Dynaudio Owner's Thread - Page 1205 - AVS Forum | Home Theater Discussions And Reviews
 5390Likes
post #36121 of 36873 Old 08-22-2017, 01:07 PM
Quoted: 36 Post(s)
Originally Posted by Frank79 View Post
Now regarding cables, its really diminishing returns after approx 10 dollars per meter. Diffetence is so neglible... its impossible to hear. Our senses are very volatile so its a self-delusion to hear a difference most of the time. Imagine if you have 2k dollar cable what that money would do if you put it into the speaker.
Speak for yourself and don't preach to others.
Peternz1 is offline
post #36122 of 36873 Old 08-22-2017, 01:11 PM
Quoted: 106 Post(s)
Liked: 57
Im just trying to allocate your cashflows more rationally.. for your own sake.
Frank79 is offline
post #36123 of 36873 Old 08-22-2017, 01:18 PM
Quoted: 36 Post(s)
Thanks. It is the thought that counts, I guess.
Peternz1 is offline
post #36124 of 36873 Old 08-22-2017, 01:51 PM
qirex's Avatar
Quoted: 42 Post(s)
Liked: 30
I'm looking for a new LCR set and my local dealer recommended the Emit series to me. Looking at the specs they're listed as 4 ohms which may pose a problem since very few current AV receivers can actually drive 4 ohm speakers well. Reviews of these I've read haven't ever listed them as particularly difficult to drive and since I already have a subwoofer I figure I've got a little wiggle room. Does anyone have experience driving these on a sub-$1000 receiver? My goal is to spend ~2/3 of my budget on speakers and 1/3 on a receiver.
Either way I'll probably go in for a listen next week. They had the Special Forty out in both colors and they looked amazing but they're way out of my price range [and no center].
qirex is offline
post #36125 of 36873 Old 08-22-2017, 02:00 PM
Quoted: 36 Post(s)
I know it is a radical idea, or perhaps not, but if your speakers are good enough you don't need a center. The fact is that the money saved on not buying the center can help in other, more useful areas.
Good luck driving a pair of Dynaudios with a $1000 AV receiver. I would suggest something more efficient and at least 6 Ohms to work well with your receiver.
Peternz1 is offline
post #36126 of 36873 Old 08-22-2017, 02:01 PM
Quoted: 106 Post(s)
Liked: 57
Whats the AV receiver model?
Frank79 is offline
post #36127 of 36873 Old 08-22-2017, 02:03 PM
Quoted: 106 Post(s)
Liked: 57
Like, you know, cables and stuff..
Sorry, had to do this
Peternz1 likes this.
Frank79 is offline
post #36128 of 36873 Old 08-22-2017, 02:17 PM
qirex's Avatar
Quoted: 42 Post(s)
Liked: 30
The vibe I'm getting here is that these are quite power hungry.
I've considered going 2 channel, at that point I would just probably use active speakers (I've heard Dynaudio's are quite good).
qirex is offline
post #36129 of 36873 Old 08-22-2017, 02:51 PM
Quoted: 36 Post(s)
Very good idea.
Peternz1 is offline
post #36130 of 36873 Old 08-22-2017, 03:09 PM
no quarter's Avatar
Quoted: 869 Post(s)
Liked: 459
Any receiver will work,but to get the best sound out of your speakers you need something a bit more than most AVR's can give.Rather than wasting money on an expensive AVR,just make sure the one you get has pre-out's,that way you can add a power amp to it,or integrated that will drive your LR channels better in the future.
7.2-Cary audio cinema 12 , confidence centre, XD 600's,excite 12's,Neat Iotas, Cary 500.1 monoblock, anthem mca-50, (2) Jl-audio fathom 112s, 65 inch Panasonic 3d plasma, marantz-blueray/sacd/dvd audio,Nordost Heimdall 2 cables
2 channel-Naim Core/N 272/XPS DR/250dr/power lines-XD 600's,Teac pd-501 DSD player.,Special 40's.
no quarter is online now
post #36131 of 36873 Old 08-22-2017, 03:39 PM
Red MC's Avatar
Quoted: 126 Post(s)
Liked: 87
I'm not so sure about actives if it's Emit + stereo amp vs. Xeo. The Xeos are close to double the price of the Emits.
