Klipsch owner thread - Page 573 - AVS Forum | Home Theater Discussions And Reviews
 7556Likes
post #17161 of 53911 Old 11-19-2011, 11:25 AM
Mupi's Avatar
Bought a sound Anchor stand from Audiogon. Worked out fine for my center channel.
Mupi is offline
post #17162 of 53911 Old 11-19-2011, 01:40 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
I am sorry I asked!
psgcdn is offline
post #17163 of 53911 Old 11-21-2011, 04:36 AM
stewey1200's Avatar
i found a klipsch dealer who has rs-62 and rs-62ii.what is a better match for my rf-83 and rc-64? price is the same.
stewey1200 is offline
post #17164 of 53911 Old 11-21-2011, 05:12 AM
nezff's Avatar
Quoted: 156 Post(s)
Liked: 76
RS62s are the better match. I would definately get him to come down on price if they are the same considering they are not made anymore.
nezff is offline
post #17165 of 53911 Old 11-21-2011, 10:57 AM
pappy97's Avatar
Can you guys rank these speakers in terms of which provide the most power/best quality/etc?
VF-35,VF-36, KF-26
My thought is it goes VF-36, VF-35, and then KF-26. But I don't really know. Any thoughts?
I will soon have a pair of all 3 for my 7.1 home theater setup, and trying to figure how which pair goes where, keeping in mind that on my Denon AVR-890, when I use a 5.1 track (most things I watch, of course, are 5.1), the rear sound comes out of the sides and I cannot choose to have it come out the back.
My thought is fronts = VF-36, sides = VF-35, back = KF-26
pappy97 is offline
post #17166 of 53911 Old 11-21-2011, 11:56 AM
the Son's Avatar
Either will work fine as surrounds. The RS-62 is the "correct" match for styling, as the 62IIs match the styling of the other reference II speakers. It should really come to whether you like the pointed or round grille better. I bought a pair of 62IIs, but I like the 62s better. I prefer the pointed grille for some reason, so now I have a brand new pair of 62IIs with no home.
I did find out that the 62 grilles fit the 62II, so if one were unable to find 62s, they could get the IIs and order the 62 grilles from Klipsch if they like the pointed grille that much more. However, the 62II grilles do not fit the 62s.
As nezff said, you should be able to get the 62s at a pretty good discount.
the Son is offline
post #17167 of 53911 Old 11-21-2011, 11:58 AM
nezff's Avatar
Quoted: 156 Post(s)
Liked: 76
Is there a reason you are going with that line?
It looks like you have it right after looking at the specs etc...
nezff is offline
post #17168 of 53911 Old 11-21-2011, 02:18 PM
COACH2369's Avatar
Quoted: 972 Post(s)
Liked: 806
Looks like I will be joining the club on Wednesday...
Going with a pair of RF-82II's and a RC-64II for now. Hoping to upgrade to the 7II's down the road..
Still deciding on a sub to compliment them.
COACH2369 is offline
post #17169 of 53911 Old 11-21-2011, 08:03 PM
manthatsnice's Avatar
Hey guys, I want to start by saying how impressed I am with the amount of knowledge I've found in this thread. I've just recently found it but have already learned much more than I could've expected.
Now that I've buttered you up, I'm hoping you might give me a little advice...
I've started a build thread in the Dedicated Theater forum. My plan had been to use the RF-52II series as 7.1 for my ~17'x18' theater room. Because of design, etc. issues, I now only have ~16.5" for my front speakers. From what I've read, this may rule out the RF-52II because of a lack of rear port clearance.
Is this clearance (~2") an issue?
If not...
  • Would (3) RF-52II's and (4) RS-52II's be the appropriate set?
  • Is there a previous generation equivalent I could use at a better price?
If so, what do you guys think about these options as replacements...
  • F-30 HT System --> (2) F-30, (1) C-20, (2) S-20, (1) SW-450 on CL for $1500
  • (2) F-3's on CL for $425
  • (2) F-2's on CL for $300
As a note, the F-30/3 would have VERY little clearance from the front port to the acoustically transparent GOM. I don't know if this is a problem or not.
Sorry for the convoluted post. I just wanted to give as much info as I could.
Thanks for your help,
Cory
manthatsnice is offline
post #17170 of 53911 Old 11-21-2011, 08:44 PM
yellowcanary73's Avatar
Quoted: 12 Post(s)
Liked: 31
If not...
Cory
Have you looked into the RB-81II for your front three they are front ported. Power rating: 150W (RMS) / 600W (peak) Impedance: 8ohms compatible Tweeter: 1" titanium diaphragm compression driver mate to a square Tractrix horn Woofer: 8" Cerametallic cone woofer Sensitivity: 97dB @ 2.83V/1m Crossover: 1400Hz Frequency response: 44Hz - 24kHz bass-reflex via front firing port Inputs: dual binding posts suitable for bi-wiring and bi-amping
yellowcanary73 is offline
post #17171 of 53911 Old 11-21-2011, 09:16 PM
Originally Posted by yellowcanary73 View Post
Have you looked into the RB-82II for your front three they are front ported. Power rating: 150W (RMS) / 600W (peak) Impedance: 8ohms compatible Tweeter: 1" titanium diaphragm compression driver mate to a square Tractrix horn Woofer: 8" Cerametallic cone woofer Sensitivity: 97dB @ 2.83V/1m Crossover: 1400Hz Frequency response: 44Hz - 24kHz bass-reflex via front firing port Inputs: dual binding posts suitable for bi-wiring and bi-amping
Thanks for the quick response. Unfortunately, I can't find any info on RB-82II. All I see is RF-82II but they're rear ported.
