Klipsch owner thread - Page 1226 - AVS Forum | Home Theater Discussions And Reviews
 7389Likes
post #36751 of 53581 Old 06-12-2014, 11:12 PM
Schwa's Avatar
Quoted: 1114 Post(s)
Liked: 1167
Originally Posted by krozman View Post
Ok so I got my speakers today. (for those who don't want to scroll up a few pages, 62ii floorstanding mains, RC 62ii center, four RB51ii surrounds). The surrounds are really a huge improvement over what I had. The floorstanding speakers are a lot smaller than my Cerwin Vega D9's, but honestly not the drastic improvement I was hoping for. The vegas do music way better still even for a 40 year old speaker so i'll just have to suck that up. The center channel speaker was .....heh....bigger than I expected. Center and the receiver doesn't fit, so as soon as my Denon X3100W is released I'm probably going for an architectural redesign.
I had a pair of Cerwin-Vega AT12s through high school and college. Man, I loved those speakers!
Schwa is offline
post #36752 of 53581 Old 06-12-2014, 11:16 PM
Schwa's Avatar
Liked: 1167
Originally Posted by rogannz View Post
Bit of help please.
I've bought a RC-10 centre from a shop that closed down. I've always wanted a Klipsch speaker system after having an audio nirvana moment with a pair of Klipsch floorstanders about 15 years ago in an audio shop I was visiting. Getting the RC10 kicked me off so I've bought RB51ii and have just finished hanging them.
The question I have is should I rush out and get the RC52 to match the RB51s or will the RC10 give me a similar sound. $$ difference isn't a big issue. I emailed Klipsch a few days ago with this question but no reply.
System is 99% for movies. Marantz NR1403 amp, SVS PB12 NSD sub, reasonably large upstairs lounge. LCR speakers mounted high (like 12 foot) off the ground and lowering them is not an option. Movie are Pixar / Dreamworks and the like (kids under 10 yrs movies)
The RC52 will match better, but considering your RB51s are 12 feet above the ground and you can't move 'em, you're getting no where near the optimal performance out of them. In other words, the difference between the RC10 and the RC52 is nothing compared to your layout issue. Save your money and keep the RC10.
rogannz likes this.
Schwa is offline
post #36753 of 53581 Old 06-12-2014, 11:37 PM
rogannz's Avatar
Just measured, bottom of speaker is 9ft off floor - not that it changes your point at all. Thanks for the reply, a good bit of common sense
rogannz is offline
post #36754 of 53581 Old 06-13-2014, 12:50 AM
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
Originally Posted by DaJoJo View Post
125 WPC is enough to get u way over a ear-damaging loudnesslevel
Is this with an extrrnal amp? What do you suggest?
Sent from my SM-N9005 using Tapatalk
blue13x is offline
post #36755 of 53581 Old 06-13-2014, 04:49 AM
Melquiades's Avatar
Quoted: 62 Post(s)
Liked: 41
I am going to mount my rs's to the wall behind the listening position. Is there a way to find the proper distance between the speakers? Or is there an angle from the main listening position that I want?
Melquiades is offline
post #36756 of 53581 Old 06-13-2014, 07:03 AM
baloo_btru's Avatar
Quoted: 116 Post(s)
Liked: 117
Hey guys,
Is there any sort of "optimal distance" I should look for when considering my speaker placement?
Recently while playing around I moved my speakers further out from the back wall and it opened up the sound significantly and sounded warmer to me. I'm thinking of moving closer to that position for the MLP, but my concern is that for people sitting closer to the screen it will be only 6-7' max from the speakers.
Is that too close? I'm probably going to focus on the MLP and just move it forward because it really was a significant difference.
Side note: I'll also probably move the sub a little further away from the wall (its a couple inches now) which will decrease SPL but should make for a flatter response. I only had about an hour to play with my new toy (REW) but once I get some time it should be a blast
- Klipsch RF-82 ii, RC-62 ii, RS-52 ii
- Klipsch RW-12D
- Sony HW50es
- Firehawk G3
- Denon 2113
baloo_btru is offline
post #36757 of 53581 Old 06-13-2014, 07:55 AM
krozman's Avatar
Quoted: 174 Post(s)
Liked: 75
A lot of speaker setups are so dependent on your room acoustics and personal preferences it's probably better advice to just try out different things and see what hears best. Remember that you don't necessarily have to move the speakers to adjust volume. That can also be done on the receiver level. Few hours rubbing your eyebrows off one speaker channel at a time is the way to do it.
Louis Bartay likes this.
krozman is offline
post #36758 of 53581 Old 06-13-2014, 10:47 AM
Schwa's Avatar
Liked: 1167
This is a good starting point. I think DTS has recommendations also and I know there's a recommended layout image in my Denons' owners manuals.
*EDIT* - added an Onkyo one too...
ID:	113953   Click image for larger version
ellisr63 and Louis Bartay like this.
Schwa is offline
post #36759 of 53581 Old 06-13-2014, 10:49 AM
Schwa's Avatar
Liked: 1167
TBH I'd probably get the RC52II anyway since it'll "match" (meaning it'll look more like a "set") the RB51IIs better.