I think Emit M10 plus a $500 stereo amp would be better than Xeo 2.
Likewise, Emit M20 plus a $1000 amp would be better Xeo 4
And I'd take Emit M30 plus a $2000 amp over Xeo 6
qirex - Are you building a three channel system, or is this just the first three channels of an eventual 7+ channel full surround rig? If your end goal is three channels, I'd say forget it, stick to stereo. But if this is the first step to a larger system, then I would get the AVR but plan on adding a multichannel amp as your next step. In the meantime, I think you will be short changing the Emits by driving them with a <$1000 multichannel receiver. The problem with inexpensive receivers is that they still have to have all the bells & whistles, so to keep the price low, there is very little budget allocated to the power supply and power amplifier.
HT: Dynaudio C2, Contour S CX, 2x BM14S, Aperion surrounds, Simaudio Titan, Marantz AV8801, Oppo 103, Linn Majik DS, and a Pioneer Kuro
Stereo: Dynaudio Focus 160, Simaudio W-5 LE or Luxman M-600A, Linn Akurate DSM, 2x Rythmik F12G
Other interests: motorcycling, skiing, being active
Red MC is offline
post #36132 of 36873 Old 08-22-2017, 04:10 PM
qirex's Avatar
Quoted: 42 Post(s)
Liked: 30
I've been using 3.1 for about 6 years and have been happy with it. Before that I was using 2.0 and before that 5 identical speakers for surround which was great it's just not practical in my current place. I like the wider sweet spot than when I was running stereo, I live in an apartment so it's definitely not about adding the center for total output levels. I ended up with some cheap Definitives that are ok but I've never really loved them like my old JBLs or Bluerooms so this time I want some speakers that will really put a smile on my face.
I'm definitely not opposed to an outboard amp but there's no pre/pros and very few receivers that can do 4k switching and have pre outs and don't cost at least $1200+ to begin with. Plus it just feels like total overkill for my little system. I have too many sources to just plug everything into the tv so I either need a receiver or a HDMI switch (and the situation with those is pretty dire at the moment). It just seems like 4k/HDR/HDCP 2.2 caught the whole industry flat-footed and they're kind of flailing. I'm half tempted to just buy this thing and hide out for a couple years until all the 4k chaos dies down.
Other speaker brands I'm researching: KEF, Focal, Ascend Acoustics all in the $1000-2000 range
qirex is offline
post #36133 of 36873 Old 08-22-2017, 05:11 PM
Garman's Avatar
Quoted: 1358 Post(s)
Liked: 611
Originally Posted by MarvinLungwitz View Post
I owned a set of Zensor 3s that I bought for an office set up after reading favorable reviews.
Perhaps the high end models sound better, but the Zensors' highs were very harsh. Lots of unnatural sibilance. And yes, I had them pointing straight forward to attenuate the on axis treble response per Dali's recommended positioning. I was very disappointed in the their grating quality, and sold them after giving them a year to settle in (which they never did).
When you compare them to Dynaudio they are a bit bright, that's for sure... I brought down my Zensor 7 to my basement and had them down their for about 2 days, hence they where playing up against from far more expensive speakers and they got moved up stairs quickly... They are rarely used thankfully, but I couldn't stick a better pair upstairs as I didn't want my kids to destroy a better pair! LOL I will most likely replace them with some Emit down the road..
Dynaudio, Magnepan, Belles, Hegel, Musical Fidelity and KEF, etc......Contour's 20's/Special 40's or Raidho next...
Kanso Audio Stand's http://kansoaudiofurniture.com/
Garman is offline
post #36134 of 36873 Old 08-22-2017, 05:57 PM
Quoted: 186 Post(s)
Liked: 82
For all the Schiit Fans... https://audio-head.com/a-trip-to-the-schiitr/
Good read.
yonson likes this.
Dynaudio Focus 260 | Focus 210C | Naim Nait 5si | Marantz 6008 | Oppo- 93 BDP | Audioquest Cables
Matrixman18 is offline
post #36135 of 36873 Old 08-22-2017, 06:05 PM
GTaudiophile's Avatar
Quoted: 697 Post(s)
Liked: 357
Originally Posted by jnelson2000 View Post
The Stand 6 is much more solid then my 3x that house the Emit10s for my bedroom. No way would I feel comfortable putting anything like the S40 in the 3x unless it was only me and there was zero chance of bumping it. No matter what I do to the 3x, I cannot get it to be as solid on floor spikes as the 6. Just my 2 cents.
