Klipsch owner thread - Page 621 - AVS Forum | Home Theater Discussions And Reviews
 7556Likes
post #18601 of 53910 Old 04-11-2012, 09:12 AM
djPerfectTrip's Avatar
Liked: 29
What's the point of adding an amp if you already have a receiver with a built in amp? In pro audio, the idea is the less components the better so you won't get as much 'noise'. Am I missing something here?
Turn it up!
djPerfectTrip is offline
post #18602 of 53910 Old 04-11-2012, 09:14 AM
D Bone's Avatar
Quoted: 297 Post(s)
Liked: 377
Hi guys, I'm a first time Klipsch owner, and I've had my (4) WB-14's and (1) WC-24 for about three months, and they just seem to be getting better and better. They are part of my 5.1 system and powered by my Onkyo 709.
Quick question, Audyssey set the x-over at 60hz for the 14's (L/R/Surr) and 50hz for the 24 (Center), but I felt that was far too low, so I changed it to 90hz for all 5 speakers..........What do you guys think?
Samsung UN60D6420 ~ DirecTV HR-44 ~ Sony S5100 BD ~ Roku 3 ~ Denon AVR-X3200W ~ SVS Prime Bookshelf L/R ~ SVS Prime Satellite Surrounds ~ MultEQ XT Flat / DEQ OFF~ Power Sound Audio XV15
D Bone is offline
post #18603 of 53910 Old 04-11-2012, 09:24 AM
Fastslappy's Avatar
Liked: 749
Yes you are missing something ,modern AVR's don't have the robust amp sections that older AVR's had . The new feature rich AVR's only have a certain amount room in the box by design , add more PCB's & the less room there is for the robust amps that were in the less feature rich older style AVR's .
The Emotiva amps have a very low noise floor, lower than a stock AVR amp section has . Add in the more watts in the Emo's per channel , the ability to run @ lower levels means lower noise floor as well . Then also Add in the added headroom factor & then added amps make a lot of sense .
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #18604 of 53910 Old 04-11-2012, 09:57 AM
Liked: 29
Fair enough. That all makes sense to me =^)
Turn it up!
post #18605 of 53910 Old 04-11-2012, 10:01 AM
bosoxfan's Avatar
Quoted: 29 Post(s)
Hey guys, i recently bought a pair of RF82ii's and using an onkyo 805. I love these speakers and have been immersed in this thread....its HUGE!
Question, i ran audessey and it set my speakers ( i am using a powered sub) to full range which i changed to 80hz. After reading i will play a bit more with the crossover freq, but does anyone have a good setting for pairing these with the RC 35( which is what i am using)?
Anyhow, glad to join a great community!
bosoxfan is offline
post #18606 of 53910 Old 04-11-2012, 10:19 AM
Mike Garrett's Avatar
Quoted: 7096 Post(s)
Liked: 4797
It depends on what SPL at the seat that you want and how hard to drive the speaker may be. Some speakers have some pretty low impedance dips.
mjgarrett100@gmail.com
Mike Garrett is online now
post #18607 of 53910 Old 04-11-2012, 11:15 AM
tony123's Avatar
Liked: 38
The RF7's that dualedge is asking about are one of those speakers.
The "Twinseltown" Theater
Construction Thread
tony123 is offline
post #18608 of 53910 Old 04-11-2012, 06:46 PM
MCF34's Avatar
Quoted: 81 Post(s)
Anyone know the correct angle adjustment screw size for a RC-25 center channel? I have misplaced mine and have angled my center channel using some rubber feet stacked on top of each other and it does seem to help some with sound direction.
Jutter is gone..zipadeedoodah zipadeeday!!!
MCF34 is offline
post #18609 of 53910 Old 04-12-2012, 07:11 PM
Liked: 4797
Correct, but I don't think the RF-7 II's have as low an impedance dip as the RF-7's. That dip is why a lot of people noticed a difference when connecting up a more powerful amp to the RF-7's.
post #18610 of 53910 Old 04-12-2012, 07:25 PM
Louis Bartay's Avatar
Quoted: 305 Post(s)
Liked: 716
Try setting the fronts as "Small" this helped my RC-62 center. And I used 80 as my cross over when I had my 805. Worrked great on movies. For music I use "Pure Direct" no processor and set cross over at 80 but I have Cornwalls and two Subs in very small den.
