Klipsch owner thread - Page 1263 - AVS Forum | Home Theater Discussions And Reviews
 7389Likes
post #37861 of 53581 Old 08-19-2014, 11:29 AM
Schwa's Avatar
Quoted: 1114 Post(s)
Liked: 1167
Originally Posted by coytee View Post
You can all me The Incredible Mr. Limpet
...now, back to your regularly-scheduled Klipsch thread.
Schwa is offline
post #37862 of 53581 Old 08-19-2014, 11:56 AM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
Originally Posted by malmstump View Post
hurry up mongo with the spray,i can't wait till your done with that c7 so i can see the result dude
hope it looks brand new
Here we go. I have 0 (ZERO)) woodworking experience. I hit the scratches with some 0000 steel wool. Wiped off and sprayed. I didn't want to sand too much off the veneer. With the paint, it makes the scratches look like indentations.
ID:	219594   Click image for larger version
ID:	219602   Click image for larger version
ID:	219610   Click image for larger version
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #37863 of 53581 Old 08-19-2014, 12:04 PM
Tasdom's Avatar
Quoted: 156 Post(s)
Liked: 585
Nice job Mongo, it looks great!
Onkyo Pre/Pro PR-SC5508 & Emotiva XPA-5's x 2
Klipsch RF-7II's Mains RC64II Center RB75's Heights RS-7's Sides RS-52II's Rears
Klipsch RW-12D Subs x 2
Klipsch Belle's
OPPO BDP-105 with Roku Streaming Stick
Epson 6030UB / Vapex 120" Electric Tensioned Screen
Tasdom is offline
post #37864 of 53581 Old 08-19-2014, 12:06 PM
Teremei's Avatar
Quoted: 538 Post(s)
Liked: 227
Originally Posted by ClawAndTalon View Post
I'm not sure what your wall looks like, but the RS series surrounds need wall space around them (3 feet would be ideal) so they can achieve a wide sound stage. A shelf to close to it, above, below, beside, it doesn't matter will potentially mess with it's ability to do this.
I see, yeah it's kinda tucked in there with a couch around it too. So there really isn't a lot of open space, just some. Maybe I am best going with the RB-51. At least then I would get the fuller sound of a larger woofer.
Upstairs Living Room - LG 65EG9600: Klipsch R-20B Soundbar
Basement - Sony 75x940d: Klipsch Reference series II speakers, 2 subwoofers, Denon x4000
Teremei is offline
post #37865 of 53581 Old 08-19-2014, 12:07 PM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
Thnx, man! I really appreciate that. I don't mind that the scratches look like indents. I just don't know what to do with the damaged ends in the corners. I guess just paint over them and call it a day. I really didn't expect much for $150.
malmstump likes this.
Mongo171 is offline
post #37866 of 53581 Old 08-19-2014, 12:17 PM
malmstump's Avatar
Quoted: 94 Post(s)
Liked: 328
mongo i am impressed ,thank you so much it looks great dude congrats .did you sand then wipe then sprayed? did you have to overlap?how many coats ?details dude please........i love it
malmstump is online now
post #37867 of 53581 Old 08-19-2014, 12:25 PM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
First, I had to dust the speaker off. I'm waiting for Dean to have time to rebuild the xover. I ran some 0000 steel wool over the scratches to try to "bring them to the surface; cut down on the sharpness of the scratch." Once you figure out what I just said, I wiped the speaker down again with just a dry rag. One coat of paint. I let it dry for a half hour before I took the after pics. I do like the wood grain that shows on the black speakers. That's why only one coat.
malmstump and Louis Bartay like this.
Mongo171 is offline
post #37868 of 53581 Old 08-19-2014, 12:32 PM
malmstump's Avatar
Quoted: 94 Post(s)
Liked: 328
very nice mongo ,now once i get those klf 30 s i will do exactly that .so you only sand lightly the scratches
not the whole thing ,i thought we had to for the paint to stick
post #37869 of 53581 Old 08-19-2014, 12:52 PM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
On the black speakers I bought new (Chorus II's and an Academy) it didn't look like they put anything on top of the paint. Thus, the satin finish. If they covered the veneer with a coat of poly
urethane, then you would have to sand that layer off to get to the wood veneer. But, as is, I just hit the scratches with the steel wool just a little bit and painted.
Mongo171 is offline
post #37870 of 53581 Old 08-19-2014, 01:05 PM
ClawAndTalon's Avatar
Quoted: 417 Post(s)
Liked: 274
Bipoles aren't good in all conditions. If you have the space for the RB 51 II then go for it. Don't point them straight at you, but at an imaginary target between you and the TV, or even right at the TV. Then you'll get some phantom sound spread along the wall.
