Klipsch owner thread - Page 1692 - AVS Forum | Home Theater Discussions And Reviews
 5644Likes
post #50731 of 50751 Old Yesterday, 06:07 PM
Liked: 1
Originally Posted by Alanlee View Post
It looks like you have enough speakers for a 5.1 system. The Lx-101 will drive two speakers at 80 watts, so if you are driving 5 speakers ( the sub-woofer has its own power) the output will be less than 80 watts per channel. I don't see how to tell from the specs that pioneer provides whether or not that is enough power, so you may not know until you hook everything up and listen.
I don't know your financial situation or the conditions under which you bought the AVR. My experience has been that dealers will let you return an AVR if you want to trade up.
But again you may be very happy with the sound you get from the Lx-101. I have had two Pioneer Elites; they are solid machines.
In terms of future expansion, you could make a 7.2 (two rear surrounds and two subs), or you could put speakers on your ceiling and create a 5.1.2 system for Dolby Atmos and/or DTS-X.
Personally, I think you have a good start, and if you want to grow your system in the future, you will be able to work your speakers into that expanded system.
Doesnt all Pioneer Elite AVR's have class D amps?
Chase_Monkey is offline
post #50732 of 50751 Old Yesterday, 06:15 PM
Quoted: 14 Post(s)
Liked: 1
They do from like 2009 and up, but the original ice amps are known to fail... D3 amps are good which I believe is 2011 and up, to be honest, if I was him, I would return the new pioneer elite receiver, and buy a higher end receiver from pioneer that is 2 or 3 years older, that way he could get the flagship ones that cost around 1600-2500, and have just as many features if not more...
Brandon8791 is online now
post #50733 of 50751 Old Yesterday, 07:32 PM
robc1976's Avatar
Quoted: 87 Post(s)
Liked: 69
Originally Posted by Brandon8791 View Post
Well... I got the RC-62 II in today, I have to say, this is a big center channel lol, and it is beautiful and matches the other reference speakers I have... but to be honest, I went from a Polk c15, to this RC-62 II... and while it does seem it matches better and everything, I don't seem to notice much more of a difference, is there something I'm missing? I'm just confused with a speaker that is 4 times the price shouldn't there be something big I'd notice? I noticed a great difference moving from the Polk monitor 40 to the rf-82 II, but the same didn't happen with the center, not disappointed in it, but just sort of surprised, glad I have a matching set though lol... maybe I should do A-B-A-B testing
lot of variables:
Are you using Audyssey xt ir better yet X32? I use audyssey pro and with each step up you will notice a difference.
Have you put a laser (measure where tweeter is then put dot on front ave rear, connect dot with laser) on the sides of the center to MLP to be sure center tweeter is at ear height?
Crossover start at 80htz unless audyssey sets it higher (never lower where audyysey sets it).
I prefer these audyssey tweaks
1. DEQ = off
2. DV = OFF
3. Audyssey flat (I have a highly treated room)
4. Tone controls on with +5DB bass (this inky effects mid range bass, not LFE OUTPUT)
I would focus on positioning of center, a 1/8" seriously matters.
robc1976 is offline
post #50734 of 50751 Old Yesterday, 08:18 PM
Liked: 0
Thanks for your input, I also think it should be a good start and I like that its "futureproof" so to speak
eyalha is offline
post #50735 of 50751 Old Yesterday, 08:22 PM
Liked: 0
Originally Posted by ClawAndTalon View Post
The first thing you'll do down the road is upgrade your sub. Otherwise this is more than enough to be dangerous. That Pioneer should be plenty of power for moderate to spirited volumes.
I was considering a different sub at first but this was a package deal (speakers only) but as you said nothing is forever and I hope I wont be disappointed with the receiver
eyalha is offline
post #50736 of 50751 Old Yesterday, 08:27 PM
Quoted: 18 Post(s)
Liked: 0
Saw the sale on Klipsch speakers just now, how do the RB 61 II compare to the RP 150-M? its a $5 difference currently.
