Insignia $50 Speakers Look And Sound Good! - Page 34 - AVS Forum | Home Theater Discussions And Reviews
post #991 of 997 Old 08-01-2009, 06:38 PM
enrayged's Avatar
Originally Posted by PiratesCove View Post
I just bought the Insignia NS-B2111 for $89 from Best Buy and combined them with a Sony Mini Hi-Fi MHC-EC55 from Walmart for $98. Let me say that this set up sounds amazing all for less than 200 dollars.
I have 6 hooked up to an Onkyo TX-sr706 stereo. I have had the speakers for about 2 years so they have had a lot of time to break in. When I bought em I got em for 60 bucks a pair then, matched them up with a velodyne vrp-12 and with old pioneer stereo sounded pretty good. When I upgraded to the onkyo, They now sound phenomenal! Audyssey seems to have really woke these things up. Blu Ray movies sound astounding!
enrayged is offline
post #992 of 997 Old 08-01-2009, 06:42 PM
openwheelracing's Avatar
Liked: 32
lol, wait til you upgrade the speakers. I have Insignias, and I consider them the best bang for your buck audio gear, but trust me, speakers make the most difference. Well, aside from room treatment.
openwheelracing is offline
post #993 of 997 Old 08-01-2009, 07:24 PM
enrayged's Avatar
I am in the process of buying a house... but when that is done then yes I am going to upgrade my speakers to something much better. I have been piecing my theater together piece by piece. These speakers I purchased with the intent of eventually moving them to other rooms... offices places where they will make people happy, but not needing something high grade.
enrayged is offline
post #994 of 997 Old 08-02-2009, 09:08 AM
Bigred7078's Avatar
If anyone likes doing mods, here is a sweet crossover upgrade from the Skiing Ninja
http://www.skiingninja.com/Insignia-p/bb-insig.htm
Bigred7078 is offline
post #995 of 997 Old 08-02-2009, 12:32 PM
enrayged's Avatar
and a couple more with crossovers so you can build yourself.
http://murphyblaster.com/content.php?f=insignia.html
(I am probably going to build this one for my front 3)
http://www.speakerdesign.net/designs...a_designs.html
He has 2 different crossovers listed for these
enrayged is offline
post #996 of 997 Old 06-30-2010, 01:14 AM
biomed_eng_2000's Avatar
Does anybody know if putting a felt ring around the tweeters will help smooth the tweeters' response?
I would try it but I don't have any measurement equipment.
biomed_eng_2000 is offline
post #997 of 997 Old 06-30-2010, 02:10 AM
TheWind's Avatar
Liked: 30
Yes that is possible. It might also improve imaging. Some speakers use a thin rectangular felt(?) piece next to the tweeter rather than a ring for this purpose. I think good quality wool carpet padding would be better than the synthetic felt that is normally sold as felt. True wool felt might be best.
As for the Insignia $50 Speakers discussed in this thread, I went to BB and listened to them. I thought they were almost twice as good as a $25 pair speakers but, not quite.
TheWind is offline
Reply Speakers
