Dynaudio Owner's Thread - Page 742 - AVS Forum | Home Theater Discussions And Reviews
 5394Likes
post #22231 of 36881 Old 06-05-2014, 07:57 AM
Garman's Avatar
Quoted: 1358 Post(s)
Liked: 611
Originally Posted by jamesblond View Post
Crap. Just got a reply from the local Dynaudio Office. They won't supply any units, other than the one I'd send in. So, if I were to send in my d28/2 in order to buy a d280 from them, that won't be possible. I'll the same unit back.
I guess I'll just start with a cross-over upgrade and see what that brings me.
They are very paranoid these days sending units out unless they get the same units back in, if there is a problem with one, they have no issues repairing them. The only other suggestion is you send the whole speaker in and ask them if they can put the different tweeter in for you. Back in the day they use to sell raw drivers on the open market and the lovely Chinese decided to make fake Dynaudio which they are still doing today. So this doesn't surprise me. Your only other option is to look for some on Ebay or buy another speaker and remove the tweeter from it, or upgrade your Center Channel to the Contour line or even the new Excite line as they have a newer tweeter which will most likely have the sound your looking for.
Dynaudio, Magnepan, Belles, Hegel, Musical Fidelity and KEF, etc......Contour's 20's/Special 40's or Raidho next...
Kanso Audio Stand's http://kansoaudiofurniture.com/
Garman is offline
post #22232 of 36881 Old 06-05-2014, 11:23 AM
Mr.Q's Avatar
Alright, so yesterday I put the final treatments in the right place.
Here is what I have done:
I first bought myself some measuring equipment. I just searched the net a bit for affordable equipment that is good enough for measurement. I came down to the Tascam US-122MKII as a sound card, since it is ruler flat out of the box, so no bothersome calibrating. For a mic I choose the Behringer ecm8000. Both are quite cheap and good out of the box. Why? because measuring beats guessing and helps fine-tuning stuff like your listening position and pin pointing problems.
Next I ordered a book called "Sound Reproduction: Loudspeakers and Rooms" By Floyd E Toole (http://www.amazon.com/Sound-Reproduction-Acoustics-Psychoacoustics-Loudspeakers/dp/0240520092). Why? Just to get my own knowledge a bit up. I like the book, because it also takes into account psychoacoustics and is based around a lot of tests. What I learned from all this:
- To fix low frequency problems, the best way to do this, is to use multiple subwoofers, with an optimum having four subwoofers, one in each corner. You could also use an EQ, but it can't fix severe nulls, and an EQ only works on a single position, making other listening positions worse. Bass traps only work well from around 70Hz and up, meaning the true problem area of loud and deep bass humps can't be fixed with treatments. The guys @ GiK also confirmed this and suggested EQ'ing.
- The book advises to not treat the first order side wall reflections for stereo listening. Multiple tests showed that people actually prefer untreated side walls, because it makes the sound image wider and ads spaciousness and envelopment.
- Over-treating a room is a bad idea. Reflections are not a bad thing and tests showed that reflections are actually needed to make speech more intelligible.
- Front and back walls can be treated, since those walls don't add anything good and cause comb filtering (though there are doubts that a human can actually 'hear' the comb filtering you see in the higher frequency range).
Alright, now I am 'smart', now what?
Next I filled in a contact form at the website of GiK Acoustics to get some free advice for my room. Got a reply pretty quickly.
It was no sales pitch at all. I think the first week I've been moving with my listening position and fiddling with my sub, sending measurements to the guy from GiK to get everything as optimal as possible. We hadn't talked about treatments at all, until I suggested we should.
I ended up moving my couch a little forward and moved the crossover of my sub to 22Hz to make the hump @33Hz and the dip @46Hz smaller. I also asked what to do with the soundstage that is leaning to the left. The guy from GiK suggested it was caused by both the slanted roof on the left side, causing louder reflections and the cabinets that hang on my right wall, that absorb reflections. He suggested to hang treatments on the slanted ceiling.
