Klipsch owner thread - Page 1636 - AVS Forum | Home Theater Discussions And Reviews
 7372Likes
post #49051 of 53536 Old 04-25-2016, 04:41 PM
Quoted: 74 Post(s)
So I also found a pair of RF-82 II's for $500/pair. So there's that, the RF-3 II's for $350/pair, or the RP-280's for $700/pair.
rrobinson1216 is offline
post #49052 of 53536 Old 04-25-2016, 04:43 PM
itsmyforte's Avatar
Quoted: 221 Post(s)
Liked: 114
IMO get the 280 and don't think twice.
Sent from my VS986 using Tapatalk
itsmyforte is offline
post #49053 of 53536 Old 04-25-2016, 04:43 PM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 552
Originally Posted by itsmyforte View Post
The RF7 is the only Reference speaker currently made that uses a "compression driver". However all of our tweeters are under compression.
http://images.klipsch.com/RF82II_635042119237310000.pdfSo I have been arguing the point using this which you are now telling me is wrong? I have a few apologies to make but perhaps it should not be on the spec sheet if it is not correct?
(2)RF-83 (1)RC-64ii (2)RF-82ii (2)RC-62ii
(2)Exodus audio tempest-x 15" subs in 200l sealed enclosures
Onkyo 705 pre/pro and rear surrounds
DSPeaker Antimode 8033 sub eq Behringer EP4000 subs
NAD C275BEE mains
AMC 2N100-3 surrounds and center
Robbiey60 is online now
post #49054 of 53536 Old 04-25-2016, 04:51 PM
itsmyforte's Avatar
Quoted: 221 Post(s)
Liked: 114
It technically isn't wrong. As I said all of our tweeters use compression. Don't feel cheated or disappointed that most models don't use a "compression driver". Trust me, many common models available on the consumer market are not very good. Our LTS tweeters really are very good, and do really have compression.
post #49055 of 53536 Old 04-25-2016, 04:52 PM
Quoted: 74 Post(s)
Thanks for the advice! Definitely seems to be where a lot of people are leaning to. It's going to be torture with it sitting there doing nothing for two weeks until the second is aquired, but I think it'd be worth it.
post #49056 of 53536 Old 04-25-2016, 05:06 PM
itsmyforte's Avatar
Quoted: 221 Post(s)
Liked: 114
Fo sho, the 2 weeks will fly by.
post #49057 of 53536 Old 04-25-2016, 05:07 PM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
The tweeters allow the speaker to have "clarity" where other manufacturers' tweeters sound muffled. The "brightness" factor of the Klipsch has anything else beat hands down.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #49058 of 53536 Old 04-25-2016, 05:13 PM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 552
All great speakers but if you can afford the 280s get them. Used is a great option if budget is a concern
post #49059 of 53536 Old 04-25-2016, 05:17 PM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 552
Still a great product and sound better than a lot of others in their price range. Still a bit annoyed I was wrong following the spec sheet on the Klipsch website. Doesn't really change anything I know just makes me look silly. Please tell me at least my rf83s have true compression drivers? Or I will have to get 7s, it would drive me nuts
post #49060 of 53536 Old 04-25-2016, 05:35 PM
itsmyforte's Avatar
Quoted: 221 Post(s)
Liked: 114
Compression driver models
from memory
RF7, RC7, RF63, RF83, RC64, RC64 II, RF7 II.
Legend Series...
KLF 20/30 midrange
Don't remember on C7, or KLF-10
Classics...
Quartet midrange
Chorus I/II midrange
Forte I/II midrange
Tangent line...
All midrange models
Heritage pre Heresy II...
All tweeters and mids
Heresy II/III mid only
Cornwall III mid only
Technically anything Klipsch makes that isn't a direct radiator is a compression driver. I merely listed out all pre-made compression driver designs I could recall.
post #49061 of 53536 Old 04-25-2016, 06:41 PM
mpirnat's Avatar
Quoted: 152 Post(s)
Liked: 121
Hook it up and throw your AVR into mono? :-D
Or just wait two weeks and get them both in one shot?
