Klipsch owner thread - Page 1251 - AVS Forum | Home Theater Discussions And Reviews
 5105Likes
Old 07-30-2014, 05:30 PM
DreamAgain2's Avatar
Quoted: 42 Post(s)
How should I be setting up my KF-28 and KC-25 crossover?
Should I set it them all to Small / 80 hz? Or should I set the KF-28's to Large/40hz?
DreamAgain2 is offline
Old 07-30-2014, 06:01 PM
SanchoPanza's Avatar
Quoted: 196 Post(s)
Liked: 511
^^^ IF you have a Subwoofer, use 80 & Small for a week or 10 days; then try 40 & Large...see what YOU like best.
If no SW, 40 & Large.
Louis Bartay and retro124 like this.
SanchoPanza is offline
Old 07-30-2014, 06:06 PM
Quoted: 42 Post(s)
okay thanks. and the center is best at 80?
Old 07-30-2014, 06:55 PM
Soupy1970's Avatar
Quoted: 145 Post(s)
Liked: 226
If you use Room correction such as Audyssey make sure you never go below what it recommends as a crossover. It's fine to raise from say 60Hz to 80Hz, but never go below. So if it would happen to suggest 60Hz then do not try 40Hz. Hope that makes sense .
For example Audyssey originally set my Klipsch KLF 10's to 40Hz and my KLF C-7 to 60Hz. I have two capable subs so I boosted the FL & FR up 20Hz. 80Hz all the way around gets mentioned a lot but that is mostly to save power draw to the AVR. Klipsch are pretty efficient so I think 60Hz works well and prevents possible localization of Sub(s).
Everyone should listen between 40, 60, & 80Hz and decide if they like the 40-80Hz slam better from the fronts, or the sub. It was really close for me between 40 & 60 (my 10" woofers can slam), so I made the deciding factor be what was easiest on my AVR which is always the higher 60Hz.
Denon X4000 - Klipsch KLF-10 Fronts - Klipsch KLF-C7 Center - Klipsch KLF-C7 X 2 Surrounds - Dual HSU VTF-3 MK4 Subs - BenQ W1070 projector - 106" Antra fixed Screen - 3D powered by AMD home built computer
Soupy1970 is offline
Old 07-30-2014, 07:01 PM
Soupy1970's Avatar
Quoted: 145 Post(s)
Liked: 226
Most likely, Same is true for the surrounds. Not much if any low end gets sent to those speakers. I do keep my center set to 60Hz to match the rest of my fronts. The dual 8" woofers on my KLF C-7 are pretty capable though so I said why not. Doubt it makes much improvement (if any at all) over 80Hz though.
Old 07-30-2014, 08:09 PM
Reference_head's Avatar
Quoted: 141 Post(s)
Liked: 724
Originally Posted by cchunter View Post
Are you looking to build a Heritage system now? That seems high if it were in the USA but not sure if that's a good deal for NZ. I know prices there are a bit steeper. Save your money and get the RF7II's. You think your 82II's rock ha just wait till you hear the 7II's.
The black ash matches pretty nice with the 7s and svs.
cchunter likes this.
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
Old 07-30-2014, 08:15 PM
Quoted: 31 Post(s)
Liked: 5
Originally Posted by Reference_head View Post
The reference line is the most popular line they have. So they must think this will make more money putting the gold/copper on everything. I personally think it will water down the line too much.
I think they will sell more lower level speakers with this. But I also think they will sell less higher level ones (like the rf82ii). Looks matter and was part of the draw of the reference line. People upgraded from the lower levels and got a whole new looking speaker. So now upgrading from a lower reference to a higher one ends up with a similar looking speaker.
