Klipsch owner thread - Page 1432 - AVS Forum | Home Theater Discussions And Reviews
 6052Likes
Old 03-01-2015, 08:06 PM
retro124's Avatar
Quoted: 1078 Post(s)
Liked: 782
Originally Posted by dprice18af View Post
Awesome setup! You are living the dream.
Better to say is he is building his dream there is a lot of work behind but worth it.
ChadA and Louis Bartay like this.
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses
Sony XBR65X850B, Oppo 203
Emotiva XPA-200
Apple Mac mini, Sony PS3,
retro124 is online now
Old 03-01-2015, 09:06 PM
bass excavator's Avatar
Quoted: 62 Post(s)
Liked: 26
I guess I'll ask the question here since I can't find the answer.
Hey all I have Klipsch RF82s, RC52, RS42s, and RS62s
The models probably don't really matter but does anybody know if the holes in the Klipsch speaker binding posts are capable of passing through 10 gauge bare wire? Right now I'm running a measly 16 AWG. My surrounds need 35 ft lengths. Anybody using 10 AWG on Klipsch?
Enter all at the strait gate and walk the narrow way.
"I am the way the truth and the life, no one enters the Fathers' Kingdom except through me."
Jesus is the strait gate.
bass excavator is offline
Old 03-01-2015, 09:28 PM
Nexgen76's Avatar
Quoted: 421 Post(s)
Liked: 99
I'm using 12 on my front & center, using that with banana plugs. But 10 going to be really close.
JVC DLA-RS400U
Sliver Ticket 120' Grey screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build).
Denon AVRX6200W
Philips BDP7501 4K UHD Player
Ported Primate SI 18" HST subs x 2(DIY)
Nexgen76 is offline
Old 03-01-2015, 09:31 PM
vantage78's Avatar
Quoted: 65 Post(s)
Liked: 5
Just setup my RP-280F with a RP-440c rounding out the LCR. It's being used in conjunction with my old Klipsch Sub-10 and an even older Onkyo TX-SR600. One step at a time, will eventually get there with the rest of the system. First impressions/questions:
-Top notch aesthetics; love the copper look!
-This may not seem like much as I'm upgrading from a Quintet III front stage, but the clarity of these Reference Premieres are amazing. I'm hearing things on re-watched movies that I've never heard before. Moreover, it's not because I'm turning up the volume; there actually is a difference!
-Really enjoying 5.1 with movies. No good music sources, however. I tried Spotify through my smart TV app; was ok, but I can't help to think how a good source would really make these shine. Anyone have experience with Tidal, and if so, how are you hooking it up through your system?
-Am I correct in setting the RP-280Fs to "Large" to let the RP-280F bad boys take some of the grunt work? Receiver crossover is currently set at 80hz, with the sub crossover set to 120hz (highest). What about the RP-440c, "Large" as well?
Thanks all.
vantage78 is online now
Old 03-01-2015, 09:32 PM
dmb12679's Avatar
Quoted: 492 Post(s)
Liked: 214
I run 12 and it's tight
Marantz SR6010 -- Marantz MM7025 -- Marantz UD5007
Klipsch RF-7ii's - RC-64ii - RB-51ii's - RS-42ii's - R-112sw(x2)
B&K AVR507
Denon DVD2900
Klipsch RF-7ii's
dmb12679 is online now
Old 03-01-2015, 09:37 PM
dmb12679's Avatar
Quoted: 492 Post(s)
Liked: 214
Thanks all.
I run my 82ii's large with my 64ii at 80hz sub 100, do what sounds best to you in your room. I notice very little difference when bouncing the crossovers for the most part, but the standard is all 80, sub 80. Everyone runs it a little different, but with Klipsch it all runs well!
B&K AVR507
Denon DVD2900
Klipsch RF-7ii's
Old 03-02-2015, 06:23 AM
Tom Riddle's Avatar
Quoted: 473 Post(s)
Liked: 408
Thanks all.
I would chage them to small and run your crossover closer to 80 hz on all speakers (that are capable). This is how I run my setup and I find it very pleasing. With that said, the main reason I suggested this for you is, your receiver only has around 80 wpc (2ch driven) so running your mains at large will eat a lot of your juice and give you less headroom.
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Samsung PN64F8500 (Master Bedroom)
Tom Riddle is online now
Old 03-02-2015, 07:11 AM
rblankster's Avatar
Quoted: 27 Post(s)
Liked: 30
I'm using 10 GA wire from Blue Jeans Cable but I had them put the flat spaded connectors on.