Can you point me in the right direction?
Cory
post #17172 of 53911 Old 11-21-2011, 10:09 PM
Quoted: 12 Post(s)
Liked: 31
Cory
I'm sorry it's the RB-81II
post #17173 of 53911 Old 11-22-2011, 03:09 AM
kemiza's Avatar
Liked: 92
Brand new pair of RS52(cherry) still in the box. My wife won't let me install them. Gotta find them a new home
Check out my user ad.
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
post #17174 of 53911 Old 11-22-2011, 03:38 AM
hordeall's Avatar
Best Buy has the KF-28 8" tower speakers on sale flack friday for $225 each. This seems like a pretty good deal (50% off). I know they arn't top of the line but I was about to get RF-82II towers for $450 each.
These would be so much cheaper.
Would the sound quality be that big of a difference between the two to warrant twice the price?
hordeall is offline
post #17175 of 53911 Old 11-22-2011, 08:38 AM
Spur Darren's Avatar
Yes. To me the Synergy line is better than these KF's. I wasnt impressed at all when I listened to them at Best Buy. Also the lack of knowledge at Best Buy is sad. It did make for a little fun for me though...
Spur Darren is offline
post #17176 of 53911 Old 11-22-2011, 09:11 AM
johnc847's Avatar
Not sure about this years icon line but I have last years model of the Icon line and love them. I'm using 2 VF-35s for fronts and 2 for front wides. You can get the VF-35s for 169 from vanns.com
http://www.vanns.com/shop/servlet/brand/25/1/klipsch/
johnc847 is offline
post #17177 of 53911 Old 11-22-2011, 10:09 AM
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 64
landshark1 is offline
post #17178 of 53911 Old 11-22-2011, 11:14 AM
RB-81ii definitely looks like an option. They fit and they're easy to get.
Tony recommended on my build thread that I get KL-650 or a great used speaker like Cornwalls. As I've looked around, I've seen several items that look like viable options...
(2) Klipsch Chorus -$995 (edit: just found a pair @ $500 total)
(2) Klipsch Heresy II - $400
(2) Klipsch KG 4 - $400
(2) Klipsch KL-650-THX Ultra2 - $1799
(2) Klipsch Cornwall - $2200 (maybe out of my $ range...)
What do you guys think about these used options? Suggestions?
Again, these would be for fronts of a 7.1 HT system.
Thanks for your time and advice,
Cory
post #17179 of 53911 Old 11-22-2011, 12:20 PM
pappy97's Avatar
VF-35,VF-36, KF-26
Spur Darren: So, considering you aren't impressed by the new KF line at Best buy, sounds like my thought of going VF-36 for the fronts, VF-35's for the sides, and KF-26's for the rears (The rears are the least used in my set up) is what you would suggest, right?
P.S. To the extent it matters, the KF-26's as the rear's would be replacing a pair of VS-14's.
Right now:
Fronts VF-36
Sides VF-35
Rear VS-14
Center VC-25
Proposed:
Fronts VF-36
Sides VF-35
Rear KF-26 (pair already purchased)
Center VC-25
VS-14's go into storage or maybe another room's set up.
pappy97 is offline
post #17180 of 53911 Old 11-22-2011, 12:43 PM
Maybe its just me but the Icon line has never impressed me. I had a Synergy F-3 setup to start with which was the lower line and to me the Icons look like they arent even built as well. To me the Synergy's just sounded better. Now that I have RF-7II's i guess maybe I am spoiled. I remember when I demoed the F-3's Transfomers was the demo material. I was amazed at how great it sounded. The new Icon's just didnt have that effect on me.
post #17181 of 53911 Old 11-22-2011, 02:00 PM
tony123's Avatar
Liked: 38
Cory, sorry I'm short on time this evening, but quickly...Cornwall is my pick of the group, and they can be found fairly often at around $500 a pair. Heresy or a bit undersized as mains, but many are happy with them. The KL650 is a better performer than Heresy, but not Cornwall. My opinions. I'll revisit the conversation tomorrow when I have more time.
The "Twinseltown" Theater
Construction Thread
tony123 is offline
post #17182 of 53911 Old 11-22-2011, 02:05 PM
johnc847's Avatar
Right now:
Fronts VF-36
Sides VF-35
Rear VS-14
Center VC-25
Proposed:
Fronts VF-36
Sides VF-35
Center VC-25
I have close to the same setup as you. Below is my suggestion and I'd sell the KF-26 or cancel if you can.
