Klipsch owner thread - Page 1734 - AVS Forum | Home Theater Discussions And Reviews
 6398Likes
post #51991 of 51999 Unread Today, 05:35 AM
Schubeedoobee's Avatar
Quoted: 37 Post(s)
Liked: 46
Jesus... $40 for jumper cables?
Astell & Kern AK120ii-Klipsch x11i-Klipsch x20i-Sony MDF-Z7
Pioneer SC85-NBS Preamp-Bel Canto REF500M-Dennis Had Inspire Hotrod
Klipsch La Scala II/Aletheia Audio-Cornwall/Crites/Aletheia Audio-Heresy II Signature-SW115
Wyred 4 Sound DAC2 DSDse-OPPO BDP93
Samsung PN64D8000
Schubeedoobee is online now
post #51992 of 51999 Unread Today, 07:59 AM
retro124's Avatar
Quoted: 1122 Post(s)
Liked: 858
Originally Posted by ereed View Post
I just use OEM brass plates and bare wire. I never take my wires on and off to need banana plugs. Banana or bare wire, its up to you. Makes no difference in sound.
Oh yes and same with jumper cables vs brass plates. I'm sure there no sound differences. Just when you dusting behind looks there pretty serious😀😀😀
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses
Sony XBR65X850B, Oppo 203
Emotiva XPA-200
Apple Mac mini, Sony PS3,
retro124 is online now
post #51993 of 51999 Unread Today, 09:13 AM
Mongo171's Avatar
Quoted: 849 Post(s)
Liked: 1299
But they look good!
Mongo171 is online now
post #51994 of 51999 Unread Today, 09:50 AM
Quoted: 37 Post(s)
Liked: 46
Spring in the Air...
Samsung PN64D8000
post #51995 of 51999 Unread Today, 01:29 PM
Quoted: 83 Post(s)
Liked: 47
Thank you all, I appreciate the feedback. I think I will leave the speakers as is for now, I don't anticipate moving them much once I have the screen wall finally finished. I liked the grip that the speakers had with bare wire a little more than the banana clips.
My other question is that I'm running a pair of R115SW's off of a Denon 6300. Where should I start with the phase, low pass and gain? Right now I'm at Zero Degrees, LFE and slightly past half way on gain. I have each of them hooked up with 50 foot mediabridge subwoofer cables directly from the DVR into the L/LFE port on the back of the sub box.
I have yet to finish up installing everything in the theater, so I have not run Auddysey yet. I'd like to make sure the basic settings are in line with where they should be before I start tuning. Any other tips or suggestions would be appreciated. As of right now, we've played a little music and listened to an older DVD of the original Transformers and I'm thoroughly impressed with these speakers.
arcticbowman is online now
post #51996 of 51999 Unread Today, 02:02 PM
ereed's Avatar
Quoted: 901 Post(s)
Liked: 427
start with phase of 0 degrees and just get spl meter out and something like disney wow disk. If not have one you can just use your AVR for calibration. You want all speakers at 75db from AVR's test tones.
If both of your subs are at same location then you want to calibrate one sub at a time. Together you will get 3 to 6db with duals so maybe calibrate it as 72db each. If you want more bass just up the gain on the subs.
arcticbowman likes this.
Main theater: Sony 45es, 120 inch 16:9 screen, Panny BDT500, Rotel RMB-1075, Rotel RSP-1068, Klipsch RP-280F, RP-450C, RP-160M, SVS PB13 x 2, Monster Power Conditioner, GIK acoustic panels
TV Room: Panasonic 60" plasma, Integra DTR-30.3, Axiom Audio M60, VP150, QS8, EP500
ereed is offline
post #51997 of 51999 Unread Today, 03:13 PM
Louis Bartay's Avatar
Quoted: 249 Post(s)
Liked: 634
Those LaScala's look awesome my bother had a pair in the 80's with a McIntosh tube amp and pre/amp our dad owned. In the 90's he added a sub and it made a difference in that room. How much does the plant vibrate when you have the sub cranked up some?
Klipsch Cornwall I,C7,RS3-II
Klipsch Heresy II, KSB 1.1
SVS PB 13 Ultra
Yamaha RX-V1900 PS3
Louis Bartay is online now
post #51998 of 51999 Unread Today, 03:42 PM
kellyk75's Avatar
Thank you for your detailed response ldgibson76, this helps a lot! I have been reading various opinions on extra amplification at moderate levels (some say they hear SQ improvements), the 450c and 64ii, and trying to filter reality with opinion.... but what you have stated reinforces my gut feeling.
Originally Posted by ldgibson76 View Post
A lot of times, the center channel performance is a dependent on the quality of the soundtrack. Not all soundtracks are created equal. Dialogue on some soundtracks are just poorly recorded.
I think this comment has a lot of merit.... with the RP-450C, I really do hear the subtle differences in recording quality as some material sounds great, other muffled and/or unrealistic which bothers me.
I agree with what has been mentioned previously. That is to buy a 3 channel amp from a retailer with a generous return policy and see if there's an improvement across the front channels, especially the center performance. If you can discern a difference and it's a positive difference, stay with the 450C. Not only that, it's the less expensive option vs. buying an RC-64II.
I live in Canada, and choices are limited... especially with a generous return policy. Almost everything is special order, then non-refundable because it was 'special order'. I do have an older RX-V657 that I could use as a dedicated centre amp, I will see if there is any improvements (if I can get it to work). The 64iii will be out later this year, the horn material is similar to the RP series but tweeter is 1.75" over the 450C 1". Might be a closer sound to the RP and easier to EQ with the RP-280F's, and (hopefully) won't be special order allowing me to trial it.
The wife and son are gone this weekend, so I will play with the PEq a bit more and see if I can flatten the response curve further to make it more palatable with a wider range of material.
Thanks for the pic, I think I can handle the size difference in my current set-up, just won't be able to angle the centre up as far!
kellyk75 is online now
post #51999 of 51999 Unread Today, 04:49 PM
Quoted: 37 Post(s)
Liked: 46
They dont move... the pictures on the walls shake, but the sub itself is very stable. I really think the plants like the vibrations
And no... I dont water the plants while they are on the speakers
Samsung PN64D8000
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