So what did I end up ordering?
- Three monster bass traps on the back wall with my very own artwork on it *looks proud cool.gif *
- 2 black 244 bass traps on the front wall.
- 2 white 244 bass traps on the slanted ceiling.
I already had the four white Tri traps.
Here are the obligatory pictures:
The sound? Better then I expected. My expectations weren't to high since I am very down to earth when it comes to audio. I am not the type of person that can rave about huge differences between great gear and other great gear.
The biggest change is in the overall clarity of the sound. The soundstage is clean and precise. The soundstage even became a little wider and extends slightly further to the right, but still a major bias to the left. What is exciting me the most though is texture and timbre. It's almost scary how 'real' and 'unique' instruments, voices or even digital sound waves sound. The first thing I played was some real old 8-bit video game music and I immediately heard a difference in the sound of the square and pulse waves and their raw texture. The sound also feels more airy and playing it loud is awesome!
I must say I am happy with the result and glad I made the investment. It even looks much better then expected (again, low expectations).
Wooo wait, that was not all!
I also ordered a MiniDSP, which is a small, cheap analog equalizer to straighten out the frequencies below 200Hz. I tried it out yesterday, using REW measurements as input, but the sound felt incredibly downgraded. All the great things I gained with the treatments, seemed to be gone. The bass felt very dull. Maybe I am a bass head eek.gif , I dunno, but it didn't feel good at all. I thought I maybe dreamed that the room treatments sounded so good, but when I removed the MiniDSP the great sound was back again.
I haven't really researched how it set it up the right way, but out of the box, no. I will give it another chance once I've done a bit more research. Maybe I should've went with an all digital EQ after all, to prevent any degradation of the sound.. maybe.. at least I have something left to toy with in this current room.
cheers!
lulimet likes this.
Mr.Q is offline
post #22233 of 36881 Old 06-05-2014, 12:05 PM
Garman's Avatar
Liked: 611
Mr Q: Setup looks great too me and I of course love the C1s I use to own the first and second versions! biggrin.gif and I am a Apple Fan as well.
Garman is offline
post #22234 of 36881 Old 06-05-2014, 03:04 PM
callas01's Avatar
Quoted: 964 Post(s)
Liked: 593
New room with a quick setup furniture will be moved on Saturday.
samsung84 likes this.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is offline
post #22235 of 36881 Old 06-05-2014, 03:14 PM
weird 23's Avatar
Quoted: 12 Post(s)
Looks great Callas! It'll be exciting to watch and read the progress in the new house.:D
Did you get a chance to have a quick listen?
weird 23 is offline
post #22236 of 36881 Old 06-05-2014, 04:35 PM
callas01's Avatar
Quoted: 964 Post(s)
Liked: 593
Originally Posted by weird 23 View Post
Looks great Callas! It'll be exciting to watch and read the progress in the new house.biggrin.gif
Listened to a lil Michael Jackson thriller and half of avengers (no calibration tho) and so far things sound pretty good. Pulling the speakers further into the room actually improved the bass with music.
callas01 is offline
post #22237 of 36881 Old 06-05-2014, 04:52 PM
OctaDyn_Dude's Avatar
Quoted: 766 Post(s)
Liked: 509
Nice room Steve. Pull the speakers out as far as you can and still use the room. Maybe time to consider some C2's!!! wink.gif
OctaDyn_Dude is offline
post #22238 of 36881 Old 06-05-2014, 06:08 PM
jamhead's Avatar
cheers!
Atta boy!
So, there is something to these treatments after all.........
jamhead is offline
post #22239 of 36881 Old 06-05-2014, 06:29 PM
callas01's Avatar
Quoted: 964 Post(s)
Liked: 593
What have you been talkin to rhett ??
