Klipsch owner thread - Page 623 - AVS Forum | Home Theater Discussions And Reviews
 6052Likes
Old 04-19-2012, 05:43 PM
travisamc's Avatar
I'm thinking of mixing up a Klipsch speaker setup.
What do you think of this 7.1 setup...
Front Left & Right - RF-7 II
Powering the RF-7 II's would be an Emotiva XPA-3 (200W x 3)
The rest will be powered by the receiver (~125W)
Center - RC-62 II
Surround Left & Right - RS-62 II
Surround Back Left & Right - RB-81 II
Subwoofer - Klipsch or SVS
I wouldn't mind the RF-82 II's but I want the better quality sound of the RF-7 II's. I DON'T want the 3 foot wide RC-64 II Center, it probably sounds great but that's too big of a speaker for my room. I know most of a movies dialogue comes from the center channel but I'm building a custom Entertainment Center and adding on another 12" just isn't possible.
Will the RF-7's way overpower the rest of the system?
Or will lightening my receivers load by 2 channels help give the rest of the system a little more power?
travisamc is offline
Old 04-19-2012, 06:05 PM
ILOVEMYHDTV's Avatar
Quoted: 47 Post(s)
Liked: 48
that is gonna sound AWESOME ! BUT it my be over powering..but you should finest the balance..
PS3+4= CHiNGOBLiNG = RUBEN...YOU NEED TO OPEN YOUR EYES TO SEE THE PICTURE!!... "SHOE MAKER HOME THEATER".7/22/16....just a KLIPSCH NUT..>7/22/16...2new videos show..https://www.youtube.com/watch?v=jWO0YtCWQxI.....https://www.youtube.com/watch?v=yIen05Wcg9w. u can even look from when I started about to present day.... i stutter sometimes....
ILOVEMYHDTV is online now
Old 04-19-2012, 06:14 PM
Chuck Miller's Avatar
I can't speak to timbre or other balance issues, but if you have an XPA-3, I would drive the left, right AND center using those three channels of high powered clarity. Leave all the surrounds to the receiver. Any reason not to use the Emotiva for the center?
Cheers!
Chuck
"The Ginky Weeds" Theater Design and Construction Thread
Sherbourn PT-7030, PA 7-350, PA 7-150, PA 4Z-75, C-12, Oppo BDP-103D
Klipsch La Scala I LCR with Crites AA crossovers & tweeters; Heresy I S&R surrounds with Crites crossover upgrades
Bill Fitzmaurice DIY THT subwoofers (2)
Chuck Miller is offline
Old 04-19-2012, 06:36 PM
Mike Garrett's Avatar
Quoted: 5568 Post(s)
Liked: 3550
Cheers!
Chuck
I agree. You will have three channels, so I would feed all three. I also would try to fit the RC-64 if possible.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 04-19-2012, 06:52 PM
Browninggold's Avatar
Liked: 37
That's what I do with my Emotiva XPA-3. I drive my 3 RF7IIs (FL,C,FR) with that and let the A100 handle surrounds.
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
Old 04-19-2012, 07:00 PM
Louis Bartay's Avatar
Quoted: 213 Post(s)
Liked: 578
Center - RC-62 II
I have the RC-62 center and huge Cornwalls for fronts(small 10X14 den), if you have normal size room the RC-62 will work fine with the RF-7II. If you have a Pre/Pro or AVR that has a room correction feature it will match all these speakers just fine. I was suprised that my blending of Heritage and Reference Series worked out very nice. In the last few years I have added some signal gain to the center for voices on some Blurays(getting older) SVS subs are great but expensive.
Klipsch Cornwall I,C7,RS3-II
Klipsch Heresy II, KSB 1.1
Klipsch Sub 12" X3 Hafler P3000,P1000, DH330 DH110
Yamaha RX-V1900, SVS PB 13 Ultra
ReVox A-77 Mk IV Dolby, Nakamichi BX-100 PL-518X DL103R
Louis Bartay is offline
Old 04-19-2012, 07:08 PM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 359
I concur... heritage and reference series work well together.
My Name is Nobody...
Klipsch x11i - Klipsch x20i - Oppo HA2
Pioneer SC85 - Bel Canto REF 500M
Klipsch La Scala II - Klipsch Cornwall/Crites/Aletheia Audio - Klipsch RC64II - SW-115
Wyred 4 Sound DAC2 DSDse - OPPO BDP-93
Samsung PN64D8000
MSchu18 is offline
Old 04-19-2012, 07:15 PM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
I have RF-83s and a RC-62 up front and the RC-62 pulls its share of the load just fine.
I really like the RC-64 but I just could not give up that much space.
