Klipsch owner thread - Page 1323 - AVS Forum
post #39661 of 39669 Old Yesterday, 11:47 AM
Tasdom's Avatar
Quoted: 36 Post(s)
Liked: 444
Originally Posted by lemonslush View Post
@Tasdom Thanks very much.
This is a pic of my rear subs just for fun. Its cleaned up a bit now and that cubbie to the left under my AV stuff is full of insulation now.
Did you use flat pack kits or cut your own? I'm leaning hard at DIY for my sub upgrades
Onkyo Pre/Pro PR-SC5508 & Emotiva XPA-5's x 2
Klipsch RF-7II's Mains RC64II Center RB75's Heights RS-7's Sides RS-52II's Rears
Klipsch RW-12D Subs x 2
Klipsch Belle's x 4
OPPO BDP-105 with Roku Streaming Stick
Epson 6030UB / Vapex 120" Electric Tensioned Screen
Tasdom is offline
post #39662 of 39669 Old Yesterday, 06:49 PM
lemonslush's Avatar
Quoted: 255 Post(s)
Liked: 55
I made them myself. I am not the best at box building but, I am getting better. The next two I build will be stacked on top of the far left , right subs. I only have Amos to power 8 subs. I may grab another just incase
lemonslush is offline
post #39663 of 39669 Old Yesterday, 07:02 PM
Mk3_wagen's Avatar
Quoted: 36 Post(s)
I have the following setup:
RF82II
RC62II
RS52II
Dual PB-2000 or single PB12-Plus (future purchase)
Do you guys think it's worth to get an Emotiva amp? Will I notice a huge difference? I was thinking about the XPA-3 or XPA-5.
FOR SALE: Denon X4000 BNIB | Klipsch RF-82 II BNIB | Klipsch RS-52 II BNIB | Klipsch SW-112 BNIB | Klipsch WA-2 BNIB | Jamo C607 used | Jamo C60 CEN used | Jamo SUB 650 used
Mk3_wagen is offline
post #39664 of 39669 Old Yesterday, 07:30 PM
cchunter's Avatar
Quoted: 224 Post(s)
Liked: 526
RF82II
RC62II
RS52II
IMHO I think a flagship AVR will do fine with your setup. If you were going to a 7.1 then maybe an amp would be justifiable if you listen at reference. If you don't crank it then a 125 w/ch will be more than enough to piss your neighbors off. . Not trying to start a piss fight with any of you external amp dudes either hee hee.
Denon 4520
Klipsch RF-7II's, RC-64II, RS-62II's
SVS SB13 Ultra
Sony BDP-S790, PS3
Panamax 5300PM
Samsung UN60F7100 3D LED
cchunter is offline
post #39665 of 39669 Old Yesterday, 07:45 PM
Mk3_wagen's Avatar
Quoted: 36 Post(s)
I'm just going with 5.1 for now, but I might upgrade to 7.1 later.
post #39666 of 39669 Old Yesterday, 07:58 PM
Zen Traveler's Avatar
Quoted: 211 Post(s)
Liked: 357
If that's the case I don't understand why you are selling your Denon X-4000 and wonder what you would be replacing it with (or driving with your system now). {EDIT: If you want an upgrade I would do your front soundstage.}
{2nd Edit: If I remember correctly, you are driving the system with an X4000 already and I stand by the recommendation above..}
Zen Traveler is offline
post #39667 of 39669 Old Yesterday, 08:04 PM
Mk3_wagen's Avatar
Quoted: 36 Post(s)
The X4000 I'm selling is a spare one I was going to use in my living room. I ended up using my SC-1522k in there instead.
post #39668 of 39669 Old Yesterday, 08:16 PM
Quoted: 211 Post(s)
Liked: 357
Got it. I was editing while you responded and see recommendation above and good luck..Fwiw, if you are considering an external amp check and see what SPL you are listening currently and decide if it's speakers (sq) or volume that you are wanting. My 2 cents.
psgcdn and Louis Bartay like this.
post #39669 of 39669 Old Yesterday, 08:37 PM
Louis Bartay's Avatar
Quoted: 79 Post(s)
Liked: 509
Originally Posted by Reference_head View Post
Klf30 has a 1.5" mid I think?
You may be right about the mid horn throat size..... I was going by memory from several years ago when I helped repair the loose motor boards on a friends pair. Anyway it's the tweeters we are swapping the diaphragms.
Reference_head likes this.
Klipsch Cornwall I,C7,RS3-II
Klipsch Heresy II, KSB 1.1
Klipsch Sub 12" X3 Hafler P3000,P1000, DH330 DH110
Yamaha RX-V1900, T-1000,A-1000 Class A, GE-20 GEQ CDC-697
ReVox A-77 Mk IV Dolby, Nakamichi BX-100 PL-518X DL103R
Louis Bartay is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
