Klipsch owner thread - Page 628 - AVS Forum | Home Theater Discussions And Reviews
 6050Likes
Old 05-02-2012, 07:01 PM
bosoxfan's Avatar
Quoted: 23 Post(s)
Advice: current setup is,
Onkyo 805
RF 82ii
RC 35 ( for now....)
Im am having a hard time comparing the RS 52ii vs 62ii, price verses performance and which may be better with the RF 82's. Thoughts?
bosoxfan is offline
Old 05-02-2012, 07:30 PM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Originally Posted by psgcdn View Post
First, great!
Second, it's "La Scala"
Third, you think that a La Scala based system will blow the doors off a Klipsch reference or Ed setup, but would probably come pretty close to your Def Tech? I guess you have a very high opinion of your system already, and am wondering why you want to swap it out then. Without knowing what Def Techs you have, I think you will be quite surprised at what a 104 dB sensitivity speaker can do to your HT: Dynamics to spare! You'll love it!
Sorry, what I should have said is that it might come close to my personal liking of my Def Techs. The main reason that I like my Def Techs so much is because they image so well and their sound stage is incredible. I doubt the La Scala will beat them in those catagorys but for what they lack in sound stage, they make up for in clarity and dynamics. It's a trade off and I am not sure how I am going to like it.
Martycool007 is offline
Old 05-03-2012, 05:58 AM
you2slo's Avatar
Onkyo 805
RF 82ii
I have the RS-52s. I really like them. I couldn't justify the price increase or the size increase. I keep my surrounds crossed over at 80 Hz. Might the 62s have a bit more punch? Perhaps but justifying the size of the 52s to the wife was difficult enough. She is not a fan of the Series II round grill compared to the Series I grill.
you2slo is offline
Old 05-03-2012, 06:06 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Originally Posted by Dionyz View Post
My objective was to restore these and convert them to be similar to La Scala II.
W O W ! Great job!
When you cut the tops off, there was no going back!
Include pics of the mid horn you are using. Are you arranging it side-by-side with the tweeter, or standard top and under?
psgcdn is offline
Old 05-03-2012, 06:14 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
In that case, you might be surprised! But it's all about how much space you have.
The best speakers I have ever heard for imaging are Klipschorns and La Scala. Mine disappear completely from the room. You'd swear that the center speaker is playing. You discover that they are two guitars being played instead of one on some recordings and can "see" theirs strings being plucked from two different spots in front of you. Voices hang in the air. But... to achieve that with La Scala, they need to be placed as you would Klipschorns: wide separation and 45 degree toe-in. Spread them out in the corners of an 18 foot wall, tow them in and sit at the crosshairs, 9 feet from the front wall, and they will image like that. Good luck!
psgcdn is offline
Old 05-03-2012, 06:15 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Originally Posted by coytee View Post
So, if I'm reading you correctly, you installed a piece of plywood on the wall to mount the speaker....then proceeded to smash the speaker through the plywood and jammed it into the hole you were trying to avoid in the first place. Nice.
My point was that sometimes it's worth doing right (and that I do have some DIY experience)
psgcdn is offline
Old 05-03-2012, 07:25 AM
Dionyz's Avatar
Quoted: 57 Post(s)
Liked: 48
W O W ! Great job!
I am still using the original K-400 horn.
I am not hearing any of the metallic ringing that some people mention.
Maybe that was the issue with mid horn being in one cabinet, with bass vibrations passing into the mid horn. It could be that because with the separate top, I have a 1/2" riser/spacer to whose bottom I have attached acoustic tape which, along with the bass bin reinforcement and bracing, may reduce the vibrations passing from the bass bin. Whatever the reason may be, I am not perceiving the ringing, so for now I stuck with the original horn.
The tweeter sits above the mid horn.
Using Bob Crites tweeter which has extension to 20kHz, (K77 tweeter goes to ~16kHz) The tweeter is attached to Faital STH100 Tractrix horn.
Since this horn is 5" high I had to make the top section taller (16" instead of ~11") to accommodate it.
Dionyz is offline
Old 05-03-2012, 07:47 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Gotcha. I use Bob's CT-125 instead of the K77, along with his A/4500 crossover. I assumed you were doing the same and since the CT-125 is the same size as the K77 I had assumed a different mid-horn was used to account for the different height.
I don't hear the K-400 ring either and I haven't done anything special about that.
Again, great looking speakers! I tip my hat!
psgcdn is offline
Old 05-03-2012, 08:07 AM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
Originally Posted by AV Science Sales 5 View Post
Now that is where you can spend some money, depending on how low of an f3 you want.
Mike, you aren't kidding!
