Extend Bose Speaker Wire - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-01-2006, 02:28 PM - Thread Starter
comp98's Avatar
I have a friend who wants to use his Bose Lifestyle 20 setup for surround sound on his new plasma. However, he wants to place the two rear small cube Bose speakers in the back of the room. This will require wire to be ran through the wall and ceiling. I know Bose has all their proprietary stuff, but will I be able to splice into the regular wire, and run standard 14-2 or 12-2 to the location, then crimp back the Bose connectors at each end (speaker and receiver)? Please let me know. I know the Lifestyle 20 doesn't switch component video either, so I was just going to use that for the audio, and run component from the DVD->Plasma and HDMI from the DirecTV->Plasma for the video. How does this sound?
Ryan
comp98 is offline
post #2 of 7 Old 06-01-2006, 02:33 PM
Bumpfish's Avatar
That will work. I did this at my old house.
Bumpfish is offline
post #3 of 7 Old 06-06-2006, 08:33 AM - Thread Starter
comp98's Avatar
Can anyone else confirm this? I just want to be certain before I go splicing into his Bose system. Thanks!
comp98 is offline
post #4 of 7 Old 06-06-2006, 09:10 AM
Logic_BomB's Avatar
Wouldn't the worst case scenereo be to just re-splice the old wire back together if it doesn't work for you?
Logic_BomB is offline
post #5 of 7 Old 06-06-2006, 09:16 AM
bigdaddy65's Avatar
BOSE makes extension wire for their systems. Call them...they sent me some free of charge several years ago.
bigdaddy65 is offline
post #6 of 7 Old 06-06-2006, 09:30 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Yes, tell your pal to purchase the extension wire. Even better, tell him to buy some better speakers. :D Sorry, I had to.
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
post #7 of 7 Old 06-10-2006, 07:41 AM
SAAudio's Avatar
Splicing the wire will work just fine. Make sure and get the polarity right though. Bose wire has little ridges on the negative side.
SAAudio is offline
Closed Thread Speakers