ClawAndTalon is offline
post #37871 of 53581 Old 08-19-2014, 01:15 PM
Teremei's Avatar
Quoted: 538 Post(s)
Liked: 227
Ok I need a little more help. I want to get this right because I will be out $80 if I order another one and change my mind. Between the RS-41, RS-42, RB-51.
RS-41: Like the clarity of the sound, only disappointed because I expected more diffuse sound. Sounds really weak during Audyssey set-up. Like the look
RS-42: in the hope it might diffuse sound more, might be slightly "fuller" due to 2 woofers. Look the look But if CandT is right and it might not diffuse the sound any better than the 41 due to it's location, then it could be a wasted purchase.
RB-51: largest woofer. supposed specs from Klipsch, 41 goes down to 85, 42 to 62, 51 to 50. Advantage here is I'm used to same size polk bookshelves. Wouldn't have any regrets as far as woofer size but might have regrets I didn't try RS-42.
I very well might still end up keeping the RS-41. I guess I just expected a tiny less directionality. And if I'm not getting it the thought would be just get a bigger woofer so I atleast get fuller sound. I'm fickle I know it guys. Help me make the best selection.
Teremei is offline
post #37872 of 53581 Old 08-19-2014, 01:17 PM
Teremei's Avatar
Quoted: 538 Post(s)
Liked: 227
I have them wall mounted flush at the wall. The one thing I can guarantee you is no matter what I get, they will be flush with the wall. I could achieve that same phantom sound with a RS-42 right? I mean that was the thought that some would bounce off the back wall and then out into the room. That's why I tried the 41.
Teremei is offline
post #37873 of 53581 Old 08-19-2014, 01:34 PM
sikclown's Avatar
Quoted: 1411 Post(s)
Liked: 716
Originally Posted by t1pid7 View Post
Hi, thanks for providing your feedback! The room that I need to fill in is 19x19x22
That is a good sized space. Any particular reason you are looking at the Gallery series?
LG OLED 65C7P, Denon AVR-X7200WA, Apple TV, Oppo UDP-203, PS4, Xbox One
Nvidia Sheild Pro, HTPC, (2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA,
(4) RP-140SA, SVS PB12-Plus, Emotiva XPA-100, XPA-200, Emotiva A-700
UN55KS9000, Denon x4200w, Apple TV, Panny BDT460, HTPC,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is online now
post #37874 of 53581 Old 08-19-2014, 01:39 PM
t1pid7's Avatar
I want it to have a small footprint but cam still fill up the room. What do you think of the Martin Logan's or Definitive speakers? Due to lack of stores that can demo klipsch in my area, I might just go with these.
t1pid7 is offline
post #37875 of 53581 Old 08-19-2014, 01:46 PM
sikclown's Avatar
Liked: 716
I can't speak to filling up the room honestly. The way I have my bedroom setup everything is really close. They have big sound but definitely need a sub for the bass. BestBuy carries the Gallery series so you could always try them for a week and then return them within Best Buy's 14 day return policy. I think you lose a little on the open box but I am not sure on that.
post #37876 of 53581 Old 08-19-2014, 02:25 PM
cchunter's Avatar
Quoted: 534 Post(s)
Liked: 827
I would get the RS42II's. Even better but I know price is a bit steep the RS52II's would be perfect with your front three. My 62II's are up against the wall and I get very good surround considering my small room and how close they are to my ears. The camera angle makes the room very narrow but it is 13 ft wide x 19 ft long. I wish I could have went the long way but there is a heater along the short wall.
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
Klipsch RF7II's, RC-64II, RS-52's Cherry
SVS Dual SB13 Ultra's
Oppo UDP-203 Sony PS4 Pro Panamax 5300PM
cchunter is offline
post #37877 of 53581 Old 08-19-2014, 02:32 PM
Teremei's Avatar
Quoted: 538 Post(s)
Liked: 227
Has anyone tried surrounds (the ones you are supposed to put to the left and right of you facing you). At ear level and then 2 feet above ear level and actually prefer it at ear level? Maybe I don't like surround that sounds "above" me.
All I know is that I've achieved "ghost sound" even with bookshelves at ear level aimed right at me. IE surround that sounded in the middle of the room. I think it's because audyssey had the levels of the speakers perfect for my position. So it's not like it's not achievable with good software.
Teremei is offline
post #37878 of 53581 Old 08-19-2014, 02:35 PM
Teremei's Avatar
Quoted: 538 Post(s)
Liked: 227
Yeah I wish I had a longer room. I think you are right CC about the 5.25 would be a bit better match for my 62s. That's why I'm thinking about the RB-52. See part of me just wants to TRY the RS-42s just to hear how they sound. But I think deep inside I might have already decided with the RB-52s because of those 5.25 woofers.
Your surrounds are much further from your LP than mine are. By about 2 feet. Does that change your opinion? Also mine can't be aimed forward they have to be aimed at the side.
Plus I tried them aimed forward and I didn't like them as much.