I think the RC-62 will work just fine with the RF7s
Charlie
chashint is offline
Old 04-19-2012, 07:50 PM
travisamc's Avatar
Cheers!
Chuck
Well I wanted to use the RC-62 II (150W) so I wasn't sure if the 200W Emotiva would be too much power for it.
I can try but its going to be a lot of extra work. I'm an Design/Engineering Draftsman at a custom cabinet company and I'm building a killer AV Center with all the house tools and tricks. As it sits now, its 74" wide. 3 cabinets total with glass doors, hidden wheels, intake/exhaust fans and internal cable management.
BUT...that RC-64 sure would sound great!! haha
That's a very close set up, I like the smaller size of the RC-62 but of course knowing myself I will always look back and want the best (within reason).
I guess I'll just have to get the RC-64 and just make it work in the cabinet, SO the newest revision will make my AV Center over 7' wide!
Old 04-19-2012, 08:20 PM
Quoted: 213 Post(s)
Liked: 578
Look on Ebay for all the different fans you can purchase and install in the back of the shelves to keep the amps etc cooler.... I never stack on my AVR and fans on all my vintage R2R and amps. Even on the back of my 55" LCD/LED I have two small fans that are for "Office Cubicles" small 4" on a stand aimed at the bottom vents. Klipsch use to make a center for the KLF fronts it's a C7 and a little bigger then a RC-62 with larger horn.......I looked for one of them used and finally purchased a RC-62 when 62II came out and saved some money.
Old 04-20-2012, 06:37 AM
Travis,
That Klipsch speaker would love to have the clean 200 watts capacity that the Emotiva will deliver. It's not power that damages speakers, it's distortion. And the more and cleaner power you can deliver to the speaker, the better it will sound. So I wouldn't worry for a nanosecond about driving the RC-62 with the Emotiva.
Having said that, I agree with Mike. If there is any way to fit the RC-64 into your system, do it. The center channel is really important! We don't want you to have regrets later when you think "I could have had an RC-64"! I remember years ago when I bought my first HT audio system, I auditioned several of the Klipsch speakers. My wallet was telling me to moderate, but when I heard the clear difference between the KLF-C7 (then Reference series) and it's next closest model, it was night and day. In fact, that sold me on the entire Klipsch Reference system and I've been a big fan ever since.
Cheers!
Chuck
Old 04-20-2012, 06:55 AM
Fastslappy's Avatar
Liked: 749
IF you can afford the RC64 then it's gonna sound best but a RC62 will worl as well but do have the Left/Center/Right on the Emo
You will love the dynamics in movies with the headroom the amp will provide
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
Old 04-20-2012, 01:25 PM
Urlryn's Avatar
Hey Guys.....
Needs some expert advice here before I pull the trigger.
Vann's gave me some pretty decent pricing today (not the best I've seen them do but its still pretty good)...so I'm looking to get the:
RF7II
RC64II
Optional right now depending on if i have to buy a new receiver or not.
RS62II and/or RB81II
I currently have:
Receiver - Denon AVR-1910
Can I get a Emotiva XPA-3 to use with my existing receiver?
Or do i need to upgrade my receiver?
if so to which is (onkyo/denon pref) best bang for buck?
Urlryn
Urlryn
Pioneer SC-1222-K
Emotiva XPA-3
Behringer EP4000
Klipsch RF 7ii
Klipsch RC 64ii
Subs: Pair of SI D4 18's 4 cuft sealed
Urlryn is offline
Old 04-20-2012, 02:10 PM
tony123's Avatar
Liked: 38
Unless my research was inaccurate, that receiver doesn't have preamp ins and outs, so you can't use an outboard amp with it. And unfortunately, it will not take full advantage of the 7's with its onboard amps. You'll be pleased, and likely not have trouble, but the 7's will be neutered by the amps.
Also, can you consider a third 7 in place of the RC64? if so, that would be preferred.
The "Twinseltown" Theater
Construction Thread
tony123 is offline
Old 04-20-2012, 02:15 PM
Urlryn's Avatar
Wish I could do a third RF7...but won't be possible with the room!
So basically I will need to replace my receiver and get the amp?
Urlryn
Urlryn
Pioneer SC-1222-K
Emotiva XPA-3
Behringer EP4000
Klipsch RF 7ii
Klipsch RC 64ii
Urlryn is offline
Old 04-20-2012, 02:24 PM
Fastslappy's Avatar
Liked: 749
Urlryn
Yeah .. remember that the AVR just needs the Pre-Out's , You could get away with a used AVR that has pre-outs & get a new model later to cut down on the $ outlay ATM, but the speakers & the Amp are the prime items. there alot of very good AVR's on the used market that are great deals .
the Speakers & the Amp will last you a life time ....... most of us when we get a top tier speakers we keep them for ever . That Emo amp is built to last & amps don't get out dated like a AVR does . There are people who have had amps for 20 years and they still work great ..