I'm coming from Pioneer BS22LR 5.1 system, will be used 90% for movies and TV. I'm also considering ELAC Debut/Uni Fi System or KEF Q100. I plan to save up for a sub later from SVS. These would be powered by Pioneer SC 63.
If its a big upgrade in quality I will likely buy, but if its only small difference i will wait and save up. I am hoping these speakers would last for at least 5-6 years.
These are going in an apartment fyi so not going to be turned all the way up.
ultraman352 is offline
post #50737 of 50751 Old Yesterday, 08:27 PM
Liked: 0
I bought the receiver separately so I can always exchange/return it, it cost me 700CAD which is about 550USD so for about that price (could go higher but only if its a significant improvement) is there anything you'll recommend? looking for something for at least 3-4 years
eyalha is offline
post #50738 of 50751 Old Yesterday, 08:35 PM
robc1976's Avatar
Quoted: 87 Post(s)
Liked: 69
RB61II will blow them out of the water, especially in bass response. I have 4 of them (2) heights 2 surrounds.
robc1976 is offline
post #50739 of 50751 Old Yesterday, 09:06 PM
jabu32's Avatar
Quoted: 85 Post(s)
Originally Posted by retro124 View Post
I had RS-52II's what I just sold and I have now RS-62II's.
They all are great surrounds. When I had speakers like you now (RF-82II's with RC-62II) I got RS-52II's and they are great.
How far they going to me from your MLP?
right now mine are 4ft from MLP. the furthest i could go is 7ft mounted on the wall.
Denon x3300w
Klipsch RF-82II - Main
Pioneer SP-T22A-LR - Atmos Fronts
Klipsch RC-62II - Center
Klipsch R-15m - Surround
Klipsch R-12sw - Subwoofer
jabu32 is online now
post #50740 of 50751 Old Yesterday, 09:39 PM
jabu32's Avatar
Quoted: 85 Post(s)
do you guys angle your mains inward?
Denon x3300w
post #50741 of 50751 Old Yesterday, 10:07 PM
robc1976's Avatar
Quoted: 87 Post(s)
Liked: 69
I have wides and fronts that I put dot in middle of speaker, run a laser so laser goes thru middle of tweeter ava the line goes on my mlp seat a bit wider that's shoulders.
robc1976 is offline
post #50742 of 50751 Old Yesterday, 10:10 PM
jabu32's Avatar
Quoted: 85 Post(s)
You want them wider then your shoulders?
Denon x3300w
post #50743 of 50751 Old Yesterday, 10:30 PM
robc1976's Avatar
Quoted: 87 Post(s)
Liked: 69
not the speakers themselves but toed in so they are just slightly wider that's shoulders. I Ann a 300lb weight lifter so my shoulders are lot wider so I use my wife's for reference lol! Is this a dedicated room or just a casual setup?
robc1976 is offline
post #50744 of 50751 Old Today, 12:41 AM
Quoted: 433 Post(s)
Liked: 117
Toe in your speakers, either at the listening position or in front of the listening position.
Living Room: Denon X2100W|Klipsch R-28F|Klipsch Academy|Klipsch KT-DS
Bedroom: Sony STR-DA5ES|Klipsch P-17B
dkfan9 is online now
post #50745 of 50751 Old Today, 05:35 AM
Quoted: 14 Post(s)
Liked: 1
Me personally, I sold my SC-68 because there wasn't a good improvement from the SC-65, but, you could return the receiver u got, if u paid around 550 for it, you could probably get an SC-79 or SC-87 for that price, just have to look on ebay for used ones. It would definitely be an improvement over the one u have, would have more features, and be a better higher powered amp. I got my SC-65 for like 350 or 375 with a 2 year extended warranty.
post #50746 of 50751 Old Today, 06:20 AM
Quoted: 56 Post(s)
Liked: 44
I have the 8" variant, the RB81ii, on corner bookshelves in my office driven by my Emotiva a-100 mini-X (50 Wpc) and Onkyo C-7030 CDP in a dedicated stereo system. The largest Reference line bookshelf speakers were chosen due to their advertised LF response and SPL rating, as well as the ease of placement due to their front porting design. Their choice was also influenced by their availability then and price (Cost after discount for 'trying' a new Amazon CC: $209/ea!). In retrospect, the slightly smaller RB61ii's, which are also front-ported and give up very little to my RB81ii's in spec's (45Hz vs 44Hz @ -3dB & SPL of 95 dB vs 97 dB!), would have been easier to place due to size and weight (~10lb/ea lighter!).