On a separate note, really enjoying the 40's. Even a bit ore then my F260s which I just unloaded. After moving them into another room, I used a microfiber to clean off fingerprints. I noticed to the touch, one speaker top is rough while the other is smooth. I cannot tell visually any difference, but it definitely is a different feel. I plan to swap out as it doesn't seen right for a 3k speaker. Unfortunately, Dyn is out of stock so now the waiting game begins and break in starts over again :-(.
In what ways do you prefer S40 over F260? Thanks.
GTaudiophile is offline
post #36136 of 36873 Old 08-22-2017, 06:06 PM
Quoted: 697 Post(s)
Liked: 357
Good read.
Looking forward to buying their TT.
post #36137 of 36873 Old 08-22-2017, 06:09 PM
jnelson2000's Avatar
Quoted: 326 Post(s)
Liked: 364
More detailed highs and mids. Soundstage for me is a bit larger and maybe a bit closer to the MLP. No doubt the 260s could dig a bit deeper, but the S40 is no slouch. And with a sub I don’t care. It’s also easier to place closer to a back wall then the 250 was.
Sony XBR-55A1E, LG OLED 65G6P, LG 55EF9500
Anthem AVM 60, Anthem MRX720
Oppo UDP-203, Sony UBP-X800
Dynaudio Focus 210C/260, Dynaudio DM Center/2/6, Dynaudio IC17, Dynaudio Studio S4-W80
AT 44-DA
SVS SB16-Ultra
jnelson2000 is online now
post #36138 of 36873 Old 08-22-2017, 06:38 PM
callas01's Avatar
Quoted: 964 Post(s)
Liked: 593
I use DM2/6s (the older emits) with a Marantz 5010. They're my surround speakers. However in all honesty, you will have no problems. I have 2 friends that drive DM3/7s with receivers and one that uses dm2/6 with a reciever also, of if the 3/7s was being driven by a $150 onkyo receiver
callas01 is online now
post #36139 of 36873 Old 08-22-2017, 06:57 PM
no quarter's Avatar
Quoted: 869 Post(s)
Liked: 459
Good read.
I really like the "pottery wheel" as George calls them...I have been itching to possibly revisit my youth and grab one,this thing might fit the bill if pricing is as reasonable as their other gear.
I just found a bit more info on the TT,looks pretty cool!
http://www.digitalaudioreview.net/20...sol-turntable/
Matrixman18 and yonson like this.
post #36140 of 36873 Old 08-22-2017, 07:06 PM
drewTT's Avatar
Quoted: 823 Post(s)
Liked: 831
Nice. The Focus 160 impressed me quite a bit. Can't wait to get these 40s and see what all the fuss is about...c'mon Thursday....lol
LG OLED65E6 | ARC DSi200 | Dynaudio Special Forty | Oppo UDP-205 | Maingear Drift GTX 1080 HTPC | audioquest CV-8 - Carbon - Columbia | BDI Mirage 8227 | Synology DS916+ | Apple TV 4K
drewTT is offline
post #36141 of 36873 Old 08-22-2017, 07:07 PM
drewTT's Avatar
Quoted: 823 Post(s)
Liked: 831
Good read.
I wonder if their name ever hurts them. I am sure all the kids think it's great though...lol
drewTT is offline
post #36142 of 36873 Old 08-22-2017, 07:08 PM
callas01's Avatar
Quoted: 964 Post(s)
Liked: 593
Here you go
http://www.accessories4less.com/make-a-store/item/marsr5011/marantz-sr5011-7.2-ch-x-100-watts-networking-a/v-receiver/1.html
post #36143 of 36873 Old 08-22-2017, 09:49 PM
yonson's Avatar
Quoted: 302 Post(s)
Liked: 209
Good read.
I broke down and ordered a couple more Vidar, I'm going to run them on the C4's for a while and do an A B A B A B A B... with the Parasound JC1's before I move them to the shop to run the F340's...