Klipsch RF-7 II, RC64 II, RS62 II
Klipsch R-115SW & Velodyne FSR-15 SW
McIntosh MC205 Amplifier (200W plus X5)
McIntosh MX151 A/V Control Center
Sony KDL-60NX810 TV
OPPO BDP-93 Blu-Ray
rblankster is offline
Old 03-02-2015, 07:22 AM
sjm817's Avatar
Quoted: 243 Post(s)
Liked: 83
Thanks all.
Spotify from a Smart TV wont give you the best experience. Its likely limited to 160K and the UI stinks. If you have Spotify premium ($10/mo) you get 320K. To use the higher bitrate, A Spotify Connect enabled receiver is the best way, but a good Bluetooth system or Airplay is you have an Apple device are also good options.
sjm817 is offline
Old 03-02-2015, 11:15 AM
PWH1's Avatar
Quoted: 76 Post(s)
Liked: 250
I run my music to my AVR via Airplay with my iPad Mini. Pandora or Spotify (using subscriptions for both) both produce very clean well balanced results. Nothing like being able to sit on you arse with a cold one and chose your music with but a swipe of or a point of your finger!
I also have Airfoil installed on my laptop and that works well, but seems to be victim to random drops and not as stable as Airplay. I rarely encounter any signal interruptions with Airplay.
Denon: AVR X2000
Klipsch: RF-82 II / RF-62 II / RC-62 II / RB-61 II
SVS: PB-2000 x 2
LG: OLED55B6P & Samsung: UN55KS9000F
Panamax M5100-PM
PWH1 is offline
Old 03-02-2015, 11:42 AM
darkleafar's Avatar
Quoted: 81 Post(s)
I have a quick random question : I know it's out of topic for this thread and I already finished my klipsch setup but I figured it's a quick painless question :
I have an APC G5 power conditioner, with delayed power feature. If I have my TV on and receiver on, for example, and press the power button on the G5, it will turn off all my devices one by one, 4 seconds interval each. When you turn it on, it ll turn them back on in the same manne4, without ever touching the power button o the devices themselves. Is this how I'm supposed to use it.? Or am I damaging my devices in any way by not turning them off manually first?
darkleafar is offline
Old 03-02-2015, 11:47 AM
vantage78's Avatar
Quoted: 65 Post(s)
Liked: 5
Cheers Tom. I'll give that suggestion a shot. Unfortunately, my receiver only allows for sub crossover adjustments; everything else is either "Large" or "Small".
Old 03-02-2015, 11:55 AM
dkami712's Avatar
Quoted: 201 Post(s)
Liked: 135
From a technical standpoint I'm not for sure one way or the other. However, I don't imagine it can be very good for the electronics to be shut off like that. You are pretty much doing a controlled power outage each time you turn your devices off. If any of the devices have a sequenced shutdown process, your conditioner is not allowing them to do that. My best example is if you were to cut the power to your PC, you would more than likely receive a prompt on next boot up that it was shutdown improperly. I know its not apples to apples but that's my $0.02
Mongo171 likes this.
dkami712 is offline
Old 03-02-2015, 11:59 AM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
These days, On and Off is the same button. Don't laff! If you leave the TV On and turn off you conditioner, the TV will lose power and turn Off. When the TV gets power again, the TV will be in the Off state. There is only MTBF (Mean Time Between Failures) that will accompany any mechanical device. Don't worry, the TV will be obsolete before the power switch fails (hopefully!).
ceptorman likes this.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
Old 03-02-2015, 12:02 PM
dkami712's Avatar
Quoted: 201 Post(s)
Liked: 135
From page 37 of your receivers' manual. Basically, set all your speakers to small and set the crossover to 80hz and you'll be GTG.
Tom Riddle and Louis Bartay like this.
dkami712 is offline
cesar123's Avatar
Quoted: 371 Post(s)
Liked: 546
Not sure if anyone has mentioned (or seen), but Crutchfield has the RF-7's for $1280 a piece.
Yippee-ki-yay...
cesar123 is offline
Old 03-02-2015, 12:22 PM
dkami712's Avatar
Quoted: 201 Post(s)
Liked: 135
World Wide Stereo has the walnut version for $1279 each and you get a free RC-64, amazing deal. I think it ends today.
dkami712 is offline
Old 03-02-2015, 12:26 PM
darkleafar's Avatar
Quoted: 81 Post(s)
But when the conditioner it's turned on, the TV turns on automatically. Doesn't that mean it stays in the On state?
Old 03-02-2015, 12:29 PM
cesar123's Avatar
Quoted: 371 Post(s)
Liked: 546
Wow, that is an incredible deal!