Klipsch Cornwall I,C7,RS3-II, R-14M
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
Yamaha RX-V1900 HD PS3
Louis Bartay is offline
post #18611 of 53910 Old 04-12-2012, 09:56 PM
Fastslappy's Avatar
Liked: 749
anyway you say it the 7's & the 7II's still pull alotta watts for those 2 large woofers . & that mostly happens only during dynamic scenes in a movie .
running a 7.1 set-up off just a modern AVR is going to over tax the AVR's amps . Might not clip,but it will be missing alotta dynamics , that's where Amp headroom comes in . I know there are people who say most AVR's need only push 5 to 10 watts a channel to make music. but in Dynamic music passages & in action movies, headroom is needed to accurately present the sounds.
Mike
post #18612 of 53910 Old 04-15-2012, 06:14 AM
bosoxfan's Avatar
Quoted: 29 Post(s)
Thanks for the response, unless I overlooked it, I dont think there is a setting for "small", just full band and then specific crossover frequencies. I feel like the center is getting drowned out by the 82's, I will play with it more and report back.
bosoxfan is offline
post #18613 of 53910 Old 04-15-2012, 06:52 AM
nezff's Avatar
Quoted: 156 Post(s)
Liked: 76
When setting a xover, you are basically setting it to small. All avrs are different in this aspect
nezff is offline
post #18614 of 53910 Old 04-15-2012, 07:41 AM
Quoted: 305 Post(s)
Liked: 716
It's beeen two years.... I have a Yamaha RX-V1900 HD AVR now. It has YPAO room correction I changed it to "small" from "large" with my huge Cornwalls for movies and my RC-62 center is balanced better in my room.
The older I get the more signal gain I add to the center. Have you tried to add gain to the center to see if this helps?
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
post #18615 of 53910 Old 04-15-2012, 08:14 AM
bosoxfan's Avatar
Quoted: 29 Post(s)
Not yet, but that's what I will try next. Not that any of it sounds bad, just looking for that sweet spot
bosoxfan is offline
post #18616 of 53910 Old 04-15-2012, 08:58 AM
Fastslappy's Avatar
Liked: 749
by setting your crossover to 80 you are taking alot of bass dynamics outta your Cornwalls. I set my CornScala's @ 40 just above rolloff that way I get the full benefit outta the 15" woofers as well as my subs
Mike
post #18617 of 53910 Old 04-15-2012, 10:00 AM
Quoted: 305 Post(s)
Liked: 716
OK I will try that. Thanks ...
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
post #18618 of 53910 Old 04-15-2012, 01:43 PM
kemiza's Avatar
Liked: 92
Originally Posted by Chuck Miller View Post
I'm planning my home theater and have pretty much decided on the THX Ultra2 system. A couple of questions. First, I see that Klipsch recommends locating the two subs next to each other. Their diagram shows them together at the front of the theater. Have you THX U2 owners experienced an advantage with this setup? Or, do you recommend something else? I realize a lot has to do with room dynamics, just looking for general experience here.
Second, I like the idea of buying a system that's been designed to optimally work together. However, I also read a lot about the great capabilities of many other subwoofers. That would seem to be about the only place that I would think about substituting another brand in the system. Any experience with this? Using maybe a couple of Hsu's instead of the KW-120s? Or are the 120s simply that good that one wouldn't consider other approaches?
Thanks for your advice.
Chuck
I heard this system at a local av store you won't be disappointed with sound as a whole or the subs.
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
post #18619 of 53910 Old 04-15-2012, 03:35 PM
Liked: 29
Anybody have any feedback on the SW-115? I'm trying to decide to go with that or the SW-112. If I go with the SW-112, I'll probably eventually go with 2 of them. What do you think would be better to go with, 2 SW-112s or a SW-115?
