Klipsch owner thread - Page 1757 - AVS Forum | Home Theater Discussions And Reviews
 6903Likes
post #52681 of 52710 Unread 05-18-2017, 02:50 PM
Quoted: 455 Post(s)
Liked: 143
Temple of the Dog sounds great coming from my Palladiums, tinged with sadness today. RIP Chris Cornell.
Setups:
Spoiler!
dkfan9 is offline
post #52682 of 52710 Unread 05-18-2017, 04:50 PM
Ladeback's Avatar
Quoted: 265 Post(s)
Liked: 80
Send a message via MSN to Ladeback
I'm listening to some now, what a shame he is gone.
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
http://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #52683 of 52710 Unread 05-18-2017, 08:36 PM
Liked: 3
It is sad to see all of the grunge guys die off. Last year it was Scott Weiland and now Chris. Both were awesome musicians.
Sent from my SAMSUNG-SM-N910A using Tapatalk
ceptorman and dkfan9 like this.
dprizal is offline
post #52684 of 52710 Unread 05-19-2017, 01:12 PM
dizzyscure's Avatar
I currently have a Denon AVR-X4300H that will be used to run a 5.1 setup with RP-280F, RP-450C & RP-160M, the rooms volume is around 4,400. The X4300H's 5 Channels continuously driven @ 8-Ohm Load = 94.6 watts,
50% HT Duty, 50% Music, Both at 50-70% volume most of the time. Never bringing to insanely loud levels though.
What do i gain if i add either a Monolith 7x200 or Emotiva XPA Gen3 to the mix and drive ALL channels with one of those amps?
dizzyscure is offline
post #52685 of 52710 Unread 05-19-2017, 02:15 PM
Kini62's Avatar
Quoted: 1612 Post(s)
Liked: 1438
A lighter wallet mostly.
Room volume matters little for speakers. It's mainly the distance to the listening position. Since you have a sub I assume you have your speakers set to small with a crossover so you would IMO gain little at your listening levels.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #52686 of 52710 Unread 05-19-2017, 02:28 PM
dizzyscure's Avatar
Kinda what I was thinking, good to have confirmation from more than myself. Thanks,
IMWhizzle likes this.
post #52687 of 52710 Unread 05-19-2017, 02:34 PM
Ladeback's Avatar
Quoted: 265 Post(s)
Liked: 80
After reading your answer I went out an d looked to see why small, because I thought it would be large. I found this that helped understand. Now I have KPS-440's with built in subs so mine would be set at large. I need to check my LFE settings though. I do know I get enough bass for my wife, because she doesn't like it when I turn it up. I am running 5-200 Marantz Mono blocks for power. It will sound better once I get the walls down and treated.
http://denon.custhelp.com/app/answer...-small-setting
Ladeback is offline
post #52688 of 52710 Unread 05-19-2017, 02:36 PM
Mongo171's Avatar
Quoted: 902 Post(s)
Liked: 1328
Originally Posted by confinoj View Post
Still interested in feedback from other users but asked Klipsch and they told me seating distance is fairly flexible and gave a range of 10-20ft. So hopefully they will work and can adjust the angle a bit if needed. I'm assuming their is just much more dispersion with the upfiring modules so they angles don't necessarily match up with the angle ranges Dolby recommends for in-ceilings?
Ideally, you want your front speakers to be equidistant to your Main Listening Position (MLP). That's where I would put the 140's. Of course, Klipsch is Klipsch. They won't steer you wrong. Why can't you put them on your front speakers?
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #52689 of 52710 Unread 05-19-2017, 03:09 PM
confinoj's Avatar
Quoted: 206 Post(s)
Liked: 115
I think you may have misunderstood me. I would put them on my front speakers. It's just that MLP is relatively far from front speakers at ~15 ft so the question was will the reflection point be to far in front of the MLP to create an adequate height effect.
