Small speakers, big sound? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 07-06-2006, 11:59 PM - Thread Starter
Tooler_686's Avatar
Hi all. I am setting up a second media area and need to satisfy my needs for big sound and wifes objection to large speakers. I tried Bose AM 10 series III and that was a huge mistake. In my opinion they sound hollow, not full. The area is two rooms, the kitchen area where I will be sitting at a bar most of the time looking down into the den where the equipment will be which is approximately 10x12. There is a fireplace in the middle of the den with a 50" plasma above it. The front speakers will sit on the mantle, which is only 7" deep. Therein lies my problem. Wife says no to tower speakers. I can hide the rears and sub. Center speaker is limited in size also as it needs to fit under plasma (no taller than 3 3/4"). I will be listening to 75% HT (mostly TV) but I'm a audio lover from way back and want music to sound good. Receiver will most likely be Denon AVR 3805 or 2807. I'm willing to spend up to $2000 on 5.1 system. Any suggestions would be appreciated. Thanks.
Tooler_686 is offline
post #2 of 24 Old 07-07-2006, 12:08 AM
Jakeman02's Avatar
Check this site. They are internet only but do give you a 30 free in home trial and they have a shipping special going on. These little things get rave reviews and should satisify the waf.
www.orbaudio.com
Found a current thread on Orbs here. Should be alble to get alot of useful info. I don't even need small speakers and I'm considering them after finding these threads for you, haha
http://www.avsforum.com/avs-vb/showthread.php?t=695825
Jakeman02 is offline
post #3 of 24 Old 07-07-2006, 01:05 AM - Thread Starter
Tooler_686's Avatar
Wow, thanks, I'm seriously interested.
post #4 of 24 Old 07-07-2006, 06:43 AM
Russdawg's Avatar
I own the Orbs as well, I needed to go small as I put a full set in a 5th wheel. I highly recommend these speakers if you want great sound and size is a consideration. They do a great job.
Russ
Russdawg is offline
post #5 of 24 Old 07-07-2006, 07:10 AM
tonygeno's Avatar
Quoted: 134 Post(s)
Liked: 37
What's a 5th wheel?
Tony
In search of the Holy Grail.
tonygeno is offline
post #6 of 24 Old 07-07-2006, 09:25 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Let me get this straight, you are looking for a center channel that is less than 4 inches tall? If so, good luck with that one buddy.
Honestly man, I would tell the wife that you will agree to the no floor standers rule, but that you want to mount some bookshelf speakers. If she agrees, check these packages out:
http://www.**********/products_produc...s&product=83.1
http://www.axiomaudio.com/epicmaster_350main.html
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
post #7 of 24 Old 07-07-2006, 09:36 AM
wingnut4772's Avatar
Liked: 29
I had a lot of success setting up my parent's Ht with the Hsu Ventriloquist system. They really surprised me with how good they sounded and everyone that has heard them has been impressed.
Kaboom.
wingnut4772 is offline
post #8 of 24 Old 07-07-2006, 10:32 AM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
I set up a set of these with a Hsu STF-2 in my Parents' family room. Sounds great.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #9 of 24 Old 07-07-2006, 11:22 AM
Jsaf65's Avatar
I'm using monitor audio radius 90's for my surrounds--they are small and sound great. For the center, I'm using the radius 225, which is about 4.5 inches tall.
Jsaf65 is offline
post #10 of 24 Old 07-07-2006, 12:22 PM
PULLIAMM's Avatar
I would look at Def Tech Mythos Gems and a Mythos 7 center. Their subs are excellent also.
PULLIAMM is offline
post #11 of 24 Old 07-07-2006, 01:32 PM
directvfreak2's Avatar
Bose Acoustimass systems are small and are rated for 200w per channel. They offer BIG sound.
directvfreak2 is offline
post #12 of 24 Old 07-07-2006, 01:56 PM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Don't take this rudely but your proof of another targeted victim of Bose. Bose has mediocre equipment at ridiculously high prices. The amount spent on a Bose system will buy you something sounding BILLIONS times better...and MOST of the time costing less! The quality of materials used in any Bose component is an insult to any conciensence comsumer and yet they tell you it's the best.
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is online now
post #13 of 24 Old 07-07-2006, 01:59 PM
PULLIAMM's Avatar
He has been recommending Bose all over the place. He is either a paid Bose rep or spoiling for a fight. :p
PULLIAMM is offline
post #14 of 24 Old 07-07-2006, 02:36 PM
Coonstev's Avatar
Ok, I should cut you some slack because I've been guilty of this before...
But you obviously didn't read the OP...he's already demoed BLOSE.
Or if you did: your cover is blown, you ARE a BLOSE rep!
Coonstev is offline
post #15 of 24 Old 07-07-2006, 02:58 PM
Jack White's Avatar
The biggest sounding small speakers I've heard are the Jensen CJR
50hz @-3db with just 5 1/4" woofers and under 1 foot I think.
Jack White is offline
post #16 of 24 Old 07-09-2006, 01:29 PM - Thread Starter
Tooler_686's Avatar
Thanks to all
post #17 of 24 Old 07-09-2006, 01:47 PM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
Bad-ass, clean-big-sounding, high-quality, beautiful, little speakers...........
http://www.energy-speakers.com/v2/pr...ine.php?id=318
The Mini's come with a very neat, built-in, wall-mounting system that works great! I installed two for surrounds within an hour.
Beautiful real wood veneer's, and classy piano black available finishes. But great sounding as well.
WestCoastD is offline
post #18 of 24 Old 07-09-2006, 02:29 PM
Russdawg's Avatar
Where did you buy those things? I'm a fan of Energy anyway I would really like to hear them. I'm in Palos Verdes...Thanks
Russ
Russdawg is offline
post #19 of 24 Old 07-09-2006, 02:46 PM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
yeah............they're still somewhat new on the market, and are just now beginning to show up in dealer showrooms. Any Energy dealer can order them if they don't have them. One major dealer in the L.A./Southern California area is Ken Cranes. There are others as well.
To be honest I purchased these by phone, from Audio Excellence, without test-listening. I'm a huge Energy fan, I appreciate the level of engineering & design they put into their products. Beautiful form & function! Good price as well.
post #20 of 24 Old 07-09-2006, 03:25 PM
Russdawg's Avatar
I just called Ken Cranes, thanks for the heads up.
Russ
Russdawg is offline
post #21 of 24 Old 07-09-2006, 03:56 PM
edster922's Avatar
These speakers are just under 7" deep and can go flush against your wall since they are sealed enclosures --- with a good sub will provide excellent music enjoyment:
http://www.ascendacoustics.com/pages...00/htm200.html
I'd get 3 of these and put them on your mantel, then wall mount the 2 rears. With the Hsu STF-2 sub, you're looking at $1080 shipped which leaves you plenty for the receiver.
edster922 is offline
post #22 of 24 Old 07-09-2006, 05:50 PM
MJSmegma's Avatar
Nice pair of larger in-walls, or flat panel monitors, close to plasma, phantom center.
Looks will win over the wife, you'll get bigger, better sound.
Don't keep upgrading, get great stuff right away.
MJSmegma is offline
post #23 of 24 Old 07-09-2006, 10:04 PM
gotchaforce's Avatar
might also want to audition paradigm mini monitors..
gotchaforce is offline
post #24 of 24 Old 07-09-2006, 10:05 PM
HSU has some new satellite coming out with horns in em! they look great, id wait for those if youre going to buy HSU
Closed Thread Speakers