Schwa is offline
post #36760 of 53581 Old 06-13-2014, 11:07 AM
Schwa's Avatar
Liked: 1167
Well, well, well -- look what just arrived!
Schwa is offline
post #36761 of 53581 Old 06-13-2014, 11:15 AM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
the cat ?
Klipsch fronts 2xRF-82-II 150W 33Hz-24KHz , center RC-64-II 200W 59Hz-24KHz , sides 2xRS-62-II 150W 50Hz-24KHz , rears 2xRB-81-II 150W 44Hz-24KHz , heights 2x Salora T25i
Yamaha RX-A3040, SVS PB13-Ultra 1000W 14-200hz
4 mm el cheapo wire / Samsung UE-ES8000S TV+evo 2014 / Optoma DH-1015 Sony PS3
DaJoJo is offline
post #36762 of 53581 Old 06-13-2014, 11:15 AM
Melquiades's Avatar
Quoted: 62 Post(s)
Liked: 41
Thank you!
post #36763 of 53581 Old 06-13-2014, 11:17 AM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
Originally Posted by blue13x View Post
Is this with an external amp? What do you suggest?
it's from the avr u have.. i suggest u keep it like it is, it's more then sufficient.
DaJoJo is offline
post #36764 of 53581 Old 06-13-2014, 11:19 AM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
Thank you!
put the sides to 110 degrees (center of the side-speaker) , it'll work for both DTS and DD as the correct angle for the speaker. 10cm above MLP ear-height
DaJoJo is offline
post #36765 of 53581 Old 06-13-2014, 11:23 AM
Schwa's Avatar
Liked: 1167
the cat ?
Yeah, right.
I gotta go for a 9-mile run then it's speaker-hangin' time!
Schwa is offline
post #36766 of 53581 Old 06-13-2014, 11:23 AM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
10cm above MLP ears height for the tweeter, or the bottom of the speaker? I was planning on putting mine almost at soffit height and angling them downward...
Yamaha CX-A5100, JBL 8340A, 4 JBL 8320, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, .
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #36767 of 53581 Old 06-13-2014, 11:24 AM
Melquiades's Avatar
Quoted: 62 Post(s)
Liked: 41
Thanks, dajojo!
post #36768 of 53581 Old 06-13-2014, 11:24 AM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
so i had time today to hang my side-surround speaker to a normal height and adjusted some trims... this was very beneficial to the overal sound in my room.
Name:	2014-06-13 18.15.34.jpg
DaJoJo is offline
post #36769 of 53581 Old 06-13-2014, 11:26 AM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
Thanks, dajojo!
that is from the middle/center of the speaker. if you put them above this height and angle them downwards then make sure the middle/center of the speaker is pointed towards 10cm above the ear on MLP
ellisr63 likes this.
DaJoJo is offline
post #36770 of 53581 Old 06-13-2014, 11:37 AM
Schwa's Avatar
Liked: 1167
Hmmm, not sure where you're getting this recommendation from. A link would be nice unless, of course, you're simply extracting it from your rectum.
Here's what Crutchfield says:
Surround speakers
Your surround speakers are meant to envelop you in a cloud of atmospheric sound and special effects, so you feel like you're actually in the middle of the action unfolding on your TV.
In a 5.1-channel system, surround speakers are best placed to the left and right of your listening position — either in line with it, or just behind it. If side placement isn't practical in your room, place your surround speakers behind your listening position, facing front. Either way, place the speakers high enough so that the drivers don’t fire directly at your ears, around ear level while standing.
Wall mounting is often a great option for surround speakers. You'll need to mount the speakers to a stud, or use wall anchors.
In addition, a cursory search will show that about 6' from the floor is the commonly-accepted surround speaker height.
Here's another recommendation that says basically the same thing.
ellisr63 and B 26354 like this.
Schwa is offline
post #36771 of 53581 Old 06-13-2014, 11:44 AM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
Hmmm, not sure where you're getting this recommendation from. Here's what Crutchfield says:
Surround speakers
well that is if u use old formats like dolby pro-logic, not if u want to have nice DTS,DTS-MA,DD,DD+, and other new formats to sound good. for setups like 9.1/2 ,11.1/2 with audyssey/yamaha/atmos/auro-3D heights it is totally not advisable that u have the side-speakers on 6' (feet ?) height.
DaJoJo is offline
post #36772 of 53581 Old 06-13-2014, 11:58 AM
Schwa's Avatar
Liked: 1167
Here's another reference, this time from THX. They recommend that surround speakers be placed "at least two feet above the listener." Of note is that they recommend this speaker positioning for the 7.1 speaker layout scheme, so they're obviously talking about modern discrete surround-sound formats.
I guess you're implying that you know better than THX, Crutchfield, and many, many others? I doubt it.
Let me put this plainly -- and no offense intended -- but YOU ARE WRONG. Stop posting dubious information, and if you are gonna post recommendations, please back them up with links.
Tasdom and B 26354 like this.
