Cambridge SoundWorks HT setups - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #391 of 394 Old 09-03-2013, 11:39 AM
boulderdashcci's Avatar
I just fired up my old M80s (I've been on The Wharfedale Evo2-10s since I last posted in this thread) and they sound great. They need a little coaxing out of the bass/treble knobs as the amp I use now is only about 30w/channel (Marantz PM5004) and they are pretty hard to drive but they sound awesome. The bass is very punchy and tight and they image well. I wish I had a more powerful amp to try them out with. Good stands make a big difference too, I remember when I had these before there was always some upper bass distortion which I think was due to the crappy wood Sanus stands I was using....I now have very heavy Focal (rebadged Target MR60, 4 post steel loaded/about 80lbs each) and it doesn't seem to be there. Could be the Marantz amp over the old Onkyo HT receiver I was using back then too. I've tried both vinyl via a Rega RP1 and digital via my computer and a Marantz CD5003 and everything sounds really nice.
boulderdashcci is offline
post #392 of 394 Old 12-03-2016, 10:34 PM
Liked: 1
Boy am I late to supper. CSW has been through many changes since I acquired my New Ensemble (5 channel) setup in 1994. In looking for help with my issue (below), I see they only make a very limited number of Bluetooth speakers now. (Most likely a very far cry from the beloved company Henry Koss started.)
My speakers were stored due to dead receiver that was never replaced (ya know, divorce and all that goes with it). And they've sat in my garage in a cardboard box for a few years. I've been without even a basic stereo outside of my computer system for several years. But I've always been very pleased with my CSW speakers when used both for either music or home theater.
Fast forward to today and I picked up a Sony STR-DH550 5.2ch AV Receiver (145W x5) at Best Buy for just $150. It's not an exotic receiver by any means, but it will certainly sound better than (a) nothing and (b) my computer speakers. And it's bound to sound "good enough" for the price.
So on to the unpacking of my CSW speakers and I find that my two mains and the two surrounds (but not the bass modules and center speaker which are vinyl coated) have suffered from the same NEXTEL paint problems mentioned in earlier posts in this section. The faux suede covering has "melted" to a sticky goo more or less. I tried to clean them with some simple glass cleaner (what I recall they recommended back in the day) and I found that in a test area I actually removed the covering altogether. I assume some paint thinner would make quick work of cleaning up all the mess. But then I'll have "naked" speakers.
From the looks of things, these speaker enclosures are built out of high density particle board stuffed into an aluminum (it's not magnetic) covering.
Anyone have any ideas what I could paint the soon-to-be bare metal with that will leave an acceptable finish? (Frankly, ANYTHING is more acceptable than the goo coating they now have.) I could go a cheap as rattle can but they'd likely look like they were finished with cheap spray paint as well. I'd consider any color, but the conventional flat-black is most likely what they'll get.
GLBright likes this.
packers-fan is offline
post #393 of 394 Old 12-07-2016, 12:20 PM
Liked: 1
Quick update on this...
Well, did some work on my speakers with a bit of Acetone (fingernail polish remover / paint stripper) and found the old NEXTEL coating comes off almost too easily. And makes one heck of a mess in the process. I thought the speakers might be in an aluminum housing based on how they looked where the NEXTEL coating had been removed before (in very small area at first), but it turns out that is just a thick layer of light grey primer over dense wood fiberboard. (MDF)
Being that these are wood (ish) speakers, I'm just going with the strip, lightly sand, then prime & repaint route. I'd hoped that I might be able to disassemble everything in order to remove the screens before painting, but it looks like everything is glued solid. So I'll have to do some careful masking. Hope to get this done over the holiday break. I'll update with a couple of pictures of the results.
The good news is that the speakers still sound great. The amp itself really seems to be missing some BASIC features. (Like no auto programming of radio station presets, etc.) But the tonal quality (at least to my 50+ year old ears) is impressive for the price I paid. SO happy to be watching NetFlix, etc. and using something 100X better than the TV speakers.
post #394 of 394 Old 12-25-2016, 10:17 PM
Bostown's Avatar
The grills on ensemble satellites are fairly easy to remove for painting. - I'd also double check the surrounds on the satellites and woofers just to make sure they are still in tact. Repainting ensembles will bring new life to them cosmetically. On the power side of things. A decent POWER amp driving them will also squeeze their true performance out of them. ( in fact 2 stereo amps is ideal. One to drive the bass module(s) and one to drive the main sats) . The NAD 2200PE is pretty easy to find on the used market as is the Adcom 555 (original or II). So for not a lot of cash, you can really make the ensemble system perform on par with some speakers costing many times what they are worth.
Bostown is offline
Reply Speakers
