Klipsch owner thread - Page 1797 - AVS Forum | Home Theater Discussions And Reviews
 7551Likes
post #53881 of 53907 Old 10-16-2017, 11:54 AM
Quoted: 33 Post(s)
Liked: 7
Originally Posted by RL616 View Post
Anyone know how long it will take to get a R115sw Klipsch sub from Klipsch, as they are currently on back order? I ordered one from them and was just wondering how long it's going to take to arrive. I'm located in Canada to if that matters.
Why not just buy it from amazon...should be the same price and in stock.
Klipschfn is offline
post #53882 of 53907 Old 10-16-2017, 05:29 PM
Quoted: 47 Post(s)
Liked: 2
There are none available through Amazon.ca.
Sent from my SM-G900W8 using Tapatalk
RL616 is offline
post #53883 of 53907 Old 10-17-2017, 12:46 AM
gygess's Avatar
Quoted: 114 Post(s)
Liked: 47
Not to crap on your purchase, but is it too late to return/cancel the order?
There are better subs and more value-per-dollar subs out there than the Klipsch. If you knew this going in, then by all means go forth. If you didn't, I and plenty others on this site can help direct you to better options (Yes, even for canadian options).
Denon 1612 ; Klipsch RP-160m ; Klipsch RP-250c ; Wharfedale Valdus 300 ; Emotiva Basx s12
gygess is online now
post #53884 of 53907 Old 10-17-2017, 12:46 PM
sddp's Avatar
Quoted: 159 Post(s)
Liked: 72
Call
www.acousticsounddesign.com
888-224-3663
I ordered another one last week and just arrived today
Louis Bartay likes this.
Epson 5040UBE | DENON X6400H | XBOX ONE S\PS4 | EMOTIVA XPA-7 GEN 2 |EMOTIVA XPA 3 GEN 3 | ELITE SCREEN 150" ZEREO EDGE W/LED KIT
KLIPSCH L&R RF-7II | CENTER RC64II | HEIGHTS RB-81II | 4 SURROUNDS RS-62II | 2 CDT-5800 | SUBS R112SW, R12SW & 2 x R115SW
VEFXI 3D-BEE DIAMOND (2D TO 3D CONVERTER) | DARBE VISION DVP-500S | LOGITECH HARMONY 800
sddp is offline
post #53885 of 53907 Old 10-18-2017, 07:58 PM
Quoted: 33 Post(s)
Liked: 7
Originally Posted by ceptorman View Post
Excellent choices, those should do you well. Are you going to hold off on an amp to see if it's needed? That's probably a good decision as well, you might not need it. Keep us posted, and we love pics
Hi. You all helped me pick out the cdt 5800 ceiling speakers (4) which I should get tomorrow. I also get the new x4300h and the second r115sw tomorrow...so I want to install it all tomorrow night. I am unsure on where the ceiling speakers should be installed. My room is approx 13x14 and the couch is all the way against the back wall. I will be doing 5.2.4 atmos setup. Thanks
post #53886 of 53907 Old 10-19-2017, 01:03 AM
ceptorman's Avatar
Quoted: 324 Post(s)
Liked: 483
Isn't it awesome getting new gear! Itsmyforte on here would be the guy to ask about Klipsch speaker placement, there are lots of variables though. Good luck playing with your new toys.
650cc on the track
1000 cc on the street
800cc on the snow
ceptorman is offline
post #53887 of 53907 Old 10-19-2017, 03:52 AM
Louis Bartay's Avatar
Quoted: 305 Post(s)
Liked: 716
Hope this helps https://www.dolby.com/us/en/guide/do...-2-setups.html
http://www.klipsch.com/blog/how-to-set-up-a-7-1-system
ceptorman likes this.
