Klipsch owner thread - Page 1769 - AVS Forum | Home Theater Discussions And Reviews
 7102Likes
post #53041 of 53052 Unread Today, 09:35 AM
confinoj's Avatar
Quoted: 286 Post(s)
Liked: 139
I realize this is in part room, distance, and preference dependent but what kind of toe in are people finding works best for the RP series? Specifically the RP-160M. Thanks.
Samsung PN59D8000 | Denon AVR-X4300H | Tivo Roamio via OTA | ATV4 | Media PC running Plex server/Plex Media Player
Front L/R Klipsch RP-160M | Center Klipsch RP-450C | Surrounds Klipsch RP-150M | Atmos Klipsch RP-140SA x 4 | Sub SVS PC12-Plus x 2
confinoj is online now
post #53042 of 53052 Unread Today, 10:04 AM
Louis Bartay's Avatar
Quoted: 282 Post(s)
Liked: 686
Follow this link. http://www.klipsch.com/blog/how-to-set-up-a-7-1-system you sould be able to look down the throats of the tweeter horn from where you set. Mid horns at ear level when possible. Hope this helps as I have my Cornwalls (fronts) "Towed IN" big time so they are aimed at me just like in the link.
Klipsch Cornwall I,C7,RS3-II, R-14M
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
Yamaha RX-V1900 HD PS3
Louis Bartay is offline
post #53043 of 53052 Unread Today, 12:31 PM
apexgrin's Avatar
Quoted: 56 Post(s)
Liked: 24
Originally Posted by Chase_Monkey View Post
Do you have a Marantz receiver?
It's a Denon X4300 and I was getting the same issue on an old Onkyo before.
LG OLED65C6P
Oppo 203 - PS4 Pro
Denon X4300H
Klipsch RP-250F, RP-450C - Dual PB-1000 Subs - Onkyo Satellites
apexgrin is offline
post #53044 of 53052 Unread Today, 12:47 PM
stereojunkie's Avatar
Quoted: 17 Post(s)
Hey guys, can the rp160m be placed on its side for center channel placement? I am considering these for my front three going from a def tech setup. Thanks.
stereojunkie is online now
post #53045 of 53052 Unread Today, 01:38 PM
Mongo171's Avatar
Quoted: 928 Post(s)
Liked: 1364
Yes they can.
Mongo171 is offline
post #53046 of 53052 Unread Today, 01:55 PM
Kini62's Avatar
Quoted: 1642 Post(s)
Liked: 1476
Originally Posted by Mongo171 View Post
Yes they can.
Nice thing about the RP series- no more 90x60 horn dispersion. You'd have to rotate the horn in the previous reference line up.
ereed likes this.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #53047 of 53052 Unread Today, 05:17 PM
JayFank's Avatar
Quoted: 32 Post(s)
I'm looking to upgrade my center channel from the Polk CS1 Series II. Would I be better off with the Klipsch RP-250 or RP-440C? Or any other recommendations?
JayFank is online now
post #53048 of 53052 Unread Today, 05:52 PM
Liked: 0
Originally Posted by Louis Bartay View Post
You might try laying the LaScala on it's side for the center and put the TV on it (with a pad) laying on it's side. If I had two LaScala I would use them for L/R ....... if you run across a nice used Klipsch C7 center from the KLF 10/20/30 series it is awesome with Heritage series for a center, two 8" and a 10" tweeter horn.
Whoa, laying it on its side???? Is that a viable option? Wouldnt that destroy the direction of the sound? And yeah I'm planning on buying a second (or even a thirth) LaScala when I find one as cheap as I did this one I have Chorus II as front and Forte II as rear, so plenty to choose as centers if needed.
Droogne is offline
post #53049 of 53052 Unread Today, 05:55 PM
Liked: 0
Originally Posted by patb93 View Post
I have 3 LaScalas for LCR and having a TV sitting on the center shouldn't be a problem. You might need to tilt the TV slightly down toward your sitting position. Is it against a wall where you could wall mount the TV and have more control over the tilt? I have my theater set up with a motorized screen that stops right at the top of the LaScala which puts the focal point of the image at a slight upward angle from my seats and it's not a problem in the least.
Whoa the tv tilting is an interesting idea! Was also thinking about maybe raising my couch by 10-20cm which would fix it and/or lowering the scale (by taking of the stand if possible). Maybe I'll do a little bit of a combination! Would really like my tv to be at ideal height.
Droogne is offline
post #53050 of 53052 Unread Today, 05:55 PM
Mongo171's Avatar
Quoted: 928 Post(s)
Liked: 1364
A La Scala standing up is good height for a center with a TV on top. Can't put Heritage on its side. Horn orientation won't allow it.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #53051 of 53052 Unread Today, 06:54 PM
Quoted: 282 Post(s)
Liked: 686
I have owned older Cornwalls with it's mid horn vertical, the same horn mounted horizonal as my 1979 Cornwall/Heritage. So I thought a LaScala laying flat for a center for HT would not be that big of a deal. I know the LaScala has a different shaped horn but for voice for HT worth a try IMHO if you have one just setting. I agree standing UP is the BEST way just thought I would throw out a idea for HT use only..IMHO I liked a Heresy BEST(TOO BIG for my den) ) but a C7 with Crites mods is darn hard to beat for Heritage fronts.
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
post #53052 of 53052 Unread Today, 08:31 PM
archer101's Avatar
Quoted: 43 Post(s)
I thought of doing this also but for $100 more vs 2 RP160M's, I snagged a black wood grain RP-450CA and so glad I did. Love the look with my 65" TV sitting on top RP450CA all speaker woofers are on same horizontal plain, looks and sounds great.
Sony 930D 65 & 55", ZVOX SB700 Soundbar, Sony XT1 Soundbar, Onkyo, Denon AVR-X2300W, Klipsch RP-160M, Klipsch RP-450C, Klipsch R-14S.
archer101 is online now
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