I'd really love to have an epic setup with the LMS Ultra in a sealed application. I am a HUGE fan of the sub-20Hz octaves. Looking at what some of the superstars of the forum have accomplished, I'd really love to achieve that ridiculous 10Hz tactical feel a serious LFE setup can accomplish.
My small HT room is only 12L x 14W x 8H so that makes roughly 1,344 cubes. With that said, my *cough* Def Tech Supercube Reference doesn't cut it in the least. I mean, it's "decent", but I've got plans for 2 Ultras and an LG Clone for the short term. Given I have a smaller room than most other people with similar setups, I'm hoping it will cure my itch until we have our home built with a serious HT in mind.
Speaking of room size here is the rest of my 5.1 setup.
L/R = RF-7II
C = RC-64II
RS/LS = RS-62II
Seems like the more I am researching, the RF-7's need more "room to breath" than what I am providing them. Is my room to small???
popalock is offline
Old 05-03-2012, 01:52 PM
Browninggold's Avatar
Liked: 37
My room is 13'x20'x8' and I have 3 RF7IIs w/RS62IIs as surrounds w/ a PB13Ultra. Your room is perfect for that setup.
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
Old 05-04-2012, 01:55 PM
jjclecky's Avatar
Hi I'm Hoping from some advice and maybe even some of you guys have done this. I want to purchase the Klipsch RB 61 II speakers for my left and right fronts and the RC 52 II center. I would be using the HSU VTF2 MK4 sub for bass management I already have rear in-walls for my surrounds.my receiver is a denon 2112 which is rated at 90w per ch, my room is 11x20,we sit about 10 feet from the display and front speakers. The speakers I have now are never turned up past -16 to -20 DB. So we would not be cranking these Klipsch up being it's not a big room. To my question will the denon receiver with 90 watts per channel be enough to power these speakers? Also this system is 100% movies, television and a little gaming for my son. Thanks very much.
jjclecky is offline
Old 05-04-2012, 02:01 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
If your receiver is setup such that 0 dB is about maximum output (i.e. audessey is not resetting it), then -20 dB is 1/100th of rated power so around 1 Watt. There's no problem at all.
psgcdn is offline
Old 05-04-2012, 02:03 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Originally Posted by MUDCAT45 View Post
I have searched and can't find speakers with doors. I have seen some cars that the sheety subs were blowing the doors.
My THT, my La Scala and Klipschorns all have covers that must be removed to reach the woofer. Those are doors.
Kinda hard to blow them off though.
psgcdn is offline
Old 05-04-2012, 02:46 PM
e84cooper's Avatar
I have this same system I love it!
Main System
Fronts RB 81 II BLK
Cener RC 52 II BLK
Rears RB 61 II CHERRY (going to be replaced with a black set)
Subwoofer SW112 BLK
SR 5006
MM7025
LG 55 LED 120HZ BDPS590 ipad 2 remote
Bedroom RB 41 II BLK/ TXSR 607 / TCL32X1 / BDPS370 / Apple TV 2 wife ipad3 remote
e84cooper is offline
Old 05-04-2012, 02:48 PM
e84cooper's Avatar
I talked to some someone at klipsch and you need to be running something that has at least 100 wpc
Main System
Fronts RB 81 II BLK
Cener RC 52 II BLK
Subwoofer SW112 BLK
SR 5006
MM7025
Old 05-04-2012, 03:14 PM
Colm's Avatar
Liked: 94
...will the denon receiver with 90 watts per channel be enough to power these speakers?
Yes.
Colm is offline
Old 05-04-2012, 07:07 PM
jjclecky's Avatar
+20 is what audyssey set the max volume at on my denon receiver.will it still be enough to power these speakers.
jjclecky is offline
Old 05-04-2012, 07:48 PM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
I have nearly the same set up with a Denon AVR 4310 and it sounds very great. The 4319 is 130 wpc. I had it mated with an Onkyo 707 which was 100 wpc and with that power it was very good espacally with movies.
I think you will be happy with the 2112.
