Klipsch owner thread - Page 1585 - AVS Forum | Home Theater Discussions And Reviews
 7556Likes
post #47521 of 53910 Old 12-12-2015, 02:22 AM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
I asked this in a separate thread but got nothing so I'm going to post it here:
I'm thinking about upgrading from my RC-62ii to the RC-64ii. I have a home theater that's on the smaller side and I sit about 13 feet from the screen which has the RC-62 right in front of it.
Sometimes it seems that the dialogue is harder to hear when sitting to the side of the RC-62. My thought it that the sound doesn't have time to fully expand into the room since I don't see that far away from the speaker. The RC 64 may create a larger soundstage from the start.
Two Questions: Would the RC-64ii be worth the upgrade for a smaller theater over the 62ii?
If I decided to get the 64ii, what is a good price to try to negotiate with a Klipsch dealer? I see retail is right under $1,100.
thanks
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 4
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #47522 of 53910 Old 12-12-2015, 02:51 AM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 557
thanks
I did exactly that and the upgrade is definitely worth it imo. The 62ii is a good center but to me always sounded small between my then rf82iis. The 64ii sounds a lot bigger and imo a better match to larger floorstanders. I believe there will always be off-axis performance issues with center specific designs but the sheer width of the 64ii helps. There is a timbre match issue but for me this turned out to be a non-issue as I liked the 64 better than the 'direct timbre match center'. A word of warning- if you do purchase the rc64ii you may feel the need to upgrade your mains, and so the journey continues...
Sorry I cannot help with pricing as I am in New Zealand.
(2)RF-83 (1)RC-64ii (2)RF-82ii (2)RC-62ii
(2)Exodus audio tempest-x 15" subs in 200l sealed enclosures
Onkyo 705 pre/pro and rear surrounds
DSPeaker Antimode 8033 sub eq Behringer EP4000 subs
NAD C275BEE mains
AMC 2N100-3 surrounds and center
Robbiey60 is offline
post #47523 of 53910 Old 12-12-2015, 03:00 AM
loudog2's Avatar
Quoted: 264 Post(s)
Liked: 198
Originally Posted by jortb View Post
Took the gamble and ordered a pair of rp-280f's.
They sound much better than the RF-3's. indeed more civilised highs and deeper, cleaner basses.
I am very happy with them.
Thanks guys.
Congrats! Im glad you agreed, they do sound better than or old RF-3's. I got a good 14 year run out of my RF-3's. It was time to upgrade. Now they are running back surround duties.
Robbiey60 likes this.
Sony 940C*Sony HX909*Samsung K8500*Yamaha 3050*klipsch front RP-280's*rear RF-3's*center RP-450C*Sides RP-280's*front heights RP-140's*overhead 5650cii's*SVS-PB2000x4*emotiva XPA-5*Yamaha YSP-1600 sound bar*Sony HT-CT370 sound bar
loudog2 is offline
post #47524 of 53910 Old 12-12-2015, 03:03 AM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
Thanks for the response. I don't see myself getting rid of my rf62ii's. They are plenty big enough for the room. Also, I have two massive 15 inch subs in there taking up even more space.
New Zealand, huh. The wife and I may be visiting next year. We have a couple friends in Auckland.
AVR: Denon X2200W
Prime316 is offline
post #47525 of 53910 Old 12-12-2015, 03:16 AM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 557
Have you tried them as side surrounds? I had 7.1, dropped back to 6.1 and now am happily running 5.1 as the towers as side surrounds sound so good.
NAD C275BEE mains
post #47526 of 53910 Old 12-12-2015, 03:45 AM
loudog2's Avatar
Quoted: 264 Post(s)
Liked: 198
I was going to test them out there eventually. Just haven't gotten around to it yet. Right now I have my 160m's as sides. I moved the 160's from the backs to sides then put the rf-3's there instead. I was thinking about selling the rf-3's or moving them upstairs with my old Yamaha 2600 for the living room. But I could let them go. Too emotionally attached to my 14 year old babies! LOL.
loudog2 is offline
post #47527 of 53910 Old 12-12-2015, 03:49 AM
Liked: 5
I took the rf-3's To my office for the friday afternoons.
psgcdn likes this.
jortb is offline
post #47528 of 53910 Old 12-12-2015, 04:50 AM
cchunter's Avatar
Quoted: 538 Post(s)
Liked: 833
thanks
If you shop around and make some phone calls you should be able to get the 64 for around 8-900. Maybe even cheaper now that they are considered older style to the premier line.
