Klipsch owner thread - Page 626 - AVS Forum | Home Theater Discussions And Reviews
 6058Likes
post #18751 of 51651 Old 04-28-2012, 07:11 AM
jedimastergrant's Avatar
Quoted: 548 Post(s)
Liked: 271
I will add that my best results so far in my second room I had the speakers about 1.5-2 feet away from the side and back walls. The main LP was 12 ft from the speakers and they were approx 25 degrees from the main LP. Both speakers with a good amount of toe in so that they are almost pointed directly at the main LP.
The equipment used was Harman Kardon AVR 3600, Emotiva XPA-5, and PS3. With my Rythmik F12SE which is underpowered next to these monsters. I have the sub pretty hot and I still want more.
I ran the room correction EQ that comes with my HK AVR3600 in the second room. It is proprietary and is called EZEQ. I suspect it is inferior to Audessey but not sure. I have not run EZEQ in my current room so lots of variables at play.
jedimastergrant is offline
post #18752 of 51651 Old 04-28-2012, 07:55 AM
Fastslappy's Avatar
Liked: 749
Your running a XPA-5 then you have enough power to set the cross-over at what audyssey or any room correction software , will set the speakers for.
setting @ 80 is not always the best way to set-up a system when you have extra headroom power that a external amp provides .
The reason most say set 80 is to take the lower frequencies & transfer them to a sub is the sub has it's own power .
You have extra power in a XPA-5 .That extra power will allow the woofers in all the speakers add more bass dynamics into your room. The sub will still play those lower frequencies as well as the speakers will too & THAT adds much more dynamics into the room .
My setup has the Mains , Surrounds set @ 40 & the Center ,Heights,Wides set as 50 . just above what each set of speaker starts to "roll off @ " Roll off is the point where the woofer start to lose the lower frequencies due to not being able to produce them . mine spec @ 30 & 40 , so they are set to 40 & 50 the roll off point is usually 10 above what the speaker is rated for .
By setting @ 80 you taking all the balls outta your 83's & that is what the 83's are good at that.....
they have good clean punch, clean well defined mid bass response in the woofer section.
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #18753 of 51651 Old 04-28-2012, 08:13 AM
Quoted: 548 Post(s)
Liked: 271
FastSlappy,
Do you have the RF-83's as well? What sub are you using? What amp? Any thoughts on the speaker placement?
post #18754 of 51651 Old 04-28-2012, 08:28 AM
Fastslappy's Avatar
Liked: 749
FastSlappy,
I have CornScala & CS-1.5's (Herisey clones ) they have 15" & 12" woofers , I use a Emo UPA-7 & a UPA-2 , I run 9 channels heights & wides ,no rears
83's should be away from walls due to them being rear ported , toed in & near corners (but a good 1 to 2 feet away from any wall )
I have dual SVS PC12-NSD's .
movies @ my house are simply amazing , the dynamics are stunning ..
Mike
post #18755 of 51651 Old 04-28-2012, 08:53 AM
Louis Bartay's Avatar
Quoted: 213 Post(s)
Liked: 578
NICE System
Klipsch Cornwall I,C7,RS3-II
Klipsch Heresy II, KSB 1.1
Klipsch Sub 12" X3 Hafler P3000,P1000, DH330 DH110
Yamaha RX-V1900, SVS PB 13 Ultra
ReVox A-77 Mk IV Dolby, Nakamichi BX-100 PL-518X DL103R
Louis Bartay is offline
post #18756 of 51651 Old 04-28-2012, 09:27 AM
Fastslappy's Avatar
Liked: 749
Originally Posted by Louis Bartay View Post
NICE System
thanx
to further break down the system is 4 CornScala's mains & surrounds , 5 CS-1.5's Center, heights,wides... onkyo TX-NR1009 & a TX-NR5008 that is being repaired & then sold , @ that point a AVR will be purchased to replace the 5008 & the 1009 goes to the bedroom to replace a TX-NR807 .
I love the Onkyo Video processors in the XXX009 & up line , beats the heck outta the XX008 line
I'm done with speakers now I have my lifetime set ...
Mike
post #18757 of 51651 Old 04-28-2012, 10:17 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
it would be cool to have the CS-1 available in a KPT surround format...
psgcdn is offline
post #18758 of 51651 Old 04-28-2012, 10:45 AM
mmiles's Avatar
Quoted: 465 Post(s)
Liked: 214
Thinking about klispchorns but one "corner" of the room is open. bad idea?
Mike Miles
mmiles is offline
post #18759 of 51651 Old 04-28-2012, 11:04 AM
Fastslappy's Avatar
Liked: 749
mine are custom horizontal's that hang from the ceiling CS-1.5 are bigger thou .. I've got them down right now but will have back in better positions soon . I post Pix when I get them back up ..
Mike
post #18760 of 51651 Old 04-28-2012, 12:28 PM
ILOVEMYHDTV's Avatar
Quoted: 47 Post(s)
Liked: 48
ha hey wrote klipschorn , and slapmehappy define "clones"...be about time for some picssss......