Teremei is offline
post #37879 of 53581 Old 08-19-2014, 02:44 PM
cchunter's Avatar
Quoted: 534 Post(s)
Liked: 827
If your going to get the RB51II's then I agree with ClawTalon and don't aim them directly at you. Mount them above your head at least to give a better effect. I had the RB51II's and they are very good bookshelves and was also using them as surrounds at one point. If your putting your surrounds on the side walls then I would definitely get the RS42II's.
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
cchunter is offline
post #37880 of 53581 Old 08-19-2014, 02:48 PM
Kini62's Avatar
Quoted: 1694 Post(s)
Liked: 1509
Just a FYI on the RB-51. They are rear ported and I saw in a post of yours that whatever you get is going to be flush mounted to the wall. The RB-51 should have at least an inch or two of space behind it.
cchunter likes this.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #37881 of 53581 Old 08-19-2014, 02:59 PM
Teremei's Avatar
Quoted: 538 Post(s)
Liked: 227
Yeah even though on Klipsch page it talks about wall mounting as an option. That's one reason I was gonna go with either 41 or 42 RS's.
So now I guess it's between the RS41 or RS42. Since I'm not sure how the 42s will sound and I can't demo them without taking an $80 risk, I'm just gonna keep the 41s.
Teremei is offline
post #37882 of 53581 Old 08-19-2014, 03:01 PM
Teremei's Avatar
Quoted: 538 Post(s)
Liked: 227
I am making this tougher than it needs to be. But there is no risk free trail with Klipsch so that's what happens when you mix that with a guy like me. Thanks everyone for putting up with me the last few pages!
Teremei is offline
post #37883 of 53581 Old 08-19-2014, 03:08 PM
Louis Bartay's Avatar
Quoted: 293 Post(s)
Liked: 700
this explains why you purchased those huge 402 horns
Klipsch Cornwall I,C7,RS3-II, R-14M
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
Yamaha RX-V1900 HD PS3
Louis Bartay is offline
post #37884 of 53581 Old 08-19-2014, 03:18 PM
PM-Performance's Avatar
Quoted: 255 Post(s)
Liked: 146
I don't like surrounds too close to my ears. Too easy to localize.
Above your head will get you the sound you are looking for. Right at your ears will localize them
PM-Performance is offline
post #37885 of 53581 Old 08-19-2014, 03:26 PM
Teremei's Avatar
Quoted: 538 Post(s)
Liked: 227
I can still localize them when I put them on the shelf 2 ish to 2.5 feet above ear level. Thing is you just gotta experiment. And so far with my limited options I actually prefer them to the side. Just turn it down slightly to blend better.
Teremei is offline
post #37886 of 53581 Old 08-19-2014, 04:15 PM
Quoted: 417 Post(s)
Liked: 274
Don't get caught up in driver size! Especially since you're playing near field and were talking surrounds! That said if you go with RB series bookshelves get a Pinpoint wall mount, and don't do flush mount. With the RS series bipoles, flush mount all you want. Again if you go with the RS series they need some room to breath, like a 2 foot radius. With your setup being so near field I'd do RB41s on pinpoint mounts.
CHHunter went for rear placement because he has no left wall (I'm guessing), otherwise side placement is ideal.
post #37887 of 53581 Old 08-19-2014, 04:34 PM
Teremei's Avatar
Quoted: 538 Post(s)
Liked: 227
Yeah I am caught up in driver size. I even look at the frequency range. The reason I went with the 41s is I convinced myself the would be perfect for how close I am. Then I heard their actual range with audyssey, and yuck.
Do you think the 20 hz difference would be noticeable with the RS-42s? I think I'd like to stick to RS because I like to wall mount. And they look good, even if in the location they lose some of their ability.
One last question I guess is, are the 42s worth it over the 41s.
Teremei is offline
post #37888 of 53581 Old 08-19-2014, 05:01 PM
Quoted: 417 Post(s)
Liked: 274
That frequency range assumes 3 foot listening distance, and you are within that. You are going to set them at 80hz, and I can assure you that at 2 feet away and Audyseey calibrated you'll be fine with the RB41. If you want maximum dispersion go with the RS42.
post #37889 of 53581 Old 08-19-2014, 05:08 PM
Teremei's Avatar
Quoted: 538 Post(s)
Liked: 227
I was talking about RS41 not RB. RB41 is def not in the discussion. Technically the RS41 only goes down to 85 so I wouldn't want to set that at 80hz.
left is 2 feet but right is 7 feet away.
Teremei is offline
post #37890 of 53581 Old 08-19-2014, 05:12 PM
cchunter's Avatar
Quoted: 534 Post(s)
Liked: 827
I do have a left wall but it was just to far away and that's a walkway to the front door. Just didn't seem right having a surround way over on the side. Someday a dedicated room will be in order. Until then we make due with what we have
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
cchunter is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