Klipsch Cornwall I,C7,RS3-II, R-14M
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
Yamaha RX-V1900 HD PS3
Louis Bartay is offline
post #53888 of 53907 Old 10-19-2017, 11:57 AM
sddp's Avatar
Quoted: 159 Post(s)
Liked: 72
Also take a look at this link from Dolby, both page 1 and page 2:
https://www.dolby.com/us/en/guide/do...-4-setups.html
Also some specs from Magnolia Design center recommendations, attached a pic.
Replying here instead of your email so others can also see for future reference
Name:	Dolby ATMOS pic .PNG
sddp is offline
post #53889 of 53907 Old 10-19-2017, 01:10 PM
Quoted: 33 Post(s)
Liked: 7
Thanks...so like I said before The couch is all the way against the back wall...I can probably pull it out 2-3 feet and it would still work good....From what I am seeing I should place the rear ceiling speakers almost up against the back wall say 3 feet behind me and then the front ceiling speakers should be mounted 3 feet in front of me so the ceiling speakers will be a total of 6 feet apart? and all 4 should be in line with the front r/l mains?
post #53890 of 53907 Old 10-19-2017, 03:28 PM
Fezick's Avatar
Looking for some measurement help for anyone that owns a RC-62 II Klipsch center channel. I can't seem to find one to look at in person but I need the measurement from the outside of the left port to the outside of the right port. (the middle of the port so the outermost part of it) I have the dimensions for the entire unit width, but that will not answer the question. Any RC-62 II owners out there that can help me out??
Fezick is offline
post #53891 of 53907 Old 10-19-2017, 05:24 PM
ILOVEMYHDTV's Avatar
Quoted: 53 Post(s)
Liked: 50
I'm a little confused...
Originally Posted by Fezick View Post
Looking for some measurement help for anyone that owns a RC-64 II Klipsch center channel. I can't seem to find one to look at in person but I need the measurement from the outside of the left port to the outside of the right port. (the middle of the port so the outermost part of it) I have the dimensions for the entire unit width, but that will not answer the question. Any RC-64 owners out there that can help me out??
the 64 do not have ports... look at my avatar.....
PS3+4= CHiNGOBLiNG = RUBEN...YOU NEED TO OPEN YOUR EYES TO SEE THE PICTURE!!... "SHOE MAKER HOME THEATER".7/22/16....just a KLIPSCH NUT..>7/22/16...2new videos show..https://www.youtube.com/watch?v=jWO0YtCWQxI.....https://www.youtube.com/watch?v=yIen05Wcg9w. u can even look from when I started about to present day.... i stutter sometimes....
ILOVEMYHDTV is offline
post #53892 of 53907 Old 10-19-2017, 05:42 PM
itsmyforte's Avatar
Quoted: 233 Post(s)
Liked: 124
For realz, no ports on that one. Perhaps the poster meant to say RC-62II?
http://www.klipsch.com/products/rc-62-ii-center-speaker
Sent from my XT1575 using Tapatalk
itsmyforte is offline
post #53893 of 53907 Old 10-19-2017, 06:39 PM
Fezick's Avatar
Sorry guys I mistyped that part number. RC-62 II.....
Still looking for some measurements if anyone happens to have this unit in their hands. Appreciated.
-Fezick
Fezick is offline
post #53894 of 53907 Old Yesterday, 12:54 AM
Quoted: 33 Post(s)
Liked: 7
Sooooo..........I got everything installed and rented the new Transformers and I must say that was the best sounding movie I have heard. The atmos makes a huge difference! You were right I need to find out what to rent next....any recommendations on the BEST atmos blu rays?
Can you stream atmos with netflix or amazon?
What about for games or just normal tv is there a "fake" atmos mode that utilizes the ceiling speakers?
Lastly what mode do you use when watching your blu rays?
sddp likes this.
post #53895 of 53907 Old Yesterday, 09:13 AM
HYPURR DBL NKL's Avatar
Quoted: 200 Post(s)
Liked: 129
-Fezick
The measurements are on Klipch's website. Dimensions: 8" H x 23.5" W x 12.5" D. I have it and it's big.