PS3+4= CHiNGOBLiNG = RUBEN...YOU NEED TO OPEN YOUR EYES TO SEE THE PICTURE!!... "SHOE MAKER HOME THEATER".7/22/16....just a KLIPSCH NUT..>7/22/16...2new videos show..https://www.youtube.com/watch?v=jWO0YtCWQxI.....https://www.youtube.com/watch?v=yIen05Wcg9w. u can even look from when I started about to present day.... i stutter sometimes....
ILOVEMYHDTV is offline
post #18761 of 51651 Old 04-28-2012, 12:34 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
You'd have to either close off the back on that one, or do some sort of false corner. I had one butted up against a thick IKEA table top once, which another piece of furniture to hold the table top in place. But there are ways of holding something like that in place. More importantly, maybe, is the size of the room and the spacing between the speakers.
psgcdn is offline
post #18762 of 51651 Old 04-28-2012, 12:39 PM
Fastslappy's Avatar
Liked: 749
here's the lastest Dope on the CS-1 & the CS-1.5
And now Bob is making a center as well
http://www.critesspeakers.com/crites...r-project.html
Mike
post #18763 of 51651 Old 04-28-2012, 01:19 PM
Quoted: 548 Post(s)
Liked: 271
Fastslappy,
I would love to see some pictures of all of the speakers and the room. I am considering a DIY sub solution right now but going DIY for speakers is a little bolder. I don't have the woodworking skills. Hopefully I can successfully integrate the RF-83's in my room. If not then anything is possible I guess...even DIY.
post #18764 of 51651 Old 04-28-2012, 01:35 PM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 169
A few months ago I purchased a pair of RF-52 IIs. They are located in a large great room with wood floors on the first floor of the house. I really like the way they sound.
I am looking to upgrade my 5.1 setup in the basement and am curious if that sound would be severely affected by placing a pair of RF-82 IIs or RF-7 IIs on carpet over concrete...
Thoughts?
TIA.
Mathematics is the reason for the season.
Nickff is offline
post #18765 of 51651 Old 04-28-2012, 03:44 PM
Fastslappy's Avatar
Liked: 749
Fastslappy,
The wood working part is now do-able as Bob Crities now has a CNC router & he can whip up the pre cut cabinets or sell you assembled speakers ..
compare those prices he's listing for those models CS-1.5's & CornScala's they are 1/3 of the price of any new Heritage speaker AND they have a much better SQ to boot .
he's taken the Klipsch idea & taken it to a much higher level thru really high quality drivers .. I'm very happy with mine & I've had Klipsch Heritage speakers since 1973 . The old 73's are modded into CornScala & my satillites are horizontal CS-1.5's
here's a few pix on the PC ...............
Mike
post #18766 of 51651 Old 04-28-2012, 06:30 PM
scrapser's Avatar
I just ordered my Klipsch RB-61 II speaker system to replace my old Bose V20 system. The center speaker weighs 22 lbs. so I will need something hefty to mount it to the wall. The point where the speaker will be mounted will be hollow drywall so I will need good wall anchors. That doesn't scare me so long as I can get a decent mounting rack or shelf.
Can anyone here recommend either a mount or shelf for this speaker? Suggestions for the floor stands for the rear surround speakers (RS-42 II) would be appreciated as well.
scrapser is offline
post #18767 of 51651 Old 04-29-2012, 11:26 AM
lflorack's Avatar
Quoted: 70 Post(s)
Liked: 59
Originally Posted by lflorack View Post
I went to the store tonight for the A<>B comparison of the new Klipsch RF-82 II's /RC62 II versus the RF-83's/RC-64. The pricing for both three-speaker 'sets' ended up virtually the same so price wasn't a factor really. I asked the speaker's age and was told they are approximately a little over 2 years old. The owner sold them back to the store in the original packaging when he recently traded them in for new Emotivas.
You may recall that I currently have RVX-54's and a RVX-42 for the center.
I first listened to the 82's. They sounded very good and a very big improvement from my current speakers. However, when we switched to the 83's, the difference was amazing. The base was deeper but tighter and the highs we more open and transparent. We switched back and forth a few times to confirm it, but in the end, there was no real choice.
Any other 83 owners here? Also, I'm thinking of relacing my current surrounds (RSX-5's) with the RVX-54's. Any thoughts?
I'll bring them home tomorrow and hook them up. Let the fun begin!
They're in! Tweaking still underway but I love them so far. Pic below:
Link: http://flic.kr/p/bRAjC6
Link: System Pix
Klipsch: (2) RF-83, (1) RC-64, (2) RVX-54, (2) RSX-5, SVS: (1) SB13-Ultra
Yamaha: Aventage RX-A2010, CDC-685, Oppo: BDP-93, JVC: Procision DLA-X550R
DragonFly: 16:9 133" High Contrast Screen, Apple: AppleTV, Roku: Roku4
Amazon: FireTV Stick, SimpleControl: IP Remote, Logitech: Harmony One
ACP: J15BLK 1.5 kVA Power Conditioner/UPS
lflorack is offline
post #18768 of 51651 Old 04-29-2012, 11:45 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Very nice picture!
psgcdn is offline
post #18769 of 51651 Old 04-29-2012, 01:05 PM
Fastslappy's Avatar
Liked: 749
Nice...How's it sound ???