Agreed. It all comes down to sales. The copper cones look much sexier than the current icon/synergy ones, and will appeal to the casual buyer. I bet they sell a lot more of the new Reference stuff, and about the same amount of the higher end Reference. I'm curious to see what they do with the new Reference II & III stuff though. Since they already have the copper cones, what will they change?
kylbarnes is offline
Old 07-30-2014, 08:46 PM
Soupy1970's Avatar
Quoted: 145 Post(s)
Liked: 226
It's all marketing and I doubt there will be any real improvements to the Reference line. It will be the same old story where they slightly change the spec (possibly with no gain or worse) so they can change the name and get people to sell their old stuff for the new stuff. I say hold on to your old speakers and if you are new to Klipsch buy used. Just like my old pair of RF 15's were basically RF 52's. They changed some numbers, put different feet/logo and called it a new speaker.
Louis Bartay likes this.
Old 07-31-2014, 12:19 AM
ocelittle's Avatar
Quoted: 48 Post(s)
Getting closer to my move-in date (We just closed escrow today, but the current homeowners are renting for 10 days to move out).
I've got about $1800 burning a hole in my pocket for my 5.1.
*rocks back and forth*
Just to triple confirm...
On Amazon, if I went fully Cherry (except the RS-52's, which are only black I guess) as they are the cheaper models, I'm at $3000 shipped for:
RF-82 II x2
RC-62 II x1
RS-52 II x2
SW-110 x1
On Sounddistributors.com, I see:
http://www.sounddistributors.com/buy...heater+Systems
$2599, still a lot better than Amazon and it's with a more expensive sub (310).
I live in Las Vegas, so I have been told I can call Sound Distributors and get a sick deal. Yes?
ocelittle is offline
Old 07-31-2014, 12:49 AM
Schwa's Avatar
Quoted: 583 Post(s)
Liked: 544
RF-82 II x2
RC-62 II x1
RS-52 II x2
SW-110 x1
Yes, CALL Sound Distributors for the best deal.
You might want to think twice about getting the cherry finish on vinyl wrapped speakers. Cherry looks great on the RF-7II and RC-64II because those speakers have real wood veneers, but the RF-82II and RC-62II are vinyl wrapped, and the cherry vinyl looks pretty cheesy.
Schwa is offline
Old 07-31-2014, 12:50 AM
ocelittle's Avatar
Quoted: 48 Post(s)
Oh. I was just using that on Amazon (I wouldn't actually buy there). The SD deal for those speakers is way better AND it's black. I want black.
I'm not a good negotiator, so I would worry that I would just be talked into paying more heh.
Old 07-31-2014, 01:07 AM
Soupy1970's Avatar
Quoted: 145 Post(s)
Liked: 226
Have you thought of buying used? I bet there are a ton of Klipsch on Craigslist in Las Vegas. I actually just spied some Klipsch KLF-20's in Las Vegas. I have KLF's on speed search I'm sure there are all kinds of RF's too.
Just saying used makes the $ go further. Maybe get a better sub.
Old 07-31-2014, 01:10 AM
ocelittle's Avatar
Quoted: 48 Post(s)
I have. There was a guy selling a full set of RF1's for around $2000...that led me to this group about a month ago. I asked if it was a good deal, everyone said NOOOOOO. So I said no to him and have been biding my time.
Those KLF-20's are massive...haha. I'm quite partial to the styling of the RF-82's.
Old 07-31-2014, 01:16 AM
Soupy1970's Avatar
Quoted: 145 Post(s)
Liked: 226
True those 10" woofers take up some space, but those might be stolen for $500 or so. A KLF-C7 is easy to find for $250 or so and sometimes cheaper. I understand though if your going for the RF style. I'm surprised there isn't any RF-82's on there for a fair price with the biggest dealer being located there. Actually surprised SD themselves isn't on there pimping great deals to the locals.
Old 07-31-2014, 01:27 AM
Silverstone-Z's Avatar
Finally returned home and got to set up my home theater. I plan on adding rears when I move to a new house that will allow it space-wise.