My suggestion:
Fronts VF-36
Sides/Surrounds VS-14
Rear VF-35
Center VC-25
My reason is because I've tried the setup's below
Fronts VF-35
Surrounds VS-14
Center VC-25
Sub SW-350 x2
Fronts VF-35
Surrounds VF-35
Front Heights VS-14
Center VC-25
Sub SW-350 x2
On this setup, the heights were nice, but the VF-35s weren't the best for surrounds. I'm guessing because their more directional or whatever you call it. Also, they didn't surround like surround speakers should.
I'm now running this:
Fronts VF-35
Front Wides VF-35
Surrounds VS-14
Center VC-25
Sub SW-350 x2
In all of the setups I've tried, the VS-14s work better for surrounds then the Towers. Also, this is my opinion and everyone is different. But I thought they served their purpose better as surrounds.
Don't get me wrong, I'm sure the Reference line blows the Icon away, and I already have plans to replace mine with RF 7s when I can afford them. Before my Klipsch Icon, I had Bose, when I had Bose, I thought they were the best. When I branched out and tried the Klipsch, I found out Bose is nothing close to the best speaker, in my opinion.
johnc847 is offline
post #17183 of 53911 Old 11-22-2011, 02:14 PM
nezff's Avatar
Quoted: 156 Post(s)
Liked: 76
Cory
From what Ive read on the Klipsch forum, the cornwalls are very nice. If you want to try your hand at Bob crites Cornscalas, he basically sends you everything you need to build two. $1200-1500.
On a side note, I heard some terrible news about Bama's kicker. He tried to commit suicide but couldnt kick the chair out from under him.
nezff is offline
post #17184 of 53911 Old 11-22-2011, 02:41 PM
Fastslappy's Avatar
Liked: 749
if you can work with wood OR have a local cabinet shop that will do the work the Crites CornScalas are a hella good deal . Bob cuts the motorboards for Ya the rest is making a box , can be done in a few hours by a pro
& you are getting better built drivers/crossovers than Klipsch is putting in the stock Cornwalls
I re-did my Cornswalls (4 of them) into CornScala's best money I ever spent on audio gear bar none they are that Good ..
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #17185 of 53911 Old 11-22-2011, 03:22 PM
Thanks for your time, Tony. 'Preciate the advice.
nezff, I just looked into the Cornscalas. Sounds like a great idea! His website is pretty bad though, so it's gonna take me some time to sort through all the info. Thanks for the lead. Oh, and, yeah, our kicker sucks. Bad.
Thanks for the info, Mike. This may my #1 option right now. The price is a bit high but if I don't buy the cabinets (I have a great woodworker in the family) I could be getting a helluva deal. Thanks again. Really encouraging stuff.
Would 3 Cornscalas make sense for L/C/R? If so, what would be good matches for the remainder of 7.1?
Thanks everyone.
Cory
post #17186 of 53911 Old 11-22-2011, 03:24 PM
nezff's Avatar
Quoted: 156 Post(s)
Liked: 76
nezff is offline
post #17187 of 53911 Old 11-22-2011, 03:32 PM
here ya go
http://www.critesspeakers.com/cornscala.html
Yeah, that's the site I'm on. It's just not laid out really well. No problem. I'm getting through it. I think I'll give them a call tomorrow.
post #17188 of 53911 Old 11-22-2011, 03:34 PM
Louis Bartay's Avatar
Quoted: 305 Post(s)
Liked: 716
Two Cornwalls for fronts just like they are can be tuned with the Reference center(RC-62) and surrounds(RS3-II) for Bluray. Spoiled with them new in 1979 and just now
replaced the cross over boards with Bob Crites complete networks....
good as new again with the same drivers etc. Old school huge boxs with 15" woofers are hard to beat with any of the tall towers for music and no sub.
I have two Klipsch subs for movies but usually just play the Corns for two channel music. Call Bob and talk to him, he will take the time to explain any questions you have. I emailed him one Sunday and he called me back a hour later, I ordered my new C/O boards after out phone call.
Louis
Klipsch Cornwall I,C7,RS3-II, R-14M
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
Yamaha RX-V1900 HD PS3
Louis Bartay is offline
post #17189 of 53911 Old 11-22-2011, 03:36 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
From everything I have heard, I'd say YES!
As for matching surrounds, the cheap way out is two pairs of used heresy II for $600 to $800 total. The expensive way could be Crites CS-1:
http://www.critesspeakers.com/crites...r-project.html
psgcdn is offline
post #17190 of 53911 Old 11-22-2011, 11:29 PM
Fastslappy's Avatar
Liked: 749
Thanks everyone.
Cory
Yeah it would make it horizontal But I found his CS-1 or CS-1.5 would work as well
I use his (Bob Crites) design CS-1.5 for a center & 4 CS-1.5's for the wides & heights
I was using a RC-64 (sold it )But the CS-1.5 kept up with the CornScala's much better . I built 2 CS-1 the 1st yaer & the 2nd year I converted the CS-1 into CS-1.5 ( they go alot lower & really added dynamics ) my avatar is a CS-1.5 .Mine are all horizontals . Works better that way in my room. Yes If you could build the cabinets then you have a lifetime set of speakers @ a great pricepoint , then throw the cash saved into audio gear , as what i've have done
Mike
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
