until March. The Klipsch RB-61 design seems a lot like the HTD L3, though the RB-61 is much more impressive looking. I'm thinking of getting a pair of cherry RB-61s, but can't find them anywhere in Atlanta. Does anyone know of an online reseller that carries Klipsch?
jswriter is offline
post #356 of 53884 Old 01-05-2007, 03:12 PM
WolfsBane's Avatar
Actually, the Yamaha's have a pretty solid following with Klipsch owners, specially the upper end Yammys, (same with Dennons). The old perception was that Yammy recievers were "bright", and that they lended the Klipsch, (whom some have already branded as having a bright sound), to have an even brighter, (read shrill), sound. This is something that buyers have to be very careful with Klipsch speakers. Klipsch is an extremely transparent speaker. Transparent enough that some folks see it as a fault. Feed a pair of Klipsch speakers a good, clean source of sound for music and the speakers will convey it in all it's glory. You will feel like you are right in the studio or concert with the performer. In all it's dynamic glory. But feed a pair of Klipsch a crappy sound source for music, and the speakers will do what it does best... also convey it in all its yucky glory. You will get out these speakers exactly what you put in them. Having said this, most users, (myself included), that have matted the new line of reference Klipsch to a Yamaha receiver have nothing but good things to say about them. And my Yammy is really a mid line model, not one of the higher end models. Still, it provides a fairly clean source for the speakers. The speakers are very efficient, so even a mid line model does the job. Now... if you want to really hear what a set of Klipsch can really do, feed it some clean power.
post #357 of 53884 Old 01-05-2007, 03:18 PM
jswriter's Avatar
This is good to know. I just bought a Yamaha RX-V695 that I want to drive a pair of RB-61 bookshelves (if I can find them anywhere).
jswriter is offline
post #358 of 53884 Old 01-05-2007, 08:21 PM
Management's Avatar
http://www.jr.com/JRProductPage.process?Product=4086580
post #359 of 53884 Old 01-06-2007, 10:43 AM
Management's Avatar
Anyone has the RS-42 surround speakers. What is the power rating on these speakers?
On the above webpage (JR's website) they are listed as having 150W RMS/600W Peak but on Klipsch's own webpage they have the RS-42 listed as 75W RMS/300W Peak. Can it really be that low or is JR incorrect? Thank you in advance.
post #360 of 53884 Old 01-07-2007, 12:30 PM
Denys's Avatar
Thanks All , this is an excellent forum. I just bought some new F-3's and B-3's to start a Home Theater set.The price was right. I'm using a vintage SCOTT 355R stereo receiver that was given to me by a co-worker.
1. Priority is to get me a descent A/V receiver.I'm currently looking at Yamaha's RX-V1700 , Onkyo's TX SR804 ,Harman/kardon's AVR 645, Pioneer's VSX-82TXS or Denon AVR-3806. These models kinds of fits my budget(1K$ Canadian). Any comments on which would be a better quality/performance ratio would be appreciated.(Or any not mentioned models)I'm planning to use the system about 80-20/movies-music. I live in a small town so comparing systems is not an option.Video from a Panny Plasma 42" HDTV so HDMI comptatibility is a must.
2. Will the B-3's and F-3's be compatible if used with a C-3 center(did not get the S-3's).Room size is 15x20.BTW can't seem to find a place to buy a C-3 online so what other options do you recommend for a centre.
Denys is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