Matrixman18 and no quarter like this.
yonson is offline
post #36144 of 36873 Old 08-22-2017, 10:07 PM
Quoted: 186 Post(s)
Liked: 82
Man you really like S C H I I T :-)
yonson likes this.
post #36145 of 36873 Old 08-23-2017, 04:30 AM
amatuerholic's Avatar
Quoted: 581 Post(s)
Liked: 334
It's going to be a pretty Schitty setup
yonson likes this.
amatuerholic is offline
post #36146 of 36873 Old 08-23-2017, 04:36 AM
MarvinLungwitz's Avatar
Quoted: 20 Post(s)
Enjoying my X18s very much now. I find them very revealing. I just switched from Nordost red dawn to Furutech speakerflux speaker cable. Good grief, the presentation of these cables sure is different. Initially I thought damn, the Furutech cable has killed the dynamics. Now I am admiring how smooth and musical the Furutech cables are.
I think the X18s are a wonderful bargain in the Dynaudio product line. Woofer from the Focus line, cabinet fit and finish on par with the higher models, and sound great.
MarvinLungwitz is online now
post #36147 of 36873 Old 08-23-2017, 07:12 AM
Quoted: 277 Post(s)
Liked: 203
after playing with it another day, Ill say that the MiniDSP Nanodigi is the some of the best money I have ever spent on audio gear. I programmed a couple more curves with boost between 30 and 125 ish Hz. I have sort of implemented a poor man's loudness contour where I use a curve with heavier bass gain at very low volumes and switch in flatter ones for higher volume settings. Usually I am listening in the evening when my kids are sleeping so the volume has to be quite low, and it is nice for the bass to not go missing when you are sub 80hz. It seems completely and 100% transparent in the non EQ band. Its pretty fun to play with a device that can have such huge and immediately noticeable effects on the sound quality. I hope to figure out how to use REW and the Umik in the next few days to see where my room is at measurements wise.
A fun experiment I tried was setting the c4s up as a sub woofer with a lowpass of around 80 Hz, with the music subtracted....you can really appreciate how powerful and low distortion they are at producing low frequencies.
yonson likes this.
aschen is online now
post #36148 of 36873 Old 08-23-2017, 07:37 AM
Quoted: 697 Post(s)
Liked: 357
Certainly has me curious. I don't think the 260s lack much, especially on the highs, but perhaps a tad of improvement on the mids would be nice. Makes we wish for a Focus 260-based Special40 instead of the 160...
I am still planning to schedule a S40 vs. C20 demo. Just may take a (half) day off of work to do it.
Current HiFi: Dynaudio Focus 260 | Schiit Modi2 Multibit (Black) | NAIM SuperNait 2
Cables: Chord Cobra VEE3 RCA>DIN | Tellurium Q Black 3M
Past HiFi: Dynaudio Excite X16 | Dynaudio Focus 160 | Harman Kardon HK3490 | NAIM XS2 (70w)
post #36149 of 36873 Old 08-23-2017, 07:42 AM
Quoted: 697 Post(s)
Liked: 357
Price for the TT, depending on options, is suppose to be between $500 and $1K I think. They want to make a market-disrupting product.
I can certainly vouche for their DACs. I dare anyone here to buy a Schiit Yiggy and A/B it with something costing around $10K like Chord DAVE. I have read it also can hang with dCS equipment as well. Their new USB>SPDIF converter, the Eitr, offers more bang-for-buck than any competing product and will enhance any of their DACs or skip Eitr and get their GEN5 USB board in their Bifrost, Gungnir, or Yiggy DACs.
Otherwise, people I know are a little more hesitant with respect to their pre- and power amps. I could see matching VIDAR perhaps with better pres like something from Belles or any good pre with balanced outputs.
yonson likes this.
post #36150 of 36873 Old 08-23-2017, 08:28 AM
Quoted: 326 Post(s)
Liked: 364
I agree with you. I had the 260s for almost 3 years. Loved everything about them. Main reason for me was just looking for a change. And the S40 deal I was able to get made it worth while.
AT 44-DA
SVS SB16-Ultra
Reply Speakers
Dynaudio , dynaudio confidence , dynaudio contours , Dynaudio Focus Powered Monitor Speakers , Speaker Systems , thereore