My set up
Marantz SR-7008, Emotiva XPA-3
Samsung UBD-K8500 Ultra 4K Blu Ray Player
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
Old 05-04-2012, 08:50 PM
jjclecky's Avatar
Were the speakers being powered with 100 watts or 130 watts?
jjclecky is offline
Old 05-04-2012, 08:57 PM
mr.pope's Avatar
I am currently powering my 7.1 system of RF/RB/RC35s with a 2112 in a similarly sized room. I find that I have plenty of power for movies. I previously had a 2807 and thought music sounded better. I'm not sure that this is in my head or not.
mr.pope is offline
Old 05-04-2012, 09:28 PM
jjclecky's Avatar
Thank you
jjclecky is offline
jjclecky's Avatar
Thank you
jjclecky is offline
Old 05-05-2012, 06:28 AM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
They were origionally powered by the Onkyo 707 which is 100 wpc. Now they are powered by the Denon which is 130 wpc. There is difference between in the two. The Onkyo did a good job of driving the RB61ii, but Denon sound is not as bright and smoother. You can see mine in my signature below. JT
My set up
jnnt29 is offline
Old 05-05-2012, 07:28 AM
jjclecky's Avatar
Your setup looks great! you did a great job on the entertainment center it really looks amazing, I take pride in doing all my own building as I'm an electrician by trade and craftsman by hobby, I been building houses with my dad since I was a little boy so I know how rewarding it is to create something from scratch. Bravo well done... Sorry to hear about the surge, have you thought about a whole house surge protector? It will only cost you about a $100 and is quite simple to install at your electric panel. I'm really excited for the new speakers and hope the 2112 does the job. I was also very disappointed about 6th ave elect going out of business, if it's the one on rt 22 your talking about I would drive by it everyday and often stop in :-(
jjclecky is offline
Old 05-05-2012, 08:14 AM
nezff's Avatar
Quoted: 141 Post(s)
Liked: 63
But remember your speakers aren't getting the full 130 with all channels driven. More like 95.
nezff is offline
Old 05-05-2012, 08:34 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Bear with me because I am a bit confused, not having a receiver with Audyssey and unsure of what it actually resets.
I was under the impression that instead of having 0 dB mean the max your receiver can produce (given a maxed input), audyssey resets 0 dB to mean reference (Is this correct? What does audyssey do when the system is not capable of reaching reference?). If that were the case, then your +20dB above implies that you reach reference 20 dB below your max and that is clearly impossible. At -20 dB on the volume dial, you would be 20 dB below reference and 40 dB below your max? Not likely.
Still, since you are listening at around -20 dB, it is likely that you are only using a fraction of full rated power.
It wouldn't matter much. There's a 1 dB difference between 100 and 130 Watts.
psgcdn is offline
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
A mere 1 dB difference...
psgcdn is offline
Old 05-05-2012, 01:58 PM
jjclecky's Avatar
Im not sure about this either but I think your saying that I'm ok using the 2112 for these speakers and that makes me warm and fuzzy. I
Not sure why audussey set the max at + 20db for max volume and not 0db. So what would reference volume be in my situation then?
jjclecky is offline
Old 05-05-2012, 02:09 PM
jconjason's Avatar
Quoted: 517 Post(s)
Liked: 807
are you using relative volume or absolute? If relative, then your reference should be 0db if you're listening at -20 I'm guessing you're using relative. I'm using the 2112 as well.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
Klipsch B-20 Rears,PA 120 12" Sub,klipsch R-10SW
jconjason is offline
Old 05-05-2012, 03:09 PM
Louis Bartay's Avatar
Quoted: 213 Post(s)
Liked: 578
If that much. I have forgotten where I saw it but one of the audio magazines
did a bench test on several AVR. One was my old 2003 non HDMI Yamaha RX-V2400 7.1 AVR rated at 130X7 (I think) and it only bench tested about 55 wpc with all 7 amps on at one time. I was suprised how much I was really getting out it. And on stereo and 2 amps on it tested 80wpc sigh. I am glad I have old school Klipsch speakers that don't need a lot of power.
Klipsch Cornwall I,C7,RS3-II
Klipsch Heresy II, KSB 1.1
Klipsch Sub 12" X3 Hafler P3000,P1000, DH330 DH110
Yamaha RX-V1900, SVS PB 13 Ultra
ReVox A-77 Mk IV Dolby, Nakamichi BX-100 PL-518X DL103R
Louis Bartay is offline
belle , Klipsch , Klipsch Audio , klipsch belle , Klipsch Cornwall Iii , klipsch icon wf 35 floorstanding speakers , Klipsch Kw 120 Thx Subwoofer , Klipsch La Scala , Klipsch Lascala Ii Walnut , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 5 , Klipsch Rf 52 Ii Reference Series Ii Floorstanding Loudspeaker Cherry , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rs 62 Ii Reference Series Wide Dispersion Surround Speaker Black Each , Klipsch Rsw 10d Subwoofer , Klipsch Rw 10d Silver , Klipsch S 1 Synergy Surround Speaker Pair Black , Klipsch Sub 12 , Velodyne Dls5000rb 15 Inch 600 Watt Dls Series Subwoofer With Remote Black