Turn it up!
post #18620 of 53910 Old 04-15-2012, 04:15 PM
Liked: 4797
With these two subs the choices are:
Good SW-115
Better Two SW-112
Best two SW-115
post #18621 of 53910 Old 04-15-2012, 04:29 PM
Fastslappy's Avatar
Liked: 749
klipsch LaScala's on sale over @ Audiogon listed ToDay !!
http://app.audiogon.com/listings/klipsch-lascala--3
Mike
post #18622 of 53910 Old 04-16-2012, 11:43 AM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 360
I will let you know in a few days when my 115 comes in.
I have high expectations for the 18hz and 121dB, But I am only buying one for now.
Good SW-115
Better Two SW-112
Best two SW-115
Truth^
Pictures would be nice!
My Name is Nobody...
Klipsch x11i - Klipsch x20i - Oppo HA2
Pioneer SC85 - Bel Canto REF 500M
Klipsch La Scala II - Klipsch Cornwall/Crites/Aletheia Audio - Klipsch RC64II - SW-115
Wyred 4 Sound DAC2 DSDse - OPPO BDP-93
Samsung PN64D8000
MSchu18 is offline
post #18623 of 53910 Old 04-16-2012, 11:48 AM
Fastslappy's Avatar
Liked: 749
Originally Posted by MSchu18 View Post
[b]
not my sale .... just referencing them here as there are some here looking for a pair .. my 4 CornScalas work fine with me !
Mike
post #18624 of 53910 Old 04-16-2012, 12:42 PM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 360
I just made a deal for a RC64ii for $800NIB... pick it up tomorrow.
Happy Happy Joy Joy!
Samsung PN64D8000
MSchu18 is offline
post #18625 of 53910 Old 04-16-2012, 01:51 PM
Nascar14's Avatar
HI I am a newb but I am a Klipsch owner. front L/R=VF-35 and center= SC-1 drivin by Yamaha RX-A800 and JVC sub with cheap Fluance Bipolar surrounds. viewed on a Sony Bravia ex 55 lcd. so Hi all.
Nascar14 is offline
post #18626 of 53910 Old 04-16-2012, 04:08 PM
ILOVEMYHDTV's Avatar
Quoted: 53 Post(s)
Liked: 50
Welcome !!
PS3+4= CHiNGOBLiNG = RUBEN...YOU NEED TO OPEN YOUR EYES TO SEE THE PICTURE!!... "SHOE MAKER HOME THEATER".7/22/16....just a KLIPSCH NUT..>7/22/16...2new videos show..https://www.youtube.com/watch?v=jWO0YtCWQxI.....https://www.youtube.com/watch?v=yIen05Wcg9w. u can even look from when I started about to present day.... i stutter sometimes....
ILOVEMYHDTV is offline
post #18627 of 53910 Old 04-16-2012, 04:20 PM
rolltide0323's Avatar
I've asked someone to move my thread but no one didn't so I'm posting it in here.
Right now I have a pair of Klipsch VF-36 towers. I came across an ad selling a pair of Klipsch RF-3's. I looked at the specs of both speakers and there is not much if any difference in Frequency respose. My question is would it be smart to pick up the RF3's or just keep my VF-36's? I know the
RF3's are older but what is the difference in the 2?
Thanks for your time.
rolltide0323 is offline
post #18628 of 53910 Old 04-16-2012, 04:27 PM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 360
RF3's are bad arse speakers... get'em!
Samsung PN64D8000
MSchu18 is offline
post #18629 of 53910 Old 04-16-2012, 06:22 PM
Quoted: 305 Post(s)
Liked: 716
DITTO..Welcome..........
Cornwalls (1979)
Heresy II (1989)
RC-64
RS3-II
Synergy Sub 12" X2
Yamaha RX-V1900 HD 7.2 AVR
Yamaha CD Player
Sony BRP
Toshiba 55" LCD/LED
ReVox R2R
Klipsch Heresy II,
Klipsch Sub 12 X 3
SVS PB 13 Ultra Sub
post #18630 of 53910 Old 04-16-2012, 08:04 PM
Liked: 29
I could have already known if who I am trying to buy my speakers from would stop being slow in responding to me. They have tomorrow to give me some sort of response or I'm ordering from somewhere else. You would think that someone buying a 7.1 Klipsch speaker setup would get some good customer service...
Turn it up!
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