Thank you for the compliment !
callas01 is offline
post #22240 of 36881 Old 06-05-2014, 06:44 PM
weird 23's Avatar
Quoted: 12 Post(s)
I gave MJ's greatest hits a listen the other day, it sounded surprisingly good.
Switched out the bookshelves for the towers as fronts and found the same thing, although not just in the bass department, everything as a whole seemed to improve. I've got them 3ft from the back of the speaker to the wall right now, the imaging and soundstage have stepped up a notch in this position as well.
That's a much larger space to fill, did the system sound more spacious or larger now that's the speakers have more room to breath? Is the bass tighter now? It also could be less overhang on the bass notes due to the larger space. Just speculating on that one though.
weird 23 is offline
post #22241 of 36881 Old 06-05-2014, 07:34 PM
Quoted: 766 Post(s)
Liked: 509
Haven't been talking to Rhett much. He is coming here on Sat. Isn't that enough??? biggrin.gif
post #22242 of 36881 Old 06-05-2014, 09:38 PM
callas01's Avatar
Quoted: 964 Post(s)
Liked: 593
Well it's hard to say exactly how they're sounding there's a lot if echoing due to the hardwood floors and lack of furniture to deaden anything. But the bass has opened up and sounds more pronounced and tighter right now. They do sound bigger. Playing MJs greatest hits as well.. Not thriller album, the further back I stepped the larger and larger everything sounded. The left front is 2 ft from the wall and they are both 21 inches from the back of the speakers to the wall.
Once I get everything setup and calibrated I'll borrow your omni mic and see what I really need to do.
That's good to hear about the towers. I was looking for gloss white RX6 on agon an eBay but no luck so far. However I think I'll be buying a pair of gloss white Dali Zensor 5s.... It's what the wife wants 😃 Is this setup still gonna find it's way to being on sale?
callas01 is offline
post #22243 of 36881 Old 06-05-2014, 09:41 PM
callas01's Avatar
Quoted: 964 Post(s)
Liked: 593
Sure a therapy session or 3 with your shrink should cure you after he leaves.
callas01 is offline
post #22244 of 36881 Old 06-06-2014, 12:10 AM
jamesblond's Avatar
Quoted: 74 Post(s)
Liked: 36
I've noticed there are some MJ albums out there that contain remasters. Those remaster don't sound nearly as good as the original releases. That's a shame, because the original masters are from way before the loudness war determined dynamics- and they sound really good! If you compare Billy Jean from Thriller and Man in the mirror from Bad with the versions from History, you'll definitely hear a diffrerence in favour of the originals.
I've heard the original two-track mix of Thriller (the mix before mastering) in Bruce Swedien's own studio in Ocala, Florida, on his Westlake monitors. Oh! My! God!! Now THAT sounded fantastic!! I wish I had a room like that!
jamesblond is offline
post #22245 of 36881 Old 06-06-2014, 06:39 PM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
cheers!
Well done Mister, well done!
lulimet is offline
post #22246 of 36881 Old 06-06-2014, 06:46 PM
CDLehner's Avatar
Quoted: 773 Post(s)
Liked: 1151
CDLehner is offline
post #22247 of 36881 Old 06-06-2014, 06:57 PM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
Originally Posted by CDLehner View Post
I sold a pair of Focal tower speakers about a month ago. Of course each speaker had its own box so there were two boxes shipped. The buyer in TX got one speaker on a Friday and the other one the following Monday. lol
lulimet is offline
post #22248 of 36881 Old 06-06-2014, 07:00 PM
CDLehner's Avatar
Quoted: 773 Post(s)
Liked: 1151
Yeah...that's bad enough; but I got one yesterday, and the carrier has no earthly idea...where the other one even is!! mad.gifmad.gif
CDLehner is offline
post #22249 of 36881 Old 06-07-2014, 06:03 AM
Quoted: 766 Post(s)
Liked: 509
Did you get a tracking # or 2? I ordered a pair of Stand 4 and got bases and top plates along with 1 set of tubes on a Friday and the other 2 tubes on Monday in 2 separate shipping tubes. But I did get 2 tracking #'s
post #22250 of 36881 Old 06-07-2014, 06:34 AM
CDLehner's Avatar
Quoted: 773 Post(s)
Liked: 1151
2 tracking #s; just one shows no scan activity in the system whatsoever...like it never was received. Dealer told me, the 2 boxes were side-by-side...and the driver took possession of both. Go figure confused.gif
CDLehner is offline
post #22251 of 36881 Old 06-07-2014, 08:00 AM
amatuerholic's Avatar
Quoted: 581 Post(s)
Liked: 334
What did you buy anyway?