HYPURR DBL NKL is offline
post #53896 of 53907 Old Yesterday, 09:41 AM
sddp's Avatar
Quoted: 159 Post(s)
Liked: 72
Mad Max: Fury Road is touted as one of the best ATMOS sound tracks
You'll find some more on these links:
https://www.digitaltrends.com/home-t...-atmos-movies/
https://www.avforums.com/article/top...blu-rays.11768
sddp is offline
post #53897 of 53907 Old Yesterday, 03:27 PM
BGLeduc's Avatar
Quoted: 1861 Post(s)
Liked: 1677
If it’s to your taste, Baby Driver 4K has a killer Atmos sound track, as does the 4K Blade Runner (good luck finding it, though).
#JB17
BGLeduc is online now
post #53898 of 53907 Old Yesterday, 04:10 PM
Fezick's Avatar
Per my original post, I am actually looking for the measurement for the width from the far outside left port to the far outside right port. (the actual 23.5 W of the unit does not matter) Since you have the actual unit would you mind taking a quick measurement of that for me? I know it seems like a small difference but it could be the difference between keeping the custom cover I have in place in my sound wall or having to make a bigger opening for the grill cloth.
Thanks!!!
-Fezick
Fezick is offline
post #53899 of 53907 Old Yesterday, 09:33 PM
Liked: 3
Thanks!!!
-Fezick
Hi I have an rc-62 ii the measurement from outside port to port is right around 22 inches, could be 21 & 15/16th if you nit pick it.
Diy_Audio_Guy is offline
post #53900 of 53907 Old Yesterday, 10:23 PM
Fezick's Avatar
DIY, thanks for the reply as that information is really helpful. However now that I have that information it brings up one more. What is the distance from the outside speaker to speaker if you don't mind a second measurement?
Thanks a ton!
-Fezick
Fezick is offline
post #53901 of 53907 Old Yesterday, 10:44 PM
Liked: 3
Thanks a ton!
-Fezick
No problem, the outside speaker to outside speaker measurement is 18 & 7/8 inches.
post #53902 of 53907 Old Yesterday, 10:54 PM
Fezick's Avatar
Great. Appreciate the information. That puts the woofers just about 3/4 an inch outside the grill cloth opening I have. I hope that will not be an issue. It also places the outside portion of the ports behind a piece of support on either side but I don't need to have it right up against them. I am hoping this will not affect the performance too much. Think I will probably give it a shot and order one. I assume you are happy with yours??
-Fezick
Fezick is offline
post #53903 of 53907 Old Yesterday, 11:08 PM
Liked: 3
-Fezick
Yeah it's a really nice speaker I have it on my 2nd lesser used tv with a pair of rf-82 ii's. My main TV also has 2 rf-82 ii's along with a 3rd rf-82 ii I modified to lay horizontally under the tv as a center. If it weren't for my diy itch I would have just used an rc-62 ii on my main TV too. I didn't think the price difference for an rc-64 ii was worth it. FYI not sure where you're buying it from, but Fry's has is for $168
post #53904 of 53907 Old Yesterday, 11:14 PM
Fezick's Avatar
Strange, I show Fry's at $329. Do you have a link or where about in the country are you looking?
-Fez
Fezick is offline
post #53905 of 53907 Old Yesterday, 11:18 PM
Liked: 3
-Fez
I seem to not be able to post links this is a new account I lost the email for my old account.
httpxx://images.frys.com/art/email/102217_sun089rty/sun_web.html?fb=#set3
Sign up for the promo codes i got mine for $168 and my 5 rf-82's were $240 each with promo codes.
post #53906 of 53907 Old Yesterday, 11:21 PM
Liked: 3
I can't edit my post either, remove the two xx's after the http from my last post link
post #53907 of 53907 Old Yesterday, 11:56 PM
Fezick's Avatar
Will do. Appreciate all the info.
Fezick is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