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
Klipsch RF7II's, RC-64II, RS-62II's
SVS Dual SB13 Ultra's
Oppo UDP-203 4K Sony PS4 Pro Panamax 5300PM
cchunter is offline
post #47529 of 53910 Old 12-12-2015, 05:39 AM
razevents's Avatar
Quoted: 75 Post(s)
Liked: 26
Hello and welcome. You may want to try the klipsch forums, lots of 2ch only guys over there and they are all willing to help. Unfortunately I have not heard rf3 or rp280f but I have read the new line is more laid back for music. The only comparison I can give is between rf82ii and rf83 with the latter being a lot smoother in the highs and tighter in the bass. Sorry I cant help more.
I may be making a purchase of 280s very soon. Also been running RF3 since 2002. If so will report back.
razevents is offline
post #47530 of 53910 Old 12-12-2015, 06:15 AM
dmb12679's Avatar
Quoted: 551 Post(s)
Liked: 258
thanks
64 is awesome, I would drop my 7's to 82's before I would drop my 64. I got mine for 899 on ebay. I want to see a picture of the 64 on end next to the 62, they have to be about the exact same size. lol
Marantz SR6010 -- Marantz MM7025 -- Marantz UD5007
Klipsch RF-7ii's - RC-64ii - RB-51ii's - RS-42ii's - R-112sw(x2)
HK990 -- HD990 -- Klipsch RF-7ii's
dmb12679 is offline
post #47531 of 53910 Old 12-12-2015, 09:46 AM
Quoted: 95 Post(s)
Liked: 60
Originally Posted by Tasdom View Post
8) The RB-81s used as front wides will be on speaker stands between the front RF7IIs and the subs.
That somewhat defeats the purpose of wides does it not?
How so? Please explain? To clarify, the front wides will be wider than the front mains. So, closer to the side wall than the front mains (the subs are in the corners).
The front wides will be at a 55-60 degree angle to the center speaker as measured from the recliner. The front mains will be between 22-30 degrees.
Please let me know if I'm missing something.
Power Sound Audio: 2 V3600i dual 18" subs; SVS: sub interconnects; Klipsch: 4 R-115SW subs, 5 RF-7 IIs (center, front mains & side surrounds), 6 RB-81 IIs (front wide, front height & rear surrounds); Belden: 10 AWG copper speaker wire; Sewell Direct: Deadbolt banana plugs; ATI Morris Kessler Signature amps: AT6005 & AT4006; Mogami Gold: interconnects; Marantz Pre-amp: AV8802A; Oppo: UDP-203; Roku Ultra; PS4; APC; Mid Atlantic: RCS-27U rack w/fans; Epson: 5040UBe projector; Elite: 125" AT screen.
Tonycpa2004 is offline
post #47532 of 53910 Old 12-12-2015, 10:30 AM
benso37's Avatar
Quoted: 45 Post(s)
Originally Posted by benso37 View Post
I'm considering matching all my speakers to be Klipsch but that decision hasn't been made yet. It looks like the true match for the R-26's will be the R-25C and R-15M's though. I think the rp-450c will be too big for my needs. I will go for the RP-250C and perhaps replace the Def Tech speakers.
Thanks for all the suggestions.
So, I purchased the RP-250c to go along with the R-26 fronts. I was able to sell all three Def Tech speakers in my system this week so I'm going to buy Klipsch speakers for my back surrounds and maybe the Atmos modules to complete my system.
For the back speakers, I'm looking at the RP-150M or the R-15M. Can you guys recommend the best match for my system.
I currently have two R-26's for fronts, one RP-250c for center and two Energy 5.1 bookshelves working as my surround sides. The Energy speakers will be replaced with two Klitsch bookshelves or two Klitsch Atmos speakers depending on which receiver I end up buying.
In the meantime, I need help selecting either the RP-150M or the R-15M. They will be mounted on the wall.
Edit: I will also consider the R-14S or RP-240S if they are better suited for my system.
benso37 is offline
post #47533 of 53910 Old 12-12-2015, 11:40 AM
Tasdom's Avatar
Quoted: 156 Post(s)
Liked: 585
You stated the 81's will be inside the 7II's
They (81's)would need to be outside the L/R to work as wides (unless you wire the 7's as wides instead)
It will sound great regardless!
Tonycpa2004 likes this.