AVR: Denon AVR-X2100W
Fronts: Klipsch RF-62 II
Center: Klipsch RC-62 II
Rears: Klipsch RS-42 II
Subwoofer: SVS PC12-NSD
Silverstone-Z is offline
Old 07-31-2014, 01:30 AM
ocelittle's Avatar
Quoted: 48 Post(s)
Gorgeous
Old 07-31-2014, 03:04 AM
Louis Bartay's Avatar
Quoted: 212 Post(s)
Liked: 576
You will be surprised how good the KLF-20/30 and C7 sound. Add you will save a lot of $$.
Soupy1970 likes this.
Klipsch Cornwall I,C7,RS3-II
Klipsch Heresy II, KSB 1.1
Klipsch Sub 12" X3 Hafler P3000,P1000, DH330 DH110
Yamaha RX-V1900, T-1000,A-1000 Class A, GE-20 GEQ CDC-697
ReVox A-77 Mk IV Dolby, Nakamichi BX-100 PL-518X DL103R
Louis Bartay is offline
Old 07-31-2014, 03:10 AM
Quoted: 196 Post(s)
Liked: 511
Craig's List used Klipsch MAY be a Steal, ymmv!
Louis, I'd love to hear your Cornwalls, one day. *sigh*
Old 07-31-2014, 03:17 AM
Schwa's Avatar
Quoted: 583 Post(s)
Liked: 544
You won't have to do any negotiating if you call SD. Eric will just give you his best price straight up. It's pretty much the same thing with Acoustic Sound Design (also in Las Vegas) from what I've heard.
If you go with either one of those dealers, you'll get brand-new speakers, the exact models that you want, with a factory warranty, for not much more than you'd pay for used. Seriously. I've bought all of my Reference II speakers (2x RF-7II, 4x RS-62II, RC-64II, 2x RB-81II, 2x RF-82II, 4x RS-52II, RC-62II) from SD and couldn't have been more pleased with the experience or the pricing.
Schwa is offline
Old 07-31-2014, 04:06 AM
Quoted: 212 Post(s)
Liked: 576
Hi Kendall, if you are ever in the DFW area in Texas come on over, lunch is on me and bring your favorite music. I would like to listen to all your Heritage collection for your HT system. I too have purchased some used Klipsch over the years and saved a lot of $$. My Cornwalls are one owners and looking back the 950.00 I borrowed from Pop back then (1974)to purchase them new was wise purchase....look at how much they cost now. I have Crites CT-125 tweeters and Crites Type B new networks in them now and Pop had them veneered in Piano Gloss Black back the 80's and they still look great. They were raw birch with risers when we purchased them new as they were less money unfinished.
Louis
Old 07-31-2014, 06:29 AM
retro124's Avatar
Quoted: 856 Post(s)
Liked: 617
Schwa is right, in Vegas SoudDistributors or Acoustic Sound Design is way to go?Lucky you many of us wish we have then in town. You will get the best prices for sure. You can ask only 2 question?
Let them priced all and then ask them if you pick them up ( if you willing to do it) if is there even better price thats all, you will safe hundreds of $$$ compare Amazon. You choice great system I will maybe just give up sub( what they want for it?) and look at choice one from SVS. Good luck!!!
Denon X4000
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's, RS-52II's (soon for sale (maybe) :-)
SVS 2x PC12-Pluses
Sony XBR65X850B
Emotiva XPA-200 , Oppo 103D
Apple Mac mini, Sony PS3
retro124 is offline
Old 07-31-2014, 06:57 AM
AVS Club Gold
Mike Garrett's Avatar
Quoted: 3810 Post(s)
Liked: 2295
I have a couple of speakers that I have been holding for height speakers, when I re-work my front wall into a baffle wall design, but I am thinking of saving them for Atmos. I am thinking, Atmos may give more benefit than heights. Just my thought.
mike@avscience.com
Sony, JVC, Epson, Denon, Marantz, Yamaha, Onkyo, Triad, Atlantic Tech, M&K, RBH, SVS, Polk, Stewart, Seymour, Falcon, DNP, SI, Screen Excellence, Carada, MicroLite & more.