Schwa is offline
post #36773 of 53581 Old 06-13-2014, 12:00 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
Here's another reference, this time from THX. They recommend "at least two feet above the listener." They recommend this speaker position for the 7.1 speaker layout scheme, so they're obviously talking about modern discrete surround-sound formats.
i am not.. check the dolby and dts website for correct speakerplacement and not the last century thx website which requires u have a thx system and thx speakers.
DaJoJo is offline
post #36774 of 53581 Old 06-13-2014, 12:02 PM
Louis Bartay's Avatar
Quoted: 293 Post(s)
Liked: 700
Surround speakers
I read something like that too a few years ago and used that as a baseline for mounting my rears for my 5.2 up near my 8' ceiling.............. I also was advised (Omnimout Tech Support) to purchase wall mounts that are rated 2X more then what the speaker weighs. I had to use sheet rock anchors that go thru the wall and butterfly out and snug up. I also mounted a DIY 3/4" plywood wall shelf just above my 55" flat screen for a heavy C7 center speaker. So don't be afraid to use these thru the wall anchors. If a stud had been there oh hell yes.
ellisr63 and DaJoJo like this.
Klipsch Cornwall I,C7,RS3-II, R-14M
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
Yamaha RX-V1900 HD PS3
Louis Bartay is offline
post #36775 of 53581 Old 06-13-2014, 12:06 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
only if u have adjustable mounts that tilt. mounts that don't tilt do fine within boundaries of the weight they can handle.
a good wall-anchor can handle a lot of load .. see here http://www.naturalhandyman.com/iip/i...infanchor.html
DaJoJo is offline
post #36776 of 53581 Old 06-13-2014, 12:13 PM
Schwa's Avatar
Liked: 1167
Are you completely daft? "Last century?" That's cute, considering that THX posted recommendations for 5.1 and 7.1 layouts -- and 7.1 layouts, in particular, are definitely not "last century." But hey, whatever, you're the expert.
Oh, thanks for the links you provided to the Dolby and DTS recommendations.
Regardless, here's another link for ya, this time right out of the Denon owner's manual. I know you know better than them, but let me point out that they mention Audyssey DSX in the setup notes, so at least we know this isn't "last-century."
Aw, what the heck, here's another recommendation from B&W -- they recommend "60cm above listening position when seated," just like Denon.
At this point, I'll leave it as an exercise for the reader to determine the correct surround speaker height based on the information I've provided.
Name:	11.x speaker layout via Denon Manual.JPG
Schwa is offline
post #36777 of 53581 Old 06-13-2014, 12:21 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
Are you completely daft? "Last century?" That's cute, considering that THX posted recommendations for 5.1 and 7.1 layouts -- and 7.1, in particular, are definitely not "last century." But hey, whatever, you're the expert. Oh, thanks for the links you provided to the Dolby and DTS recommendations. :roll eyes:
Regardless, here's another link for ya, this time right out of the Denon owner's manual. I know you know better than them, but let me point out that they mention Audyssey DSX in the setup notes, so at least we know his isn't last-century.
yup... pro logic..
now add to the fronts (which are 20cm lower for my ears, i have a low couch and am tall) a 2 ft which is 66cm and u get a 46cm difference which differs about 26cm from my advise. and again its for dolby II and not for dts , thx and DD. so to fill the gap and have all formats sound ok it works fine using the 10cm above the ear. so i say about 10-30cm above the ear works fine.
DaJoJo is offline
post #36778 of 53581 Old 06-13-2014, 12:35 PM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 359
congratulations... and ENJOY!
Schwa likes this.
My Name is Nobody...
Klipsch x11i - Klipsch x20i - Oppo HA2
Pioneer SC85 - Bel Canto REF 500M
Klipsch La Scala II - Klipsch Cornwall/Crites/Aletheia Audio - Klipsch RC64II - SW-115
Wyred 4 Sound DAC2 DSDse - OPPO BDP-93
Samsung PN64D8000
MSchu18 is offline
post #36779 of 53581 Old 06-13-2014, 12:41 PM
Schwa's Avatar
Liked: 1167
yup... pro logic..
You're just making stuff up now. Where are you getting this crap about Pro Logic? Oh, I know, you're inventing it to make your own argument more plausible.
Nowhere do any of the recommendations I've posted say they're for Pro Logic!! Nowhere! In fact, the Denon owner's manual clearly shows it's for an Audyssey 9.1 / 11.1 layout!
If you want to ignore the substantial amount of hard evidence that's placed in front of you and go your own way, have at it. But please, PLEASE don't act like yours is the generally-accepted way of mounting speakers. Clearly I've shown that it's not. More to the point, stop giving out bad recommendations based on your highly dubious logic. It's unhealthy for the forum.
Schwa is offline
post #36780 of 53581 Old 06-13-2014, 01:12 PM
Quoted: 293 Post(s)
Liked: 700
I used these and that have a long steel shaft with angles off set and ball on the end that attaches to the ball clamp you mount on the back of the speaker.
http://www.ebay.com/itm/Omni-Mount-U...vip=true&rt=nc
These are rated at 30# and there are still some up to 100# models like these on this auction site as Omnimount is out of stock the last time I called them. Looks like they are making a different design now. These are holding my RS3-II rears great for the last two years and I can adjust then in several directions.
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