Onkyo Pre/Pro PR-SC5508 & Emotiva XPA-5's x 2
Klipsch RF-7II's Mains RC64II Center RB75's Heights RS-7's Sides RS-52II's Rears
Klipsch RW-12D Subs x 2
Klipsch Belle's
OPPO BDP-105 with Roku Streaming Stick
Epson 6030UB / Vapex 120" Electric Tensioned Screen
Tasdom is offline
post #47534 of 53910 Old 12-12-2015, 11:49 AM
ClintonH's Avatar
Quoted: 101 Post(s)
Liked: 49
"So, closer to the side wall than the front mains (the subs are in the corners)."
You read it wrong, his RF-7 II will be on the inside of the RB-81's , subs in the corner.
ClintonH is offline
post #47535 of 53910 Old 12-12-2015, 12:11 PM
Tasdom's Avatar
Quoted: 156 Post(s)
Liked: 585
ahh I did read it wrong. My bad, I see what you are saying now.
carry on.......
Klipsch Belle's
Tasdom is offline
post #47536 of 53910 Old 12-12-2015, 01:17 PM
Quoted: 95 Post(s)
Liked: 60
To clarify, they will be outside the 7IIs. I guessed that the wides would end up between the front mains and the subs. Meaning from left wall to right wall...left corner sub, left wide, left main, center, right main, right wide and right sub.
So, we are good. Thanks for clarifying the question.
I had not measured the final position of the front wides when I posted earlier but your question prompted me to check the recommended placement per my Denon owner's manual (which is front wides 55-60 degree angle to the center speaker as measured from the recliner, while the front mains will be between 22-30 degrees. Turns out 55-60 degrees will be a shelf I build on the side walls (somewhere between the front subs and the side surrounds)...that will be the home for the front wides
post #47537 of 53910 Old 12-12-2015, 01:50 PM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 557
I like monopoles as surrounds and they are actually recommended for integration with atmos speakers. Why not save and get rp260f as mains and move r26f to surrounds? If you must have bookshelves the rp are the better speaker but then your mains will be of a lower line to the rest of your speakers.
Edit: you would still have a good system with the r15m.
post #47538 of 53910 Old 12-12-2015, 02:17 PM
benso37's Avatar
Quoted: 45 Post(s)
Due to space constraints and furniture placement, I won't be able to add two more floorstanding speakers to my setup. I guess that means that I'm stuck with the R-15m for my rear and side.
benso37 is offline
post #47539 of 53910 Old 12-12-2015, 02:21 PM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 557
My friend will be getting a system very similar to yours with rp260f instead of r26f. The r15m will be fine for surrounds matched with both systems and will be better than what both of you have now.
post #47540 of 53910 Old 12-12-2015, 02:52 PM
Quoted: 485 Post(s)
Liked: 149
Agreed. My only concern is with mounting the bookshelves on the wall, since both the R and RP are rear ported. Although a higher crossover and possibly some EQ like Audyssey could combat that.
dkfan9 is offline
post #47541 of 53910 Old 12-12-2015, 03:24 PM
benso37's Avatar
Quoted: 45 Post(s)
I should have about 2 to 3 inches behind the speakers. Will that not be enough? My current receiver also supports Audyssey MultEQ XT32.
benso37 is offline
post #47542 of 53910 Old 12-12-2015, 04:30 PM
Quoted: 95 Post(s)
Liked: 60
Originally Posted by dmb12679 View Post
Please post pics of your set ups when complete. Congrats on some major purchases! I think they will sound amazing.
Some updated photos as of right now. When the amps arrive in Jan/Feb, I will post again.
Thanks for the info, thats 2 nice setups you have there and 1 very nice room!
Here is how they are set up right now. All the Klipsch speakers are approximately where they will wind up. I am waiting until the amps arrive (by the end of January or early February) before I measure everything and run Audyssey. Too much work to do it twice.
Some things that will change in the photos below...
1) All wires will be cut to the right length and hidden once I determine where I will place the amps. Right now, I think they may go in a Mid Atlantic rack or Sanus rack which will be placed behind the screen in the center of the room next to my center channel speaker (which is in transit). I hope to receive suggestions from everyone regarding if I should go with a rack or amp stands, and where you guys think that should be located.
2) The RF7 II which I will use for my center channel will go behind the acoustically transparent Elite screen. It will be centered between the left and right walls. The Monster Power (bottom shelf, left side), Denon X-5200W (bottom shelf, middle), PS4 (top shelf, left side), Amazon FireTV and External TV Tuner (top shelf, right side) will be placed in the rack along with the two amps. The RC-64 II center speaker in the photo below, TV stand and old Denon AVR (bottom shelf, right side) will all be removed from the room.