Yippee-ki-yay...
cesar123 is offline
Old 03-02-2015, 12:43 PM
Nexgen76's Avatar
Quoted: 421 Post(s)
Liked: 99
Question......I'm waitng on a reply back from someone trying to sell me a Klipsch Reference R-12SW...What i wanted to know is which should i keep up front(Sub 12 or 12SW) ...The other sub going beside the couch which i heard sounds really good.....Also what wired will i need far as connections extending it across the floor to my couch 16-18ft ? Thxs
JVC DLA-RS400U
Denon AVRX6200W
Nexgen76 is offline
Old 03-02-2015, 12:44 PM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
If the TV comes On when you turn on the conditioner, then it is On. My TV (Panny) would remain Off. However, like dkami712 noted, it wouldn't allow the device to "Turn Off Properly." Like turning the key Off in your car, if it could, without going to Park. I know that my BD player (OPPO) has a turn Off routine. Doing a "Hard Reset" can probably do damage to components (i.e. not being able to disengage relays and such) if not allowed to undergo its shut Off routine.
Mongo171 is offline
Old 03-02-2015, 12:45 PM
darkleafar's Avatar
Quoted: 81 Post(s)
Ok thanks
Old 03-02-2015, 12:46 PM
darkleafar's Avatar
Quoted: 81 Post(s)
Unrelated to your question but I have an r12sw and I love it. Just fyi, not sure how much you buying it for but I got it brand new from frys for 199. Hopefully you get a similar deal
Nexgen76 likes this.
Old 03-02-2015, 12:51 PM
Nexgen76's Avatar
Quoted: 421 Post(s)
Liked: 99
Wow.....Let me call Fry now because this is a Craigslist deal & he want 400.00 for it...It's still new he have proof of purchase he got last Nov.
JVC DLA-RS400U
Denon AVRX6200W
Nexgen76 is offline
Old 03-02-2015, 12:55 PM
darkleafar's Avatar
Quoted: 81 Post(s)
To be clear, msrp at frys is 449, but they have this "promo codes" things they do when you sign up for the promo code mailing list where every day you get an email with different sales, and the email will have your personal promo code. You need the promo code to redeem the offer in store. I dont think it works online.
Old 03-02-2015, 12:57 PM
Nexgen76's Avatar
Quoted: 421 Post(s)
Liked: 99
Omg i signed up to their site but i haven't received anything from them....That deal you got was insane....I need that code...lol
JVC DLA-RS400U
Denon AVRX6200W
Nexgen76 is offline
Old 03-02-2015, 12:59 PM
cbatc's Avatar
Quoted: 86 Post(s)
Liked: 32
I use this kit from Best buy. It works pretty good for me
http://www.bestbuy.com/site/rocketfi...&skuId=6965266
cbatc is offline
Old 03-02-2015, 01:07 PM
darkleafar's Avatar
Quoted: 81 Post(s)
Lol at first I bought it for 314, as I got someone to give me employee discount. Then I found the promo code deal and I had them retroactively price match to the 199. Here is an example of when it goes on sale http://www.hotnewdeal.com/2015/01/12...rence_Series_/
Old 03-02-2015, 01:14 PM
Nexgen76's Avatar
Quoted: 421 Post(s)
Liked: 99
Okay bro i was wrong he trying to sale me Klipsch R-112SW for 400.00...Think that on goes always down too 24bd vs the Klipsch 12SW goes to 29db...600 watts vs 400.
JVC DLA-RS400U
Denon AVRX6200W
Nexgen76 is offline
Old 03-02-2015, 01:37 PM
gene4ht's Avatar
Quoted: 748 Post(s)
Liked: 737
I was finally able to install the RB-41 II's and RB-51 II's I bought a couple of weeks ago...wanted to experiment with FH's...these are my impressions. I positioned them at a height of 7 feet above and just inside my 82's and angled them down at my MLP. I installed the 41's first with 3" long wood screws into studs using the speaker's built-in keyhole and extending the screw to attain the angle I needed. I then reconfigured my AVR for 7.2, ran Audyssey, and played with Dolby Pro Logic IIz Height and Audyssey DSX listening modes. Using and alternating both listening modes with various movies and music, my preference is DSX as it sounded more natural to my ears. My understanding is IIz is more suited for game content. I then repeated this exercise with the 51's.
My overall experience puts me in the camp of: It's a very nice "subtle" effect in that FH's do indeed broaden the front sound stage. The degree and the effectiveness depend on the source material that is used to upmix the content. I did not notice a great deal of difference between the 41's and 51's for FH use. The 51's were a bit louder but adjusting the 41's trim up a bit accomplished the same effect. From my experience, smalll/medium FH speakers are more than capable of handling the upmixed FH material...timbre matching could be more important...YMMV. In conclusion, for me, FH's are a nice to have rather than a must have. Unfortunately, my room cannot accommodate FW's.
Now, I will be directing my attention to Dolby Atmos...which I believe will be more of a game changer.
cbatc likes this.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Denon: X6300H (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501 Oppo: UDP-203
gene4ht is online now
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