Mike
Old 04-20-2012, 02:25 PM
tony123's Avatar
Liked: 38
Yes. With the amp, you would also need either a receiver that does have preamps, or a bonifide preamp.
Don't misunderstand, the 7's will be impressive with your receiver. Just not running at 100%, and there is potential for you to damage them if you run them on the edge. Maybe don't do anything now and see how you feel after you listen awhile?
Construction Thread
tony123 is offline
Old 04-20-2012, 02:31 PM
Fastslappy's Avatar
Liked: 749
Emotiva is having a Sale right now as well !
10% off that XPA-3 & Free Shipping
http://shop.emotiva.com/
Mike
Old 04-20-2012, 04:15 PM
Urlryn's Avatar
Yeah I might just give them a try....its not like I'm gonna be blasting them. Its 90% movies and maybe some 5% TV and 5% Gaming (Wii/PS3).
Also with the Vanns card gives you 2 years interest free financing...so thought I might take advantage of it...unfortunately they don't sell Emotiva's! hehe
Thats why i was asking about the Receiver.....i could add that...just needed to know what was good. Looking at the Denon 2312IC or Onkyo NR809?
Urlryn
Pioneer SC-1222-K
Emotiva XPA-3
Behringer EP4000
Klipsch RF 7ii
Klipsch RC 64ii
Urlryn is offline
Old 04-20-2012, 04:35 PM
StuBerger's Avatar
I saw a pair of KLF20's for sale in my local Craig's List...are these any good? I have a older receiver I am planning on using for music.
Those are my principles, and if you don't like them... well, I have others.
StuBerger is offline
Old 04-20-2012, 04:41 PM
Fastslappy's Avatar
Liked: 749
KLF-20's are Great ! easy to get parts for as well
Mike
Old 04-20-2012, 05:52 PM
StuBerger's Avatar
Hey fast, how are they compared to newer Klipsch's and what are they comparable to?
BTW...what size woofers do they have? I saw a small pic and noticed two horns as well???
Old 04-20-2012, 06:24 PM
Fastslappy's Avatar
Liked: 749
they got a tweeter horn ,a squawker horn, & 2 10" woofers
& they are Kick A$$ speakers I'd say they are as good or better than the RF7II's
100dB@1watt/1meter so they be sensitive as heck
200 watts 800 watts peak they move a whole lotta air
next to your old reference system you sold they will blow them outta the water Big Time
they had some lamination problems on the cab walls with them but it's easy to fix
http://www.klipsch.com/klf-20
the woofs go low into the 30's .
bob crites sells a titanium diaphragms for the mid drivers so even if the mids are harsh then they can be tamed .
how much are they going for ??
Mike
Old 04-20-2012, 07:18 PM
Liked: 3550
You need the Denon 3312. AVS is now a Klipsch dealer.
Old 04-20-2012, 08:05 PM
StuBerger's Avatar
Fast, the guy is asking 750 for the pair...is that a okay price...they seem to be in excellent shape!
Old 04-20-2012, 08:40 PM
Fastslappy's Avatar
Liked: 749
that's very decent those are very rare .. they didn't sell many at all ... that's why you don't see them very often .. if U get them replace the diaphragms as the new diaphragms Bob has will really sweeten the sound ,they are better than stock .
Tell the guy the drivers need work & he might come down some
Mike
Old 04-20-2012, 09:18 PM
I bought a pair in 1998. If it's any help for your negotiation, they retailed for $1500 a pair and I paid $1000. On that basis, $750 sounds high now, but if they are rare now, perhaps it's not so bad.
Chuck
Old 04-21-2012, 01:52 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
RF7 II are 8 ohm with 101db sensitivity. Shouldn't take much power at all to get them to sing.
Afro GT
afrogt is offline
Old 04-21-2012, 05:20 AM
tony123's Avatar
Liked: 38
It's the impedence curve that makes them a bit demanding on an amp (apparently not so much in the 7ii version). Particularly, a receiver that has a power supply trying to deliver to 7 different amps simultaneously.
I've been down this path myself and blew a driver for it.
Construction Thread
tony123 is offline
Old 04-21-2012, 06:40 AM
06GTOguy's Avatar
The 2312 does not have preouts, you would need the 3312 or higher.
I believe the 809 does have preouts but not 100% on that.
06GTOguy is offline
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