Samsung PN59D8000 | Denon AVR-X4300H | Tivo Roamio via OTA | ATV4 | Media PC running Plex server/Plex Media Player
Front L/R Polk RTiA3 | Center Polk CSiA6 | Front Heights Polk RCi55 | Surround Polk OWM3 | Sub SVS PC12-Plus x 2
confinoj is online now
post #52690 of 52710 Unread 05-19-2017, 03:10 PM
Quoted: 231 Post(s)
Liked: 51
Voicing curve- La Scala II
Do you guys have a particular voicing curve that compliments the La Scala?
My pre-pro allows user created voicing curves to be applied, using up to 8 filters per curve.
Each filter allows for choice of filter-type, crossover, Q, and gain.
Thank you.
(La Scala L/C/R, Heresey LS/RS + LRS/RRS, KL525THX used for upward firing Atmos modules)
daimler2015 is offline
post #52691 of 52710 Unread 05-19-2017, 03:14 PM
Quoted: 151 Post(s)
Liked: 150
Even if you were to get an outboard amp for that setup, no reason to power all the speakers with it, getting a 2 or 3 channel amp for the fronts would be just as effective at a lower cost. It's what I do, but I listen at higher levels than you.
Denon AVR-4520CI
Emotiva XPA Gen3 3 channel
Klipsch RP and Reference II mish mash
SVS SB12-NSD x4
OPPO UDP-203
TiVo Roamio, sometimes buzzy Samsung Plasma
drh3b is online now
post #52692 of 52710 Unread 05-19-2017, 03:34 PM
dizzyscure's Avatar
So did you notice a difference between ur Denon's internal amp and the Emotiva XPA Gen3 when powering your RP's? Whats ur front setup exactly?
Yeah i know these bookshelf's would not honestly benefit from such an Amp powering them, more or less for future upgrade path once im in a larger room with the ability to push multiple pairs of floor standing units and for the few SACD's ive got.
post #52693 of 52710 Unread 05-19-2017, 04:29 PM
Mongo171's Avatar
Quoted: 902 Post(s)
Liked: 1328
If Klipsch says 10-20 ft. is acceptable, then do it. You must have a big TV or projector to be sitting that far back.
Mongo171 is offline
post #52694 of 52710 Unread 05-19-2017, 04:43 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3428
I listen at high playback volumes for HT, AND have my 7II's crossed at 60hz, I prefer my Outlaw amp and preamp vs an AVR. That being said, you have to consider everything when considering an amp.
A lot of folks will give you a blanket "Klipsch only needs 5 watts" speech, but there is a lot more to it, especially transients. I can also hear a difference when running the 7II's in 2 channel pure mode for music, the dual 10's really kick.
Plus, during long movies, nothing in my setup gets above warm.
gadgtfreek is offline
post #52695 of 52710 Unread 05-19-2017, 05:04 PM
confinoj's Avatar
Quoted: 206 Post(s)
Liked: 115
I wish that were the case. Just a suboptimaly placed sofa in terms of HT. It's a big living room and furniture decisions were made before I had much of an HT setup. My wife has allowed all equipment so far but no way I could re-arrange the room. It is what it is. Will get a bigger tv when oled prices come down.
Mongo171 likes this.
post #52696 of 52710 Unread 05-19-2017, 05:57 PM
Luisfc1972's Avatar
Quoted: 265 Post(s)
want these stands for my rp160ms
https://www.amazon.com/gp/product/B0...A1YX7EB80E4EIU
reviews say they are top heavy so im not sure yet. just want inexpensive but sturdy stands
Luisfc1972 is offline
post #52697 of 52710 Unread 05-20-2017, 01:08 AM
Quoted: 151 Post(s)
Liked: 150
The only thing I get out of it is not getting my Denon so hot it runs a really loud fan. I have an Emotiva gen3 3 channel 300 wpc 2 channels driven, 275 wpc 3 channels driven. Basically, I have my Denon run the side rear channels, and when I get them set up, the surround back. If you don't set your fan off, you probably don't need an external amp. However, it does take strain off your receiver.