Mike
post #18770 of 51651 Old 04-29-2012, 01:14 PM
lflorack's Avatar
Quoted: 70 Post(s)
Liked: 59
Very nice picture!
Thank you!
Link: System Pix
lflorack is offline
post #18771 of 51651 Old 04-29-2012, 01:20 PM
lflorack's Avatar
Quoted: 70 Post(s)
Liked: 59
They sound very, very nice and a big improvement from my previous speakers (whcih are now in the surround position). Just a bit of tweaking (isn't there always?) I ran YPAO and it sounds very good. YPAO made them 'big' and set the crossover at 80. I think I may try setting them to small and seeing what that sounds like too.
They seem to fill the room (20x20) much better than my previous speakers. Bass is tighter and highs are very clear. My wife is having fun learning the real words to a lot of songs now
Link: System Pix
lflorack is offline
post #18772 of 51651 Old 04-29-2012, 04:46 PM
JBrax's Avatar
Quoted: 47 Post(s)
Liked: 35
Thoughts?
TIA.
Some really nice subs would really compliment that setup. Very nice speakers.
JBrax is offline
post #18773 of 51651 Old 04-29-2012, 05:15 PM
Carnut12's Avatar
Take a peice of 3/8-1/2 plywood, cut it slightly smaller than the back of the Speaker, find your studs and screw it to them. Then mount your speaker to the plywood. Paint the sides of the plywood black if your worried about someone seeing them.
Carnut12 is offline
post #18774 of 51651 Old 04-30-2012, 05:49 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
If the speaker is over hollow drywall, then surely a piece of plywood smaller than the speaker will also be over hollow drywall?
I'd be tempted to open up the wall between two joists, screw in some support 2x4 horizontally between then, cover up with drywall, plaster, prime, paint.
psgcdn is offline
post #18775 of 51651 Old 04-30-2012, 07:27 AM
Mike Garrett's Avatar
Quoted: 5575 Post(s)
Liked: 3554
If the location is in the center between two studs, then get a piece of 3/4" AC plywood. Cut 16" wide (can be wider if wanted) and slightly longer than the speaker height. Fasten to the two studs, place molding around the plywood to dress it up. Paint to match walls and then hang the speaker in the center.
mjgarrett100@gmail.com
Mike Garrett is offline
post #18776 of 51651 Old 04-30-2012, 10:10 AM
Fastslappy's Avatar
Liked: 749
this is the best way to do it studs are on 16" centers meaning it is 16" from each center of a stud to the next , if a slight downward tilt is needed that can be done with small blocks of wood ,a chain .. what ever if you need advice on tilting report back
Mike
post #18777 of 51651 Old 04-30-2012, 12:44 PM
Carnut12's Avatar
Sorry but just like the 2 people after me posted, this is how you do it, the plywood hits the studs so your speaker does not have to. No wall is hollow for more than 24", most should not be over 16".
Your way, opening up the wall, is absolutley ridiculous, just saying.
Carnut12 is offline
post #18778 of 51651 Old 04-30-2012, 02:59 PM
Sepen's Avatar
Quoted: 27 Post(s)
Liked: 31
If you would know, or even speculate, how would the CS-1.5's compare to the ED Cinema 12's? The Cinemas have gotten positive feedback and would be cheaper with a lcr setup than the CS-1.5, and they are finished. Thanks.
Sepen is offline
post #18779 of 51651 Old 04-30-2012, 03:27 PM
Fastslappy's Avatar
Liked: 749
Nezff here on this thread has some of their stuff shoot him a email .
Actually it's all in which drivers that are being used to tell the truth , & I don't know if Ed tells which drivers they use ..
I suspect the Crites Drivers are of higher quality as he really does not mark up the drivers he sells .I did price comparisons(as he does list p/n#'s) & he is in the same ball park as most retail sellers of drivers . I was going to shop them my self but when I added shipping &taxes they were a wash between his & retail.
that is Russian Birch Bob uses ,all that is needed is a oil finish and /Or stain & poly coated . that you can do your selfeasy
Oil finish is the easiest ,wipe on & then polish
Danish oil for a blonde color OR they has oil finishes that have dark colors ..
mine are stained RedOak plywood 1&1/2" thick on the CornScalas & 3/4" redOak on the CS-1.5's
Minwax "red chestnut" stain =>teak oil => beeswax polish
Best part about doing yer own finish is the color choices
Mike
post #18780 of 51651 Old 04-30-2012, 03:51 PM
Sepen's Avatar
Quoted: 27 Post(s)
Liked: 31
The Cinema 12's have,
Eminence Kappa Pro 12A
Selenium D220Ti
Eminence H290S 90x40
For $75 more you have the option to upgrade to the B&C DE250.
Sepen is offline
Reply Speakers
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