3) The RF7 IIs that I am using for my front mains will be moved just a little closer to the screen than shown in the photos below (they are between a 22-30 degrees angle to the center speaker as measure from the recliners). The RB81 IIs used as front heights will be right above the front mains (as shown in the photo below). The R-115SW front subs will remain in the front corners of the room (as shown in the photos below).
4) I will build a shelf on the side walls to hold the RB81 IIs used as front wide speakers. So, they will be somewhere between by front subs and my side surrounds (at an angle between 55-60 degrees from my center speaker as measured from my recliners).
5) The RF7 IIs used as my side surrounds will stay where they are about two thirds of the distance from the front wall to the rear wall (slightly more than a 90 degree angle to the recliners). The R-115SW rear subs will remain in the rear corners of the room (as shown in the photos below).
6) The RB81 IIs used as my rear surround will stay as they appear in the photo below.
Any other suggestions are welcome.
RC-64 II will be swapped out and replaced with one RF7 II - center channel which will be centered between the side walls. A Mid Atlantic or Sanus rack will be place on the right or left side of the center RF7 II and will hold both amps, the Denon X-5200W, the Monster Power, PS4, Amazon FireTV and External TV tuner. Wires will be hidden.
RF-7 IIs front main channel (will be moved closer to the screen), RB-81 II front height channel (will be right over the front mains), RB-81 II front wide channel (I will build a shelf on the side walls somewhere between the front subs and the side surrounds to hold these) and R-115SW front subs (will remain in the front corners of the room). Wires will be hidden.
RF-7 IIs - side surround channels and R-115SW rear subs (will remain in the rear corners of the room). Wires will be hidden.
RB-81 IIs - rear surround channels. Wires will be hidden.
post #47543 of 53910 Old 12-12-2015, 04:47 PM
Mongo171's Avatar
Quoted: 994 Post(s)
Liked: 1425
Don't have anything over the amps. They need to be able to have air circulate around them.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #47544 of 53910 Old 12-12-2015, 04:59 PM
Quoted: 95 Post(s)
Liked: 60
Hey pal, I hope all is well.
Do you recommend amp stands like these instead?
I was more impressed with the racks in this thread... Show me your RACK
Do you not believe the Mid Atlantic racks will allow the ATI amps enough room to breath?
Here are some images of Mid Atlantic racks...
http://www.middleatlantic.com/produc...nclosures.aspx
https://www.google.com/search?q=mid+...ctj6oCEgA5M%3A
Here are some images of Sanus racks...
http://www.sanus.com/en_US/products/racks/#tab-one
post #47545 of 53910 Old 12-12-2015, 05:16 PM
Quoted: 485 Post(s)
Liked: 149
It could work out alright, and I'm hardly opposed to unconventional speaker/layout choices (I have an entirely unmatched 5.0 Klipsch setup). I bet you can make it work, either it will work on its own, or with the help of crossover level and/or Audussey.
dkfan9 is offline
post #47546 of 53910 Old 12-12-2015, 05:21 PM
Mongo171's Avatar
Quoted: 994 Post(s)
Liked: 1425
Do you recommend amp stands like these instead? http://www.youtube.com/watch?v=iQn_9rC05N0
The Mid Atlantic racks will work. Seems like they have an exhaust fan. If they get enclosed or mounted with other equipment within a rack, make sure you have good air flow. Heat is the #1 killer of electronics.
Mongo171 is offline
post #47547 of 53910 Old 12-12-2015, 06:25 PM
Liked: 2
I posted this in the polk thread but thought I'd ask here too. The Polk Monitor 75T is on sale for $469 for a pair. Should I jump on that, or get two RP280F at $479 each? Cheers.
Nuova is offline
post #47548 of 53910 Old 12-13-2015, 08:01 AM
Quoted: 95 Post(s)
Liked: 60
No need to worry about heat in my room, it never hits 70 degrees. Check that second photo I posted above...yes, the A/C is on in December! HAHA!
post #47549 of 53910 Old 12-13-2015, 09:57 AM
Mongo171's Avatar
Quoted: 994 Post(s)
Liked: 1425
We keep our heat set at 65*. The room temp isn't the main problem. It's the interior temp of the amp and its ability to have adequate air flow around it to dissipate the heat.
Mongo171 is offline
post #47550 of 53910 Old 12-13-2015, 01:01 PM
ceptorman's Avatar
Quoted: 324 Post(s)
Liked: 484
I have a feeling the Klipsch will sound better, for music and movies.
650cc on the track
1000 cc on the street
800cc on the snow
ceptorman is online now
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