amatuerholic is offline
post #22252 of 36881 Old 06-07-2014, 08:14 AM
CDLehner's Avatar
Quoted: 773 Post(s)
Liked: 1151
CDLehner is offline
post #22253 of 36881 Old 06-07-2014, 08:17 AM
ambesolman's Avatar
Quoted: 1100 Post(s)
Liked: 921
Nice choice!
ambesolman is online now
post #22254 of 36881 Old 06-07-2014, 10:28 AM
Garman's Avatar
Liked: 611
CD: Didn't you get some new PCM speakers? wink.gif Are you still looking for the Holy Grail? biggrin.gif The above speakers for sure is not even remotely close eek.gif hahahaha
Garman is offline
post #22255 of 36881 Old 06-07-2014, 12:09 PM
Mr.Q's Avatar
I'll go get a doctor for you that can give a treatment for mental breakdown wink.gif
Mr.Q is offline
post #22256 of 36881 Old 06-07-2014, 01:11 PM
Garman's Avatar
Liked: 611
Well according to engineers paper cone drivers are great to use because they are light weight but they don't last and get damage easily. You would think now that Bose is charging a premium price for old technology they at least couldn't dip them in a polymer to make them last longer. LOL The only Bose thing I have ever owned was one of their small box for music playback in an office and that lasted about 6 months because I wanted quality.
Garman is offline
post #22257 of 36881 Old 06-07-2014, 04:50 PM
CDLehner's Avatar
Quoted: 773 Post(s)
Liked: 1151
No...I got these http://www.parts-express.com/dayton-audio-b652-6-1-2-2-way-bookshelf-speaker-pair--300-652
Got a great review in Stereophile; and I basically buy my gear, based on their reviews http://www.stereophile.com/content/dayton-audio-b652-loudspeaker
amatuerholic likes this.
CDLehner is offline
post #22258 of 36881 Old 06-07-2014, 05:01 PM
Garman's Avatar
Liked: 611
Yeah right! I am not buying it! LOL biggrin.gif You got too good of ears to go backwards!
As long as your expectations are realistic and you're willing to have fun, the Daytons are sure to please. <<<<<<<<<<<<<<<<<<<< I like Stereophile's way on how they spin that last sentence in the review! wink.gif
Garman is offline
post #22259 of 36881 Old 06-07-2014, 06:07 PM
CDLehner's Avatar
Quoted: 773 Post(s)
Liked: 1151
OK, you got me there. My ears are sooo good, as a matter of fact...I actually got a pair of these
Bit of a s t r e t c h; but the dealer worked something out with me. I'll pay $1,000/month...and in 2114, these babies are all mine. cool.gif
LOL...fellas, I'll post a pic of the new blowers; when the time is right (like they find its sibling, and I can open the one I have...or the dealer sends me a replacement pair).
CDLehner is offline
post #22260 of 36881 Old 06-08-2014, 07:35 PM
Garman's Avatar
Liked: 611
You go for it! 2114, I hope your around to listen too them, before then they will want you too trade up!
Garman is offline
Reply Speakers
Dynaudio , dynaudio confidence , dynaudio contours , Dynaudio Focus Powered Monitor Speakers , Speaker Systems , thereore