If you have the money, a 2 or 3 channel amp would give you some headroom, but to replace all of the Denon's channels with an outboard amp would be unnecessarily expensive. I play multichannel music really loudly at times, with the Emotiva running the LCR, and the Denon running the surrounds, and it works great. If I do the same thing with just the Denon, it still sounds great, but the Denon gets really hot.
Not only would your bookshelves not benefit from an external amp, you wouldn't be able to use the full ability of your amp. I had a pair of Rp 150m, and they would distort somewhere between 80-150Hz without even getting close to straining my Emotiva. Even with my RP-260f, if I'm playing loudly, I have to run my crossover all the way at 150 Hz to stop the potential of midbass distortion. At some point, I will buy a pair of RP-280f, and move the 260's to surround, and they should be able to handle all the power, no sweat. (Based on previous experience with the similar RF-82 II)
Denon AVR-4520CI
SVS SB12-NSD x4
OPPO UDP-203
drh3b is online now
post #52698 of 52710 Unread 05-21-2017, 06:58 AM
retro124's Avatar
Quoted: 1182 Post(s)
Liked: 935
Hey guys I have a chance to get pair like new RB-61II's for good price so I'm thinking to get it and use it against RB-81II's ( front height) on top back wall behind sofa facing down to MLP to have 4 speakers 🔊 for Atmos. Is that good idea? Or leave it for now just like I have front heights and then one day when I will have bigger room get 4 in ceiling speakers for Atmos?
gene4ht likes this.
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses
Sony XBR65X850B, Oppo 203
Emotiva XPA-200
Apple Mac mini, Sony PS3,
retro124 is offline
post #52699 of 52710 Unread 05-21-2017, 07:38 AM
JBrax's Avatar
Quoted: 93 Post(s)
Liked: 68
Originally Posted by retro124 View Post
Hey guys I have a chance to get pair like new RB-61II's for good price so I'm thinking to get it and use it against RB-81II's ( front height) on top back wall behind sofa facing down to MLP to have 4 speakers ? for Atmos. Is that good idea? Or leave it for now just like I have front heights and then one day when I will have bigger room get 4 in ceiling speakers for Atmos?
If the price is that good why not? You can never have enough speakers and like you said someday you might have a bigger room.
JBrax is offline
post #52700 of 52710 Unread 05-21-2017, 08:26 AM
Louis Bartay's Avatar
Quoted: 274 Post(s)
Liked: 670
I am looking at stands too, the one from your link is on my list, still looking. I found this one that has a larger base.
http://www.ebay.com/itm/172311844830...%3AMEBIDX%3AIT
Klipsch Cornwall I,C7,RS3-II, R-14M
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
Yamaha RX-V1900 HD PS3
Louis Bartay is offline
post #52701 of 52710 Unread 05-21-2017, 10:20 AM
gene4ht's Avatar
Quoted: 913 Post(s)
Liked: 945
Hi Retro...see my response to your question in the Atmos thread.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-NR636 (5.2.2) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501 Oppo: UDP-203
gene4ht is online now
post #52702 of 52710 Unread 05-21-2017, 04:45 PM
Luisfc1972's Avatar
Quoted: 265 Post(s)
i found them on amazon
https://www.amazon.com/Pyle-PSTND35-...+Speaker+Stand
still not sure what to do here. looks like your stands reviewed a lil less positive vs the ones i asked about. i like that you can just clamp the speakers.
Louis Bartay likes this.
post #52703 of 52710 Unread 05-21-2017, 05:26 PM
Quoted: 151 Post(s)
Liked: 150
I have those. Very sturdy, especially for the price. I don't know if they're especially stable. They're fine for me, because they aren't in a spot where people should touch them. I wouldn't consider them unstable, either, just not any better than the ones they replaced. I'd be nervous putting heavy speakers on them at full extension. I think if you center the weight properly, they should be fine. I have the weight un-centered at the moment, and they are OK at about 4 ft.