Robbiey60 likes this.
mpirnat is offline
post #49062 of 53536 Old 04-25-2016, 06:48 PM
Quoted: 74 Post(s)
That's true - I think the main reason I want to get the first one right off the bat is partially to keep myself from using that money for anything else I'm terrible like that. But I'm definitely sold on the 280's. I was before, just had to fight off the temptation of 'cheaper then upgrade later' which translates more to 'you've spent more money'.
post #49063 of 53536 Old 04-25-2016, 08:09 PM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
If anyone of you might happen to be one of the twelve people watching this listing. Beware that they might have structual damage that is not listed. After close inspection I noticed one of these speakers have two screws in the top corners of the back. Just a heads up. http://www.ebay.com/itm/Klipsch-KLF-...AAAOSwjKpXHA5i
ID:	1404922   Click image for larger version
Denon X6200W - Klipsch KLF-10 Fronts - Klipsch KLF-C7 Center - Klipsch KLF-C7 X 2 Surrounds - Klipsch RB-61 II Back surround -OSD ACE850 ceiling x 4 Atmos - Dual HSU VTF-3 MK4 Subs - 4 Dayton Audio BST-1 Bass Shakers with SA230 Amp - BenQ W1070 projector - 106" Antra fixed Screen
Soupy1970 is offline
post #49064 of 53536 Old 04-25-2016, 08:14 PM
itsmyforte's Avatar
Quoted: 221 Post(s)
Liked: 114
A case of glue failure with a bad fix applied. They can still be saved, however I would not pay as much. Repair time is money.
Soupy1970 likes this.
post #49065 of 53536 Old 04-26-2016, 02:03 AM
ceptorman's Avatar
Quoted: 315 Post(s)
Liked: 472
I would wait and get both at the same time also. It's not a big deal, but they would probably have consecutive serial numbers that way. I've heard great things about the RP280s. Good luck.
650cc on the track
1000 cc on the street
800cc on the snow
ceptorman is offline
post #49066 of 53536 Old 04-26-2016, 02:22 AM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
I haven't seen consecutive serial numbers in a long time. Does it still happen? My La Scala's did. My Chorus II's didn't. Neither did my RS-62's.
Mongo171 is offline
post #49067 of 53536 Old 04-26-2016, 04:45 AM
Quoted: 74 Post(s)
These are a used pair, so no idea if they do or not, but I can always ask him. I'll be getting both either way, so for this set it wouldn't matter if I waited or not. He seems to have kept them in great shape, and $700 for the pair instead of the retail $1200 or $960 current cherry sale price got my attention for sure. I'm going to head to Fry's after work today and see if I can listen to any of them.
post #49068 of 53536 Old 04-26-2016, 10:21 AM
Quoted: 24 Post(s)
I just picked up a pair of RP-280F's this weekend.
Sounds quality is fantastic!... as long as I'm sitting in exactly the right place - and I mean *exactly*. I noticed a kink in my neck at one point because I was leaning over to be in the sweet spot. Move from that sweet spot and the sound seemed much more, umm, mediocre.
These are my first new speakers in a long time, and I guess that's how things are done nowadays.
Anyone know of a way to broaden the sound a bit, so that I can invite a guest (or my family) to watch movies with me?
-Bob C.
bobc455 is offline
post #49069 of 53536 Old 04-26-2016, 10:34 AM
Mongo171's Avatar
Quoted: 973 Post(s)
Liked: 1398
Spread the speakers out. They do have a 90 degree horizontal and vertical tweeter dispersion that should give you the same sound.
Mongo171 is offline
post #49070 of 53536 Old 04-26-2016, 11:09 AM
cyclones22's Avatar
Quoted: 124 Post(s)
Liked: 148
Yep, speaker location and positioning matters. For any kind of speaker. Distance from walls, toed in or not etc.
Denon X4200W, Emotiva XPA-5
Klipsch RF-7II Front Cherry (x2), RC-64II Center Cherry, RP-280FA Surround/Atmos (x2), RP-140SA Atmos (x2)
SVS SB-2000 Subwoofer (x2)
OPPO BDP-103D, Sony UBP-X800, Synology NAS
LG OLED65C6P
cyclones22 is offline
post #49071 of 53536 Old 04-26-2016, 11:27 AM
Quoted: 74 Post(s)
-Bob C.