Mike Garrett is offline
Old 07-31-2014, 07:06 AM
retro124's Avatar
Quoted: 856 Post(s)
Liked: 617
Hello Mike let me ask you what you will get for front height RB-61II or RB-81II? All my speakers are in my signature,thanks.
Denon X4000
SVS 2x PC12-Pluses
Sony XBR65X850B
retro124 is offline
Old 07-31-2014, 07:52 AM
MSchu18's Avatar
Quoted: 165 Post(s)
Liked: 343
I'm in vegas and have used both local resellers before... they are just about the best pricing available most anywhere and I can go pick them up in person.
that being said, the Vegas market is hit and miss for speakers. At times there are really good items for sale... but they sit on craigslist for weeks and never move... and then they are gone as the seller decides to keep them. I know pretty much all the Klipsch here locally that have been for sale and there is a fair choice of unsold items from P37's, La Scala, Heresy's and an occasional RF 82/83 and KLF... you just have to look weekly.
My Name is Nobody...
Klipsch x11i - Klipsch x20i - Oppo HA2
Pioneer SC85 - Bel Canto REF 500M
Klipsch La Scala II - Klipsch Cornwall/Crites/Aletheia Audio - Klipsch RC64II - SW-115
Wyred 4 Sound DAC2 DSDse - OPPO BDP-93
Samsung PN64D8000
MSchu18 is offline
Old 07-31-2014, 08:09 AM
ocelittle's Avatar
Quoted: 48 Post(s)
Cool, so Eric is the one I should be talking to at SD.
Nice.
Thanks, can't wait to see what he can offer.
baloo_btru's Avatar
Quoted: 114 Post(s)
Liked: 115
Audyssey has been setting my center (rc-62 ii) at 150hz....no idea why. And LPF is 120hz. So I set it down to 120.
I'm not sure if it's a room null, a calibration issue, or what, but it is very frustrating. My first few times it never did that.
- Klipsch RF-82 ii, RC-62 ii, RS-52 ii
- Klipsch RW-12D
- Sony HW50es
- Firehawk G3
- Denon 2113
baloo_btru is offline
Old 07-31-2014, 08:34 AM
baloo_btru's Avatar
Quoted: 114 Post(s)
Liked: 115
RF-82 II x2
RC-62 II x1
RS-52 II x2
SW-110 x1
FYI, I got the speakers you are looking for (without a sub) for $1800 from Sound Distributors and Eric. YMMV since that was a year ago.
- Klipsch RW-12D
- Sony HW50es
- Firehawk G3
- Denon 2113
Old 07-31-2014, 08:39 AM
ocelittle's Avatar
Quoted: 48 Post(s)
Nice! Do these speakers tend to drop in price?
What's a good matching sub for this set? Everyone tells me to upgrade the sub when i talk about the 310.
Old 07-31-2014, 08:53 AM
baloo_btru's Avatar
Quoted: 114 Post(s)
Liked: 115
I'm still looking to upgrade my rw-12d, but most would recommend an internet direct brand. SVS is highly recommended. However you are looking at $500 as a starting price ($450 if you get from the outlet) for the pb1000.
There is no need to match brand for the sub (and most wouldn't recommend it, since klipsch subs are sub-par; no pun intended )
I am looking at the pb2000. I got my RW-12D refurbished for <$200, so I'm hoping to sell it for around the same price. I may also keep it until I can get a second pb2000 to see how duals are in my room, though space is at a premium. You can talk to Mike who just posted here (AV Science Sales 5) or directly to SVS to figure out what would work for you.
- Klipsch RW-12D
- Sony HW50es
- Firehawk G3
- Denon 2113
Old 07-31-2014, 10:36 AM
Schwa's Avatar
Quoted: 583 Post(s)
Liked: 544
Nice.
Every single time I've called SD Eric's who answers the phone. If you manage to actually talk to someone else I'd be shocked.
Schwa is offline
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
taboola here