In an odd turn of events, earlier this fall I found my VG++ '77 vintage Heresys and placed them in front of the corner bookcases, adding a new Emotiva A-100 BAS-X to drive them. I can now A-B the two speakers. Their is no doubt - the RB's are brighter, go lower, and are slightly more sensitive than the vintage Heresys. Understandably, the vintage Klipsch speakers have a bit more presence due to their MF horn (Actually, they have the same MF & HF horns as the then model Klipschorns!). The pair are enough different that I am not in any hurry to decide which pair I like best. I would say that by interpolation, the RB61ii's would make a fine sounding main set of speakers - and, at $329/pr vs $1,998/pr for the Heresys, clearly, they are a great value!
Of course, I've always wanted the Heresys... and even my older pair sound great...
Stainz is offline
post #50747 of 50751 Old Today, 06:26 AM
Quoted: 24 Post(s)
Liked: 34
FS: Klipsch RP-450C **MINT**
See link for klipsch center for sale
iThor is online now
post #50748 of 50751 Old Today, 06:50 AM
jabu32's Avatar
Quoted: 85 Post(s)
Dang I just bought the rc-62ii
I may have a buddy that wants it
iThor likes this.
Denon x3300w
post #50749 of 50751 Old Today, 06:58 AM
Quoted: 24 Post(s)
Liked: 34
Let me know, I need it gone asap!! Trying to sell some stuff I no longer use to make some extra cash for Christmas
iThor is online now
post #50750 of 50751 Old Today, 07:50 AM
ereed's Avatar
Quoted: 569 Post(s)
Liked: 255
I have one just like it and I love it! Also I've mentioned before that I love your new Paradigm center also. Any big center speaker is a good center speaker.
iThor likes this.
Main theater: Sony 45es, 120 inch ST screen, Panny BDT500, Rotel RMB-1075, Rotel RSP-1068, Klipsch RP-280F, RP-450C, RP-160M, SVS PB13-Ultra x 2
Loft theater: Panasonic 60" plasma, Integra DTR-30.3, Axiom Audio M60, VP150, QS8, EP500
ereed is online now
post #50751 of 50751 Old Today, 09:53 AM
Quoted: 172 Post(s)
Liked: 71
Hmmmmm...............the two most important speakers are the center and the sub in my opinion, so maybe another sub. Since we are talking down the road, hold on to your pocketbook, and buy a beefier center, then you take the center you have and put it in service as a rear surround. If you want a second rear surround, you might find it on eBay where there is a nice used market for Klipsch speakers.
In the meantime lurk around this forum researching the infinite possibilities for audio systems.
Wow - I find it very satisfying to spend someone else's money. Thanks for the opportunity.
7.4.4 system with Denon 5200 (Height 1, Height 2), Emotiva XPA-5 (front, center), NAD 275 (front, middle Surround), NAD 275 (Rear Surround), All Klipsch speakers: Cornwall (front), 2 Heresy (center), 2-kg-1.5 (front surround), 2-kg-1.5 (middle surround), 2 RS-7 (rear surround), 4 KSW 15 (sub), 2 SA-2 height-1, 2 SA-2 height-2, Oppo 103, Mac Mini (network), Apple TV (DNLA), Roku 4, 3TB My Book (DNLA), Dell PC (Network), Vizio UM-P702uiB3, Logitech Harmony Companion, X-box one s
Alanlee is online now
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