This is what kind of worries me a little bit - my bedroom is only 11' x 12', and the 280's would be on the shorter wall facing the longer end. Wondering if they might be too much to get started with - how big is the room you're using? Really, my only other current choice would be to go with the pair of RF3-II's that are half the price and the 12" subwoofer, then expand from there to 5.1 - then, down the road, move the RF3-II's out and replace them with RP-280's. Can anyone say whether Fry's has live demos of the RP series? Looking to go today perhaps, but bad storms are coming...so who knows...
Cyclones22, I see you have the RF7-II's - how do you like those? Do they compare to the 280's, and the RF3-II's would compare to something like the 250 or 260's?
post #49072 of 53536 Old 04-26-2016, 01:29 PM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
I don't have the RP-280", but I have horns. My room is just over 13' wide, and my speakers are spread out to 11' and toed in. I think Paul Klipsch recommended toeing in speakers, but that might have been more in relation to stereo recordings. I might still have the Dope from Hope article (I'll look).
Below shows my toe in. First picture is older and I have since removed the Klipsch Ceiling speaker for in-ceiling speakers. Just for kicks, I'll include a picture of the new surround stand I just built for my KLF-C7 as surrounds.
ID:	1406562   Click image for larger version
post #49073 of 53536 Old 04-26-2016, 01:35 PM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
Your AVR should set the correct trim for your speakers, so going from one horn to the next probably won't matter much. Stick with the biggest you can afford. By the way the RF-7II is the Reference line Flagship speaker. Everything is larger on the Rf-7's like the 10" woofers, the Horn, the 1.75" tweeter, and the Cabinet. It's still made in USA. I'm sure the Crossover etc are even better components.
post #49074 of 53536 Old 04-26-2016, 01:38 PM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
Dope from Hope article on Toeing in Speakers.
https://community.klipsch.com/dope/D...0801_v15n2.pdf
post #49075 of 53536 Old 04-26-2016, 02:08 PM
ceptorman's Avatar
Quoted: 315 Post(s)
Liked: 472
I know some are concerned with it, but I don't think it's a big deal. My Klipsch speakers don't have any serial numbers!
650cc on the track
800cc on the snow
post #49076 of 53536 Old 04-26-2016, 02:10 PM
ceptorman's Avatar
Quoted: 315 Post(s)
Liked: 472
Oh….I didn't know they're used. That is a good buy, and I'll bet you will like them.
650cc on the track
800cc on the snow
post #49077 of 53536 Old 04-26-2016, 02:13 PM
Quoted: 74 Post(s)
I'm curious as to what you mean by the move from one horn to the next won't matter much (which models)? My new AVR is the Yamaha RX-V479, which has 115w per channel, is only 5.1 though - but I don't plan on expanding to 7 or more for a long time anyway and I got a killer deal on it price wise, so I'm not complaining there.
Right now, it's basically been narrowed to two choices for my fronts at the moment, the RF3-II pair, or one RP-280 then another in 2 weeks for double the investment, but both are used - of course, they both look great and both sellers are going to let me test them out when I see them. I'm sure they won't mind me giving them the once over. Can't wait to get started either way! Definitely need to find a decent A/V tower to go below my TV too.
post #49078 of 53536 Old 04-26-2016, 02:17 PM
Quoted: 74 Post(s)
Yeah, I'm not sure if they consecutive, but they might be - he might have bought them that way. Overall a much better deal to invest another 350 in rather than going with the lower reference line? It'll take a while to build the rest but I'm alright with that.
post #49079 of 53536 Old 04-26-2016, 03:32 PM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
My reply was in reply to your comment that you were worried that the RP-280 might to much for your size room and that the RF-3 was your only other choice. You would dial the trim to fit either speaker and one isn't going fit any better over the other. Modern AVR's set the Trim level, or you can use a inexpensive SPL meter to set the trim levels yourself. It won't matter much going from the RP-280 to the Rf-3 in that regards (or any other size reference floor standing).
post #49080 of 53536 Old 04-26-2016, 04:04 PM
Quoted: 74 Post(s)
Gotcha, thanks! Can't wait to hear the 280's on Friday.
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