Denon AVR-4520CI
SVS SB12-NSD x4
OPPO UDP-203
drh3b is online now
post #52704 of 52710 Unread 05-21-2017, 06:28 PM
bxbigpipi's Avatar
Quoted: 53 Post(s)
Liked: 39
I I have those stands and they are pretty good as long as no one will be next to them. They are holding the r-15's.
bxbigpipi is offline
post #52705 of 52710 Unread Yesterday, 10:17 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3428
Well, wanted a new preamp to pass Dolby Vision and I have been kinda miffed at D&M lately with how they treat people who bought their flagship models, so I ordered an A3060 today. First ever Yamaha, should be fun.
Louis Bartay and retro124 like this.
post #52706 of 52710 Unread Yesterday, 10:41 AM
suniths's Avatar
Liked: 1
Newbie here...help needed please.
Have been combing the forums for a few weeks now, and appreciate the time everyone puts in to help.
I am in process of finalizing my speaker list and could definitely use some help with rear surrounds and subs. Below is what I had in mind and it seems from various forums, threads and inpust it is an acceptable combination, but I was looking for the preferred option.
Room is 18' x 16'6" in a basement. MLP will be about 36"-40" from the back wall.
RP-280F (L, R)
RP-450C (C)
RP-250S (Side surrounds)
RP-160M (rear surrounds)
R-112SW (x2)
Request 1) If LCR & side surround are as indicated above, what is preferred for the rear surrounds? RP-160M, RP-250S or RP-250F? The reason I ask is all 3 choices are within ballpark of each other after I consider cost of stands for the RP-160M and I wanted to ensure I am getting the most out of the $$ spent.
Request 2) Is it better to have 2 R-112SW vs. 1 R-115SW? (having 2 R-115SW will basically blow my budget)
Thank you in advance for help and guidance.
suniths is offline
post #52707 of 52710 Unread Yesterday, 10:44 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3428
For subs, after my experiences, I would take duals over a single any day.
suniths and Louis Bartay like this.
post #52708 of 52710 Unread Yesterday, 11:14 AM
Ladeback's Avatar
Quoted: 265 Post(s)
Liked: 80
RP-280F (L, R)
RP-450C (C)
R-112SW (x2)
IMO for rear surrounds and if you have the room for the RP-250F's I think that would be cool with your fronts being the RP-280F's. Also if you decide to upgrade to Dolby Atmos you could add the RP-140SA's easily.
What is your screen source? I take it is either a fixed regular screen or a large flat panel? If that it the case I see why you went with the RP-450C. If you are going with a AT screen I would look at going with another RP-280F for the center. I think it would match better with the L&R.
As for subs, I agree, go with 2-R-112SW's over one R-115SW unless you think you could get another 15 down the road. @chirpie has one 12" SVS sub in his current HT and I would swear there was more then one based on the base response. It is all about placement of the sub. Below is his current theater and you can also check out the new one he will be building in his new house.
Cinema Midwest 1.0 - 1.1
Ladeback is offline
post #52709 of 52710 Unread Yesterday, 11:20 AM
Quoted: 274 Post(s)
Liked: 670
I have had Great service from both of my Yamaha AVR. I purchased a RX-V 2400 120x7... 7.1 in 2004 non HDMI or it would still be in the den. , it is my bedroom receiver now. In late 2008 I purchased the RX-V1900 HD 130X7 7.1.... HDMI, I still use in the den for my 7.2 HT system.. Both are still going fine after all these years.
gadgtfreek likes this.
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
post #52710 of 52710 Unread Yesterday, 11:59 PM
apexgrin's Avatar
Quoted: 50 Post(s)
Awesome set up. The 160's will be fine for rear surrounds (will they be far back from the MLP?)
If I were you I'd get the 115 now and another one later on. Dual is definitely much better and if you're sticking with Klipsch for the subs then I'd hold out for a second 115. I went with SVS for subs because of their upgrade program, so was able to start off with smaller duals while still being able to easily upgrade later.
Also if you have a Fry's nearby they have the 115 on sale every couple months it seems.
LG OLED65C6P
Oppo 203 - PS4 Pro
Denon X4300H
Klipsch RP-250F, RP-450C - Dual PB-1000 Subs - Onkyo Satellites
apexgrin is online now
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
